path: root/drivers/macintosh
2018-08-24macintosh: therm_windtunnel: drop using attach_adapterWolfram Sang
As we now have deferred probing, we can use a custom mechanism and finally get rid of the legacy interface from the i2c core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Michael Ellerman <mpe@ellerman.id.au>
2018-07-31macintosh/via-pmu: Disambiguate interrupt statisticsFinn Thain
Some of the event counters are overloaded which makes it very difficult to interpret their values. Counter 0 is supposed to report CB1 interrupts but it can also count PMU_INT_WAITING_CHARGER events. Counter 1 is supposed to report GPIO interrupts but it can also count other events (depending upon the value of the PMU_INT_ADB bit). Disambiguate these statistics with dedicated counters for GPIO and CB1 interrupts. Comments in the MkLinux source code say that the type 0 and type 1 interrupts are model-specific. Label them as "unknown". This change to the contents of /proc/pmu/interrupts is by necessity visible in userland. However, packages which interact with the PMU (that is, pbbuttonsd, pmac-utils and pmud) don't open this file. AFAIK, user software has no need to poll these counters. Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2018-07-31macintosh/via-pmu: Clean up interrupt statisticsFinn Thain
Replace an open-coded ffs() with the function call. Simplify an if-else cascade using a switch statement. Correct a typo and an indentation issue. Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2018-07-31macintosh/via-pmu: Replace via-pmu68k driver with via-pmu driverFinn Thain
Now that the PowerMac via-pmu driver supports m68k PowerBooks, switch over to that driver and remove the via-pmu68k driver. Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2018-07-31macintosh/via-pmu68k: Don't load driver on unsupported hardwareFinn Thain
Don't load the via-pmu68k driver on early PowerBooks. The M50753 PMU device found in those models was never supported by this driver. Attempting to load the driver usually causes a boot hang. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Michael Schmitz <schmitzmic@gmail.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2018-07-31macintosh/via-pmu: Explicitly specify CONFIG_PPC_PMAC dependenciesFinn Thain
At present, CONFIG_ADB_PMU depends on CONFIG_PPC_PMAC. When this gets relaxed to CONFIG_PPC_PMAC || CONFIG_MAC, those Kconfig symbols with implicit deps on PPC_PMAC will need explicit deps. Add them now. No functional change. Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2018-07-31macintosh/via-pmu: Add support for m68k PowerBooksFinn Thain
Put #ifdefs around the Open Firmware, xmon, interrupt dispatch, battery and suspend code. Add the necessary interrupt handling to support m68k PowerBooks. The pmu_kind value is available to userspace using the PMU_IOC_GET_MODEL ioctl. It is not clear yet what hardware classes are be needed to describe m68k PowerBook models, so pmu_kind is given the provisional value PMU_UNKNOWN. To find out about the hardware, user programs can use /proc/bootinfo or /proc/hardware, or send the PMU_GET_VERSION command using /dev/adb. Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2018-07-31macintosh/via-pmu: Replace via pointer with via1 and via2 pointersFinn Thain
On most PowerPC Macs, the PMU driver uses the shift register and IO port B from a single VIA chip. On 68k and early PowerPC PowerBooks, the driver uses the shift register from one VIA chip together with IO port B from another. Replace via with via1 and via2 to accommodate this. For the CONFIG_PPC_PMAC case, set via1 = via2 so there is no change. Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2018-07-31macintosh/via-pmu: Enhance state machine with new 'uninitialized' stateFinn Thain
On 68k Macs, the via/vias pointer can't be used to determine whether the PMU driver has been initialized. For portability, add a new state to indicate that via_find_pmu() succeeded. After via_find_pmu() executes, testing vias == NULL is equivalent to testing via == NULL. Replace these tests with pmu_state == uninitialized which is simpler and more consistent. No functional change. Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2018-07-31macintosh/via-pmu: Don't clear shift register interrupt flag twiceFinn Thain
The shift register interrupt flag gets cleared in via_pmu_interrupt() and once again in pmu_sr_intr(). Fix this theoretical race condition. Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2018-07-31macintosh/via-pmu: Add missing mmio accessorsFinn Thain
Add missing in_8() accessors to init_pmu() and pmu_sr_intr(). This fixes several sparse warnings: drivers/macintosh/via-pmu.c:536:29: warning: dereference of noderef expression drivers/macintosh/via-pmu.c:537:33: warning: dereference of noderef expression drivers/macintosh/via-pmu.c:1455:17: warning: dereference of noderef expression drivers/macintosh/via-pmu.c:1456:69: warning: dereference of noderef expression Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2018-07-31macintosh/via-pmu: Fix section mismatch warningFinn Thain
The pmu_init() function has the __init qualifier, but the ops struct that holds a pointer to it does not. This causes a build warning. The driver works fine because the pointer is only dereferenced early. The function is so small that there's negligible benefit from using the __init qualifier. Remove it to fix the warning, consistent with the other ADB drivers. Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2018-06-07Merge tag 'powerpc-4.18-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux Pull powerpc updates from Michael Ellerman: "Notable changes: - Support for split PMD page table lock on 64-bit Book3S (Power8/9). - Add support for HAVE_RELIABLE_STACKTRACE, so we properly support live patching again. - Add support for patching barrier_nospec in copy_from_user() and syscall entry. - A couple of fixes for our data breakpoints on Book3S. - A series from Nick optimising TLB/mm handling with the Radix MMU. - Numerous small cleanups to squash sparse/gcc warnings from Mathieu Malaterre. - Several series optimising various parts of the 32-bit code from Christophe Leroy. - Removal of support for two old machines, "SBC834xE" and "C2K" ("GEFanuc,C2K"), which is why the diffstat has so many deletions. And many other small improvements & fixes. There's a few out-of-area changes. Some minor ftrace changes OK'ed by Steve, and a fix to our powernv cpuidle driver. Then there's a series touching mm, x86 and fs/proc/task_mmu.c, which cleans up some details around pkey support. It was ack'ed/reviewed by Ingo & Dave and has been in next for several weeks. Thanks to: Akshay Adiga, Alastair D'Silva, Alexey Kardashevskiy, Al Viro, Andrew Donnellan, Aneesh Kumar K.V, Anju T Sudhakar, Arnd Bergmann, Balbir Singh, Cédric Le Goater, Christophe Leroy, Christophe Lombard, Colin Ian King, Dave Hansen, Fabio Estevam, Finn Thain, Frederic Barrat, Gautham R. Shenoy, Haren Myneni, Hari Bathini, Ingo Molnar, Jonathan Neuschäfer, Josh Poimboeuf, Kamalesh Babulal, Madhavan Srinivasan, Mahesh Salgaonkar, Mark Greer, Mathieu Malaterre, Matthew Wilcox, Michael Neuling, Michal Suchanek, Naveen N. Rao, Nicholas Piggin, Nicolai Stange, Olof Johansson, Paul Gortmaker, Paul Mackerras, Peter Rosin, Pridhiviraj Paidipeddi, Ram Pai, Rashmica Gupta, Ravi Bangoria, Russell Currey, Sam Bobroff, Samuel Mendoza-Jonas, Segher Boessenkool, Shilpasri G Bhat, Simon Guo, Souptick Joarder, Stewart Smith, Thiago Jung Bauermann, Torsten Duwe, Vaibhav Jain, Wei Yongjun, Wolfram Sang, Yisheng Xie, YueHaibing" * tag 'powerpc-4.18-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (251 commits) powerpc/64s/radix: Fix missing ptesync in flush_cache_vmap cpuidle: powernv: Fix promotion from snooze if next state disabled powerpc: fix build failure by disabling attribute-alias warning in pci_32 ocxl: Fix missing unlock on error in afu_ioctl_enable_p9_wait() powerpc-opal: fix spelling mistake "Uniterrupted" -> "Uninterrupted" powerpc: fix spelling mistake: "Usupported" -> "Unsupported" powerpc/pkeys: Detach execute_only key on !PROT_EXEC powerpc/powernv: copy/paste - Mask SO bit in CR powerpc: Remove core support for Marvell mv64x60 hostbridges powerpc/boot: Remove core support for Marvell mv64x60 hostbridges powerpc/boot: Remove support for Marvell mv64x60 i2c controller powerpc/boot: Remove support for Marvell MPSC serial controller powerpc/embedded6xx: Remove C2K board support powerpc/lib: optimise PPC32 memcmp powerpc/lib: optimise 32 bits __clear_user() powerpc/time: inline arch_vtime_task_switch() powerpc/Makefile: set -mcpu=860 flag for the 8xx powerpc: Implement csum_ipv6_magic in assembly powerpc/32: Optimise __csum_partial() powerpc/lib: Adjust .balign inside string functions for PPC32 ...
2018-05-25powerpc/sparse: Fix plain integer as NULL pointer warningMathieu Malaterre
Trivial fix to remove the following sparse warnings: arch/powerpc/kernel/module_32.c:112:74: warning: Using plain integer as NULL pointer arch/powerpc/kernel/module_32.c:117:74: warning: Using plain integer as NULL pointer drivers/macintosh/via-pmu.c:1155:28: warning: Using plain integer as NULL pointer drivers/macintosh/via-pmu.c:1230:20: warning: Using plain integer as NULL pointer drivers/macintosh/via-pmu.c:1385:36: warning: Using plain integer as NULL pointer drivers/macintosh/via-pmu.c:1752:23: warning: Using plain integer as NULL pointer drivers/macintosh/via-pmu.c:2084:19: warning: Using plain integer as NULL pointer drivers/macintosh/via-pmu.c:2110:32: warning: Using plain integer as NULL pointer drivers/macintosh/via-pmu.c:2167:19: warning: Using plain integer as NULL pointer drivers/macintosh/via-pmu.c:2183:19: warning: Using plain integer as NULL pointer drivers/macintosh/via-pmu.c:277:20: warning: Using plain integer as NULL pointer arch/powerpc/platforms/powermac/setup.c:155:67: warning: Using plain integer as NULL pointer arch/powerpc/platforms/powermac/setup.c:247:27: warning: Using plain integer as NULL pointer arch/powerpc/platforms/powermac/setup.c:249:27: warning: Using plain integer as NULL pointer arch/powerpc/platforms/powermac/setup.c:252:37: warning: Using plain integer as NULL pointer arch/powerpc/mm/tlb_hash32.c:127:21: warning: Using plain integer as NULL pointer arch/powerpc/mm/tlb_hash32.c:148:21: warning: Using plain integer as NULL pointer arch/powerpc/mm/tlb_hash32.c:44:21: warning: Using plain integer as NULL pointer arch/powerpc/mm/tlb_hash32.c:57:21: warning: Using plain integer as NULL pointer arch/powerpc/mm/tlb_hash32.c:87:21: warning: Using plain integer as NULL pointer arch/powerpc/kernel/btext.c:160:31: warning: Using plain integer as NULL pointer arch/powerpc/kernel/btext.c:167:22: warning: Using plain integer as NULL pointer arch/powerpc/kernel/btext.c:274:21: warning: Using plain integer as NULL pointer arch/powerpc/kernel/btext.c:285:31: warning: Using plain integer as NULL pointer arch/powerpc/include/asm/hugetlb.h:204:16: warning: Using plain integer as NULL pointer arch/powerpc/mm/ppc_mmu_32.c:170:21: warning: Using plain integer as NULL pointer arch/powerpc/platforms/powermac/pci.c:1227:23: warning: Using plain integer as NULL pointer arch/powerpc/platforms/powermac/pci.c:65:24: warning: Using plain integer as NULL pointer Also use `--fix` command line option from `script/checkpatch --strict` to remove the following: CHECK: Comparison to NULL could be written "!dispDeviceBase" #72: FILE: arch/powerpc/kernel/btext.c:160: + if (dispDeviceBase == NULL) CHECK: Comparison to NULL could be written "!vbase" #80: FILE: arch/powerpc/kernel/btext.c:167: + if (vbase == NULL) CHECK: Comparison to NULL could be written "!base" #89: FILE: arch/powerpc/kernel/btext.c:274: + if (base == NULL) CHECK: Comparison to NULL could be written "!dispDeviceBase" #98: FILE: arch/powerpc/kernel/btext.c:285: + if (dispDeviceBase == NULL) CHECK: Comparison to NULL could be written "strstr" #117: FILE: arch/powerpc/kernel/module_32.c:117: + if (strstr(secstrings + sechdrs[i].sh_name, ".debug") != NULL) CHECK: Comparison to NULL could be written "!Hash" #130: FILE: arch/powerpc/mm/ppc_mmu_32.c:170: + if (Hash == NULL) CHECK: Comparison to NULL could be written "Hash" #143: FILE: arch/powerpc/mm/tlb_hash32.c:44: + if (Hash != NULL) { CHECK: Comparison to NULL could be written "!Hash" #152: FILE: arch/powerpc/mm/tlb_hash32.c:57: + if (Hash == NULL) { CHECK: Comparison to NULL could be written "!Hash" #161: FILE: arch/powerpc/mm/tlb_hash32.c:87: + if (Hash == NULL) { CHECK: Comparison to NULL could be written "!Hash" #170: FILE: arch/powerpc/mm/tlb_hash32.c:127: + if (Hash == NULL) { CHECK: Comparison to NULL could be written "!Hash" #179: FILE: arch/powerpc/mm/tlb_hash32.c:148: + if (Hash == NULL) { ERROR: space required after that ';' (ctx:VxV) #192: FILE: arch/powerpc/platforms/powermac/pci.c:65: + for (; node != NULL;node = node->sibling) { CHECK: Comparison to NULL could be written "node" #192: FILE: arch/powerpc/platforms/powermac/pci.c:65: + for (; node != NULL;node = node->sibling) { CHECK: Comparison to NULL could be written "!region" #201: FILE: arch/powerpc/platforms/powermac/pci.c:1227: + if (region == NULL) CHECK: Comparison to NULL could be written "of_get_property" #214: FILE: arch/powerpc/platforms/powermac/setup.c:155: + if (of_get_property(np, "cache-unified", NULL) != NULL && dc) { CHECK: Comparison to NULL could be written "!np" #223: FILE: arch/powerpc/platforms/powermac/setup.c:247: + if (np == NULL) CHECK: Comparison to NULL could be written "np" #226: FILE: arch/powerpc/platforms/powermac/setup.c:249: + if (np != NULL) { CHECK: Comparison to NULL could be written "l2cr" #230: FILE: arch/powerpc/platforms/powermac/setup.c:252: + if (l2cr != NULL) { CHECK: Comparison to NULL could be written "via" #243: FILE: drivers/macintosh/via-pmu.c:277: + if (via != NULL) CHECK: Comparison to NULL could be written "current_req" #252: FILE: drivers/macintosh/via-pmu.c:1155: + if (current_req != NULL) { CHECK: Comparison to NULL could be written "!req" #261: FILE: drivers/macintosh/via-pmu.c:1230: + if (req == NULL || pmu_state != idle CHECK: Comparison to NULL could be written "!req" #270: FILE: drivers/macintosh/via-pmu.c:1385: + if (req == NULL) { CHECK: Comparison to NULL could be written "!pp" #288: FILE: drivers/macintosh/via-pmu.c:2084: + if (pp == NULL) CHECK: Comparison to NULL could be written "!pp" #297: FILE: drivers/macintosh/via-pmu.c:2110: + if (count < 1 || pp == NULL) CHECK: Comparison to NULL could be written "!pp" #306: FILE: drivers/macintosh/via-pmu.c:2167: + if (pp == NULL) CHECK: Comparison to NULL could be written "pp" #315: FILE: drivers/macintosh/via-pmu.c:2183: + if (pp != NULL) { Link: https://github.com/linuxppc/linux/issues/37 Signed-off-by: Mathieu Malaterre <malat@debian.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2018-05-16proc: introduce proc_create_single{,_data}Christoph Hellwig
Variants of proc_create{,_data} that directly take a seq_file show callback and drastically reduces the boilerplate code in the callers. All trivial callers converted over. Signed-off-by: Christoph Hellwig <hch@lst.de>
2018-05-14macintosh/windfarm: fix spelling mistake: "ttarged" -> "ttarget"Colin Ian King
Trivial fix to spelling mistake in debug messages of a structure field name Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2018-04-07Merge tag 'powerpc-4.17-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux Pull powerpc updates from Michael Ellerman: "Notable changes: - Support for 4PB user address space on 64-bit, opt-in via mmap(). - Removal of POWER4 support, which was accidentally broken in 2016 and no one noticed, and blocked use of some modern instructions. - Workarounds so that the hypervisor can enable Transactional Memory on Power9. - A series to disable the DAWR (Data Address Watchpoint Register) on Power9. - More information displayed in the meltdown/spectre_v1/v2 sysfs files. - A vpermxor (Power8 Altivec) implementation for the raid6 Q Syndrome. - A big series to make the allocation of our pacas (per cpu area), kernel page tables, and per-cpu stacks NUMA aware when using the Radix MMU on Power9. And as usual many fixes, reworks and cleanups. Thanks to: Aaro Koskinen, Alexandre Belloni, Alexey Kardashevskiy, Alistair Popple, Andy Shevchenko, Aneesh Kumar K.V, Anshuman Khandual, Balbir Singh, Benjamin Herrenschmidt, Christophe Leroy, Christophe Lombard, Cyril Bur, Daniel Axtens, Dave Young, Finn Thain, Frederic Barrat, Gustavo Romero, Horia Geantă, Jonathan Neuschäfer, Kees Cook, Larry Finger, Laurent Dufour, Laurent Vivier, Logan Gunthorpe, Madhavan Srinivasan, Mark Greer, Mark Hairgrove, Markus Elfring, Mathieu Malaterre, Matt Brown, Matt Evans, Mauricio Faria de Oliveira, Michael Neuling, Naveen N. Rao, Nicholas Piggin, Paul Mackerras, Philippe Bergheaud, Ram Pai, Rob Herring, Sam Bobroff, Segher Boessenkool, Simon Guo, Simon Horman, Stewart Smith, Sukadev Bhattiprolu, Suraj Jitindar Singh, Thiago Jung Bauermann, Vaibhav Jain, Vaidyanathan Srinivasan, Vasant Hegde, Wei Yongjun" * tag 'powerpc-4.17-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (207 commits) powerpc/64s/idle: Fix restore of AMOR on POWER9 after deep sleep powerpc/64s: Fix POWER9 DD2.2 and above in cputable features powerpc/64s: Fix pkey support in dt_cpu_ftrs, add CPU_FTR_PKEY bit powerpc/64s: Fix dt_cpu_ftrs to have restore_cpu clear unwanted LPCR bits Revert "powerpc/64s/idle: POWER9 ESL=0 stop avoid save/restore overhead" powerpc: iomap.c: introduce io{read|write}64_{lo_hi|hi_lo} powerpc: io.h: move iomap.h include so that it can use readq/writeq defs cxl: Fix possible deadlock when processing page faults from cxllib powerpc/hw_breakpoint: Only disable hw breakpoint if cpu supports it powerpc/mm/radix: Update command line parsing for disable_radix powerpc/mm/radix: Parse disable_radix commandline correctly. powerpc/mm/hugetlb: initialize the pagetable cache correctly for hugetlb powerpc/mm/radix: Update pte fragment count from 16 to 256 on radix powerpc/mm/keys: Update documentation and remove unnecessary check powerpc/64s/idle: POWER9 ESL=0 stop avoid save/restore overhead powerpc/64s/idle: Consolidate power9_offline_stop()/power9_idle_stop() powerpc/powernv: Always stop secondaries before reboot/shutdown powerpc: hard disable irqs in smp_send_stop loop powerpc: use NMI IPI for smp_send_stop powerpc/powernv: Fix SMT4 forcing idle code ...
2018-03-31drivers: macintosh: rack-meter: really fix bogus memsetsAaro Koskinen
We should zero an array using sizeof instead of number of elements. Fixes the following compiler (GCC 7.3.0) warnings: drivers/macintosh/rack-meter.c: In function 'rackmeter_do_pause': drivers/macintosh/rack-meter.c:157:2: warning: 'memset' used with length equal to number of elements without multiplication by element size [-Wmemset-elt-size] drivers/macintosh/rack-meter.c:158:2: warning: 'memset' used with length equal to number of elements without multiplication by element size [-Wmemset-elt-size] Fixes: 4f7bef7a9f69 ("drivers: macintosh: rack-meter: fix bogus memsets") Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2018-03-31macintosh/adb: Use C99 initializers for struct adb_driver instancesFinn Thain
No change to object files. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2018-03-20powerpc: Use sizeof(*foo) rather than sizeof(struct foo)Markus Elfring
It's slightly less error prone to use sizeof(*foo) rather than specifying the type. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> [mpe: Consolidate into one patch, rewrite change log] Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2018-03-19macintosh/via-pmu68k: Initialize PMU driver with setup_arch and arch_initcallFinn Thain
The PMU watchdog will power down the system if the kernel is slow to start up, e.g. due to unpacking a large initrd. The powerpc version of this driver (via-pmu.c) has a solution for the same problem. It uses this call sequence: setup_arch find_via_pmu init_pmu ... arch_initcall via_pmu_start Bring via-pmu68k.c into line with via-pmu.c to fix this issue. Cc: Geert Uytterhoeven <geert@linux-m68k.org> Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2018-03-13powerpc/via-pmu: Fix section mismatch warningMathieu Malaterre
Make the struct via_pmu_driver const to avoid following warning: WARNING: vmlinux.o(.data+0x4739c): Section mismatch in reference from the variable via_pmu_driver to the function .init.text:pmu_init() The variable via_pmu_driver references the function __init pmu_init() If the reference is valid then annotate the variable with __init* or __refdata (see linux/init.h) or name the variable: *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console Signed-off-by: Mathieu Malaterre <malat@debian.org> Suggested-by: Laurent Vivier <lvivier@redhat.com> Reviewed-by: Laurent Vivier <lvivier@redhat.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2018-03-13macintosh: Add module license to ans-lcdLarry Finger
In kernel 4.15, the modprobe step on my PowerBook G4 started complaining that there was no module license for ans-lcd. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2018-02-13powerpc/macio: set a proper dma_coherent_maskChristoph Hellwig
We have expected busses to set up a coherent mask to properly use the common dma mapping code for a long time, and now that I've added a warning macio turned out to not set one up yet. This sets it to the same value as the dma_mask, which seems to be what the drivers expect. Reported-by: Mathieu Malaterre <malat@debian.org> Tested-by: Mathieu Malaterre <malat@debian.org> Reported-by: Meelis Roos <mroos@linux.ee> Tested-by: Meelis Roos <mroos@linux.ee> Signed-off-by: Christoph Hellwig <hch@lst.de>
2018-02-11vfs: do bulk POLL* -> EPOLL* replacementLinus Torvalds
This is the mindless scripted replacement of kernel use of POLL* variables as described by Al, done by this script: for V in IN OUT PRI ERR RDNORM RDBAND WRNORM WRBAND HUP RDHUP NVAL MSG; do L=`git grep -l -w POLL$V | grep -v '^t' | grep -v /um/ | grep -v '^sa' | grep -v '/poll.h$'|grep -v '^D'` for f in $L; do sed -i "-es/^\([^\"]*\)\(\<POLL$V\>\)/\\1E\\2/" $f; done done with de-mangling cleanups yet to come. NOTE! On almost all architectures, the EPOLL* constants have the same values as the POLL* constants do. But they keyword here is "almost". For various bad reasons they aren't the same, and epoll() doesn't actually work quite correctly in some cases due to this on Sparc et al. The next patch from Al will sort out the final differences, and we should be all done. Scripted-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-02-06Merge tag 'pci-v4.16-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: - skip AER driver error recovery callbacks for correctable errors reported via ACPI APEI, as we already do for errors reported via the native path (Tyler Baicar) - fix DPC shared interrupt handling (Alex Williamson) - print full DPC interrupt number (Keith Busch) - enable DPC only if AER is available (Keith Busch) - simplify DPC code (Bjorn Helgaas) - calculate ASPM L1 substate parameter instead of hardcoding it (Bjorn Helgaas) - enable Latency Tolerance Reporting for ASPM L1 substates (Bjorn Helgaas) - move ASPM internal interfaces out of public header (Bjorn Helgaas) - allow hot-removal of VGA devices (Mika Westerberg) - speed up unplug and shutdown by assuming Thunderbolt controllers don't support Command Completed events (Lukas Wunner) - add AtomicOps support for GPU and Infiniband drivers (Felix Kuehling, Jay Cornwall) - expose "ari_enabled" in sysfs to help NIC naming (Stuart Hayes) - clean up PCI DMA interface usage (Christoph Hellwig) - remove PCI pool API (replaced with DMA pool) (Romain Perier) - deprecate pci_get_bus_and_slot(), which assumed PCI domain 0 (Sinan Kaya) - move DT PCI code from drivers/of/ to drivers/pci/ (Rob Herring) - add PCI-specific wrappers for dev_info(), etc (Frederick Lawler) - remove warnings on sysfs mmap failure (Bjorn Helgaas) - quiet ROM validation messages (Alex Deucher) - remove redundant memory alloc failure messages (Markus Elfring) - fill in types for compile-time VGA and other I/O port resources (Bjorn Helgaas) - make "pci=pcie_scan_all" work for Root Ports as well as Downstream Ports to help AmigaOne X1000 (Bjorn Helgaas) - add SPDX tags to all PCI files (Bjorn Helgaas) - quirk Marvell 9128 DMA aliases (Alex Williamson) - quirk broken INTx disable on Ceton InfiniTV4 (Bjorn Helgaas) - fix CONFIG_PCI=n build by adding dummy pci_irqd_intx_xlate() (Niklas Cassel) - use DMA API to get MSI address for DesignWare IP (Niklas Cassel) - fix endpoint-mode DMA mask configuration (Kishon Vijay Abraham I) - fix ARTPEC-6 incorrect IS_ERR() usage (Wei Yongjun) - add support for ARTPEC-7 SoC (Niklas Cassel) - add endpoint-mode support for ARTPEC (Niklas Cassel) - add Cadence PCIe host and endpoint controller driver (Cyrille Pitchen) - handle multiple INTx status bits being set in dra7xx (Vignesh R) - translate dra7xx hwirq range to fix INTD handling (Vignesh R) - remove deprecated Exynos PHY initialization code (Jaehoon Chung) - fix MSI erratum workaround for HiSilicon Hip06/Hip07 (Dongdong Liu) - fix NULL pointer dereference in iProc BCMA driver (Ray Jui) - fix Keystone interrupt-controller-node lookup (Johan Hovold) - constify qcom driver structures (Julia Lawall) - rework Tegra config space mapping to increase space available for endpoints (Vidya Sagar) - simplify Tegra driver by using bus->sysdata (Manikanta Maddireddy) - remove PCI_REASSIGN_ALL_BUS usage on Tegra (Manikanta Maddireddy) - add support for Global Fabric Manager Server (GFMS) event to Microsemi Switchtec switch driver (Logan Gunthorpe) - add IDs for Switchtec PSX 24xG3 and PSX 48xG3 (Kelvin Cao) * tag 'pci-v4.16-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (140 commits) PCI: cadence: Add EndPoint Controller driver for Cadence PCIe controller dt-bindings: PCI: cadence: Add DT bindings for Cadence PCIe endpoint controller PCI: endpoint: Fix EPF device name to support multi-function devices PCI: endpoint: Add the function number as argument to EPC ops PCI: cadence: Add host driver for Cadence PCIe controller dt-bindings: PCI: cadence: Add DT bindings for Cadence PCIe host controller PCI: Add vendor ID for Cadence PCI: Add generic function to probe PCI host controllers PCI: generic: fix missing call of pci_free_resource_list() PCI: OF: Add generic function to parse and allocate PCI resources PCI: Regroup all PCI related entries into drivers/pci/Makefile PCI/DPC: Reformat DPC register definitions PCI/DPC: Add and use DPC Status register field definitions PCI/DPC: Squash dpc_rp_pio_get_info() into dpc_process_rp_pio_error() PCI/DPC: Remove unnecessary RP PIO register structs PCI/DPC: Push dpc->rp_pio_status assignment into dpc_rp_pio_get_info() PCI/DPC: Squash dpc_rp_pio_print_error() into dpc_rp_pio_get_info() PCI/DPC: Make RP PIO log size check more generic PCI/DPC: Rename local "status" to "dpc_status" PCI/DPC: Squash dpc_rp_pio_print_tlp_header() into dpc_rp_pio_print_error() ...
2018-02-02Merge tag 'powerpc-4.16-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux Pull powerpc updates from Michael Ellerman: "Highlights: - Enable support for memory protection keys aka "pkeys" on Power7/8/9 when using the hash table MMU. - Extend our interrupt soft masking to support masking PMU interrupts as well as "normal" interrupts, and then use that to implement local_t for a ~4x speedup vs the current atomics-based implementation. - A new driver "ocxl" for "Open Coherent Accelerator Processor Interface (OpenCAPI)" devices. - Support for new device tree properties on PowerVM to describe hotpluggable memory and devices. - Add support for CLOCK_{REALTIME/MONOTONIC}_COARSE to the 64-bit VDSO. - Freescale updates from Scott: fixes for CPM GPIO and an FSL PCI erratum workaround, plus a minor cleanup patch. As well as quite a lot of other changes all over the place, and small fixes and cleanups as always. Thanks to: Alan Modra, Alastair D'Silva, Alexey Kardashevskiy, Alistair Popple, Andreas Schwab, Andrew Donnellan, Aneesh Kumar K.V, Anju T Sudhakar, Anshuman Khandual, Anton Blanchard, Arnd Bergmann, Balbir Singh, Benjamin Herrenschmidt, Bhaktipriya Shridhar, Bryant G. Ly, Cédric Le Goater, Christophe Leroy, Christophe Lombard, Cyril Bur, David Gibson, Desnes A. Nunes do Rosario, Dmitry Torokhov, Frederic Barrat, Geert Uytterhoeven, Guilherme G. Piccoli, Gustavo A. R. Silva, Gustavo Romero, Ivan Mikhaylov, Joakim Tjernlund, Joe Perches, Josh Poimboeuf, Juan J. Alvarez, Julia Cartwright, Kamalesh Babulal, Madhavan Srinivasan, Mahesh Salgaonkar, Mathieu Malaterre, Michael Bringmann, Michael Hanselmann, Michael Neuling, Nathan Fontenot, Naveen N. Rao, Nicholas Piggin, Paul Mackerras, Philippe Bergheaud, Ram Pai, Russell Currey, Santosh Sivaraj, Scott Wood, Seth Forshee, Simon Guo, Stewart Smith, Sukadev Bhattiprolu, Thiago Jung Bauermann, Vaibhav Jain, Vasyl Gomonovych" * tag 'powerpc-4.16-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (199 commits) powerpc/mm/radix: Fix build error when RADIX_MMU=n macintosh/ams-input: Use true and false for boolean values macintosh: change some data types from int to bool powerpc/watchdog: Print the NIP in soft_nmi_interrupt() powerpc/watchdog: regs can't be null in soft_nmi_interrupt() powerpc/watchdog: Tweak watchdog printks powerpc/cell: Remove axonram driver rtc-opal: Fix handling of firmware error codes, prevent busy loops powerpc/mpc52xx_gpt: make use of raw_spinlock variants macintosh/adb: Properly mark continued kernel messages powerpc/pseries: Fix cpu hotplug crash with memoryless nodes powerpc/numa: Ensure nodes initialized for hotplug powerpc/numa: Use ibm,max-associativity-domains to discover possible nodes powerpc/kernel: Block interrupts when updating TIDR powerpc/powernv/idoa: Remove unnecessary pcidev from pci_dn powerpc/mm/nohash: do not flush the entire mm when range is a single page powerpc/pseries: Add Initialization of VF Bars powerpc/pseries/pci: Associate PEs to VFs in configure SR-IOV powerpc/eeh: Add EEH notify resume sysfs powerpc/eeh: Add EEH operations to notify resume ...
2018-01-28macintosh/ams-input: Use true and false for boolean valuesGustavo A. R. Silva
Assign true or false to boolean variables instead of an integer value. This issue was detected with the help of Coccinelle Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com> Reviewed-by: Michael Hanselmann <public@hansmi.ch> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2018-01-28macintosh: change some data types from int to boolGustavo A. R. Silva
Change the data type of the following variables from int to bool across all macintosh drivers: started slots_started pm121_started wf_smu_started Some of these issues were detected with the help of Coccinelle. Suggested-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2018-01-27macintosh/adb: Properly mark continued kernel messagesAndreas Schwab
Use pr_cont where appropriate, and switch to pr_foo throughout. Additionally, lower messages in adb_probe_task to debug level. Signed-off-by: Andreas Schwab <schwab@linux-m68k.org> [mpe: Clean up whitespace slightly] Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2018-01-21backlight: Fix old-style function definitionMathieu Malaterre
Fix warning: drivers/macintosh/via-pmu-backlight.c: In function ‘pmu_backlight_init’: drivers/macintosh/via-pmu-backlight.c:140:13: warning: old-style function definition [-Wold-style-definition] void __init pmu_backlight_init() ^~~~~~~~~~~~~~~~~~ Signed-off-by: Mathieu Malaterre <malat@debian.org> Acked-by: Daniel Thompson <daniel.thompson@linaro.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2018-01-17powerpc/via-pmu: Deprecate pci_get_bus_and_slot()Sinan Kaya
pci_get_bus_and_slot() is restrictive such that it assumes domain=0 as where a PCI device is present. This restricts the device drivers to be reused for other domain numbers. Getting ready to remove pci_get_bus_and_slot() function in favor of pci_get_domain_bus_and_slot(). Hard-code the domain number as 0 to match the previous behavior. Signed-off-by: Sinan Kaya <okaya@codeaurora.org> Signed-off-by: Bjorn Helgaas <helgaas@kernel.org>
2017-11-28the rest of drivers/*: annotate ->poll() instancesAl Viro
2017-11-13Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer updates from Thomas Gleixner: "Yet another big pile of changes: - More year 2038 work from Arnd slowly reaching the point where we need to think about the syscalls themself. - A new timer function which allows to conditionally (re)arm a timer only when it's either not running or the new expiry time is sooner than the armed expiry time. This allows to use a single timer for multiple timeout requirements w/o caring about the first expiry time at the call site. - A new NMI safe accessor to clock real time for the printk timestamp work. Can be used by tracing, perf as well if required. - A large number of timer setup conversions from Kees which got collected here because either maintainers requested so or they simply got ignored. As Kees pointed out already there are a few trivial merge conflicts and some redundant commits which was unavoidable due to the size of this conversion effort. - Avoid a redundant iteration in the timer wheel softirq processing. - Provide a mechanism to treat RTC implementations depending on their hardware properties, i.e. don't inflict the write at the 0.5 seconds boundary which originates from the PC CMOS RTC to all RTCs. No functional change as drivers need to be updated separately. - The usual small updates to core code clocksource drivers. Nothing really exciting" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (111 commits) timers: Add a function to start/reduce a timer pstore: Use ktime_get_real_fast_ns() instead of __getnstimeofday() timer: Prepare to change all DEFINE_TIMER() callbacks netfilter: ipvs: Convert timers to use timer_setup() scsi: qla2xxx: Convert timers to use timer_setup() block/aoe: discover_timer: Convert timers to use timer_setup() ide: Convert timers to use timer_setup() drbd: Convert timers to use timer_setup() mailbox: Convert timers to use timer_setup() crypto: Convert timers to use timer_setup() drivers/pcmcia: omap1: Fix error in automated timer conversion ARM: footbridge: Fix typo in timer conversion drivers/sgi-xp: Convert timers to use timer_setup() drivers/pcmcia: Convert timers to use timer_setup() drivers/memstick: Convert timers to use timer_setup() drivers/macintosh: Convert timers to use timer_setup() hwrng/xgene-rng: Convert timers to use timer_setup() auxdisplay: Convert timers to use timer_setup() sparc/led: Convert timers to use timer_setup() mips: ip22/32: Convert timers to use timer_setup() ...
2017-11-13Merge tag 'm68k-for-v4.15-tag1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k Pull m68k updates from Geert Uytterhoeven: - more printk modernization - various cleanups and fixes (incl. a race condition) for Mac - defconfig updates * tag 'm68k-for-v4.15-tag1' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: m68k/defconfig: Update defconfigs for v4.14-rc7 m68k/mac: Add mutual exclusion for IOP interrupt polling m68k/mac: Disentangle VIA/RBV and NuBus initialization m68k/mac: Disentangle VIA and OSS initialization m68k/mac: More printk modernization
2017-11-09m68k/mac: Add mutual exclusion for IOP interrupt pollingFinn Thain
The IOP interrupt handler iop_ism_irq() is used by the adb-iop driver to poll for ADB request completion. Unfortunately, it is not re-entrant. Fix the race condition by adding an iop_ism_irq_poll() function with suitable mutual exclusion. Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: linuxppc-dev@lists.ozlabs.org Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2017-11-02drivers/macintosh: Convert timers to use timer_setup()Kees Cook
In preparation for unconditionally passing the struct timer_list pointer to all timer callbacks, switch to using the new timer_setup() and from_timer() to pass the timer pointer explicitly. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: linuxppc-dev@lists.ozlabs.org Signed-off-by: Kees Cook <keescook@chromium.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-01powerpc/macintosh: constify wf_sensor_ops structuresJulia Lawall
The wf_sensor_ops structures are only stored in the ops field of a wf_sensor structure, which is declared as const. Thus the wf_sensor_ops structures themselves can be const. Done with the help of Coccinelle. // <smpl> @r disable optional_qualifier@ identifier i; position p; @@ static struct wf_sensor_ops i@p = { ... }; @ok1@ identifier r.i; struct wf_sensor s; position p; @@ s.ops = &i@p @ok2@ identifier r.i; struct wf_sat_sensor s; position p; @@ s.sens.ops = &i@p @bad@ position p != {r.p,ok1.p,ok2.p}; identifier r.i; struct wf_sensor_ops e; @@ e@i@p @depends on !bad disable optional_qualifier@ identifier r.i; @@ static +const struct wf_sensor_ops i = { ... }; // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2017-09-01macintosh: Convert to using %pOF instead of full_nameRob Herring
Now that we have a custom printf format specifier, convert users of full_name to use %pOF instead. This is preparation to remove storing of the full path string for each node. Signed-off-by: Rob Herring <robh@kernel.org> [mpe: Also convert the two cases inside #if 0] Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2017-08-21macintosh/rack-meter: Make of_device_ids constArvind Yadav
of_device_ids are not supposed to change at runtime. All functions working with of_device_ids provided by <linux/of.h> work with const of_device_ids. So mark the non-const structs as const. File size before: text data bss dec hex filename 407 576 0 983 3d7 drivers/macintosh/rack-meter.o File size after constify rackmeter_match. text data bss dec hex filename 807 176 0 983 3d7 drivers/macintosh/rack-meter.o Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2017-08-14drivers/macintosh: Make wf_control_ops and wf_pid_param constBhumika Goyal
Make wf_control_ops const as they are only stored in the ops field of a wf_control structure, which is const. Make wf_pid_param const as they are only used during a copy operation. Done using Coccinelle. Signed-off-by: Bhumika Goyal <bhumirks@gmail.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2017-07-05Merge branch 'work.misc-set_fs' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull misc user access cleanups from Al Viro: "The first pile is assorted getting rid of cargo-culted access_ok(), cargo-culted set_fs() and field-by-field copyouts. The same description applies to a lot of stuff in other branches - this is just the stuff that didn't fit into a more specific topical branch" * 'work.misc-set_fs' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: Switch flock copyin/copyout primitives to copy_{from,to}_user() fs/fcntl: return -ESRCH in f_setown when pid/pgid can't be found fs/fcntl: f_setown, avoid undefined behaviour fs/fcntl: f_setown, allow returning error lpfc debugfs: get rid of pointless access_ok() adb: get rid of pointless access_ok() isdn: get rid of pointless access_ok() compat statfs: switch to copy_to_user() fs/locks: don't mess with the address limit in compat_fcntl64 nfsd_readlink(): switch to vfs_get_link() drbd: ->sendpage() never needed set_fs() fs/locks: pass kernel struct flock to fcntl_getlk/setlk fs: locks: Fix some troubles at kernel-doc comments
2017-06-09macintosh: use dev_groups and not dev_attrs for bus_typeGreg Kroah-Hartman
The dev_attrs field has long been "depreciated" and is finally being removed, so move the driver to use the "correct" dev_groups field instead for struct bus_type. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: <linuxppc-dev@lists.ozlabs.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-04adb: get rid of pointless access_ok()Al Viro
2017-05-05Merge tag 'devicetree-for-4.12' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull DeviceTree updates from Rob Herring: - fix sparse warnings in drivers/of/ - add more overlay unittests - update dtc to v1.4.4-8-g756ffc4f52f6. This adds more checks on dts files such as unit-address formatting and stricter character sets for node and property names - add a common DT modalias function - move trivial-devices.txt up and out of i2c dir - ARM NVIC interrupt controller binding - vendor prefixes for Sensirion, Dioo, Nordic, ROHM - correct some binding file locations * tag 'devicetree-for-4.12' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (24 commits) of: fix sparse warnings in fdt, irq, reserved mem, and resolver code of: fix sparse warning in of_pci_range_parser_one of: fix sparse warnings in of_find_next_cache_node of/unittest: Missing unlocks on error of: fix uninitialized variable warning for overlay test of: fix unittest build without CONFIG_OF_OVERLAY of: Add unit tests for applying overlays of: per-file dtc compiler flags fpga: region: add missing DT documentation for config complete timeout of: Add vendor prefix for ROHM Semiconductor of: fix "/cpus" reference leak in of_numa_parse_cpu_nodes() of: Add vendor prefix for Nordic Semiconductor dt-bindings: arm,nvic: Binding for ARM NVIC interrupt controller on Cortex-M dtc: update warning settings for new bus and node/property name checks scripts/dtc: Update to upstream version v1.4.4-8-g756ffc4f52f6 scripts/dtc: automate getting dtc version and log in update script of: Add function for generating a DT modalias with a newline of: fix of_device_get_modalias returned length when truncating buffers Documentation: devicetree: move trivial-devices out of I2C realm dt-bindings: add vendor prefix for Dioo ..
2017-03-24drivers: Clean up duplicated email addressFinn Thain
My email address may be found in the git commit logs and in MAINTAINERS. Remove duplicate addresses so they won't have to be kept up-to-date. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2017-03-22of: Add function for generating a DT modalias with a newlineRob Herring
The modalias sysfs attr is lacking a newline for DT aliases on platform devices. The macio and ibmebus correctly add the newline, but open code it. Introduce a new function, of_device_modalias(), that fills the buffer with the modalias including the newline and update users of the old of_device_get_modalias function. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Frank Rowand <frowand.list@gmail.com> Cc: linuxppc-dev@lists.ozlabs.org Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-10powerpc/pmac: Fix crash in dma-mapping.h with NULL dma_opsLarry Finger
Commit 5657933dbb6e ("treewide: Move dma_ops from struct dev_archdata into struct device") introduced a crash for macio devices, an example backtrace being: kernel BUG at ./include/linux/dma-mapping.h:465! Oops: Exception in kernel mode, sig: 5 [#1] ... NIP [c031ddb0] dmam_alloc_coherent+0x74/0x140 LR [c031de70] dmam_alloc_coherent+0x134/0x140 Call Trace: dmam_alloc_coherent+0x134/0x140 (unreliable) pata_macio_port_start+0x3c/0x8c ata_host_start.part.5+0xfc/0x208 ata_host_activate+0x128/0x154 pata_macio_common_init+0x2f0/0x538 pata_macio_attach+0xd8/0x180 macio_device_probe+0x5c/0xec driver_probe_device+0x21c/0x314 __driver_attach+0xcc/0xd0 bus_for_each_dev+0x68/0xb4 bus_add_driver+0x1dc/0x244 driver_register+0x88/0x130 pata_macio_init+0x5c/0x88 do_one_initcall+0x40/0x170 kernel_init_freeable+0x134/0x1d0 kernel_init+0x18/0x110 ret_from_kernel_thread+0x5c/0x64 This was caused by the device having NULL dma_ops, triggering the BUG_ON(). Previously the device inherited its dma_ops via the assignment to dev->ofdev.dev.archdata. However after commit 5657933dbb6e the dma_ops are moved into dev->ofdev.dev, and so they need to be explicitly copied. Fixes: 5657933dbb6e ("treewide: Move dma_ops from struct dev_archdata into struct device") Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Suggested-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> [mpe: Rewrite change log, add backtrace] Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2017-03-02sched/headers: Prepare to move signal wakeup & sigpending methods from ↵Ingo Molnar
<linux/sched.h> into <linux/sched/signal.h> Fix up affected files that include this signal functionality via sched.h. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
