path: root/drivers/lguest/interrupts_and_traps.c
2008-03-28lguest: comment documentation update.Rusty Russell
Took some cycles to re-read the Lguest Journey end-to-end, fix some rot and tighten some phrases. Only comments change. No new jokes, but a couple of recycled old jokes. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: get rid of lg variable assignmentsGlauber de Oliveira Costa
We can save some lines of code by getting rid of *lg = cpu... lines of code spread everywhere by now. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: move changed bitmap to lg_cpuGlauber de Oliveira Costa
events represented in the 'changed' bitmap are per-cpu, not per-guest. move it to the lg_cpu structure Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: per-vcpu lguest pgdir managementGlauber de Oliveira Costa
this patch makes the pgdir management per-vcpu. The pgdirs pool is still guest-wide (although it'll probably need to grow when we are really executing more vcpus), but the pgdidx index is gone, since it makes no sense anymore. Instead, we use a per-vcpu index. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: makes special fields be per-vcpuGlauber de Oliveira Costa
lguest struct have room for some fields, namely, cr2, ts, esp1 and ss1, that are not really guest-wide, but rather, vcpu-wide. This patch puts it in the vcpu struct Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: per-vcpu lguest task managementGlauber de Oliveira Costa
lguest uses tasks to control its running behaviour (like sending breaks, controlling halted state, etc). In a per-vcpu environment, each vcpu will have its own underlying task. So this patch makes the infrastructure for that possible Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: replace lguest_arch with lg_cpu_arch.Glauber de Oliveira Costa
The fields found in lguest_arch are not really per-guest, but per-cpu (gdt, idt, etc). So this patch turns lguest_arch into lg_cpu_arch. It makes sense to have a per-guest per-arch struct, but this can be addressed later, when the need arrives. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: make registers per-vcpuGlauber de Oliveira Costa
This is the most obvious per-vcpu field: registers. So this patch moves it from struct lguest to struct vcpu, and patch the places in which they are used, accordingly Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: per-vcpu interrupt processing.Glauber de Oliveira Costa
This patch adapts interrupt processing for using the vcpu struct. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: per-vcpu lguest timersGlauber de Oliveira Costa
Here, I introduce per-vcpu timers. With this, we can have local expiries, needed for accounting time in smp guests Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-25lguest: documentation updateRusty Russell
Went through the documentation doing typo and content fixes. This patch contains only comment and whitespace changes. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-23generalize lgread_u32/lgwrite_u32.Rusty Russell
Jes complains that page table code still uses lgread_u32 even though it now uses general kernel pte types. The best thing to do is to generalize lgread_u32 and lgwrite_u32. This means we lose the efficiency of getuser(). We could potentially regain it if we used __copy_from_user instead of copy_from_user, but I'm not certain that our range check is equivalent to access_ok() on all platforms. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Jes Sorensen <jes@sgi.com>
2007-10-23Boot with virtual == physical to get closer to native Linux.Rusty Russell
1) This allows us to get alot closer to booting bzImages. 2) It means we don't have to know page_offset. 3) The Guest needs to modify the boot pagetables to create the PAGE_OFFSET mapping before jumping to C code. 4) guest_pa() walks the page tables rather than using page_offset. 5) We don't use page_offset to figure out whether to emulate: it was always kinda quesationable, and won't work for instructions done before remapping (bzImage unpacking in particular). 6) We still want the kernel address for tlb flushing: have the initial hypercall give us that, too. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-23Allow guest to specify syscall vector to use.Rusty Russell
(Based on Ron Minnich's LGUEST_PLAN9_SYSCALL patch). This patch allows Guests to specify what system call vector they want, and we try to reserve it. We only allow one non-Linux system call vector, to try to avoid DoS on the Host. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-23Move i386 part of core.c to x86/core.c.Jes Sorensen
Separate i386 architecture specific from core.c and move it to x86/core.c and add x86/lguest.h header file to match. Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-23Make shadow IDT a complete IDT with 256 entries.Rusty Russell
This simplifies the code a little, in preparation for allowing alternate system call vectors in guests (Plan 9 uses 0x40). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-08-30Fix lguest page-pinning logic ("lguest: bad stack page 0xc057a000")Rusty Russell
If the stack pointer is 0xc057a000, then the first stack page is at 0xc0579000 (the stack pointer is decremented before use). Not calculating this correctly caused guests with CONFIG_DEBUG_PAGEALLOC=y to be killed with a "bad stack page" message: the initial kernel stack was just proceeding the .smp_locks section which CONFIG_DEBUG_PAGEALLOC marks read-only when freeing. Thanks to Frederik Deweerdt for the bug report! Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-09lguest: Fix Malicious Guest GDT Host CrashRusty Russell
If a Guest makes hypercall which sets a GDT entry to not present, we currently set any segment registers using that GDT entry to 0. Unfortunately, this is not sufficient: there are other ways of altering GDT entries which will cause a fault. The correct solution to do what Linux does: let them set any GDT value they want and handle the #GP when popping causes a fault. This has the added benefit of making our Switcher slightly more robust in the case of any other bugs which cause it to fault. We kill the Guest if it causes a fault in the Switcher: it's the Guest's responsibility to make sure it's not using segments when it changes them. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-28Provide timespec to guests rather than jiffies clock.Rusty Russell
A non-periodic clock_event_device and the "jiffies" clock don't mix well: tick_handle_periodic() can go into an infinite loop. Currently lguest guests use the jiffies clock when the TSC is unusable. Instead, make the Host write the current time into the lguest page on every interrupt. This doesn't cost much but is more precise and at least as accurate as the jiffies clock. It also gets rid of the GET_WALLCLOCK hypercall. Also, delay setting sched_clock until our clock is set up, otherwise the early printk timestamps can go backwards (not harmful, just ugly). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26lguest: documentation VII: FIXMEsRusty Russell
Documentation: The FIXMEs Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26lguest: documentation V: HostRusty Russell
Documentation: The Host Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26lguest: documentation I: PreparationRusty Russell
The netfilter code had very good documentation: the Netfilter Hacking HOWTO. Noone ever read it. So this time I'm trying something different, using a bit of Knuthiness. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-20lguest: fix sense if IF flag on interrupt injectionRusty Russell
The sense of the IF bit is backwards in the host interrupt handling. This means we always save "IF=1" on the stack when injecting an interrupt. It turns out this is almost always correct (unless the guest is taking a page fault in an interrupt due to an unpopulated vmalloc mapping), so went unnoticed. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19lguest: the host codeRusty Russell
This is the code for the "lg.ko" module, which allows lguest guests to be launched. [akpm@linux-foundation.org: update for futex-new-private-futexes] [akpm@linux-foundation.org: build fix] [jmorris@namei.org: lguest: use hrtimers] [akpm@linux-foundation.org: x86_64 build fix] Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Andi Kleen <ak@suse.de> Cc: Eric Dumazet <dada1@cosmosbay.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
