Signed-off-by: Brian Swetland <swetland@google.com>
commit cb871513f656bdfc48b185b55f37857b5c750c40 upstream.
Revert commit 6123b0e274503a0d3588e84fbe07c9aa01bfaf5d.
The problem this patch intends to solve has alreadqy been fixed by
commit 7a5caabd090b ("drivers/leds/ledtrig-timer.c: fix broken sysfs
delay handling").
Signed-off-by: Johan Hovold <jhovold@gmail.com>
Cc: Antonio Ospite <ospite@studenti.unina.it>
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: Richard Purdie <rpurdie@rpsys.net>
commit 488bc35bf40df89d37486c1826b178a2fba36ce7 upstream.
Depending on the implementation of the hardware blinking function in
blink_set(), the led can support hardware blinking for some values of
delay_on and delay_off and fall-back to software blinking for some other
values.
Turning off the blink_timer unconditionally before starting to blink
make sure that a sequence like:
OFF
hardware blinking
software blinking
hardware blinking
does not leave the software blinking timer active.
Signed-off-by: Antonio Ospite <ospite@studenti.unina.it>
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
commit 6123b0e274503a0d3588e84fbe07c9aa01bfaf5d upstream.
When calling the hardware blinking function implemented by blink_set(),
the delay_on and delay_off values are not preserved across calls.
Fix that and make the "timer" trigger work as expected when hardware
blinking is available.
BEFORE the fix:
$ cd /sys/class/leds/someled
$ echo timer > trigger
$ cat delay_on delay_off
0
0
$ echo 100 > delay_on
0
0
$ echo 100 > delay_off
0
0
AFTER the fix:
0
0
100
0
100
100
Fix regression introduced by commit 5ada28bf7675 ("led-class: always
implement blinking") which broke sysfs delay handling by not storing the
updated value. Consequently it was only possible to set one of the delays
through the sysfs interface as the other delay was automatically restored
to it's default value. Reading the parameters always gave the defaults.
Acked-by: Florian Fainelli <florian@openwrt.org>
Acked-by: Richard Purdie <richard.purdie@linuxfoundation.org>
Cc: <stable@kernel.org> [2.6.37+]
unregister all registered leds
bd2802_unregister_led_classdev() should unregister all registered
instances of led_classdev class that had registered by
bd2802_register_led_classdev().
Acked-by: Kim Kyuwon <q1.kim@samsung.com>
Add missing include of linux/module.h for drivers that use interfaces from
linux/module.h. This patch fixes build errors.
Cc: Jonathan McDowell <noodles@earth.li>
Acked-by: Kristoffer Ericson <kristoffer.ericson@gmail.com>
Cc: Magnus Damm <damm@opensource.se>
Provide the support for auto calibration of ALS Zone boundaries based on
min/max ALS input voltage.
Signed-off-by: Shreshtha Kumar Sahu <shreshthakumar.sahu@stericsson.com>
Cc: Lee Jones <lee.jones@linaro.org>
We call led_classdev_register/led_classdev_unregister in
create_netxbig_led/delete_netxbig_led, thus make LEDS_NETXBIG depend on
LEDS_CLASS.
This patch fixes below build error if LEDS_CLASS is not configured.
LD .tmp_vmlinux1
drivers/built-in.o: In function `create_netxbig_led':
drivers/leds/leds-netxbig.c:350: undefined reference to `led_classdev_register'
drivers/leds/leds-netxbig.c:361: undefined reference to `led_classdev_unregister'
drivers/built-in.o: In function `delete_netxbig_led':
drivers/leds/leds-netxbig.c:313: undefined reference to `led_classdev_unregister'
Acked-by: Simon Guinot <sguinot@lacie.com>
- return -ENOMEM if kzalloc fails, rather than the current -EINVAL
- fix a memory leak in the case of goto out_unregister_led_cdevs
Tag the and remove() function as __devexit respectively.
* 'gpio/next' of git://git.secretlab.ca/git/linux-2.6: (61 commits)
gpio/mxc/mxs: fix build error introduced by the irq_gc_ack() renaming
mcp23s08: add i2c support
mcp23s08: isolate spi specific parts
mcp23s08: get rid of setup/teardown callbacks
gpio/tegra: dt: add binding for gpio polarity
mcp23s08: remove unused work queue
gpio/da9052: remove a redundant assignment for gpio->da9052
gpio/mxc: add device tree probe support
ARM: mxc: use ARCH_NR_GPIOS to define gpio number
gpio/mxc: get rid of the uses of cpu_is_mx()
gpio/mxc: add missing initialization of basic_mmio_gpio shadow variables
gpio: Move mpc5200 gpio driver to drivers/gpio
GPIO: DA9052 GPIO module v3
gpio/tegra: Use engineering names in DT compatible property
of/gpio: Add new method for getting gpios under different property names
gpio/dt: Refine GPIO device tree binding
gpio/ml-ioh: fix off-by-one for displaying variable i in dev_err
gpio/pca953x: Deprecate meaningless device-tree bindings
gpio/pca953x: Remove dynamic platform data pointer
gpio/pca953x: Fix IRQ support.
This driver handles the variants pca9530-pca9533, so it chose the name
"pca953x". However, there is a gpio driver which decided on the same
name. As a result, those two can't be loaded at the same time. Add a
subsystem prefix to make the driver name unique. Device matching will not
suffer, because both are I2C drivers which match using a
i2c_device_id-table which is not altered.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Acked-by: Jean Delvare <khali@linux-fr.org>
Cc: Richard Purdie <richard.purdie@linuxfoundation.org>
Fix this section mismatch:
WARNING: drivers/leds/leds-lp5523.o(.text+0x12f4): Section mismatch in reference from the function lp5523_probe() to the function .init.text:lp5523_init_led()
The function lp5523_probe() references
the function __init lp5523_init_led().
This is often because lp5523_probe lacks a __init
annotation or the annotation of lp5523_init_led is wrong.
Fixing this one triggers one more mismatch, fix that one as well.
WARNING: drivers/leds/leds-lp5521.o(.text+0xf2c): Section mismatch in reference from the function lp5521_probe() to the function .init.text:lp5521_init_led()
The function lp5521_probe() references
the function __init lp5521_init_led().
This is often because lp5521_probe lacks a __init
annotation or the annotation of lp5521_init_led is wrong.
Fixing this mismatch triggers one more mismatch, fix that one as well.
Seems when a config option does not have a dependency of the menuconfig,
it messes the display of the rest configs, even if it's a hidden one.
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
Cc: Valdis Kletnieks <Valdis.Kletnieks@vt.edu>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Commit 4440673a95e6 ("leds: provide helper to register "leds-gpio"
devices") broke the display of the NEW_LEDS menu as it didn't depend on
NEW_LEDS and so made "LED drivers" and "LED Triggers" appear at the same
level as "LED Support" instead of below it as it was before 4440673a.
Moving LEDS_GPIO_REGISTER out of the menuconfig NEW_LEDS fixes this
unintended side effect.
Reported-by: Axel Lin <axel.lin@gmail.com>
We call led_classdev_unregister/led_classdev_register in
asic3_led_remove/asic3_led_probe, thus make LEDS_ASIC3 depend on
LEDS_CLASS.
LD .tmp_vmlinux1
drivers/built-in.o: In function `asic3_led_remove':
clkdev.c:(.devexit.text+0x1860): undefined reference to `led_classdev_unregister'
drivers/built-in.o: In function `asic3_led_probe':
clkdev.c:(.devinit.text+0xcee8): undefined reference to `led_classdev_register'
make: *** [.tmp_vmlinux1] Error 1
Cc: Paul Parsons <lost.distance@yahoo.com>
Since the commit a314c5c0040aab51ebb1ecfd37a9198a91962243
(leds/leds-gpio: merge platform_driver with of_platform_driver),
the config option LEDS_GPIO_PLATFORM becomes useless, so remove it.
[grant.likely: also remove LEDS_GPIO_OF for same reason]
Add LED support for the HTC ASIC3. Underlying support is provided by the mfd/asic3 and leds/leds-asic3 drivers. An example configuration is provided by the pxa/hx4700 platform.
Signed-off-by: Paul Parsons <lost.distance@yahoo.com>
With the addition of a platform device mfd_cell pointer, MFD drivers
can go back to passing platform back to their sub drivers.
This allows for an mfd_cell->mfd_data removal and thus keep the
sub drivers MFD agnostic. This is mostly needed for non MFD aware
sub drivers.
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
Cc: Liam Girdwood <lrg@slimlogic.co.uk>
Acked-by: Haojian Zhuang <haojian.zhuang@marvell.com>
can go back to passing platform data back to their sub drivers.
sub drivers.
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
This function makes a deep copy of the platform data to allow it to live
in init memory. For a kernel that supports several machines and so
includes the definition for several leds-gpio devices this saves quite
some memory because all but one definition can be free'd after boot.
As the function is used by arch code it must be builtin and so cannot go
into leds-gpio.c.
[akpm@linux-foundation.org: s/CONFIG_LED_REGISTER_GPIO/CONFIG_LEDS_REGISTER_GPIO/]
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Tested-by: H Hartley Sweeten <hartleys@visionengravers.com>
Add add regulator support to lm3530 driver. The lm3530 driver needs to
get proper regulator during device probe and enable it before accessing
the device. Also it disables the regulator in case of brightness ==
LED_OFF, and puts it back during driver removal.
Cc: Shreshtha Kumar Sahu <shreshthakumar.sahu@stericsson.com>
The H1940 machine now uses leds-gpio and leds-h1940 has no users anymore.
Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
Cc: "Arnaud Patard (Rtp)" <arnaud.patard@rtp-net.org>
Cc: Ben Dooks <ben-linux@fluff.org>
The pca953x family are only different in number of leds and register
layout Adding chipinfo to use driver with whole pca953x family Rename
driver to pca953x, but left files and platformflags named pca9532.
Tested with pca9530 and pca9533
Tested-by: Juergen Kilb <j.kilb@phytec.de>
Signed-off-by: Jan Weitzel <j.weitzel@phytec.de>
Acked-by: Joachim Eastwood <joachim.eastwood@jotron.com>
Tested-by: Joachim Eastwood <joachim.eastwood@jotron.com>
Cc: Wolfram Sang <w.sang@pengutronix.de>
Cc: H Hartley Sweeten <hsweeten@visionengravers.com>
Cc: Grant Likely <grant.likely@secretlab.ca>
Allow unused leds on pca9532 to be used as gpio. The board I am working
on now has no less than 6 pca9532 chips. One chips is used for only leds,
one has 14 leds and 2 gpio and the rest of the chips are gpio only.
There is also one board in mainline which could use this capabilty;
arch/arm/mach-iop32x/n2100.c
232 { .type = PCA9532_TYPE_NONE }, /* power OFF gpio */
233 { .type = PCA9532_TYPE_NONE }, /* reset gpio */
This patch defines a new pin type, PCA9532_TYPE_GPIO, and registers a
gpiochip if any pin has this type set. The gpio will registers all chip
pins but will filter on gpio_request.
[randy.dunlap@oracle.com: fix build when GPIOLIB is not enabled]
Signed-off-by: Joachim Eastwood <joachim.eastwood@jotron.com>
Reviewed-by: Wolfram Sang <w.sang@pengutronix.de>
Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Cc: Jan Weitzel <j.weitzel@phytec.de>
Cc: Juergen Kilb <j.kilb@phytec.de>
By setting initial values blink_delay_on and blink_delay_off in a
led_classdev struct, this change starts the blinking when the led is
initialized.
With this patch, you can initialize blink_delay_on and blink_delay_off in
led_classdev with default_trigger set to "timer", and the led will start
up blinking. The current ledtrig-timer implementation ignores any initial
blink_delay_on/blink_delay_off settings, and requires setting
blink_delay_on/blink_delay_off (typically from userspace) before the led
blinks.
Signed-off-by: Esben Haabendal <eha@doredevelopment.dk>
Cc: Randy Dunlap <rdunlap@xenotime.net>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
b43: fix comment typo reqest -> request
Haavard Skinnemoen has left Atmel
cris: typo in mach-fs Makefile
Kconfig: fix copy/paste-ism for dell-wmi-aio driver
doc: timers-howto: fix a typo ("unsgined")
perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c
md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course').
treewide: fix a few typos in comments
regulator: change debug statement be consistent with the style of the rest
Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations"
audit: acquire creds selectively to reduce atomic op overhead
rtlwifi: don't touch with treewide double semicolon removal
treewide: cleanup continuations and remove logging message whitespace
ath9k_hw: don't touch with treewide double semicolon removal
include/linux/leds-regulator.h: fix syntax in example code
tty: fix typo in descripton of tty_termios_encode_baud_rate
xtensa: remove obsolete BKL kernel option from defconfig
m68k: fix comment typo 'occcured'
arch:Kconfig.locks Remove unused config option.
treewide: remove extra semicolons
Adding the necessary MODULE_DEVICE_TABLE() information allows the driver
to be automatically loaded by udev.
Cc: Shreshtha Kumar SAHU <shreshthakumar.sahu@stericsson.com>
Fast-forwarded to current state of Linus' tree as there are patches to be
applied for files that didn't exist on the old branch.
Make the driver aware of the initial status of the regulator.
The leds-regulator driver was ignoring the initial status of the
regulator; this resulted in rdev->use_count being incremented to 2 after
calling regulator_led_set_value() in the .probe method when a regulator
was already enabled at insmod time, which made it impossible to ever
disable the regulator.
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Cc: Daniel Ribeiro <drwyrm@gmail.com>
* git://git.infradead.org/battery-2.6: (30 commits)
bq20z75: Fix time and temp units
bq20z75: Fix issues with present and suspend
z2_battery: Fix count of properties
s3c_adc_battery: Fix method names when PM not set
z2_battery: Add MODULE_DEVICE_TABLE
ds2782_battery: Add MODULE_DEVICE_TABLE
bq20z75: Add MODULE_DEVICE_TABLE
power_supply: Update power_supply_is_watt_property
bq20z75: Add i2c retry mechanism
bq20z75: Add optional battery detect gpio
twl4030_charger: Make the driver atomic notifier safe
bq27x00: Use single i2c_transfer call for property read
bq27x00: Cleanup bq27x00_i2c_read
bq27x00: Minor cleanups
bq27x00: Give more specific reports on battery status
bq27x00: Add MODULE_DEVICE_TABLE
bq27x00: Add new properties
bq27x00: Poll battery state
bq27x00: Cache battery registers
bq27x00: Add bq27000 support
Copy 88pm860x platform data into different mfd_data structure for
led driver. So move the identification of device node from led
driver to mfd driver.
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
The cell's platform_data is now accessed with a helper function;
change clients to use that, and remove the now-unused data_size.
Note that mfd-core no longer makes a copy of platform_data, but the
mc13xxx-core driver creates the pdata structures on the stack. In
order to get around that, the various ARM mach types that set the
pdata have been changed to hold the variable in static (global) memory.
Also note that __initdata references in aforementioned pdata structs
have been dropped.
Signed-off-by: Andres Salomon <dilinger@queued.net>
Don't allow everybody to change LED settings.
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
And fix a typo.
Cc: Lars-Peter Clausen <lars@metafoo.de>
Simple backlight driver for National Semiconductor LM3530. Presently only
manual mode is supported, PWM and ALS support to be added.
Cc: Linus Walleij <linus.walleij@stericsson.com>
There is a move to deprecate bus-specific PM operations and move to using
dev_pm_ops instead in order to reduce the amount of boilerplate code in
buses and facilitiate updates to the PM core. Do this move for the bs2802
driver.
[akpm@linux-foundation.org: fix warnings]
Cc: Kim Kyuwon <q1.kim@samsung.com>
Cc: Kim Kyuwon <chammoru@gmail.com>
Both interfaces can be driven with the same driver, and
of_platform_driver is getting removed. This patch merges the two
driver registrations.
As blink API is now available, it's possible to add ability to blink via
simple trigger.
Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
Return PTR_ERR(led_dat->pwm) instead of 0 if pwm_request failed
Cc: Luotao Fu <l.fu@pengutronix.de>
Cc: Reviewed-by: Dmitry Torokhov <dtor@mail.ru>
Replicate changes made to drivers/leds/ledtrig-backlight.c.
Extend the LED backlight tirgger driver with an option that allows for
inverting the trigger output polarity.
With the invertion option provided, I (ab)use the backlight trigger for
driving a LED that indicates LCD display blank condtition on my Amstrad
Delta videophone. Since the machine has no dedicated power LED, it was
not possible to distinguish if the display was blanked, or the machine was
turned off, without touching it.
The invert sysfs control is patterned after a similiar function of the GPIO
trigger driver.
[akpm@linux-foundation.org: make output match input, tighten input checking]
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Currently the led device name is fetched from the device_type in
I2C_BOARD_INFO which comes from the platform data. This name is in turn
used to create an entry in sysfs.
If there exists two or more lp5521 on a particular platform, the
device_type in I2C_BOARD_INFO has to be the same, else lp5521 driver probe
wont be called and if used so, results in run time warning "cannot create
sysfs with same name" and hence a failure.
The name that is used to create sysfs entry is to be passed by the struct
led_platform_data. Hence adding an element of type const char * and
change in lp5521 driver to use this name in creating the led device if
present else use the name obtained by I2C_BOARD_INFO.
Signed-off-by: Arun Murthy <arun.murthy@stericsson.com>
Acked-by: Samu Onkalo <samu.p.onkalo@nokia.com>
Cc: Ilkka Koskinen <ilkka.koskinen@nokia.com>
Driver contained possibility for circular locking.
One lock is held by sysfs-core and another one by the driver itself. This
happened when the driver created or removed sysfs entries dynamically.
There is no real need to do those operations. Now all the sysfs entries
are created at probe and removed at removal. Engine load sysfs entries
are now visible all the time. However, access to the entries fails if the
engine is disabled or running.
Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com>
Cc: Arun Murthy <arun.murthy@stericsson.com>
Reviewed-by: Ilkka Koskinen <ilkka.koskinen@nokia.com>
are created at probe and removed at removal. Engine load and mux
configuration sysfs entries are now visible all the time. However, access
to the entries fails if the engine is disabled or running.
