path: root/drivers/macintosh/mediabay.c
2012-02-03macintosh: fix string typo in mediabay.cMasanari Iida
Fix typo "unsuported" to "unsupported" in drivers/machintosh/mediabay.c Signed-off-by: Masanari Iida<standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-06-02powerpc/macio: Fix probing of macio devices by using the right of match tableBenjamin Herrenschmidt
Grant patches added an of mach table to struct device_driver. However, while he changed the macio device code to use that, he left the match table pointer in struct macio_driver and didn't update drivers to use the "new" one, thus breaking the probing. This completes the change by moving all drivers to setup the "new" one, removing all traces of the old one, and while at it (since it changes the exact same locations), I also remove two other duplicates from struct driver which are the name and owner fields. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-05-18of: Always use 'struct device.of_node' to get device node pointer.Grant Likely
The following structure elements duplicate the information in 'struct device.of_node' and so are being eliminated. This patch makes all readers of these elements use device.of_node instead. (struct of_device *)->node (struct dev_archdata *)->prom_node (sparc) (struct dev_archdata *)->of_node (powerpc & microblaze) Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2009-12-09powerpc/macio: Rework hotplug media bay supportBenjamin Herrenschmidt
The hotplug mediabay has tendrils deep into drivers/ide code which makes a libata port reather difficult. In addition it's ugly and could be done better. This reworks the interface between the mediabay and the rest of the world so that: - Any macio_driver can now have a mediabay_event callback which will be called when that driver sits on a mediabay and it's been either plugged or unplugged. The device type is passed as an argument. We can now move all the IDE cruft into the IDE driver itself - A check_media_bay() function can be used to take a peek at the type of device currently in the bay if any, a cleaner variant of the previous function with the same name. - A pair of lock/unlock functions are exposed to allow the IDE driver to block the hotplug callbacks during the initial setup and probing of the bay in order to avoid nasty race conditions. - The mediabay code no longer needs to spin on the status register of the IDE interface when it detects an IDE device, this is done just fine by the IDE code itself Overall, less code, simpler, and allows for another driver than our old drivers/ide based one. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-04-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: MAINTAINERS: update IDE entry palm_bk3710: palm_bk3710_udmatimings[] CodingStyle fixup palm_bk3710: those registers/bitfields don't exist mediabay: fix build for CONFIG_BLOCK=n ide: Stop disks on reboot for laptop which cuts power ide-cd: fix kernel crash on hppa regression palm_bk3710: UDMA performance fix
2009-04-22mediabay: fix build for CONFIG_BLOCK=nBartlomiej Zolnierkiewicz
On Tuesday 14 April 2009 20:31:21 Subrata Modak wrote: > Observed the following build error: > --- > CC drivers/macintosh/mediabay.o > In file included from drivers/macintosh/mediabay.c:21: > include/linux/ide.h:605: error: field ‘request_sense_rq’ has incomplete > type > make[2]: *** [drivers/macintosh/mediabay.o] Error 1 > make[1]: *** [drivers/macintosh] Error 2 > make: *** [drivers] Error 2 > --- mediabay shouldn't include <linux/ide.h> unconditionally so remove the superfluous include from mediabay.c (<asm/mediabay.h> will pull <linux/ide.h> in for CONFIG_BLK_DEV_IDE_PMAC=y). Reported-by: Subrata Modak <subrata@linux.vnet.ibm.com> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-22powerpc: Fix modular build of ide-pmac when mediabay is built inBartlomiej Zolnierkiewicz
Now that the powermac IDE host driver can be modular, we need to export check_media_bay_by_base() and media_bay_set_ide_infos() from drivers/macintosh/mediabay.c for it. This fixes the following build error: > CC [M] drivers/ide/pmac.o > drivers/ide/pmac.c: In function ‘pmac_ide_init_dev’: > drivers/ide/pmac.c:955: error: implicit declaration of function > ‘check_media_bay_by_base’ > drivers/ide/pmac.c: In function ‘pmac_ide_setup_device’: > drivers/ide/pmac.c:1090: error: implicit declaration of function > ‘media_bay_set_ide_infos’ > make[2]: *** [drivers/ide/pmac.o] Error 1 > make[1]: *** [drivers/ide] Error 2 > make: *** [drivers] Error 2 Reported-by: Subrata Modak <subrata@linux.vnet.ibm.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-05remove unnecessary <linux/hdreg.h> includesBartlomiej Zolnierkiewicz
Following files don't need <linux/hdreg.h> at all: - arch/mips/jazz/setup.c - arch/sh/boards/mach-systemh/irq.c - drivers/macintosh/mediabay.c - drivers/scsi/hptiop.c - drivers/usb/storage/freecom.c - arch/powerpc/include/asm/ide.h - init/main.c Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-06-30macintosh/media bay: Convert semaphore to mutexDaniel Walker
Signed-off-by: Daniel Walker <dwalker@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-06-16[POWERPC] Build fix for drivers/macintosh/mediabay.cAdrian Bunk
This fixes the following build error with CONFIG_BLK_DEV_IDE_PMAC=n: <-- snip --> ... CC drivers/macintosh/mediabay.o /home/bunk/linux/kernel-2.6/git/linux-2.6/drivers/macintosh/mediabay.c: In function 'check_media_bay': /home/bunk/linux/kernel-2.6/git/linux-2.6/drivers/macintosh/mediabay.c:428: error: 'struct media_bay_info' has no member named 'cd_index' make[3]: *** [drivers/macintosh/mediabay.o] Error 1 <-- snip --> Reported-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-06-15ide-pmac: bugfix for media-bay support reworkBartlomiej Zolnierkiewicz
Fix bug introduced by: commit 2dde7861afa23cd59db83515cb0b810b92b220aa Author: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Date: Fri Apr 18 00:46:23 2008 +0200 ide: rework PowerMac media-bay support (take 2) ... [ Yeah, I suck. ] bay->cd_index shouldn't be changed if IDE devices are not present or retry operations won't happen. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: rework PowerMac media-bay support (take 2)Bartlomiej Zolnierkiewicz
Rework PowerMac media-bay support in such way that instead of un/registering the IDE interface we un/register IDE devices: * Add ide_port_scan() helper for probing+registerering devices on a port. * Rename ide_port_unregister_devices() to __ide_port_unregister_devices(). * Add ide_port_unregister_devices() helper for unregistering devices on a port. * Add 'ide_hwif_t *cd_port' to 'struct media_bay_info', pass 'hwif' instead of hwif->index to media_bay_set_ide_infos() and use it to setup 'cd_port'. * Use ide_port_unregister_devices() instead of ide_unregister() and ide_port_scan() instead of ide_register_hw() in media_bay_step(). * Unexport ide_register_hw() and make it static. v2: * Fix build by adding <linux/ide.h> include to <asm-powerpc/mediabay.h>. (Reported by Michael/Kamalesh/Andrew). Cc: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Cc: Michael Ellerman <michael@ellerman.id.au> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-23PM: Introduce PM_EVENT_HIBERNATE callback stateRafael J. Wysocki
During the last step of hibernation in the "platform" mode (with the help of ACPI) we use the suspend code, including the devices' ->suspend() methods, to prepare the system for entering the ACPI S4 system sleep state. But at least for some devices the operations performed by the ->suspend() callback in that case must be different from its operations during regular suspend. For this reason, introduce the new PM event type PM_EVENT_HIBERNATE and pass it to the device drivers' ->suspend() methods during the last phase of hibernation, so that they can distinguish this case and handle it as appropriate. Modify the drivers that handle PM_EVENT_SUSPEND in a special way and need to handle PM_EVENT_HIBERNATE in the same way. These changes are necessary to fix a hibernation regression related to the i915 driver (ref. http://lkml.org/lkml/2008/2/22/488). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Tested-by: Jeff Chua <jeff.chua.linux@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Fix compile of swim3 as moduleTony Breeds
The current pmac32_defconfig fails to build with the following error: Building modules, stage 2. ERROR: "check_media_bay" [drivers/block/swim3.ko] undefined! WARNING: modpost: Found 23 section mismatch(es). To see full details build your kernel with: 'make CONFIG_DEBUG_SECTION_MISMATCH=y' make[2]: *** [__modpost] Error 1 This patch fixes that. Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06ppc: fix #ifdef-s in mediabay driver (take 2)Bartlomiej Zolnierkiewicz
* Replace incorrect CONFIG_BLK_DEV_IDE #ifdef in check_media_bay() by CONFIG_MAC_FLOPPY one. * Replace incorrect CONFIG_BLK_DEV_IDE #ifdef-s by CONFIG_BLK_DEV_IDE_PMAC ones. * check_media_bay() is used only by drivers/block/swim3.c so make this function available only if CONFIG_MAC_FLOPPY is defined. * check_media_bay_by_base() and media_bay_set_ide_infos() are used only by drivers/ide/ppc/pmac.c so so make these functions available only if CONFIG_MAC_FLOPPY is defined. v2: * Remove ifdefs from function prototypes. (Andrew Morton) Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-02ide: add 'init_default' and 'restore' arguments to ide_unregister()Bartlomiej Zolnierkiewicz
* Add 'init_default' (flag for calling init_hwif_default()) and 'restore' (flag for calling ide_hwif_restore()) arguments to ide_unregister(). * Update ide_unregister() users to set 'init_default' and 'restore' flags. * No need to set 'init_default' flag in ide_register_hw() if the setup done by init_hwif_default() is going to be overridden by ide_init_port_hw(). * No need to set 'init_default' and 'restore' flags in cleanup_module(). There should be no functionality changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-31Merge branch 'linux-2.6'Paul Mackerras
2008-01-26ide: drop 'initializing' argument from ide_register_hw()Bartlomiej Zolnierkiewicz
* Rename init_hwif_data() to ide_init_port_data() and export it. * For all users of ide_register_hw() with 'initializing' argument set hwif->present and hwif->hold are always zero so convert these host drivers to use ide_find_port()+ide_init_port_data()+ide_init_port_hw() instead (also no need for init_hwif_default() call since the setup done by it gets over-ridden by ide_init_port_hw() call). * Drop 'initializing' argument from ide_register_hw(). Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-12-19[POWERPC] Convert media-bay.c to use the kthread APIPaul Mackerras
We aren't supposed to use kernel_thread directly in drivers any more, and in fact using kthread_run is a bit simpler. Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-20ide: add ->fixup method to ide_hwif_tBartlomiej Zolnierkiewicz
* Add ->fixup method to ide_hwif_t. * Set hwif->fixup in ide_pci_setup_ports() to d->fixup. * Use hwif->fixup in probe_hwif(). * Use probe_hwif_init() instead of probe_hwif_init_with_fixup() in ide_setup_pci_device(). * Add 'fixup' argument to ide_register_hw() and use it to set hwif->fixup, update all ide_register_hw() users accordingly. * Convert ide-cs/delkin_cb host drivers to use ide_register_hw(). * Restore hwif->fixup in ide_hwif_restore(). * Remove ide_register_hw_with_fixup(), probe_hwif_init_with_fixup() and 'fixup' argument from probe_hwif(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-05-10ide: add "initializing" argument to ide_register_hw()Bartlomiej Zolnierkiewicz
Add "initializing" argument to ide_register_hw() and use it instead of ide.c wide variable of the same name. Update all users of ide_register_hw() accordingly. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2006-03-28[PATCH] powerpc: Kill _machine and hard-coded platform numbersBenjamin Herrenschmidt
This removes statically assigned platform numbers and reworks the powerpc platform probe code to use a better mechanism. With this, board support files can simply declare a new machine type with a macro, and implement a probe() function that uses the flattened device-tree to detect if they apply for a given machine. We now have a machine_is() macro that replaces the comparisons of _machine with the various PLATFORM_* constants. This commit also changes various drivers to use the new macro instead of looking at _machine. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] powerpc: Remove device_node addrs/n_addrBenjamin Herrenschmidt
The pre-parsed addrs/n_addrs fields in struct device_node are finally gone. Remove the dodgy heuristics that did that parsing at boot and remove the fields themselves since we now have a good replacement with the new OF parsing code. This patch also fixes a bunch of drivers to use the new code instead, so that at least pmac32, pseries, iseries and g5 defconfigs build. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-09-19[PATCH] powerpc: Remove sections use from ppc64 and driversJon Loeliger
Here is a new patch that removes all notion of the pmac, prep, chrp and openfirmware initialization sections, and then unifies the sections.h files without those __pmac, etc, sections identifiers cluttering things up. Signed-off-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-09-05[PATCH] swsusp: switch pm_message_t to structPavel Machek
This adds type-checking to pm_message_t, so that people can't confuse it with int or u32. It also allows us to fix "disk yoyo" during suspend (disk spinning down/up/down). [We've tried that before; since that cpufreq problems were fixed and I've tried make allyes config and fixed resulting damage.] Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Alexander Nyberg <alexn@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] swsusp: fix remaining u32 vs. pm_message_t confusionPavel Machek
Fix remaining bits of u32 vs. pm_message confusion. Should not break anything. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-06[PATCH] openfirmware: generate device table for userspaceJeff Mahoney
This converts the usage of struct of_match to struct of_device_id, similar to pci_device_id. This allows a device table to be generated, which can be parsed by depmod(8) to generate a map file for module loading. In order for hotplug to work with macio devices, patches to module-init-tools and hotplug must be applied. Those patches are available at: ftp://ftp.suse.com/pub/people/jeffm/linux/macio-hotplug/ Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] fix u32 vs. pm_message_t in drivers/macintoshPavel Machek
I thought I'm done with fixing u32 vs. pm_message_t ... unfortunately that turned out not to be the case as Russel King pointed out. Here are fixes for drivers/macintosh. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
