path: root/drivers/lguest/x86/core.c
2010-04-14lguest: workaround cmpxchg8b_emu by ignoring cli in the guest.Rusty Russell
It's only used by cmpxchg8b_emu (see db677ffa5f5a for the gory details), and fixing that to be paravirt aware would be more work than simply ignoring it (and AFAICT only help lguest). This makes lguest work on machines which have cmpxchg8b, for kernels compiled for older processors. (We can't emulate it properly: the popf which expects to restore interrupts does not trap). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: virtualization@lists.osdl.org
2009-10-29percpu: make misc percpu symbols uniqueTejun Heo
This patch updates misc percpu related symbols such that percpu symbols are unique and don't clash with local symbols. This serves two purposes of decreasing the possibility of global percpu symbol collision and allowing dropping per_cpu__ prefix from percpu symbols. * drivers/crypto/padlock-aes.c: s/last_cword/paes_last_cword/ * drivers/lguest/x86/core.c: s/last_cpu/lg_last_cpu/ * drivers/s390/net/netiucv.c: rename the variable used in a macro to avoid clashing with percpu symbol * arch/mn10300/kernel/kprobes.c: replace current_ prefix with cur_ for static variables. Please note that percpu symbol current_kprobe can't be changed as it's used by generic code. Partly based on Rusty Russell's "alloc_percpu: rename percpu vars which cause name clashes" patch. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Chuck Ebbert <cebbert@redhat.com> Cc: David Howells <dhowells@redhat.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Cc: Masami Hiramatsu <mhiramat@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: linux390@de.ibm.com
2009-07-30lguest: update commentryRusty Russell
Every so often, after code shuffles, I need to go through and unbitrot the Lguest Journey (see drivers/lguest/README). Since we now use RCU in a simple form in one place I took the opportunity to expand that explanation. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@redhat.com> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
2009-07-30lguest: fix comment styleRusty Russell
I don't really notice it (except to begrudge the extra vertical space), but Ingo does. And he pointed out that one excuse of lguest is as a teaching tool, it should set a good example. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@redhat.com>
2009-05-26lguest: fix on Intel when KVM loaded (unhandled trap 13)Rusty Russell
When KVM is loaded, and hence VT set up, the vmcall instruction in an lguest guest causes a #GP, not #UD. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-19lguest: fix guest crash on non-linear addresses in gdt pvopsRusty Russell
Fixes guest crash 'lguest: bad read address 0x4800000 len 256' The new per-cpu allocator ends up handing a non-linear address to write_gdt_entry. We do __pa() on it, and hand it to the host, which kills us. I've long wanted to make the hypercall "LOAD_GDT_ENTRY" to match the IDT code, but had no pressing reason until now. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: lguest@ozlabs.org
2009-04-19lguest: fix crash on vmlinux imagesMatias Zabaljauregui
Typical message: 'lguest: unhandled trap 6 at 0x418726 (0x0)' vmlinux guests were broken by 4cd8b5e2a159f18a1507f1187b44a1acbfa6341b 'lguest: use KVM hypercalls', which rewrites guest text from kvm hypercalls to trap 31. The Launcher mmaps the kernel image. The Guest executes and immediately faults in the first text page (read-only). Then it hits a hypercall, and we rewrite that hypercall, causing a copy-on-write. But the Guest pagetables still refer to the old page: we fault again, but as Host we see the hypercall already rewritten, and pass the fault back to the Guest. The Guest hasn't set up an IDT yet, so we kill it. This doesn't happen with bzImages: they unpack themselves and so the text pages are already read-write. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Tested-by: Patrick McHardy <kaber@trash.net>
2009-03-30lguest: use KVM hypercallsMatias Zabaljauregui
Impact: cleanup This patch allow us to use KVM hypercalls Signed-off-by: Matias Zabaljauregui <zabaljauregui at gmail.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-07-29lguest: use cpu capability accessorsAndrew Morton
To support my little make-x86-bitops-use-proper-typechecking projectlet. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andrea Arcangeli <andrea@qumranet.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-06-26on_each_cpu(): kill unused 'retry' parameterJens Axboe
It's not even passed on to smp_call_function() anymore, since that was removed. So kill it. Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-06-20x86: fix NULL pointer deref in __switch_toSuresh Siddha
I am able to reproduce the oops reported by Simon in __switch_to() with lguest. My debug showed that there is at least one lguest specific issue (which should be present in 2.6.25 and before aswell) and it got exposed with a kernel oops with the recent fpu dynamic allocation patches. In addition to the previous possible scenario (with fpu_counter), in the presence of lguest, it is possible that the cpu's TS bit it still set and the lguest launcher task's thread_info has TS_USEDFPU still set. This is because of the way the lguest launcher handling the guest's TS bit. (look at lguest_set_ts() in lguest_arch_run_guest()). This can result in a DNA fault while doing unlazy_fpu() in __switch_to(). This will end up causing a DNA fault in the context of new process thats getting context switched in (as opossed to handling DNA fault in the context of lguest launcher/helper process). This is wrong in both pre and post 2.6.25 kernels. In the recent 2.6.26-rc series, this is showing up as NULL pointer dereferences or sleeping function called from atomic context(__switch_to()), as we free and dynamically allocate the FPU context for the newly created threads. Older kernels might show some FPU corruption for processes running inside of lguest. With the appended patch, my test system is running for more than 50 mins now. So atleast some of your oops (hopefully all!) should get fixed. Please give it a try. I will spend more time with this fix tomorrow. Reported-by: Simon Holm Thøgersen <odie@cs.aau.dk> Reported-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-03-28lguest: comment documentation update.Rusty Russell
Took some cycles to re-read the Lguest Journey end-to-end, fix some rot and tighten some phrases. Only comments change. No new jokes, but a couple of recycled old jokes. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-31lguest: fix mis-merge against hpa's TSS renamingRusty Russell
drivers/lguest/x86/core.c: In function ‘copy_in_guest_info’: drivers/lguest/x86/core.c:97: error: ‘struct x86_hw_tss’ has no member named ‘esp1’ Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (27 commits) lguest: use __PAGE_KERNEL instead of _PAGE_KERNEL lguest: Use explicit includes rateher than indirect lguest: get rid of lg variable assignments lguest: change gpte_addr header lguest: move changed bitmap to lg_cpu lguest: move last_pages to lg_cpu lguest: change last_guest to last_cpu lguest: change spte_addr header lguest: per-vcpu lguest pgdir management lguest: make pending notifications per-vcpu lguest: makes special fields be per-vcpu lguest: per-vcpu lguest task management lguest: replace lguest_arch with lg_cpu_arch. lguest: make registers per-vcpu lguest: make emulate_insn receive a vcpu struct. lguest: map_switcher_in_guest() per-vcpu lguest: per-vcpu interrupt processing. lguest: per-vcpu lguest timers lguest: make hypercalls use the vcpu struct lguest: make write() operation smp aware ... Manual conflict resolved (maybe even correctly, who knows) in drivers/lguest/x86/core.c
2008-01-30x86: use generic register name in the thread and tss structuresH. Peter Anvin
This changes size-specific register names (eip/rip, esp/rsp, etc.) to generic names in the thread and tss structures. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30lguest: get rid of lg variable assignmentsGlauber de Oliveira Costa
We can save some lines of code by getting rid of *lg = cpu... lines of code spread everywhere by now. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: move changed bitmap to lg_cpuGlauber de Oliveira Costa
events represented in the 'changed' bitmap are per-cpu, not per-guest. move it to the lg_cpu structure Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: move last_pages to lg_cpuGlauber de Oliveira Costa
in our new model, pages are assigned to a virtual cpu, not to a guest. We move it to the lg_cpu structure. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: change last_guest to last_cpuGlauber de Oliveira Costa
in our model, a guest does not run in a cpu anymore: a virtual cpu does. So we change last_guest to last_cpu Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: per-vcpu lguest pgdir managementGlauber de Oliveira Costa
this patch makes the pgdir management per-vcpu. The pgdirs pool is still guest-wide (although it'll probably need to grow when we are really executing more vcpus), but the pgdidx index is gone, since it makes no sense anymore. Instead, we use a per-vcpu index. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: makes special fields be per-vcpuGlauber de Oliveira Costa
lguest struct have room for some fields, namely, cr2, ts, esp1 and ss1, that are not really guest-wide, but rather, vcpu-wide. This patch puts it in the vcpu struct Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: replace lguest_arch with lg_cpu_arch.Glauber de Oliveira Costa
The fields found in lguest_arch are not really per-guest, but per-cpu (gdt, idt, etc). So this patch turns lguest_arch into lg_cpu_arch. It makes sense to have a per-guest per-arch struct, but this can be addressed later, when the need arrives. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: make registers per-vcpuGlauber de Oliveira Costa
This is the most obvious per-vcpu field: registers. So this patch moves it from struct lguest to struct vcpu, and patch the places in which they are used, accordingly Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: make emulate_insn receive a vcpu struct.Glauber de Oliveira Costa
emulate_insn() needs to know about current eip, which will be, in the future, a per-vcpu thing. So in this patch, the function prototype is modified to receive a vcpu struct Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: map_switcher_in_guest() per-vcpuGlauber de Oliveira Costa
The switcher needs to be mapped per-vcpu, because different vcpus will potentially have different page tables (they don't have to, because threads will share the same). So our first step is the make the function receive a vcpu struct Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: per-vcpu interrupt processing.Glauber de Oliveira Costa
This patch adapts interrupt processing for using the vcpu struct. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: make hypercalls use the vcpu structGlauber de Oliveira Costa
this patch changes do_hcall() and do_async_hcall() interfaces (and obviously their callers) to get a vcpu struct. Again, a vcpu services the hypercall, not the whole guest Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: per-cpu run guestGlauber de Oliveira Costa
This patch makes the run_guest() routine use the lg_cpu struct. This is required since in a smp guest environment, there's no more the notion of "running the guest", but rather, it is "running the vcpu" Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-25cpu-hotplug: replace lock_cpu_hotplug() with get_online_cpus()Gautham R Shenoy
Replace all lock_cpu_hotplug/unlock_cpu_hotplug from the kernel and use get_online_cpus and put_online_cpus instead as it highlights the refcount semantics in these operations. The new API guarantees protection against the cpu-hotplug operation, but it doesn't guarantee serialized access to any of the local data structures. Hence the changes needs to be reviewed. In case of pseries_add_processor/pseries_remove_processor, use cpu_maps_update_begin()/cpu_maps_update_done() as we're modifying the cpu_present_map there. Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-25lguest: documentation updateRusty Russell
Went through the documentation doing typo and content fixes. This patch contains only comment and whitespace changes. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-25lguest: use defines from x86 headers instead of magic numbersRusty Russell
2007-10-23generalize lgread_u32/lgwrite_u32.Rusty Russell
Jes complains that page table code still uses lgread_u32 even though it now uses general kernel pte types. The best thing to do is to generalize lgread_u32 and lgwrite_u32. This means we lose the efficiency of getuser(). We could potentially regain it if we used __copy_from_user instead of copy_from_user, but I'm not certain that our range check is equivalent to access_ok() on all platforms. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Jes Sorensen <jes@sgi.com>
2007-10-23Remove old lguest bus and drivers.Rusty Russell
This gets rid of the lguest bus, drivers and DMA mechanism, to make way for a generic virtio mechanism. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-23Boot with virtual == physical to get closer to native Linux.Rusty Russell
1) This allows us to get alot closer to booting bzImages. 2) It means we don't have to know page_offset. 3) The Guest needs to modify the boot pagetables to create the PAGE_OFFSET mapping before jumping to C code. 4) guest_pa() walks the page tables rather than using page_offset. 5) We don't use page_offset to figure out whether to emulate: it was always kinda quesationable, and won't work for instructions done before remapping (bzImage unpacking in particular). 6) We still want the kernel address for tlb flushing: have the initial hypercall give us that, too. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-23Allow guest to specify syscall vector to use.Rusty Russell
(Based on Ron Minnich's LGUEST_PLAN9_SYSCALL patch). This patch allows Guests to specify what system call vector they want, and we try to reserve it. We only allow one non-Linux system call vector, to try to avoid DoS on the Host. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-23Move register setup into i386_core.cJes Sorensen
Move setup_regs() to lguest_arch_setup_regs() in i386_core.c given that this is very architecture specific. Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-23Make hypercalls arch-independent.Jes Sorensen
Clean up the hypercall code to make the code in hypercalls.c architecture independent. First process the common hypercalls and then call lguest_arch_do_hcall() if the call hasn't been handled. Rename struct hcall_ring to hcall_args. This patch requires the previous patch which reorganize the layout of struct lguest_regs on i386 so they match the layout of struct hcall_args. Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-23Introduce "hcall" pointer to indicate pending hypercall.Rusty Russell
Currently we look at the "trapnum" to see if the Guest wants a hypercall. But once the hypercall is done we have to reset trapnum to a bogus value, otherwise if we exit to userspace and return, we'd run the same hypercall twice (that was a nasty bug to find!). This has two main effects: 1) When Jes's patch changes the hypercall args to be a generic "struct hcall_args" we simply change the type of "lg->hcall". It's set by arch code, so if it has to copy args or something it can do so, and point "hcall" into lg->arch somewhere. 2) Async hypercalls only get run when an actual hypercall is pending. This simplfies the code a little and is a more logical semantic. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-23Move i386 part of core.c to x86/core.c.Jes Sorensen
Separate i386 architecture specific from core.c and move it to x86/core.c and add x86/lguest.h header file to match. Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
