path: root/drivers/macintosh/Makefile
2008-04-29[POWERPC] windfarm: Add PowerMac 12,1 supportÉtienne Bersac
This implements a new driver named windfarm_pm121, which drives the fans on PowerMac 12,1 machines : iMac G5 iSight (rev C) 17" and 20". It's based on the windfarm_pm81 driver from Benjamin Herrenschmidt. This includes fixes from David Woodhouse correcting the names of some of the sensors. Signed-off-by: Étienne Bersac <bersace@gmail.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-12-04[POWERPC] Xserve cpu-meter driverBenjamin Herrenschmidt
This is a small driver for the Xserve G5 CPU-meter blue LEDs on the front-panel. It might work on the Xserve G4 as well though that was not tested. It's pretty basic and could use some improvements if somebody cares doing them. :) Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-28[POWERPC] Convert powermac ide blink to new led infrastructureJohannes Berg
This patch removes the old pmac ide led blink code and adds generic LED subsystem support for the LED. It maintains backward compatibility with the old BLK_DEV_IDE_PMAC_BLINK Kconfig option which now simply selects the new code and influences the default trigger. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-26Input: via-pmu - add input device supportJohannes Berg
Add an input device for the button and lid switch so that userspace gets notified about the user pressing them via the standard input layer. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-06-25[PATCH] Rewritten backlight infrastructure for portable Apple computersMichael Hanselmann
This patch contains a total rewrite of the backlight infrastructure for portable Apple computers. Backward compatibility is retained. A sysfs interface allows userland to control the brightness with more steps than before. Userland is allowed to upload a brightness curve for different monitors, similar to Mac OS X. [akpm@osdl.org: add needed exports] Signed-off-by: Michael Hanselmann <linux-kernel@hansmi.ch> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-07[PATCH] powerpc: Thermal control for dual core G5sBenjamin Herrenschmidt
This patch adds a windfarm module, windfarm_pm112, for the dual core G5s (both 2 and 4 core models), keeping the machine from getting into vacuum-cleaner mode ;) For proper credits, the patch was initially written by Paul Mackerras, and slightly reworked by me to add overtemp handling among others. The patch also removes the sysfs attributes from windfarm_pm81 and windfarm_pm91 and instead adds code to the windfarm core to automagically expose attributes for sensor & controls. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-08[PATCH] ppc64: Thermal control for SMU based machinesBenjamin Herrenschmidt
This adds a new thermal control framework for PowerMac, along with the implementation for PowerMac8,1, PowerMac8,2 (iMac G5 rev 1 and 2), and PowerMac9,1 (latest single CPU desktop). In the future, I expect to move the older G5 thermal control to the new framework as well. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-07-06[PATCH] openfirmware: add sysfs nodes for open firmware devicesJeff Mahoney
This adds sysfs nodes that the hotplug userspace can use to load the appropriate modules. In order for hotplug to work with macio devices, patches to module-init-tools and hotplug must be applied. Those patches are available at: ftp://ftp.suse.com/pub/people/jeffm/linux/macio-hotplug/ Changes: The previous versions were built on 2.6.12. 2.6.13-rcX introduced a device_attribute parameter to the show functions. Since that parameter was treated as the output buffer, memory corruption would result, causing Oopsen very quickly. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27[PATCH] ppc32: Remove CONFIG_PMAC_PBOOKBenjamin Herrenschmidt
This patch removes CONFIG_PMAC_PBOOK (PowerBook support). This is now split into CONFIG_PMAC_MEDIABAY for the actual hotswap bay that some powerbooks have, CONFIG_PM for power management related code, and just left out of any CONFIG_* option for some generally useful stuff that can be used on non-laptops as well. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27[PATCH] ppc32: remove obsolete macserial driverBenjamin Herrenschmidt
The macserial driver has been obsoleted by the new pmac_zilog driver for a while now and probably doesn't even work anymore on recent kernels. This patch removes it. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
