path: root/drivers/leds/led-class.c
2011-11-21Revert "leds: save the delay values after a successful call to blink_set()"Johan Hovold
commit cb871513f656bdfc48b185b55f37857b5c750c40 upstream. Revert commit 6123b0e274503a0d3588e84fbe07c9aa01bfaf5d. The problem this patch intends to solve has alreadqy been fixed by commit 7a5caabd090b ("drivers/leds/ledtrig-timer.c: fix broken sysfs delay handling"). Signed-off-by: Johan Hovold <jhovold@gmail.com> Cc: Antonio Ospite <ospite@studenti.unina.it> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11leds: turn the blink_timer off before starting to blinkAntonio Ospite
commit 488bc35bf40df89d37486c1826b178a2fba36ce7 upstream. Depending on the implementation of the hardware blinking function in blink_set(), the led can support hardware blinking for some values of delay_on and delay_off and fall-back to software blinking for some other values. Turning off the blink_timer unconditionally before starting to blink make sure that a sequence like: OFF hardware blinking software blinking hardware blinking does not leave the software blinking timer active. Signed-off-by: Antonio Ospite <ospite@studenti.unina.it> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11leds: save the delay values after a successful call to blink_set()Antonio Ospite
commit 6123b0e274503a0d3588e84fbe07c9aa01bfaf5d upstream. When calling the hardware blinking function implemented by blink_set(), the delay_on and delay_off values are not preserved across calls. Fix that and make the "timer" trigger work as expected when hardware blinking is available. BEFORE the fix: $ cd /sys/class/leds/someled $ echo timer > trigger $ cat delay_on delay_off 0 0 $ echo 100 > delay_on $ cat delay_on delay_off 0 0 $ echo 100 > delay_off $ cat delay_on delay_off 0 0 AFTER the fix: $ cd /sys/class/leds/someled $ echo timer > trigger $ cat delay_on delay_off 0 0 $ echo 100 > delay_on $ cat delay_on delay_off 100 0 $ echo 100 > delay_off $ cat delay_on delay_off 100 100 Signed-off-by: Antonio Ospite <ospite@studenti.unina.it> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-25leds: support automatic start of blinking with ledtrig-timerEsben Haabendal
By setting initial values blink_delay_on and blink_delay_off in a led_classdev struct, this change starts the blinking when the led is initialized. With this patch, you can initialize blink_delay_on and blink_delay_off in led_classdev with default_trigger set to "timer", and the led will start up blinking. The current ledtrig-timer implementation ignores any initial blink_delay_on/blink_delay_off settings, and requires setting blink_delay_on/blink_delay_off (typically from userspace) before the led blinks. Signed-off-by: Esben Haabendal <eha@doredevelopment.dk> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-22led_class: fix typo in blink APIJohannes Berg
When I added led_blink_set I had a typo: the return value of the hw offload is a regular error code that is zero when succesful, and in that case software emulation should not be used, rather than the other way around. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Cc: Richard Purdie <rpurdie@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-12led-class: always implement blinkingJohannes Berg
Currently, blinking LEDs can be awkward because it is not guaranteed that all LEDs implement blinking. The trigger that wants it to blink then needs to implement its own timer solution. Rather than require that, add led_blink_set() API that triggers can use. This function will attempt to use hw blinking, but if that fails implements a timer for it. To stop blinking again, brightness_set() also needs to be wrapped into API that will stop the software blink. As a result of this, the timer trigger becomes a very trivial one, and hopefully we can finally see triggers using blinking as well because it's always easy to use. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Acked-by: Richard Purdie <rpurdie@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-26leds: led-class: set permissions on max_brightness file to 0444Axel Lin
max_brightness is not writable, thus set permissions to 0444. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2010-03-16leds: Fix race between LED device uevent and actual attributes creationFlorian Fainelli
If we were to dynamically register/unregister leds and have udev or other daemons handle the leds class uevents, we would be notified of the adding of a new LED and if the daemon immediately tries to open one of the attributes of the led device, it would fail with a "no such file or directory" error since this the attributes are not yet created. Fix this by switching attributes to be class-wide, such that the driver core will register these attributes with device_add_attrs and then emit the kobject_uevent ADD signal. Signed-off-by: Fainelli <ffainelli@freebox.fr> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2010-03-16leds: led-class.c - Quiet boot messagesH Hartley Sweeten
As each led device gets registered a kernel message gets printed. In an embedded system with a number of leds this can produce a lot of output that just looks like noise. Change the message type to KERN_DEBUG since it might be useful in the dmesg output "after" booting. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-12-15tree-wide: convert open calls to remove spaces to skip_spaces() lib functionAndré Goddard Rosa
Makes use of skip_spaces() defined in lib/string.c for removing leading spaces from strings all over the tree. It decreases lib.a code size by 47 bytes and reuses the function tree-wide: text data bss dec hex filename 64688 584 592 65864 10148 (TOTALS-BEFORE) 64641 584 592 65817 10119 (TOTALS-AFTER) Also, while at it, if we see (*str && isspace(*str)), we can be sure to remove the first condition (*str) as the second one (isspace(*str)) also evaluates to 0 whenever *str == 0, making it redundant. In other words, "a char equals zero is never a space". Julia Lawall tried the semantic patch (http://coccinelle.lip6.fr) below, and found occurrences of this pattern on 3 more files: drivers/leds/led-class.c drivers/leds/ledtrig-timer.c drivers/video/output.c @@ expression str; @@ ( // ignore skip_spaces cases while (*str && isspace(*str)) { \(str++;\|++str;\) } | - *str && isspace(*str) ) Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Cc: Julia Lawall <julia@diku.dk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Neil Brown <neilb@suse.de> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: David Howells <dhowells@redhat.com> Cc: <linux-ext4@vger.kernel.org> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: Patrick McHardy <kaber@trash.net> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-06leds: allow led-drivers to use a variable range of brightness valuesGuennadi Liakhovetski
This patch allows drivers to override the default maximum brightness value of 255. We take care to preserve backwards-compatibility as much as possible, so that user-space ABI doesn't change for existing drivers. LED trigger code has also been updated to use the per-LED maximum. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-01-08leds: Add suspend/resume to the core classRichard Purdie
Add suspend/resume to the core class and remove all the now unneeded code from various drivers. Originally the class code couldn't support suspend/resume but since class_device can there is no reason for each driver doing its own suspend/resume anymore.
2009-01-08leds: Fixup kdoc comment to match parameter namesSven Wegener
Signed-off-by: Sven Wegener <sven.wegener@stealer.net> Signed-off-by: Richard Purdie <rpurdie@intel.linux.com>
2008-10-20leds: Fix trigger registration raceRichard Purdie
Fix a race during trigger registration where we could try and use a lock before it was initialised. Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2008-10-20leds: Fix leds-class.c commentQinghuang Feng
led_classdev_unregister() has no "__" prefix, remove it. Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2008-10-20leds: Remove uneeded strlen callsSven Wegener
There's no need for the additional call to strlen(), we can directly return the value returned by sprintf(). We now return a length value that doesn't include the final '\0', but user space shouldn't bother about it anyway. Signed-off-by: Sven Wegener <sven.wegener@stealer.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2008-10-16device create: misc: convert device_create_drvdata to device_createGreg Kroah-Hartman
Now that device_create() has been audited, rename things back to the original call to be sane. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20LEDS: fix race in device_createGreg Kroah-Hartman
There is a race from when a device is created with device_create() and then the drvdata is set with a call to dev_set_drvdata() in which a sysfs file could be open, yet the drvdata will be NULL, causing all sorts of bad things to happen. This patch fixes the problem by using the new function, device_create_drvdata(). Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-29Remove duplicated unlikely() in IS_ERR()Hirofumi Nakagawa
Some drivers have duplicated unlikely() macros. IS_ERR() already has unlikely() in itself. This patch cleans up such pointless code. Signed-off-by: Hirofumi Nakagawa <hnakagawa@miraclelinux.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Jeff Garzik <jeff@garzik.org> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Patrick McHardy <kaber@trash.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-24leds: Add support to leds with readable statusHenrique de Moraes Holschuh
Some led hardware allows drivers to query the led state, and this patch adds a hook to let the led class take advantage of that information when available. Without this functionality, when access to the led hardware is not exclusive (i.e. firmware or hardware might change its state behind the kernel's back), reality goes out of sync with the led class' idea of what the led is doing, which is annoying at best. Behaviour for drivers that do not or cannot read the led status is unchanged. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2008-04-24leds: disable triggers on brightness setNémeth Márton
Disable any active triggers when the brightness attribute is set to zero. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Márton Németh <nm127@freemail.hu> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2008-04-19PM: Remove destroy_suspended_device()Rafael J. Wysocki
After 2.6.24 there was a plan to make the PM core acquire all device semaphores during a suspend/hibernation to protect itself from concurrent operations involving device objects. That proved to be too heavy-handed and we found a better way to achieve the goal, but before it happened, we had introduced the functions device_pm_schedule_removal() and destroy_suspended_device() to allow drivers to "safely" destroy a suspended device and we had adapted some drivers to use them. Now that these functions are no longer necessary, it seems reasonable to remove them and modify their users to use the normal device unregistration instead. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-05leds: add possibility to remove leds classdevs during suspend/resumeRafael J. Wysocki
Make it possible to unregister a led classdev object in a safe way during a suspend/resume cycle. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Michael Buesch <mb@bu3sch.de> Cc: Pavel Machek <pavel@ucw.cz> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Len Brown <lenb@kernel.org> Cc: Greg KH <greg@kroah.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-31leds: Fix leds_list_lock locking issuesRichard Purdie
Covert leds_list_lock to a rw_sempahore to match previous LED trigger locking fixes, fixing lock ordering. Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-12-07leds: Fix led trigger locking bugsRichard Purdie
Convert part of the led trigger core from rw spinlocks to rw semaphores. We're calling functions which can sleep from invalid contexts otherwise. Fixes bug #9264. Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-07-16leds: Convert from struct class_device to struct deviceRichard Purdie
Convert the LEDs class from struct class_device to struct device since class_device is scheduled for removal. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-17[PATCH] drivers/led: handle sysfs errorsJeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03kerneldoc-typo in led-class.cHenrik Kretzschmar
Fixes a typo in led-class.c kerneldoc. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-05-15[PATCH] LED: Fix sysfs store function error handlingRichard Purdie
Fix the error handling of some LED _store functions. This corrects them to return -EINVAL if the value is not numeric with an optional byte of trailing whitespace. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] LED: add LED trigger tupportRichard Purdie
Add support for LED triggers to the LED subsystem. "Triggers" are events which change the state of an LED. Two kinds of trigger are available, simple ones which can be added to exising code with minimum disruption and complex ones for implementing new or more complex functionality. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] LED: add LED classRichard Purdie
Add the foundations of a new LEDs subsystem. This patch adds a class which presents LED devices within sysfs and allows their brightness to be controlled. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
