path: root/drivers/macintosh/mac_hid.c
2010-11-11Input: mac mouse emulation - add lockingDmitry Torokhov
We need to add appropriate locking when toggling mac mouse emulation on and off to ensure that input device and handler are in consistent state. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-30Input: Mac button emulation - allow compiling as a moduleDmitry Torokhov
Not all systems require Mac-style button emulation, however distributions enable it by default so it is readily available. Allow compiling it as a module so it can be loaded only on systems that actually require it. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-01-30Input: Mac button emulation - implement as an input filterDmitry Torokhov
Current implementation of Mac mouse button emulation plugs into legacy keyboard driver, converts certain keys into button events on a separate device, and suppresses the real events from reaching tty. This worked well enough until user space started using evdev which was completely unaware of this arrangement and kept sending original key presses to its users. Change the implementation to use newly added input filter framework so that original key presses are not transmitted to any handlers. As a bonus remove SYSCTL dependencies from the code and use Kconfig instead; also do not create the emulated mouse device until user activates emulation. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-11-18sysctl: Drop & in front of every proc_handler.Eric W. Biederman
For consistency drop & in front of every proc_handler. Explicity taking the address is unnecessary and it prevents optimizations like stubbing the proc_handlers to NULL. Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joe Perches <joe@perches.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-12sysctl drivers: Remove dead binary sysctl supportEric W. Biederman
Now that sys_sysctl is a wrapper around /proc/sys all of the binary sysctl support elsewhere in the tree is dead code. Cc: Jens Axboe <axboe@kernel.dk> Cc: Corey Minyard <minyard@acm.org> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Matt Mackall <mpm@selenic.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Neil Brown <neilb@suse.de> Cc: "James E.J. Bottomley" <James.Bottomley@suse.de> Acked-by: Clemens Ladisch <clemens@ladisch.de> for drivers/char/hpet.c Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2008-04-25mac-hid: fix build after lockdep annotationHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-24Input: mac_hid - add lockdep annotation to emumousebtnPeter Zijlstra
The mouse button emulation calls input device methods from an input device. This causes funny lock nesting which is harmless as each device has its own locks. Give the nesting device its own lock classes so that lockdep will not consider them the same. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-10-19get rid of input BIT* duplicate definesJiri Slaby
get rid of input BIT* duplicate defines use newly global defined macros for input layer. Also remove includes of input.h from non-input sources only for BIT macro definiton. Define the macro temporarily in local manner, all those local definitons will be removed further in this patchset (to not break bisecting). BIT macro will be globally defined (1<<x) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: <dtor@mail.ru> Acked-by: Jiri Kosina <jkosina@suse.cz> Cc: <lenb@kernel.org> Acked-by: Marcel Holtmann <marcel@holtmann.org> Cc: <perex@suse.cz> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: <vernux@us.ibm.com> Cc: <malattia@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-22m68k/mac: Make mac_hid_mouse_emulate_buttons() declaration visibleGeert Uytterhoeven
m68k/mac: Make mac_hid_mouse_emulate_buttons() declaration visible drivers/char/keyboard.c: In function 'kbd_keycode': drivers/char/keyboard.c:1142: error: implicit declaration of function 'mac_hid_mouse_emulate_buttons' The forward declaration of mac_hid_mouse_emulate_buttons() is not visible on m68k because it's hidden in the middle of a big #ifdef block. Move it to <linux/kbd_kern.h>, correct the type of the second parameter, and include <linux/kbd_kern.h> where needed. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02[POWERPC] drivers/macintosh/mac_hid.c: Make code staticAdrian Bunk
This patch makes some needlessly global code static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-03-08[POWERPC] Unexport mac_hid_mouse_emulate_buttonsAdrian Bunk
This patch removes the unused EXPORT_SYMBOL(mac_hid_mouse_emulate_buttons). Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-14[PATCH] sysctl: remove insert_at_head from register_sysctlEric W. Biederman
The semantic effect of insert_at_head is that it would allow new registered sysctl entries to override existing sysctl entries of the same name. Which is pain for caching and the proc interface never implemented. I have done an audit and discovered that none of the current users of register_sysctl care as (excpet for directories) they do not register duplicate sysctl entries. So this patch simply removes the support for overriding existing entries in the sys_sysctl interface since no one uses it or cares and it makes future enhancments harder. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Jens Axboe <axboe@kernel.dk> Cc: Corey Minyard <minyard@acm.org> Cc: Neil Brown <neilb@suse.de> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jan Kara <jack@ucw.cz> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: mac_hid: remove unnecessary insert_at_head flagEric W. Biederman
With unique sysctl binary numbers setting insert_at_head is pointless. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-13[POWERPC] move variables in drivers/macintosh to bssOlaf Hering
Move all the initialized variables to bss. Mark a version string as const. Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-11-24Input: handle errors from input_register_device in drivers/macintoshDmitry Torokhov
2005-10-28[PATCH] Input: convert drivers/macintosh to dynamic input_dev allocationDmitry Torokhov
Input: convert drivers/macntosh to dynamic input_dev allocation This is required for input_dev sysfs integration Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
