path: root/drivers/macintosh
2016-09-20powerpc: Remove all usages of NO_IRQMichael Ellerman
NO_IRQ has been == 0 on powerpc for just over ten years (since commit 0ebfff1491ef ("[POWERPC] Add new interrupt mapping core and change platforms to use it")). It's also 0 on most other arches. Although it's fairly harmless, every now and then it causes confusion when a driver is built on powerpc and another arch which doesn't define NO_IRQ. There's at least 6 definitions of NO_IRQ in drivers/, at least some of which are to work around that problem. So we'd like to remove it. This is fairly trivial in the arch code, we just convert: if (irq == NO_IRQ) to if (!irq) if (irq != NO_IRQ) to if (irq) irq = NO_IRQ; to irq = 0; return NO_IRQ; to return 0; And a few other odd cases as well. At least for now we keep the #define NO_IRQ, because there is driver code that uses NO_IRQ and the fixes to remove those will go via other trees. Note we also change some occurrences in PPC sound drivers, drivers/ps3, and drivers/macintosh. Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2016-08-22drivers/macintosh: Delete owner assignmentMarkus Elfring
The field "owner" is set by core. Thus delete an extra initialisation. Generated by: scripts/coccinelle/api/platform_no_drv_owner.cocci Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2016-07-30Merge tag 'powerpc-4.8-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux Pull powerpc updates from Michael Ellerman: "Highlights: - PowerNV PCI hotplug support. - Lots more Power9 support. - eBPF JIT support on ppc64le. - Lots of cxl updates. - Boot code consolidation. Bug fixes: - Fix spin_unlock_wait() from Boqun Feng - Fix stack pointer corruption in __tm_recheckpoint() from Michael Neuling - Fix multiple bugs in memory_hotplug_max() from Bharata B Rao - mm: Ensure "special" zones are empty from Oliver O'Halloran - ftrace: Separate the heuristics for checking call sites from Michael Ellerman - modules: Never restore r2 for a mprofile-kernel style mcount() call from Michael Ellerman - Fix endianness when reading TCEs from Alexey Kardashevskiy - start rtasd before PCI probing from Greg Kurz - PCI: rpaphp: Fix slot registration for multiple slots under a PHB from Tyrel Datwyler - powerpc/mm: Add memory barrier in __hugepte_alloc() from Sukadev Bhattiprolu Cleanups & fixes: - Drop support for MPIC in pseries from Rashmica Gupta - Define and use PPC64_ELF_ABI_v2/v1 from Michael Ellerman - Remove unused symbols in asm-offsets.c from Rashmica Gupta - Fix SRIOV not building without EEH enabled from Russell Currey - Remove kretprobe_trampoline_holder from Thiago Jung Bauermann - Reduce log level of PCI I/O space warning from Benjamin Herrenschmidt - Add array bounds checking to crash_shutdown_handlers from Suraj Jitindar Singh - Avoid -maltivec when using clang integrated assembler from Anton Blanchard - Fix array overrun in ppc_rtas() syscall from Andrew Donnellan - Fix error return value in cmm_mem_going_offline() from Rasmus Villemoes - export cpu_to_core_id() from Mauricio Faria de Oliveira - Remove old symbols from defconfigs from Andrew Donnellan - Update obsolete comments in setup_32.c about entry conditions from Benjamin Herrenschmidt - Add comment explaining the purpose of setup_kdump_trampoline() from Benjamin Herrenschmidt - Merge the RELOCATABLE config entries for ppc32 and ppc64 from Kevin Hao - Remove RELOCATABLE_PPC32 from Kevin Hao - Fix .long's in tlb-radix.c to more meaningful from Balbir Singh Minor cleanups & fixes: - Andrew Donnellan, Anna-Maria Gleixner, Anton Blanchard, Benjamin Herrenschmidt, Bharata B Rao, Christophe Leroy, Colin Ian King, Geliang Tang, Greg Kurz, Madhavan Srinivasan, Michael Ellerman, Michael Ellerman, Stephen Rothwell, Stewart Smith. Freescale updates from Scott: - "Highlights include more 8xx optimizations, device tree updates, and MVME7100 support." PowerNV PCI hotplug from Gavin Shan: - PCI: Add pcibios_setup_bridge() - Override pcibios_setup_bridge() - Remove PCI_RESET_DELAY_US - Move pnv_pci_ioda_setup_opal_tce_kill() around - Increase PE# capacity - Allocate PE# in reverse order - Create PEs in pcibios_setup_bridge() - Setup PE for root bus - Extend PCI bridge resources - Make pnv_ioda_deconfigure_pe() visible - Dynamically release PE - Update bridge windows on PCI plug - Delay populating pdn - Support PCI slot ID - Use PCI slot reset infrastructure - Introduce pnv_pci_get_slot_id() - Functions to get/set PCI slot state - PCI/hotplug: PowerPC PowerNV PCI hotplug driver - Print correct PHB type names Power9 idle support from Shreyas B. Prabhu: - set power_save func after the idle states are initialized - Use PNV_THREAD_WINKLE macro while requesting for winkle - make hypervisor state restore a function - Rename idle_power7.S to idle_book3s.S - Rename reusable idle functions to hardware agnostic names - Make pnv_powersave_common more generic - abstraction for saving SPRs before entering deep idle states - Add platform support for stop instruction - cpuidle/powernv: Use CPUIDLE_STATE_MAX instead of MAX_POWERNV_IDLE_STATES - cpuidle/powernv: cleanup cpuidle-powernv.c - cpuidle/powernv: Add support for POWER ISA v3 idle states - Use deepest stop state when cpu is offlined Power9 PMU from Madhavan Srinivasan: - factor out power8 pmu macros and defines - factor out power8 pmu functions - factor out power8 __init_pmu code - Add power9 event list macros for generic and cache events - Power9 PMU support - Export Power9 generic and cache events to sysfs Power9 preliminary interrupt & PCI support from Benjamin Herrenschmidt: - Add XICS emulation APIs - Move a few exception common handlers to make room - Add support for HV virtualization interrupts - Add mechanism to force a replay of interrupts - Add ICP OPAL backend - Discover IODA3 PHBs - pci: Remove obsolete SW invalidate - opal: Add real mode call wrappers - Rename TCE invalidation calls - Remove SWINV constants and obsolete TCE code - Rework accessing the TCE invalidate register - Fallback to OPAL for TCE invalidations - Use the device-tree to get available range of M64's - Check status of a PHB before using it - pci: Don't try to allocate resources that will be reassigned Other Power9: - Send SIGBUS on unaligned copy and paste from Chris Smart - Large Decrementer support from Oliver O'Halloran - Load Monitor Register Support from Jack Miller Performance improvements from Anton Blanchard: - Avoid load hit store in __giveup_fpu() and __giveup_altivec() - Avoid load hit store in setup_sigcontext() - Remove assembly versions of strcpy, strcat, strlen and strcmp - Align hot loops of some string functions eBPF JIT from Naveen N. Rao: - Fix/enhance 32-bit Load Immediate implementation - Optimize 64-bit Immediate loads - Introduce rotate immediate instructions - A few cleanups - Isolate classic BPF JIT specifics into a separate header - Implement JIT compiler for extended BPF Operator Panel driver from Suraj Jitindar Singh: - devicetree/bindings: Add binding for operator panel on FSP machines - Add inline function to get rc from an ASYNC_COMP opal_msg - Add driver for operator panel on FSP machines Sparse fixes from Daniel Axtens: - make some things static - Introduce asm-prototypes.h - Include headers containing prototypes - Use #ifdef __BIG_ENDIAN__ #else for REG_BYTE - kvm: Clarify __user annotations - Pass endianness to sparse - Make ppc_md.{halt, restart} __noreturn MM fixes & cleanups from Aneesh Kumar K.V: - radix: Update LPCR HR bit as per ISA - use _raw variant of page table accessors - Compile out radix related functions if RADIX_MMU is disabled - Clear top 16 bits of va only on older cpus - Print formation regarding the the MMU mode - hash: Update SDR1 size encoding as documented in ISA 3.0 - radix: Update PID switch sequence - radix: Update machine call back to support new HCALL. - radix: Add LPID based tlb flush helpers - radix: Add a kernel command line to disable radix - Cleanup LPCR defines Boot code consolidation from Benjamin Herrenschmidt: - Move epapr_paravirt_early_init() to early_init_devtree() - cell: Don't use flat device-tree after boot - ge_imp3a: Don't use the flat device-tree after boot - mpc85xx_ds: Don't use the flat device-tree after boot - mpc85xx_rdb: Don't use the flat device-tree after boot - Don't test for machine type in rtas_initialize() - Don't test for machine type in smp_setup_cpu_maps() - dt: Add of_device_compatible_match() - Factor do_feature_fixup calls - Move 64-bit feature fixup earlier - Move 64-bit memory reserves to setup_arch() - Use a cachable DART - Move FW feature probing out of pseries probe() - Put exception configuration in a common place - Remove early allocation of the SMU command buffer - Move MMU backend selection out of platform code - pasemi: Remove IOBMAP allocation from platform probe() - mm/hash: Don't use machine_is() early during boot - Don't test for machine type to detect HEA special case - pmac: Remove spurrious machine type test - Move hash table ops to a separate structure - Ensure that ppc_md is empty before probing for machine type - Move 64-bit probe_machine() to later in the boot process - Move 32-bit probe() machine to later in the boot process - Get rid of ppc_md.init_early() - Move the boot time info banner to a separate function - Move setting of {i,d}cache_bsize to initialize_cache_info() - Move the content of setup_system() to setup_arch() - Move cache info inits to a separate function - Re-order the call to smp_setup_cpu_maps() - Re-order setup_panic() - Make a few boot functions __init - Merge 32-bit and 64-bit setup_arch() Other new features: - tty/hvc: Use IRQF_SHARED for OPAL hvc consoles from Sam Mendoza-Jonas - tty/hvc: Use opal irqchip interface if available from Sam Mendoza-Jonas - powerpc: Add module autoloading based on CPU features from Alastair D'Silva - crypto: vmx - Convert to CPU feature based module autoloading from Alastair D'Silva - Wake up kopald polling thread before waiting for events from Benjamin Herrenschmidt - xmon: Dump ISA 2.06 SPRs from Michael Ellerman - xmon: Dump ISA 2.07 SPRs from Michael Ellerman - Add a parameter to disable 1TB segs from Oliver O'Halloran - powerpc/boot: Add OPAL console to epapr wrappers from Oliver O'Halloran - Assign fixed PHB number based on device-tree properties from Guilherme G. Piccoli - pseries: Add pseries hotplug workqueue from John Allen - pseries: Add support for hotplug interrupt source from John Allen - pseries: Use kernel hotplug queue for PowerVM hotplug events from John Allen - pseries: Move property cloning into its own routine from Nathan Fontenot - pseries: Dynamic add entires to associativity lookup array from Nathan Fontenot - pseries: Auto-online hotplugged memory from Nathan Fontenot - pseries: Remove call to memblock_add() from Nathan Fontenot cxl: - Add set and get private data to context struct from Michael Neuling - make base more explicitly non-modular from Paul Gortmaker - Use for_each_compatible_node() macro from Wei Yongjun - Frederic Barrat - Abstract the differences between the PSL and XSL - Make vPHB device node match adapter's - Philippe Bergheaud - Add mechanism for delivering AFU driver specific events - Ignore CAPI adapters misplaced in switched slots - Refine slice error debug messages - Andrew Donnellan - static-ify variables to fix sparse warnings - PCI/hotplug: pnv_php: export symbols and move struct types needed by cxl - PCI/hotplug: pnv_php: handle OPAL_PCI_SLOT_OFFLINE power state - Add cxl_check_and_switch_mode() API to switch bi-modal cards - remove dead Kconfig options - fix potential NULL dereference in free_adapter() - Ian Munsie - Update process element after allocating interrupts - Add support for CAPP DMA mode - Fix allowing bogus AFU descriptors with 0 maximum processes - Fix allocating a minimum of 2 pages for the SPA - Fix bug where AFU disable operation had no effect - Workaround XSL bug that does not clear the RA bit after a reset - Fix NULL pointer dereference on kernel contexts with no AFU interrupts - powerpc/powernv: Split cxl code out into a separate file - Add cxl_slot_is_supported API - Enable bus mastering for devices using CAPP DMA mode - Move cxl_afu_get / cxl_afu_put to base - Allow a default context to be associated with an external pci_dev - Do not create vPHB if there are no AFU configuration records - powerpc/powernv: Add support for the cxl kernel api on the real phb - Add support for using the kernel API with a real PHB - Add kernel APIs to get & set the max irqs per context - Add preliminary workaround for CX4 interrupt limitation - Add support for interrupts on the Mellanox CX4 - Workaround PE=0 hardware limitation in Mellanox CX4 - powerpc/powernv: Fix pci-cxl.c build when CONFIG_MODULES=n selftests: - Test unaligned copy and paste from Chris Smart - Load Monitor Register Tests from Jack Miller - Cyril Bur - exec() with suspended transaction - Use signed long to read perf_event_paranoid - Fix usage message in context_switch - Fix generation of vector instructions/types in context_switch - Michael Ellerman - Use "Delta" rather than "Error" in normal output - Import Anton's mmap & futex micro benchmarks - Add a test for PROT_SAO" * tag 'powerpc-4.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (263 commits) powerpc/mm: Parenthesise IS_ENABLED() in if condition tty/hvc: Use opal irqchip interface if available tty/hvc: Use IRQF_SHARED for OPAL hvc consoles selftests/powerpc: exec() with suspended transaction powerpc: Improve comment explaining why we modify VRSAVE powerpc/mm: Drop unused externs for hpte_init_beat[_v3]() powerpc/mm: Rename hpte_init_lpar() and move the fallback to a header powerpc/mm: Fix build break when PPC_NATIVE=n crypto: vmx - Convert to CPU feature based module autoloading powerpc: Add module autoloading based on CPU features powerpc/powernv/ioda: Fix endianness when reading TCEs powerpc/mm: Add memory barrier in __hugepte_alloc() powerpc/modules: Never restore r2 for a mprofile-kernel style mcount() call powerpc/ftrace: Separate the heuristics for checking call sites powerpc: Merge 32-bit and 64-bit setup_arch() powerpc/64: Make a few boot functions __init powerpc: Re-order setup_panic() powerpc: Re-order the call to smp_setup_cpu_maps() powerpc/32: Move cache info inits to a separate function powerpc/64: Move the content of setup_system() to setup_arch() ...
2016-07-21powerpc/pmac: Remove early allocation of the SMU command bufferBenjamin Herrenschmidt
The SMU command buffer needs to be allocated below 2G using memblock. In the past, this had to be done very early from the arch code as memblock wasn't available past that point. That is no longer the case though, smu_init() is called from setup_arch() when memblock is still functional these days. So move the allocation to the SMU driver itself. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2016-06-27powerpc: use the new LED disk activity triggerStephan Linz
- dts: rename 'ide-disk' to 'disk-activity' - defconfig: rename 'ADB_PMU_LED_IDE' to 'ADB_PMU_LED_DISK' Cc: Joseph Jezak <josejx@gentoo.org> Cc: Jörg Sommer <joerg@alea.gnuu.de> Signed-off-by: Stephan Linz <linz@li-pro.net> Signed-off-by: Jacek Anaszewski <j.anaszewski@samsung.com>
2016-05-01powerpc/mm: Abstraction for switch_mmu_context()Aneesh Kumar K.V
How we switch MMU context differs between hash and radix. For hash we need to switch the SLB details and for radix we need to switch the PID SPR. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2016-04-12drivers: macintosh: rack-meter: fix bogus memsetsAaro Koskinen
Fix bogus memsets pointed out by sparse: linux-v4.3/drivers/macintosh/rack-meter.c:157:15: warning: memset with byte count of 0 linux-v4.3/drivers/macintosh/rack-meter.c:158:15: warning: memset with byte count of 0 Probably "&" is mistyped "*"; use ARRAY_SIZE to make it more safe. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2016-04-12drivers: macintosh: rack-meter: limit idle ticks to total ticksAaro Koskinen
Limit idle ticks to total ticks. This prevents the annoying rackmeter leds fully ON / OFF blinking state that happens on fully idling G5 Xserve systems. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2016-02-05PCI: Remove includes of asm/pci-bridge.hBjorn Helgaas
Drivers should include asm/pci-bridge.h only when they need the arch- specific things provided there. Outside of the arch/ directories, the only drivers that actually need things provided by asm/pci-bridge.h are the powerpc RPA hotplug drivers in drivers/pci/hotplug/rpa*. Remove the includes of asm/pci-bridge.h from the other drivers, adding an include of linux/pci.h if necessary. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2015-11-26powerpc/rackmeter: Fix module autoload for OF platform driverLuis de Bethencourt
This platform driver has a OF device ID table but the OF module alias information is not created so module autoloading won't work. Signed-off-by: Luis de Bethencourt <luisbg@osg.samsung.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-11-26powerpc/powermac: IRQF_NO_SUSPEND not IRQF_TIMER for non-timerJohn Ogness
Since gpio1 is not a timer, it also should not use IRQF_TIMER. Similar to commit ba461f094bab ("powerpc: Use IRQF_NO_SUSPEND not IRQF_TIMER for non-timer interrupts"). Signed-off-by: John Ogness <john.ogness@linutronix.de> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-10-15drivers/macintosh: adb: fix misleading Kconfig help textAaro Koskinen
CONFIG_INPUT_KEYBDEV does not exist and no additional keyboard-specific options are needed to get the keyboard working. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-09-03Merge tag 'powerpc-4.3-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux Pull powerpc updates from Michael Ellerman: - support "hybrid" iommu/direct DMA ops for coherent_mask < dma_mask from Benjamin Herrenschmidt - EEH fixes for SRIOV from Gavin - introduce rtas_get_sensor_fast() for IRQ handlers from Thomas Huth - use hardware RNG for arch_get_random_seed_* not arch_get_random_* from Paul Mackerras - seccomp filter support from Michael Ellerman - opal_cec_reboot2() handling for HMIs & machine checks from Mahesh Salgaonkar - add powerpc timebase as a trace clock source from Naveen N. Rao - misc cleanups in the xmon, signal & SLB code from Anshuman Khandual - add an inline function to update POWER8 HID0 from Gautham R. Shenoy - fix pte_pagesize_index() crash on 4K w/64K hash from Michael Ellerman - drop support for 64K local store on 4K kernels from Michael Ellerman - move dma_get_required_mask() from pnv_phb to pci_controller_ops from Andrew Donnellan - initialize distance lookup table from drconf path from Nikunj A Dadhania - enable RTC class support from Vaibhav Jain - disable automatically blocked PCI config from Gavin Shan - add LEDs driver for PowerNV platform from Vasant Hegde - fix endianness issues in the HVSI driver from Laurent Dufour - kexec endian fixes from Samuel Mendoza-Jonas - fix corrupted pdn list from Gavin Shan - fix fenced PHB caused by eeh_slot_error_detail() from Gavin Shan - Freescale updates from Scott: Highlights include 32-bit memcpy/memset optimizations, checksum optimizations, 85xx config fragments and updates, device tree updates, e6500 fixes for non-SMP, and misc cleanup and minor fixes. - a ton of cxl updates & fixes: - add explicit precision specifiers from Rasmus Villemoes - use more common format specifier from Rasmus Villemoes - destroy cxl_adapter_idr on module_exit from Johannes Thumshirn - destroy afu->contexts_idr on release of an afu from Johannes Thumshirn - compile with -Werror from Daniel Axtens - EEH support from Daniel Axtens - plug irq_bitmap getting leaked in cxl_context from Vaibhav Jain - add alternate MMIO error handling from Ian Munsie - allow release of contexts which have been OPENED but not STARTED from Andrew Donnellan - remove use of macro DEFINE_PCI_DEVICE_TABLE from Vaishali Thakkar - release irqs if memory allocation fails from Vaibhav Jain - remove racy attempt to force EEH invocation in reset from Daniel Axtens - fix + cleanup error paths in cxl_dev_context_init from Ian Munsie - fix force unmapping mmaps of contexts allocated through the kernel api from Ian Munsie - set up and enable PSL Timebase from Philippe Bergheaud * tag 'powerpc-4.3-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (140 commits) cxl: Set up and enable PSL Timebase cxl: Fix force unmapping mmaps of contexts allocated through the kernel api cxl: Fix + cleanup error paths in cxl_dev_context_init powerpc/eeh: Fix fenced PHB caused by eeh_slot_error_detail() powerpc/pseries: Cleanup on pci_dn_reconfig_notifier() powerpc/pseries: Fix corrupted pdn list powerpc/powernv: Enable LEDS support powerpc/iommu: Set default DMA offset in dma_dev_setup cxl: Remove racy attempt to force EEH invocation in reset cxl: Release irqs if memory allocation fails cxl: Remove use of macro DEFINE_PCI_DEVICE_TABLE powerpc/powernv: Fix mis-merge of OPAL support for LEDS driver powerpc/powernv: Reset HILE before kexec_sequence() powerpc/kexec: Reset secondary cpu endianness before kexec powerpc/hvsi: Fix endianness issues in the HVSI driver leds/powernv: Add driver for PowerNV platform powerpc/powernv: Create LED platform device powerpc/powernv: Add OPAL interfaces for accessing and modifying system LED states powerpc/powernv: Fix the log message when disabling VF cxl: Allow release of contexts which have been OPENED but not STARTED ...
2015-08-20macintosh/therm_windtunnel: Export OF module alias informationJavier Martinez Canillas
The I2C core always reports the MODALIAS uevent as "i2c:<client name" regardless if the driver was matched using the I2C id_table or the of_match_table. So technically there's no need for a driver to export the OF table since currently it's not used. In fact, the I2C device ID table is mandatory for I2C drivers since a i2c_device_id is passed to the driver's probe function even if the I2C core used the OF table to match the driver. And since the I2C core uses different tables, OF-only drivers needs to have duplicated data that has to be kept in sync and also the dev node compatible manufacturer prefix is stripped when reporting the MODALIAS. To avoid the above, the I2C core behavior may be changed in the future to not require an I2C device table for OF-only drivers and report the OF module alias. So, it's better to also export the OF table to prevent breaking module autoloading if that happens. Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-08-20macintosh/therm_windtunnel: Export I2C module alias informationJavier Martinez Canillas
The I2C core always reports the MODALIAS uevent as "i2c:<client name" regardless if the driver was matched using the I2C id_table or the of_match_table. So the driver needs to export the I2C table and this be built into the module or udev won't have the necessary information to auto load the correct module when the device is added. Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-08-06windfarm: remove three exported but unused functionsPaul Bolle
wf_find_control(), wf_find_sensor(), and wf_is_overtemp() are exported but unused. Remove these three functions. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-08-06windfarm: make wf_critical_overtemp() staticPaul Bolle
wf_critical_overtemp() is exported. But nothing uses that export. That's unsurprising because there's no header that defines it. Stop exporting that function and make it static. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-08-06windfarm: decrement client count when unregisteringPaul Bolle
wf_unregister_client() increments the client count when a client unregisters. That is obviously incorrect. Decrement that client count instead. Fixes: 75722d3992f5 ("[PATCH] ppc64: Thermal control for SMU based machines") Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-07-23macintosh/ans-lcd: fix build failure after module_init/exit relocationLuis Henriques
After commit 0fd972a7d91d ("module: relocate module_init from init.h to module.h") ans-lcd module fails to build with: drivers/macintosh/ans-lcd.c:201:1: warning: data definition has no type or storage class [enabled by default] module_init(anslcd_init); ^ drivers/macintosh/ans-lcd.c:201:1: error: type defaults to 'int' in declaration of 'module_init' [-Werror=implicit-int] drivers/macintosh/ans-lcd.c:201:1: warning: parameter names (without types) in function declaration [enabled by default] drivers/macintosh/ans-lcd.c:202:1: warning: data definition has no type or storage class [enabled by default] module_exit(anslcd_exit); ^ drivers/macintosh/ans-lcd.c:202:1: error: type defaults to 'int' in declaration of 'module_exit' [-Werror=implicit-int] drivers/macintosh/ans-lcd.c:202:1: warning: parameter names (without types) in function declaration [enabled by default] drivers/macintosh/ans-lcd.c:155:1: warning: 'anslcd_init' defined but not used [-Wunused-function] anslcd_init(void) ^ drivers/macintosh/ans-lcd.c:195:1: warning: 'anslcd_exit' defined but not used [-Wunused-function] anslcd_exit(void) ^ This commit fixes it by replacing linux/init.h by linux/module.h. Fixes: 0fd972a7d91d ("module: relocate module_init from init.h to module.h") Signed-off-by: Luis Henriques <luis.henriques@canonical.com> Acked-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-15macintosh/nvram: Remove as unusedFinn Thain
The full history Linux tree says it was moved: commit 17c6f4635bea74e110ab3558d408c9cd218c568a Author: Benjamin Herrenschmidt <benh@kernel.crashing.org> Date: Fri Feb 6 14:20:56 2004 +1100 ppc32: Rework nvram management move drivers/macintosh/nvram.c to drivers/char/generic_nvram.c, update platform hooks, fix powermac nvram driver for newer machines But it's still there, and not buildable, so remove it. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-04-07Merge branch 'next-remove-ldst' of ↵Michael Ellerman
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc into next
2015-03-25powerpc/pmac: replace current->state by set_current_state()Fabian Frederick
Use helper functions to access current->state. Direct assignments are prone to races and therefore buggy. current->state = TASK_RUNNING can be replaced by __set_current_state() Thanks to Peter Zijlstra for the exact definition of the problem. Suggested-By: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2015-03-25drivers/macintosh: Delete an unnecessary check before the function call ↵Markus Elfring
"of_node_put" The of_node_put() function tests whether its argument is NULL and then returns immediately. Thus the test around the call is not needed. This issue was detected by using the Coccinelle software. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2015-03-23powerpc: Move Power Macintosh drivers to generic byteswappersDavid Gibson
ppc has special instruction forms to efficiently load and store values in non-native endianness. These can be accessed via the arch-specific {ld,st}_le{16,32}() inlines in arch/powerpc/include/asm/swab.h. However, gcc is perfectly capable of generating the byte-reversing load/store instructions when using the normal, generic cpu_to_le*() and le*_to_cpu() functions eaning the arch-specific functions don't have much point. Worse the "le" in the names of the arch specific functions is now misleading, because they always generate byte-reversing forms, but some ppc machines can now run a little-endian kernel. To start getting rid of the arch-specific forms, this patch removes them from all the old Power Macintosh drivers, replacing them with the generic byteswappers. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2015-03-17powerpc/via-pmu: fix OF node leak in Keylargo initPhil Carmody
If we of_find_node_by_name() then we must of_node_put() too. Signed-off-by: Phil Carmody <pc+lkml@asdf.org> Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2015-03-17powerpc/via-pmu: fix error path in find_via_pmu()Phil Carmody
Cleanup was not in the reverse order from the set-up, so not all the gotos made sense, and also it was being avoided completely upon failure of init_pmu(). Signed-off-by: Phil Carmody <pc+lkml@asdf.org> Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-12-19macintosh: therm_pm72: delete deprecated driverWolfram Sang
The new driver is around for more than 2 years now, so the old one can go. Getting rid of it helps the removal of the legacy .attach_adapter callback of the I2C subsystem. Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-10-20macintosh: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-09-25powerpc: Move via-cuda symbol exports next to function definitionsAnton Blanchard
Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2014-09-25powerpc: Move adb symbol exports next to function definitionsAnton Blanchard
2014-08-07Merge tag 'backlight-for-linus-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lee/backlight Pull backlight changes from Lee Jones: Changes to existing drivers: - remove get brightness implementations in via-pmu-backlight samsung-q10 aat2870_bl ams369fg06 bd6107 gpio_backlight ld9040 lp855x_bl lp8788_bl lv5207lp pandora_bl pwm_bl s6e63m0 tps65217_bl aty128fb atyfb_base radeon_backlight s6e8ax0 nv_backlight riva/fbdev - improve error handling in jornada720_lcd - make use of new 'get optional' GPIO command in pwm_bl - fix sparse warning in ipaq_micro_bl New drivers/supported devices: - new driver for iPAQ" * tag 'backlight-for-linus-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/backlight: backlight: ipaq_micro: Fix sparse non static symbol warning backlight: Add driver for iPAQ micro backlight backlight: pwm-backlight: Use devm_gpiod_get_optional() backlight: jornada720: Minimise code duplication and handle errors better backlight: Show brightness even if get_brightness is not implemented backlight: Remove trivial get_brightness implementations
2014-06-24powerpc/macintosh/smu.c: Fix closing brace followed by ifRasmus Villemoes
A closing brace followed by "if" is almost certainly a mistake. Maybe "else if" was meant, but in this case it doesn't really matter. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-06-23backlight: Remove trivial get_brightness implementationsAndrzej Hajda
Since backlight core returns props.brightness in case get_brightness is not implemented trivial implementations are not needed anymore. Acked-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-05-20macintosh/windfarm_pm121.c: Fix for possible null pointer dereferenceRickard Strandqvist
There is otherwise a risk of a possible null pointer dereference. Was largely found by using a static code analysis program called cppcheck. Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-03-07macintosh/adb: Change platform power management to use dev_pm_opsShuah Khan
Change adb platform driver to register pm ops using dev_pm_ops instead of legacy pm_ops. .pm hooks call existing legacy suspend and resume interfaces by passing in the right pm state. Signed-off-by: Shuah Khan <shuah.kh@samsung.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-03-07macintosh/adb: Fixed some coding style problemsBrandon Stewart
Signed-off-by: Brandon Stewart <stewartb2@gmail.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-01-27Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc updates from Ben Herrenschmidt: "So here's my next branch for powerpc. A bit late as I was on vacation last week. It's mostly the same stuff that was in next already, I just added two patches today which are the wiring up of lockref for powerpc, which for some reason fell through the cracks last time and is trivial. The highlights are, in addition to a bunch of bug fixes: - Reworked Machine Check handling on kernels running without a hypervisor (or acting as a hypervisor). Provides hooks to handle some errors in real mode such as TLB errors, handle SLB errors, etc... - Support for retrieving memory error information from the service processor on IBM servers running without a hypervisor and routing them to the memory poison infrastructure. - _PAGE_NUMA support on server processors - 32-bit BookE relocatable kernel support - FSL e6500 hardware tablewalk support - A bunch of new/revived board support - FSL e6500 deeper idle states and altivec powerdown support You'll notice a generic mm change here, it has been acked by the relevant authorities and is a pre-req for our _PAGE_NUMA support" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (121 commits) powerpc: Implement arch_spin_is_locked() using arch_spin_value_unlocked() powerpc: Add support for the optimised lockref implementation powerpc/powernv: Call OPAL sync before kexec'ing powerpc/eeh: Escalate error on non-existing PE powerpc/eeh: Handle multiple EEH errors powerpc: Fix transactional FP/VMX/VSX unavailable handlers powerpc: Don't corrupt transactional state when using FP/VMX in kernel powerpc: Reclaim two unused thread_info flag bits powerpc: Fix races with irq_work Move precessing of MCE queued event out from syscall exit path. pseries/cpuidle: Remove redundant call to ppc64_runlatch_off() in cpu idle routines powerpc: Make add_system_ram_resources() __init powerpc: add SATA_MV to ppc64_defconfig powerpc/powernv: Increase candidate fw image size powerpc: Add debug checks to catch invalid cpu-to-node mappings powerpc: Fix the setup of CPU-to-Node mappings during CPU online powerpc/iommu: Don't detach device without IOMMU group powerpc/eeh: Hotplug improvement powerpc/eeh: Call opal_pci_reinit() on powernv for restoring config space powerpc/eeh: Add restore_config operation ...
2014-01-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k Pull m68k updates from Geert Uytterhoeven: - Zorro bus cleanups and UAPI revival - Bootinfo cleanups and UAPI revival - Kexec support - Memory size reductions and bug fixes for multi-platform kernels - Polled interrupt support for Atari EtherNAT, EtherNEC and NetUSBee - Machine-specific random_get_entropy() - Defconfig updates and cleanups * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: (46 commits) m68k/mac: Make SCC reset work more reliably m68k/irq - Use polled IRQ flag for MFP timer cascaded interrupts m68k: Update defconfigs for v3.13-rc1 m68k/defconfig: Enable EARLY_PRINTK m68k/mm: kmap spelling/grammar fixes m68k: Convert arch/m68k/kernel/traps.c to pr_*() m68k: Convert arch/m68k/mm/fault.c to pr_*() m68k/mm: Check for mm != NULL in do_page_fault() debug code m68k/defconfig: Disable /sbin/hotplug fork-bomb by default m68k/atari: Hide RTC_PORT() macro from rtc-cmos m68k/amiga,atari: Fix specifying multiple debug= parameters m68k/defconfig: Use ext4 for ext2/ext3 file systems m68k: Add support to export bootinfo in procfs m68k: Add kexec support m68k/mac: Mark Mac IIsi ADB driver BROKEN m68k/amiga: Provide mach_random_get_entropy() m68k: Add infrastructure for machine-specific random_get_entropy() m68k/atari: Call paging_init() before nf_init() m68k: Remove superfluous inclusions of <asm/bootinfo.h> m68k/UAPI: Use proper types (endianness/size) in <asm/bootinfo*.h> ...
2013-12-08m68k/mac: Mark Mac IIsi ADB driver BROKENGeert Uytterhoeven
As reported by Finn Thain, the Mac IIsi ADB driver should be disabled because it will crash. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2013-12-05powerpc/windfarm: Remove superfluous name castsGeert Uytterhoeven
wf_sensor.name is "const char *" Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: linuxppc-dev@lists.ozlabs.org Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-11-27powerpc/windfarm: Fix XServe G5 fan control Makefile issueBenjamin Herrenschmidt
We are missing building windfarm_max6690_sensor.o when building CONFIG_WINDFARM_RM31. Usually all the windfarm drivers are built and thus this isn't a problem but some more "tailored" setups (Gentoo ?) building only that driver are not working because the require sensor module is missing. Reported-by: Stanislav Ponomarev <devhexorg@gmail.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-11-12Merge tag 'devicetree-for-3.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull devicetree updates from Rob Herring: "DeviceTree updates for 3.13. This is a bit larger pull request than usual for this cycle with lots of clean-up. - Cross arch clean-up and consolidation of early DT scanning code. - Clean-up and removal of arch prom.h headers. Makes arch specific prom.h optional on all but Sparc. - Addition of interrupts-extended property for devices connected to multiple interrupt controllers. - Refactoring of DT interrupt parsing code in preparation for deferred probe of interrupts. - ARM cpu and cpu topology bindings documentation. - Various DT vendor binding documentation updates" * tag 'devicetree-for-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (82 commits) powerpc: add missing explicit OF includes for ppc dt/irq: add empty of_irq_count for !OF_IRQ dt: disable self-tests for !OF_IRQ of: irq: Fix interrupt-map entry matching MIPS: Netlogic: replace early_init_devtree() call of: Add Panasonic Corporation vendor prefix of: Add Chunghwa Picture Tubes Ltd. vendor prefix of: Add AU Optronics Corporation vendor prefix of/irq: Fix potential buffer overflow of/irq: Fix bug in interrupt parsing refactor. of: set dma_mask to point to coherent_dma_mask of: add vendor prefix for PHYTEC Messtechnik GmbH DT: sort vendor-prefixes.txt of: Add vendor prefix for Cadence of: Add empty for_each_available_child_of_node() macro definition arm/versatile: Fix versatile irq specifications. of/irq: create interrupts-extended property microblaze/pci: Drop PowerPC-ism from irq parsing of/irq: Create of_irq_parse_and_map_pci() to consolidate arch code. of/irq: Use irq_of_parse_and_map() ...
2013-10-31powerpc/pmu: Fix ADB_PMU_LED_IDE dependenciesChristian Kujau
for quite some time the following is printed (twice) after doing "make oldconfig": [...] scripts/kconfig/conf --oldconfig Kconfig warning: (ADB_PMU_LED_IDE) selects LEDS_TRIGGER_IDE_DISK which has unmet direct dependencies (NEW_LEDS && IDE_GD_ATA && LEDS_TRIGGERS) warning: (ADB_PMU_LED_IDE) selects LEDS_TRIGGER_IDE_DISK which has unmet direct dependencies (NEW_LEDS && IDE_GD_ATA && LEDS_TRIGGERS) The following patch causes ADB_PMU_LED to depend on IDE_GD_ATA, so that the options above are only available when IDE_GD_ATA is actually selected and thus eliminates the warning. Signed-off-by: Christian Kujau <lists@nerdbynature.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-10-09drivers: clean-up prom.h implicit includesRob Herring
Powerpc is a mess of implicit includes by prom.h. Add the necessary explicit includes to drivers in preparation of prom.h cleanup. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Grant Likely <grant.likely@linaro.org>
2013-08-14macintosh/ams: Replace strict_strtoul() with kstrtoul()Jingoo Han
The usage of strict_strtoul() is not preferred, because strict_strtoul() is obsolete. Thus, kstrtoul() should be used. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-08-01powerpc/windfarm: Fix noisy slots-fan on Xserve (rm31)Aaro Koskinen
slots-fan on G5 Xserve is always running at full speed with windfarm_rm31 driver, resulting in a very high acoustic noise level. It seems the fan parameters are incorrect, and have been copied from the Drive Bay fan (RPM, not present on rm31) of the legacy therm_pm72 driver. This patch changes the parameters to match the Slots fan (PWM) of therm_pm72. With the patch, slots-fan speed drops from 99% to 19% during normal use, and slots-temp settle to ~42'C. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> CC: <stable@vger.kernel.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-07-01macintosh/windfarm: Remove obsolete cleanup for clientdataWolfram Sang
A few new i2c-drivers came into the kernel which clear the clientdata-pointer on exit or error. This is obsolete meanwhile, the core will do it. Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-07-01mac: Make cuda_init_via() __initGeert Uytterhoeven
cuda_init_via() is called from find_via_cuda() only, which is __init. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-07-01macintosh: Convert use of typedef ctl_table to struct ctl_tableJoe Perches
This typedef is unnecessary and should just be removed. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-07-01powerpc/windfarm: Fix overtemperature clearingAaro Koskinen
With pm81/pm91/pm121, when the overtemperature state is entered, and when it remains on after skipped ticks, the driver will try to leave it too soon (immediately on the next tick). This is because the active FAILURE_OVERTEMP state is not visible in "new_failure" variable of the current tick. Furthermore, the driver will keep trying to clear condition in subsequent ticks as FAILURE_OVERTEMP remains set in the "last_failure" variable. These will start to trigger WARNINGS from windfarm core: [ 100.082735] windfarm: Clamping CPU frequency to minimum ! [ 100.108132] windfarm: Overtemp condition detected ! [ 101.952908] windfarm: Overtemp condition cleared ! [...] [ 102.980388] WARNING: at drivers/macintosh/windfarm_core.c:463 [...] [ 103.982227] WARNING: at drivers/macintosh/windfarm_core.c:463 [...] [ 105.030494] WARNING: at drivers/macintosh/windfarm_core.c:463 [...] [ 105.973666] WARNING: at drivers/macintosh/windfarm_core.c:463 [...] [ 106.977913] WARNING: at drivers/macintosh/windfarm_core.c:463 Fix by adding a helper global variable. We leave the overtemp state only after all failure bits have been cleared. I saw this error on iMac G5 iSight (pm121). Also pm81/pm91 are fixed based on the observation that these are almost identical/copy-pasted code. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
