path: root/drivers/macintosh/therm_adt746x.c
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-08-06of/device: Replace struct of_device with struct platform_deviceGrant Likely
of_device is just an alias for platform_device, so remove it entirely. Also replace to_of_device() with to_platform_device() and update comment blocks. This patch was initially generated from the following semantic patch, and then edited by hand to pick up the bits that coccinelle didn't catch. @@ @@ -struct of_device +struct platform_device Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: David S. Miller <davem@davemloft.net>
2010-06-03i2c: Remove all i2c_set_clientdata(client, NULL) in driversWolfram Sang
I2C drivers can use the clientdata-pointer to point to private data. As I2C devices are not really unregistered, but merely detached from their driver, it used to be the drivers obligation to clear this pointer during remove() or a failed probe(). As a couple of drivers forgot to do this, it was agreed that it was cleaner if the i2c-core does this clearance when appropriate, as there is no guarantee for the lifetime of the clientdata-pointer after remove() anyhow. This feature was added to the core with commit e4a7b9b04de15f6b63da5ccdd373ffa3057a3681 to fix the faulty drivers. As there is no need anymore to clear the clientdata-pointer, remove all current occurrences in the drivers to simplify the code and prevent confusion. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Richard Purdie <rpurdie@linux.intel.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-04-07powerpc/pmac: Fix dangling pointersWolfram Sang
Fix I2C-drivers which missed setting clientdata to NULL before freeing the structure it points to. Also fix drivers which do this _after_ the structure was freed already. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Colin Leroy <colin@colino.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-02-09powerpc: Remove trailing space in messagesFrans Pop
Signed-off-by: Frans Pop <elendil@planet.nl> Cc: linuxppc-dev@ozlabs.org Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-02-03macintosh/therm_adt746x: Fix sysfs attributes lifetimeJean Delvare
Looking at drivers/macintosh/therm_adt746x.c, the sysfs files are created in thermostat_init() and removed in thermostat_exit(), which are the driver's init and exit functions. These files are backed-up by a per-device structure, so it looks like the wrong thing to do: the sysfs files have a lifetime longer than the data structure that is backing it up. I think that sysfs files creation should be moved to the end of probe_thermostat() and sysfs files removal should be moved to the beginning of remove_thermostat(). Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Christian Kujau <lists@nerdbynature.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Colin Leroy <colin@colino.net> Cc: stable@kernel.org Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-12-09powerpc/therm_adt746x: Record pwm invert bit at module load time]Darrick J. Wong
In commit 0512a9a8e277a9de2820211eef964473b714ae65, we unilaterally zero the "pwm invert" bit in the fan behavior configuration register. On my PowerBook G4, this results in the fans going to full speed at low temperature and shutting off at high temperature because the pwm invert bit is supposed to be set. Therefore, record the pwm invert bit at driver load time, and write the bit into the fan behavior control register. This restores correct behavior on my PBG4 and should work around the bit being set to the wrong value after suspend/resume (which is what the original patch was trying to fix). It also fixes a minor omission where the pwm invert bit correction is NOT performed when switching into automatic mode. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> CC: <stable@kernel.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-10-30powerpc/therm_adt746x: Don't access non-existing registerJean Delvare
The ADT746x don't have any register at sub-address 0, so better use an existing register for the initial test read. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Colin Leroy <colin@colino.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-10-04macintosh: Don't assume i2c device probing always succeedsJean Delvare
If i2c device probing fails, then there is no driver to dereference after calling i2c_new_device(). Stop assuming that probing will always succeed, to avoid NULL pointer dereferences. We have an easier access to the driver anyway. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Tim Shepard <shep@alum.mit.edu> Cc: Colin Leroy <colin@colino.net>
2009-06-16Merge branch 'i2c-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: therm_windtunnel: Convert to a new-style i2c driver therm_adt746x: Convert to a new-style i2c driver windfarm: Convert to new-style i2c drivers therm_pm72: Convert to a new-style i2c driver i2c-viapro: Add new PCI device ID for VX855 i2c/chips: Move max6875 to drivers/misc/eeprom i2c: Do not give adapters a default parent i2c: Do not probe for TV chips on Voodoo3 adapters i2c: Retry automatically on arbitration loss i2c: Remove void casts
2009-06-15therm_adt746x: Convert to a new-style i2c driverJean Delvare
The legacy i2c binding model is going away soon, so convert the ppc therm_adt746x driver to the new model or it will break. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Andreas Schwab <schwab@linux-m68k.org> Tested-by: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-02therm_adt746x: Always clear hardware bit which inverts fan speed range.Michel Dänzer
This bit would get enabled sometimes (probably after suspend/resume), so the fan would run at full speed below the temperature thresholds, but slow down and eventually stop if temperatures rose above the thresholds... not exactly what you want. Signed-off-by: Michel Dänzer <michel@daenzer.net> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-02-11therm_adt746x: Fix signed/unsigned confusionroel kluin
As suggested, this is used for signed rather than unsigned Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-01-06drivers/macintosh: Add missing of_node_put in therm_adt746x.cNicolas Palix
of_node_put is needed before discarding a value received from of_find_node_by_name, eg in error handling code or when the device node is no longer used. The semantic match that catches the bug is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @r exists@ local idexpression struct device_node *n; position p1, p2; struct device_node *n1; statement S; identifier f; expression E; expression *ptr != NULL; @@ n@p1 = of_find_node_by_name(...) ... if (!n) S ... when != of_node_put(n) when != n1 = f(n,...) when != E = n when any when strict ( return \(0\|<+...n...+>\|ptr\); | return@p2 ...; | of_node_put(n); | n1 = f(n,...) | E = n ) @script:python@ p1 << r.p1; p2 << r.p2; @@ print "* file: %s of_find_node_by_name %s return %s" % (p1[0].file,p1[0].line,p2[0].line) // </smpl> Signed-off-by: Nicolas Palix <npalix@diku.dk> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-30macintosh: Use linux/of_{device,platform}.h instead of asmStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-06-16[POWERPC] Add missing of_node_put in drivers/macintosh/therm_adt746x.cJulia Lawall
of_node_put is needed before discarding a value received from of_find_node_by_name, eg in error handling code. The semantic patch that makes the change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ struct device_node *n; struct device_node *n1; statement S; identifier f; expression E; constant C; @@ n = of_find_node_by_name(...) ... if (!n) S ... when != of_node_put(n) when != n1 = f(n,...) when != E = n when any when strict ( + of_node_put(n); return -C; | of_node_put(n); | n1 = f(n,...) | E = n | return ...; ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-01-17[POWERPC] therm_adt746x: Eliminate some build warningsStephen Rothwell
We don't care if the device_create_file calls fail, the driver will work just as well without them, so just issue a runtime warning. drivers/macintosh/therm_adt746x.c: In function 'thermostat_init': drivers/macintosh/therm_adt746x.c:615: warning: ignoring return value of 'device_create_file', declared with attribute warn_unused_result drivers/macintosh/therm_adt746x.c:616: warning: ignoring return value of 'device_create_file', declared with attribute warn_unused_result drivers/macintosh/therm_adt746x.c:617: warning: ignoring return value of 'device_create_file', declared with attribute warn_unused_result drivers/macintosh/therm_adt746x.c:618: warning: ignoring return value of 'device_create_file', declared with attribute warn_unused_result drivers/macintosh/therm_adt746x.c:619: warning: ignoring return value of 'device_create_file', declared with attribute warn_unused_result drivers/macintosh/therm_adt746x.c:620: warning: ignoring return value of 'device_create_file', declared with attribute warn_unused_result drivers/macintosh/therm_adt746x.c:621: warning: ignoring return value of 'device_create_file', declared with attribute warn_unused_result drivers/macintosh/therm_adt746x.c:622: warning: ignoring return value of 'device_create_file', declared with attribute warn_unused_result drivers/macintosh/therm_adt746x.c:623: warning: ignoring return value of 'device_create_file', declared with attribute warn_unused_result drivers/macintosh/therm_adt746x.c:625: warning: ignoring return value of 'device_create_file', declared with attribute warn_unused_result Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-08-17[POWERPC] drivers/macintosh/therm_adt746x.c: kmalloc + memset conversion to ↵Mariusz Kozlowski
kzalloc Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-07-17Freezer: make kernel threads nonfreezable by defaultRafael J. Wysocki
Currently, the freezer treats all tasks as freezable, except for the kernel threads that explicitly set the PF_NOFREEZE flag for themselves. This approach is problematic, since it requires every kernel thread to either set PF_NOFREEZE explicitly, or call try_to_freeze(), even if it doesn't care for the freezing of tasks at all. It seems better to only require the kernel threads that want to or need to be frozen to use some freezer-related code and to remove any freezer-related code from the other (nonfreezable) kernel threads, which is done in this patch. The patch causes all kernel threads to be nonfreezable by default (ie. to have PF_NOFREEZE set by default) and introduces the set_freezable() function that should be called by the freezable kernel threads in order to unset PF_NOFREEZE. It also makes all of the currently freezable kernel threads call set_freezable(), so it shouldn't cause any (intentional) change of behaviour to appear. Additionally, it updates documentation to describe the freezing of tasks more accurately. [akpm@linux-foundation.org: build fixes] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Nigel Cunningham <nigel@nigel.suspend2.net> Cc: Pavel Machek <pavel@ucw.cz> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (77 commits) [POWERPC] Abolish powerpc_flash_init() [POWERPC] Early serial debug support for PPC44x [POWERPC] Support for the Ebony 440GP reference board in arch/powerpc [POWERPC] Add device tree for Ebony [POWERPC] Add powerpc/platforms/44x, disable platforms/4xx for now [POWERPC] MPIC U3/U4 MSI backend [POWERPC] MPIC MSI allocator [POWERPC] Enable MSI mappings for MPIC [POWERPC] Tell Phyp we support MSI [POWERPC] RTAS MSI implementation [POWERPC] PowerPC MSI infrastructure [POWERPC] Rip out the existing powerpc msi stubs [POWERPC] Remove use of 4level-fixup.h for ppc32 [POWERPC] Add powerpc PCI-E reset API implementation [POWERPC] Holly bootwrapper [POWERPC] Holly DTS [POWERPC] Holly defconfig [POWERPC] Add support for 750CL Holly board [POWERPC] Generalize tsi108 PCI setup [POWERPC] Generalize tsi108 PHY types ... Fixed conflict in include/asm-powerpc/kdebug.h manually Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07[POWERPC] Rename device_is_compatible to of_device_is_compatibleStephen Rothwell
for consistency with other Open Firmware interfaces (and Sparc). This is just a straight replacement. This leaves the compatibility define in place. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-27[POWERPC] Rename get_property to of_get_property: partial driversStephen Rothwell
This does drivers/machintosh and the hvc code. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-26Revert "[POWERPC] Rename get_property to of_get_property: drivers"Paul Mackerras
This reverts commit d05c7a80cf39ae7d0f8d0c3e47c93d51fcd393d3, which included changes which should go via other subsystem maintainers.
2007-04-13[POWERPC] Rename get_property to of_get_property: driversStephen Rothwell
2007-02-13[POWERPC] move variables in drivers/macintosh to bssOlaf Hering
Move all the initialized variables to bss. Mark a version string as const. Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-12-07[PATCH] Add include/linux/freezer.h and move definitions from sched.hNigel Cunningham
Move process freezing functions from include/linux/sched.h to freezer.h, so that modifications to the freezer or the kernel configuration don't require recompiling just about everything. [akpm@osdl.org: fix ueagle driver] Signed-off-by: Nigel Cunningham <nigel@suspend2.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-04[POWERPC] Souped-up of_platform_device supportBenjamin Herrenschmidt
This patch first splits of_device.c and of_platform.c, the later containing the bits relative to of_platform_device's. On the "breaks" side of things, drivers uisng of_platform_device(s) need to include asm/of_platform.h now and of_(un)register_driver is now of_(un)register_platform_driver. In addition to a few utility functions to locate of_platform_device(s), the main new addition is of_platform_bus_probe() which allows the platform code to trigger an automatic creation of of_platform_devices for a whole tree of devices. The function acts based on the type of the various "parent" devices encountered from a provided root, using either a default known list of bus types that can be "probed" or a passed-in list. It will only register devices on busses matching that list, which mean that typically, it will not register PCI devices, as expected (since they will be picked up by the PCI layer). This will be used by Cell platforms using 4xx-type IOs in the Axon bridge and can be used by any embedded-type device as well. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-07-31[POWERPC] powermac: Constify & voidify get_property()Jeremy Kerr
Now that get_property() returns a void *, there's no need to cast its return value. Also, treat the return value as const, so we can constify get_property later. powermac platform & macintosh driver changes. Built for pmac32_defconfig, g5_defconfig Signed-off-by: Jeremy Kerr <jk@ozlabs.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-04-21[PATCH] powerpc: fix oops in alsa powermac driverBenjamin Herrenschmidt
This fixes an oops in 2.6.16.X when loading the snd_powermac module. The name of the requested module changed during the 2.6.16 development cycle from i2c-keylargo to i2c-powermac. Signed-off-by: Guido Guenther <agx@sigxcpu.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-06Merge ../torvalds-2.6/Greg Kroah-Hartman
2006-01-06[PATCH] therm_adt746x: Quiet fan speed change messagesBen Collins
Only output the messages about fan speed changes with a verbose=1 module param. Signed-off-by: Fabio M. Di Nitto <fabbione@ubuntu.com> Signed-off-by: Ben Collins <bcollins@ubuntu.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-05[PATCH] I2C: Remove .owner setting from i2c_driver as it's no longer neededGreg Kroah-Hartman
Now that i2c_add_driver() doesn't need the module owner to be set by hand, we can delete it from the drivers. This patch catches all of the drivers that I found in the current tree (if a driver sets the .owner by hand, it's not a problem, just not needed.) Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Jean Delvare <khali@linux-fr.org>
2006-01-05[PATCH] i2c: Drop i2c_driver.{owner,name}, 4 of 11Laurent Riffard
We should use the i2c_driver.driver's .name and .owner fields instead of the i2c_driver's ones. This patch updates the drivers for macintosh. Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] i2c: Drop i2c_driver.flags, 2 of 3Jean Delvare
Just about every i2c chip driver sets the I2C_DF_NOTIFY flag, so we can simply make it the default and drop the flag. If any driver really doesn't want to be notified when i2c adapters are added, that driver can simply omit to set .attach_adapter. This approach is also more robust as it prevents accidental NULL pointer dereferences. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-22[PATCH] ppc64: SMU driver update & i2c supportBenjamin Herrenschmidt
The SMU is the "system controller" chip used by Apple recent G5 machines including the iMac G5. It drives things like fans, i2c busses, real time clock, etc... The current kernel contains a very crude driver that doesn't do much more than reading the real time clock synchronously. This is a completely rewritten driver that provides interrupt based command queuing, a userland interface, and an i2c/smbus driver for accessing the devices hanging off the SMU i2c busses like temperature sensors. This driver is a basic block for upcoming work on thermal control for those machines, among others. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jean Delvare <khali@linux-fr.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] Cleanup patch for process freezingChristoph Lameter
1. Establish a simple API for process freezing defined in linux/include/sched.h: frozen(process) Check for frozen process freezing(process) Check if a process is being frozen freeze(process) Tell a process to freeze (go to refrigerator) thaw_process(process) Restart process frozen_process(process) Process is frozen now 2. Remove all references to PF_FREEZE and PF_FROZEN from all kernel sources except sched.h 3. Fix numerous locations where try_to_freeze is manually done by a driver 4. Remove the argument that is no longer necessary from two function calls. 5. Some whitespace cleanup 6. Clear potential race in refrigerator (provides an open window of PF_FREEZE cleared before setting PF_FROZEN, recalc_sigpending does not check PF_FROZEN). This patch does not address the problem of freeze_processes() violating the rule that a task may only modify its own flags by setting PF_FREEZE. This is not clean in an SMP environment. freeze(process) is therefore not SMP safe! Signed-off-by: Christoph Lameter <christoph@lameter.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] Driver Core: drivers/i2c/chips/w83781d.c - ↵Yani Ioannou
drivers/s390/block/dcssblk.c: update device attribute callbacks Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-05-25[PATCH] therm_adt746x: show correct sensor locationsColin Leroy
This patch shows the correct locations of the heat sensors present in iBook and PowerBooks G4, instead of displaying them as being on CPU and GPU (which is not always the case). Signed-off-by: Colin Leroy <colin@colino.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-25[PATCH] Make sure therm_adt746x only handles known hardwareColin Leroy
This patch limits therm_adt746x to currently existing fan controllers in Apple laptops. It may avoid problems with future hardware. Signed-off-by: Colin Leroy <colin@colino.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
