path: root/drivers/isdn
2015-02-02isdn: off by one in connect_res()Dan Carpenter
The bug here is that we use "Reject" as the index into the cau_t[] array in the else path. Since the cau_t[] has 9 elements if Reject == 9 then we are reading beyond the end of the array. My understanding of the code is that it's saying that if Reject is 1 or too high then that's invalid and we should hang up. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-12isdn: fix NUL (\0 or \x00) specification in stringGiel van Schijndel
In C one can either use '\0' or '\x00' (or '\000') to add a NUL byte to a string. '\0x00' isn't part of these and will in fact result in a single NUL followed by "x00". This fixes that. Signed-off-by: Giel van Schijndel <me@mortis.eu> Reported-at: http://www.viva64.com/en/b/0299/ Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree update from Jiri Kosina: "Usual stuff: documentation updates, printk() fixes, etc" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (24 commits) intel_ips: fix a type in error message cpufreq: cpufreq-dt: Move newline to end of error message ps3rom: fix error return code treewide: fix typo in printk and Kconfig ARM: dts: bcm63138: change "interupts" to "interrupts" Replace mentions of "list_struct" to "list_head" kernel: trace: fix printk message scsi: mpt2sas: fix ioctl in comment zbud, zswap: change module author email clocksource: Fix 'clcoksource' typo in comment arm: fix wording of "Crotex" in CONFIG_ARCH_EXYNOS3 help gpio: msm-v1: make boolean argument more obvious usb: Fix typo in usb-serial-simple.c PCI: Fix comment typo 'COMFIG_PM_OPS' powerpc: Fix comment typo 'CONIFG_8xx' powerpc: Fix comment typos 'CONFiG_ALTIVEC' clk: st: Spelling s/stucture/structure/ isci: Spelling s/stucture/structure/ usb: gadget: zero: Spelling s/infrastucture/infrastructure/ treewide: Fix company name in module descriptions ...
2014-12-10isdn/capi: correct argument types of command_2_indexTilman Schmidt
Utility function command_2_index is always called with arguments of type u8. Adapt its declaration accordingly. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-10isdn/gigaset: enable Kernel CAPI support by defaultTilman Schmidt
Kernel CAPI has been the recommended ISDN subsystem for the Gigaset driver since kernel release 2.6.34.2. It provides full backwards compatibility to the old I4L subsystem thanks to the capidrv module. I4L has been marked as deprecated for more than seven years. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-10isdn/gigaset: elliminate unnecessary argument from send_cb()Tilman Schmidt
No need to pass a member of the cardstate structure as a separate argument if the entire structure is already passed. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-10isdn/gigaset: clarify gigaset_modem_fill control structureTilman Schmidt
Replace the flag-controlled retry loop by explicit goto statements in the error branches to make the control structure easier to understand. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-10isdn/gigaset: drop duplicate declarationTilman Schmidt
Function gigaset_skb_sent was declared twice, identically, in gigaset.h. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-09isdn: fix misspelling of current function in stringJulia Lawall
Replace a misspelled function name by %s and then __func__. In the first case, the print is just dropped, because kmalloc itself does enough error reporting. This was done using Coccinelle, including the use of Levenshtein distance, as proposed by Rasmus Villemoes. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-24new helper: memcpy_from_msg()Al Viro
2014-11-21mISDN: Deletion of unnecessary checks before the function call "vfree"Markus Elfring
The vfree() function performs also input parameter validation. Thus the test around the call is not needed. This issue was detected by using the Coccinelle software. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-20treewide: fix typo in printk and KconfigMasanari Iida
This patch fix spelling typo in printk and Kconfig within various part of kernel sources. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2014-11-05net: Add and use skb_copy_datagram_msg() helper.David S. Miller
This encapsulates all of the skb_copy_datagram_iovec() callers with call argument signature "skb, offset, msghdr->msg_iov, length". When we move to iov_iters in the networking, the iov_iter object will sit in the msghdr. Having a helper like this means there will be less places to touch during that transformation. Based upon descriptions and patch from Al Viro. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14isdn/gigaset: fix usb_gigaset write_cmd result raceTilman Schmidt
In usb_gigaset function gigaset_write_cmd(), the length field of the command buffer structure could be cleared by the transmit tasklet before it was used for the function's return value. Fix by copying to a local variable before scheduling the tasklet. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14isdn/capi: don't return NULL from capi_cmd2str()Tilman Schmidt
capi_cmd2str() is used in many places to build log messages. None of them is prepared to handle NULL as a result. Change the function to return printable string "INVALID_COMMAND" instead. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14isdn/capi: handle CAPI 2.0 message parser failuresTilman Schmidt
Have callers of capi_cmsg2message and capi_message2cmsg handle non-zero return values indicating failure. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14isdn/capi: prevent NULL pointer dereference on invalid CAPI commandTilman Schmidt
An invalid CAPI 2.0 command/subcommand combination may retrieve a NULL pointer from the cpars[] array which will later be dereferenced by the parser routines. Fix by adding NULL pointer checks in strategic places. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14isdn/capi: refactor command/subcommand table accessesTilman Schmidt
Encapsulate accesses to the CAPI 2.0 command/subcommand name and parameter tables in a single place in preparation for redesign. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14isdn/capi: prevent index overrun from command_2_index()Tilman Schmidt
The result of the function command_2_index() is used to index two arrays mnames[] and cpars[] with max. index 0x4e but in its current form that function can produce results up to 3*(0x9+0x9)+0x7f = 0xb5. Fix by clamping all result values potentially overrunning the arrays to zero which is already handled as an invalid value. Re-spotted with Coverity. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14isdn/capi: correct capi20_manufacturer argument type mismatchTilman Schmidt
Function capi20_manufacturer() is declared with unsigned int cmd argument but called with unsigned long. Fix by correcting the function prototype since the actual argument is part of the user visible API. Spotted with Coverity. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14isdn/gigaset: fix non-heap pointer deallocationTilman Schmidt
at_state structures may be allocated individually or as part of a cardstate or bc_state structure. The disconnect() function handled both cases, creating a risk that it might try to deallocate an at_state structure that had not been allocated individually. Fix by splitting disconnect() into two variants handling cases with and without an associated B channel separately, and adding an explicit check. Spotted with Coverity. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14isdn/gigaset: fix NULL pointer dereferenceTilman Schmidt
In do_action, a NULL pointer might be passed to function start_dial which will dereference it. Fix by adding a check for NULL before the call. Spotted with Coverity. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14isdn/gigaset: limit raw CAPI message dump lengthTilman Schmidt
In dump_rawmsg, the length field from a received data package was used unscrutinized, allowing an attacker to control the size of the allocated buffer and the number of times the output loop iterates. Fix by limiting to a reasonable value. Spotted with Coverity. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14isdn/gigaset: make sure controller name is null terminatedTilman Schmidt
In gigaset_isdn_regdev, the name field may not have a null terminator if the source string's length is equal to the buffer size. Fix by zero filling the structure and excluding the last byte of the name field from the copy. Spotted with Coverity. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-14isdn/gigaset: missing break in do_facility_reqTilman Schmidt
If we take the unsupported supplementary service notification mask path, we end up falling through and overwriting the error code. Insert a break statement to skip the remainder of the switch case and proceed to sending the reply message. Spotted with Coverity. Reported-by: Dave Jones <davej@redhat.com> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Most notable changes in here: 1) By far the biggest accomplishment, thanks to a large range of contributors, is the addition of multi-send for transmit. This is the result of discussions back in Chicago, and the hard work of several individuals. Now, when the ->ndo_start_xmit() method of a driver sees skb->xmit_more as true, it can choose to defer the doorbell telling the driver to start processing the new TX queue entires. skb->xmit_more means that the generic networking is guaranteed to call the driver immediately with another SKB to send. There is logic added to the qdisc layer to dequeue multiple packets at a time, and the handling mis-predicted offloads in software is now done with no locks held. Finally, pktgen is extended to have a "burst" parameter that can be used to test a multi-send implementation. Several drivers have xmit_more support: i40e, igb, ixgbe, mlx4, virtio_net Adding support is almost trivial, so export more drivers to support this optimization soon. I want to thank, in no particular or implied order, Jesper Dangaard Brouer, Eric Dumazet, Alexander Duyck, Tom Herbert, Jamal Hadi Salim, John Fastabend, Florian Westphal, Daniel Borkmann, David Tat, Hannes Frederic Sowa, and Rusty Russell. 2) PTP and timestamping support in bnx2x, from Michal Kalderon. 3) Allow adjusting the rx_copybreak threshold for a driver via ethtool, and add rx_copybreak support to enic driver. From Govindarajulu Varadarajan. 4) Significant enhancements to the generic PHY layer and the bcm7xxx driver in particular (EEE support, auto power down, etc.) from Florian Fainelli. 5) Allow raw buffers to be used for flow dissection, allowing drivers to determine the optimal "linear pull" size for devices that DMA into pools of pages. The objective is to get exactly the necessary amount of headers into the linear SKB area pre-pulled, but no more. The new interface drivers use is eth_get_headlen(). From WANG Cong, with driver conversions (several had their own by-hand duplicated implementations) by Alexander Duyck and Eric Dumazet. 6) Support checksumming more smoothly and efficiently for encapsulations, and add "foo over UDP" facility. From Tom Herbert. 7) Add Broadcom SF2 switch driver to DSA layer, from Florian Fainelli. 8) eBPF now can load programs via a system call and has an extensive testsuite. Alexei Starovoitov and Daniel Borkmann. 9) Major overhaul of the packet scheduler to use RCU in several major areas such as the classifiers and rate estimators. From John Fastabend. 10) Add driver for Intel FM10000 Ethernet Switch, from Alexander Duyck. 11) Rearrange TCP_SKB_CB() to reduce cache line misses, from Eric Dumazet. 12) Add Datacenter TCP congestion control algorithm support, From Florian Westphal. 13) Reorganize sk_buff so that __copy_skb_header() is significantly faster. From Eric Dumazet" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1558 commits) netlabel: directly return netlbl_unlabel_genl_init() net: add netdev_txq_bql_{enqueue, complete}_prefetchw() helpers net: description of dma_cookie cause make xmldocs warning cxgb4: clean up a type issue cxgb4: potential shift wrapping bug i40e: skb->xmit_more support net: fs_enet: Add NAPI TX net: fs_enet: Remove non NAPI RX r8169:add support for RTL8168EP net_sched: copy exts->type in tcf_exts_change() wimax: convert printk to pr_foo() af_unix: remove 0 assignment on static ipv6: Do not warn for informational ICMP messages, regardless of type. Update Intel Ethernet Driver maintainers list bridge: Save frag_max_size between PRE_ROUTING and POST_ROUTING tipc: fix bug in multicast congestion handling net: better IFF_XMIT_DST_RELEASE support net/mlx4_en: remove NETDEV_TX_BUSY 3c59x: fix bad split of cpu_to_le32(pci_map_single()) net: bcmgenet: fix Tx ring priority programming ...
2014-10-05isdn/gigaset: use USB API function usb_endpoint_num()Tilman Schmidt
Use function usb_endpoint_num() for the bulk endpoint and store the endpoint number in the cardstate structure instead of the raw endpoint address value. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-05isdn/gigaset: drop unused cardstate structure memberTilman Schmidt
Field int_in_endpointAddr was set but never used. Drop it. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-05isdn/gigaset: improve error handling when leaving DLE modeTilman Schmidt
Avoid cascading warnings when leaving DLE mode fails by clearing the DLE flag before entering recovery. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-05isdn/capi: drop two dead if branchesTilman Schmidt
The last branch in command_2_index() cannot be reached since c==0xff is already caught by the first "if". The empty second branch makes no difference since no other branch will be taken for c<0x0f. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-23isdn: i4l: Remove ASYNC_CTS_FLOWPeter Hurley
ISDN4Linux always enables CTS flow control and does not use the tty_port_cts_enabled() helper function; remove ASYNC_CTS_FLOW state enable/disable. cc: Karsten Keil <isdn@linux-pingi.de> cc: <netdev@vger.kernel.org> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-05mISDN: remove DSP_NEVER_DEFINED and adjust code identationColin Ian King
The DSP_NEVER_DEFINED #ifdef is confusing, it slips in an extra } which is not required because the previous code is indented incorrectly. Correct the identation and remove the extraneous DSP_NEVER_DEFINED Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Pulling to get some TIPC fixes that a net-next series depends upon. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-22isdn/bas_gigaset: use USB API functions rather than constantsHimangi Saraogi
This patch introduces the use of the function usb_endpoint_num. The Coccinelle semantic patch that makes these changes is as follows: @@ struct usb_endpoint_descriptor *epd; @@ - (epd->bEndpointAddress & \(USB_ENDPOINT_NUMBER_MASK\|0x0f\)) + usb_endpoint_num(epd) Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Acked-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-22isdn/gigaset: use USB API functions rather than constantsHimangi Saraogi
2014-08-22drivers: isdn: eicon: xdi_msg.h: Fix typo in #ifndefRasmus Villemoes
Test for definedness of the macro which is actually defined (the change is hard to see: it is s/SSS/SSA/). Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-02net: filter: split 'struct sk_filter' into socket and bpf partsAlexei Starovoitov
clean up names related to socket filtering and bpf in the following way: - everything that deals with sockets keeps 'sk_*' prefix - everything that is pure BPF is changed to 'bpf_*' prefix split 'struct sk_filter' into struct sk_filter { atomic_t refcnt; struct rcu_head rcu; struct bpf_prog *prog; }; and struct bpf_prog { u32 jited:1, len:31; struct sock_fprog_kern *orig_prog; unsigned int (*bpf_func)(const struct sk_buff *skb, const struct bpf_insn *filter); union { struct sock_filter insns[0]; struct bpf_insn insnsi[0]; struct work_struct work; }; }; so that 'struct bpf_prog' can be used independent of sockets and cleans up 'unattached' bpf use cases split SK_RUN_FILTER macro into: SK_RUN_FILTER to be used with 'struct sk_filter *' and BPF_PROG_RUN to be used with 'struct bpf_prog *' __sk_filter_release(struct sk_filter *) gains __bpf_prog_release(struct bpf_prog *) helper function also perform related renames for the functions that work with 'struct bpf_prog *', since they're on the same lines: sk_filter_size -> bpf_prog_size sk_filter_select_runtime -> bpf_prog_select_runtime sk_filter_free -> bpf_prog_free sk_unattached_filter_create -> bpf_prog_create sk_unattached_filter_destroy -> bpf_prog_destroy sk_store_orig_filter -> bpf_prog_store_orig_filter sk_release_orig_filter -> bpf_release_orig_filter __sk_migrate_filter -> bpf_migrate_filter __sk_prepare_filter -> bpf_prepare_filter API for attaching classic BPF to a socket stays the same: sk_attach_filter(prog, struct sock *)/sk_detach_filter(struct sock *) and SK_RUN_FILTER(struct sk_filter *, ctx) to execute a program which is used by sockets, tun, af_packet API for 'unattached' BPF programs becomes: bpf_prog_create(struct bpf_prog **)/bpf_prog_destroy(struct bpf_prog *) and BPF_PROG_RUN(struct bpf_prog *, ctx) to execute a program which is used by isdn, ppp, team, seccomp, ptp, xt_bpf, cls_bpf, test_bpf Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-31ISDN: pcbit: off by one bugs in pcbit_set_msn()Dan Carpenter
1) We don't allocate enough space for the NUL terminator so we end up corrupting one character beyond the end of the buffer. 2) The "len - 1" should just be "len". The code is trying to copy a word from a buffer up to a comma or the last word in the buffer. Say you have the buffer, "foo,bar,baz", then this code truncates the last letter off each word so you get "fo", "ba", and "ba". You would hope this kind of bug would get noticed in testing... I'm not very familiar with this code and I can't test it, but I think we should copy the final character. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-30CAPI: use correct structure type name in sizeofJulia Lawall
Correct typo in the name of the type given to sizeof. Because it is the size of a pointer that is wanted, the typo has no impact on compilation or execution. This problem was found using Coccinelle (http://coccinelle.lip6.fr/). The semantic patch used can be found in message 0 of this patch series. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2014-07-29isdn/bas_gigaset: fix a leak on failure path in gigaset_probe()Alexey Khoroshilov
There is a lack of usb_put_dev(udev) on failure path in gigaset_probe(). Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru> Acked-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-24isdn: use constants instead of magicnumbersHimangi Saraogi
This patch changes instances of magic numbers like 4 and 8 to equivalent constants. The Coccinelle semantic patch used for making the change is as follows: // <smpl> @r@ type T; T E; identifier fld; identifier c; @@ E->fld & c @s@ constant C; identifier r.c; @@ #define c C @@ r.T E; identifier r.fld; identifier r.c; constant s.C; @@ E->fld & - C + c // </smpl> Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/infiniband/hw/cxgb4/device.c The cxgb4 conflict was simply overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-16net: ppp: fix creating PPP pass and active filtersChristoph Schulz
Commit 568f194e8bd16c353ad50f9ab95d98b20578a39d ("net: ppp: use sk_unattached_filter api") inadvertently changed the logic when setting PPP pass and active filters. This applies to both the generic PPP subsystem implemented by drivers/net/ppp/ppp_generic.c and the ISDN PPP subsystem implemented by drivers/isdn/i4l/isdn_ppp.c. The original code in ppp_ioctl() (or isdn_ppp_ioctl(), resp.) handling PPPIOCSPASS and PPPIOCSACTIVE allowed to remove a pass/active filter previously set by using a filter of length zero. However, with the new code this is not possible anymore as this case is not explicitly checked for, which leads to passing NULL as a filter to sk_unattached_filter_create(). This results in returning EINVAL to the caller. Additionally, the variables ppp->pass_filter and ppp->active_filter (or is->pass_filter and is->active_filter, resp.) are not reset to NULL, although the filters they point to may have been destroyed by sk_unattached_filter_destroy(), so in this EINVAL case dangling pointers are left behind (provided the pointers were previously non-NULL). This patch corrects both problems by checking whether the filter passed is empty or non-empty, and prevents sk_unattached_filter_create() from being called in the first case. Moreover, the pointers are always reset to NULL as soon as sk_unattached_filter_destroy() returns. Signed-off-by: Christoph Schulz <develop@kristov.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2014-07-15net: set name_assign_type in alloc_netdev()Tom Gundersen
Extend alloc_netdev{,_mq{,s}}() to take name_assign_type as argument, and convert all users to pass NET_NAME_UNKNOWN. Coccinelle patch: @@ expression sizeof_priv, name, setup, txqs, rxqs, count; @@ ( -alloc_netdev_mqs(sizeof_priv, name, setup, txqs, rxqs) +alloc_netdev_mqs(sizeof_priv, name, NET_NAME_UNKNOWN, setup, txqs, rxqs) | -alloc_netdev_mq(sizeof_priv, name, setup, count) +alloc_netdev_mq(sizeof_priv, name, NET_NAME_UNKNOWN, setup, count) | -alloc_netdev(sizeof_priv, name, setup) +alloc_netdev(sizeof_priv, name, NET_NAME_UNKNOWN, setup) ) v9: move comments here from the wrong commit Signed-off-by: Tom Gundersen <teg@jklm.no> Reviewed-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-14net: ppp: don't call sk_chk_filter twiceChristoph Schulz
Commit 568f194e8bd16c353ad50f9ab95d98b20578a39d ("net: ppp: use sk_unattached_filter api") causes sk_chk_filter() to be called twice when setting a PPP pass or active filter. This applies to both the generic PPP subsystem implemented by drivers/net/ppp/ppp_generic.c and the ISDN PPP subsystem implemented by drivers/isdn/i4l/isdn_ppp.c. The first call is from within get_filter(). The second one is through the call chain ppp_ioctl() or isdn_ppp_ioctl() --> sk_unattached_filter_create() --> __sk_prepare_filter() --> sk_chk_filter() The first call from within get_filter() should be deleted as get_filter() is called just before calling sk_unattached_filter_create() later on, which eventually calls sk_chk_filter() anyway. For 3.15.x, this proposed change is a bugfix rather than a pure optimization as in that branch, sk_chk_filter() may replace filter codes by other codes which are not recognized when executing sk_chk_filter() a second time. So with 3.15.x, if sk_chk_filter() is called twice, the second invocation may yield EINVAL (this depends on the filter codes found in the filter to be set, but because the replacement is done for frequently used codes, this is almost always the case). The net effect is that setting pass and/or active PPP filters does not work anymore, since sk_unattached_filter_create() always returns EINVAL due to the second call to sk_chk_filter(), regardless whether the filter was originally sane or not. Signed-off-by: Christoph Schulz <develop@kristov.de> Acked-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-08isdn: hisax: l3ni1.c: Fix for possible null pointer dereferenceRickard Strandqvist
There is otherwise a risk of a possible null pointer dereference. Was largely found by using a static code analysis program called cppcheck. Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se>
2014-06-16isdn: hisax: Drop duplicate Kconfig entryJean Delvare
There are 2 HISAX_AVM_A1_PCMCIA Kconfig entries. The kbuild system ignores the second one, and apparently nobody noticed the problem so far, so let's remove that second entry. Signed-off-by: Jean Delvare <jdelvare@suse.de> Cc: Karsten Keil <isdn@linux-pingi.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-16isdn: hisax: Merge Kconfig ifsJean Delvare
The first half of the HiSax config options is presented if ISDN_DRV_HISAX!=n, while the second half of the options is presented if ISDN_DRV_HISAX. That's the same, so merge both conditionals. Signed-off-by: Jean Delvare <jdelvare@suse.de> Cc: Karsten Keil <isdn@linux-pingi.de> Signed-off-by: David S. Miller <davem@davemloft.net>
