path: root/drivers/mailbox
2015-09-05Merge branch 'mailbox-for-next' of ↵Linus Torvalds
git://git.linaro.org/landing-teams/working/fujitsu/integration Pull mailbox updates from Jassi Brar: "Mainly we move from jiffy based timer to HRTIMER for finer control over polling. Then a controller reduces its polling period from 10 to 1ms" * 'mailbox-for-next' of git://git.linaro.org/landing-teams/working/fujitsu/integration: mailbox: arm_mhu: reduce txpoll_period from 10ms to 1 ms mailbox: switch to hrtimer for tx_complete polling mailbox: Drop owner assignment from platform_driver
2015-09-01Merge tag 'pm+acpi-4.3-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management and ACPI updates from Rafael Wysocki: "From the number of commits perspective, the biggest items are ACPICA and cpufreq changes with the latter taking the lead (over 50 commits). On the cpufreq front, there are many cleanups and minor fixes in the core and governors, driver updates etc. We also have a new cpufreq driver for Mediatek MT8173 chips. ACPICA mostly updates its debug infrastructure and adds a number of fixes and cleanups for a good measure. The Operating Performance Points (OPP) framework is updated with new DT bindings and support for them among other things. We have a few updates of the generic power domains framework and a reorganization of the ACPI device enumeration code and bus type operations. And a lot of fixes and cleanups all over. Included is one branch from the MFD tree as it contains some PM-related driver core and ACPI PM changes a few other commits are based on. Specifics: - ACPICA update to upstream revision 20150818 including method tracing extensions to allow more in-depth AML debugging in the kernel and a number of assorted fixes and cleanups (Bob Moore, Lv Zheng, Markus Elfring). - ACPI sysfs code updates and a documentation update related to AML method tracing (Lv Zheng). - ACPI EC driver fix related to serialized evaluations of _Qxx methods and ACPI tools updates allowing the EC userspace tool to be built from the kernel source (Lv Zheng). - ACPI processor driver updates preparing it for future introduction of CPPC support and ACPI PCC mailbox driver updates (Ashwin Chaugule). - ACPI interrupts enumeration fix for a regression related to the handling of IRQ attribute conflicts between MADT and the ACPI namespace (Jiang Liu). - Fixes related to ACPI device PM (Mika Westerberg, Srinidhi Kasagar). - ACPI device registration code reorganization to separate the sysfs-related code and bus type operations from the rest (Rafael J Wysocki). - Assorted cleanups in the ACPI core (Jarkko Nikula, Mathias Krause, Andy Shevchenko, Rafael J Wysocki, Nicolas Iooss). - ACPI cpufreq driver and ia64 cpufreq driver fixes and cleanups (Pan Xinhui, Rafael J Wysocki). - cpufreq core cleanups on top of the previous changes allowing it to preseve its sysfs directories over system suspend/resume (Viresh Kumar, Rafael J Wysocki, Sebastian Andrzej Siewior). - cpufreq fixes and cleanups related to governors (Viresh Kumar). - cpufreq updates (core and the cpufreq-dt driver) related to the turbo/boost mode support (Viresh Kumar, Bartlomiej Zolnierkiewicz). - New DT bindings for Operating Performance Points (OPP), support for them in the OPP framework and in the cpufreq-dt driver plus related OPP framework fixes and cleanups (Viresh Kumar). - cpufreq powernv driver updates (Shilpasri G Bhat). - New cpufreq driver for Mediatek MT8173 (Pi-Cheng Chen). - Assorted cpufreq driver (speedstep-lib, sfi, integrator) cleanups and fixes (Abhilash Jindal, Andrzej Hajda, Cristian Ardelean). - intel_pstate driver updates including Skylake-S support, support for enabling HW P-states per CPU and an additional vendor bypass list entry (Kristen Carlson Accardi, Chen Yu, Ethan Zhao). - cpuidle core fixes related to the handling of coupled idle states (Xunlei Pang). - intel_idle driver updates including Skylake Client support and support for freeze-mode-specific idle states (Len Brown). - Driver core updates related to power management (Andy Shevchenko, Rafael J Wysocki). - Generic power domains framework fixes and cleanups (Jon Hunter, Geert Uytterhoeven, Rajendra Nayak, Ulf Hansson). - Device PM QoS framework update to allow the latency tolerance setting to be exposed to user space via sysfs (Mika Westerberg). - devfreq support for PPMUv2 in Exynos5433 and a fix for an incorrect exynos-ppmu DT binding (Chanwoo Choi, Javier Martinez Canillas). - System sleep support updates (Alan Stern, Len Brown, SungEun Kim). - rockchip-io AVS support updates (Heiko Stuebner). - PM core clocks support fixup (Colin Ian King). - Power capping RAPL driver update including support for Skylake H/S and Broadwell-H (Radivoje Jovanovic, Seiichi Ikarashi). - Generic device properties framework fixes related to the handling of static (driver-provided) property sets (Andy Shevchenko). - turbostat and cpupower updates (Len Brown, Shilpasri G Bhat, Shreyas B Prabhu)" * tag 'pm+acpi-4.3-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (180 commits) cpufreq: speedstep-lib: Use monotonic clock cpufreq: powernv: Increase the verbosity of OCC console messages cpufreq: sfi: use kmemdup rather than duplicating its implementation cpufreq: drop !cpufreq_driver check from cpufreq_parse_governor() cpufreq: rename cpufreq_real_policy as cpufreq_user_policy cpufreq: remove redundant 'policy' field from user_policy cpufreq: remove redundant 'governor' field from user_policy cpufreq: update user_policy.* on success cpufreq: use memcpy() to copy policy cpufreq: remove redundant CPUFREQ_INCOMPATIBLE notifier event cpufreq: mediatek: Add MT8173 cpufreq driver dt-bindings: mediatek: Add MT8173 CPU DVFS clock bindings PM / Domains: Fix typo in description of genpd_dev_pm_detach() PM / Domains: Remove unusable governor dummies PM / Domains: Make pm_genpd_init() available to modules PM / domains: Align column headers and data in pm_genpd_summary output powercap / RAPL: disable the 2nd power limit properly tools: cpupower: Fix error when running cpupower monitor PM / OPP: Drop unlikely before IS_ERR(_OR_NULL) PM / OPP: Fix static checker warning (broken 64bit big endian systems) ...
2015-08-26PCC: Disable compilation by defaultAshwin Chaugule
PCC is made selectable only by clients which use it. e.g. CPPC Default it to disabled so that it is not included accidentally on platforms which dont use it. Signed-off-by: Ashwin Chaugule <ashwin.chaugule@linaro.org> Reviewed-by: Al Stone <al.stone@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-08-25PCC: Initialize PCC Mailbox earlier at bootAshwin Chaugule
This change initializes the PCC Mailbox earlier than the ACPI processor driver. This enables drivers introduced in follow up patches (e.g. CPPC) to be probed via the ACPI processor driver interface. The CPPC probe requires the PCC channel to be initialized for it to query each CPUs performance capabilities. Signed-off-by: Ashwin Chaugule <ashwin.chaugule@linaro.org> Reviewed-by: Al Stone <al.stone@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-08-10mailbox: arm_mhu: reduce txpoll_period from 10ms to 1 msSudeep Holla
Since the mailbox core users hrtimers now, it can handle much higher resolutions. We can reduce the txpoll_period to 1 ms as the transmit usually takes just few microseconds. Reported-and-suggested-by: Juri Lelli <Juri.Lelli@arm.com> Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Jassi Brar <jaswinder.singh@linaro.org>
2015-08-10mailbox: switch to hrtimer for tx_complete pollingSudeep Holla
The mailbox core uses jiffy based timer to handle polling for the transmit completion. If the client/protocol have/support notification of the last packet transmit completion via ACK packet, then we tick the Tx state machine immediately in the callback. However if the client doesn't support that mechanism we might end-up waiting for atleast a jiffy even though the remote is ready to receive the next request. This patch switches the timer used for that polling from jiffy-based to hrtimer-based so that we can support polling at much higher time resolution. Reported-and-suggested-by: Juri Lelli <Juri.Lelli@arm.com> Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Jassi Brar <jaswinder.singh@linaro.org>
2015-08-07treewide: Fix typo in printkMasanari Iida
This patch fix spelling typo inv various part of sources. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.com>
2015-08-05mailbox: Drop owner assignment from platform_driverKrzysztof Kozlowski
platform_driver does not need to set an owner because platform_driver_register() will set it. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Lee Jones <lee@kernel.org> Reviewed-by: Eric Anholt <eric@anholt.net> Signed-off-by: Jassi Brar <jaswinder.singh@linaro.org>
2015-07-02Merge tag 'module_init-alternate_initcall-v4.1-rc8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull module_init replacement part two from Paul Gortmaker: "Replace module_init with appropriate alternate initcall in non modules. This series converts non-modular code that is using the module_init() call to hook itself into the system to instead use one of our alternate priority initcalls. Unlike the previous series that used device_initcall and hence was a runtime no-op, these commits change to one of the alternate initcalls, because (a) we have them and (b) it seems like the right thing to do. For example, it would seem logical to use arch_initcall for arch specific setup code and fs_initcall for filesystem setup code. This does mean however, that changes in the init ordering will be taking place, and so there is a small risk that some kind of implicit init ordering issue may lie uncovered. But I think it is still better to give these ones sensible priorities than to just assign them all to device_initcall in order to exactly preserve the old ordering. Thad said, we have already made similar changes in core kernel code in commit c96d6660dc65 ("kernel: audit/fix non-modular users of module_init in core code") without any regressions reported, so this type of change isn't without precedent. It has also got the same local testing and linux-next coverage as all the other pull requests that I'm sending for this merge window have got. Once again, there is an unused module_exit function removal that shows up as an outlier upon casual inspection of the diffstat" * tag 'module_init-alternate_initcall-v4.1-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: x86: perf_event_intel_pt.c: use arch_initcall to hook in enabling x86: perf_event_intel_bts.c: use arch_initcall to hook in enabling mm/page_owner.c: use late_initcall to hook in enabling lib/list_sort: use late_initcall to hook in self tests arm: use subsys_initcall in non-modular pl320 IPC code powerpc: don't use module_init for non-modular core hugetlb code powerpc: use subsys_initcall for Freescale Local Bus x86: don't use module_init for non-modular core bootflag code netfilter: don't use module_init/exit in core IPV4 code fs/notify: don't use module_init for non-modular inotify_user code mm: replace module_init usages with subsys_initcall in nommu.c
2015-06-16arm: use subsys_initcall in non-modular pl320 IPC codePaul Gortmaker
The drivers/mailbox/pl320-ipc.o is dependent on config PL320_MBOX which is declared as a bool. Hence the code is never going to be modular. So using module_init as an alias for __initcall can be somewhat misleading. Fix this up now, so that we can relocate module_init from init.h into module.h in the future. If we don't do this, we'd have to add module.h to obviously non-modular code, and that would be a worse thing. Also add an inclusion of init.h, as that was previously implicit. Note that direct use of __initcall is discouraged, vs. one of the priority categorized subgroups. As __initcall gets mapped onto device_initcall, our use of subsys_initcall (which seems to make sense for IPC code) will thus change this registration from level 6-device to level 4-subsys (i.e. slightly earlier). However no impact of that small difference is expected. Cc: Russell King <linux@arm.linux.org.uk> Cc: linux-arm-kernel@lists.infradead.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2015-06-13mailbox/bcm2835: Fix mailbox full detection.Eric Anholt
With the VC reader blocked and the ARM writing, MAIL0_STA reads empty permanently while MAIL1_STA goes from empty (0x40000000) to non-empty (0x00000001-0x00000007) to full (0x80000008). This bug ended up having no effect on us, because all of our transactions in the client driver were synchronous and under a mutex. Suggested-by: Phil Elwell <phil@raspberrypi.org> Signed-off-by: Eric Anholt <eric@anholt.net> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Jassi Brar <jaswinder.singh@linaro.org>
2015-06-11mailbox: Add ability for clients to request channels by nameLee Jones
This patch supplies a new framework API; mbox_request_channel_byname(). It works by supplying the usual client pointer as the first argument and a string as the second. The API will search the client's node for a 'mbox-names' property then request a channel in the normal way using the requested string's index as the expected second 'index' argument. Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Jassi Brar <jaswinder.singh@linaro.org>
2015-06-11mailbox: Enable BCM2835 mailbox supportLubomir Rintel
This mailbox driver provides a single mailbox channel to write 32-bit values to the VPU and get a 32-bit response. The Raspberry Pi firmware uses this mailbox channel to implement firmware calls, while Roku 2 (despite being derived from the same firmware tree) doesn't. The driver was originally submitted by Lubomir, based on the out-of-tree 2708 mailbox driver. Eric Anholt fixed it up for upstreaming, with the major functional change being that it now has no notion of multiple channels (since that is a firmware-dependent concept) and instead the raspberrypi-firmware driver will do that bit-twiddling in its own messages. [Jassi: made the 'mbox_chan_ops' struct as const and removed a redundant variable] Signed-off-by: Lubomir Rintel <lkundrak@v3.sk> Signed-off-by: Craig McGeachie <slapdau@yahoo.com.au> Signed-off-by: Eric Anholt <eric@anholt.net> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Jassi Brar <jaswinder.singh@linaro.org>
2015-05-12mailbox: Fix up error handling in mbox_request_channel()Benson Leung
mbox_request_channel() currently returns EBUSY in the event the controller is not present or if of_xlate() fails, but in neither case is EBUSY really appropriate. Return EPROBE_DEFER if the controller is not yet present and change of_xlate() to return an ERR_PTR instead of NULL so that the error can be propagated back to the caller of mbox_request_channel(). Signed-off-by: Benson Leung <bleung@chromium.org> Signed-off-by: Andrew Bresticker <abrestic@chromium.org> Acked-by: Suman Anna <s-anna@ti.com> Reviewed-by: Jon Hunter <jonathanh@nvidia.com> Tested-by: Jon Hunter <jonathanh@nvidia.com> Signed-off-by: Jassi Brar <jaswinder.singh@linaro.org>
2015-05-12mailbox: Make mbox_chan_ops constAndrew Bresticker
The mailbox controller's channel ops ought to be read-only. Update all the mailbox drivers to make their mbox_chan_ops const as well. Signed-off-by: Andrew Bresticker <abrestic@chromium.org> Cc: Ashwin Chaugule <ashwin.chaugule@linaro.org> Cc: Ley Foon Tan <lftan@altera.com> Acked-by: Suman Anna <s-anna@ti.com> Signed-off-by: Jassi Brar <jaswinder.singh@linaro.org>
2015-05-12mailbox: altera: Add dependency on HAS_IOMEMRichard Weinberger
Not all architectures have io memory. Fixes: drivers/built-in.o: In function `altera_mbox_probe': mailbox-altera.c:(.text+0x409fd2): undefined reference to `devm_ioremap_resource' Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Jassi Brar <jaswinder.singh@linaro.org>
2015-03-17mailbox: arm_mhu: add driver for ARM MHU controllerJassi Brar
Add driver for the ARM Primecell Message-Handling-Unit(MHU) controller. Signed-off-by: Jassi Brar <jaswinder.singh@linaro.org> Signed-off-by: Andy Green <andy.green@linaro.org> Signed-off-by: Vincent Yang <vincent.yang@socionext.com> Signed-off-by: Tetsuya Nuriya <nuriya.tetsuya@socionext.com>
2015-03-04Mailbox: Restructure and simplify PCC mailbox codeAshwin Chaugule
Previously the PCC driver depended on the client side to map the communication space base address. This region was was then used in the PCC driver and the client side. The client side used this region to read and write its data and the PCC driver used it to only write the PCC command. Removing this split simplifies the PCC driver a lot. This patch moves all communication region read/writes to the client side. The PCC clients can now drive the PCC mailbox controller via the mbox_client_txdone() method. Signed-off-by: Ashwin Chaugule <ashwin.chaugule@linaro.org>
2015-02-11Merge branch 'mailbox-devel' of ↵Linus Torvalds
git://git.linaro.org/landing-teams/working/fujitsu/integration Pull mailbox framework updates from Jassi Brar. * 'mailbox-devel' of git://git.linaro.org/landing-teams/working/fujitsu/integration: mailbox: Add Altera mailbox driver mailbox: check for bit set before polling Mailbox: Fix return value check in pcc_init()
2015-02-06mailbox: Add Altera mailbox driverLey Foon Tan
The Altera mailbox allows for interprocessor communication. It supports only one channel and work as either sender or receiver. Signed-off-by: Ley Foon Tan <lftan@altera.com>
2015-02-06mailbox: check for bit set before pollingJassi Brar
Before polling we just need to see if the TXDONE_BY_POLL bit is set in txdone_method. There may be another bit (method) specified as well, like TXDONE_BY_ACK. Signed-off-by: Jassi Brar <jassisinghbrar@gmail.com>
2015-02-06Mailbox: Fix return value check in pcc_init()Wei Yongjun
In case of error, the function platform_create_bundle() returns ERR_PTR() and never returns NULL. The NULL test in the return value check should be replaced with IS_ERR(). Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
2015-02-05ACPI / PCC: Use pr_debug() for debug messages in pcc_init()Rafael J. Wysocki
pcc_init() uses pr_err() to print two messages that are really debug and not interesting to users. Replace those pr_err() with pr_debug(). Reported-by: Cristian <caravena@gmail.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-11-27Mailbox: Add support for Platform Communication ChannelAshwin Chaugule
ACPI 5.0+ spec defines a generic mode of communication between the OS and a platform such as the BMC. This medium (PCC) is typically used by CPPC (ACPI CPU Performance management), RAS (ACPI reliability protocol) and MPST (ACPI Memory power states). This patch adds PCC support as a Mailbox Controller. As of ACPI v5.1 there is no provision for clients to lookup mailbox controllers in a way that Linux expects. e.g. in DT the clients can list the mailboxes they can associate with in the DT binding and then provide a unique index to lookup a channel within a mailbox. Since the ACPI spec doesn't have anything similar, we introduce a mailbox controller specific API so that when the client calls it, we know to lookup in the context of a specific controller. This also helps in keeping a consistent interface across DT and ACPI for such drivers. This patch implements basic PCC support using the ACPI v5.1 structures. IRQ mode support will be provided as follow up patches. Signed-off-by: Ashwin Chaugule <ashwin.chaugule@linaro.org> Reviewed-by: Mark Brown <broonie@kernel.org> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jassi Brar <jaswinder.singh@linaro.org>
2014-11-27mailbox/omap: adapt to the new mailbox frameworkSuman Anna
The OMAP mailbox driver and its existing clients (remoteproc for OMAP4+) are adapted to use the generic mailbox framework. The main changes for the adaptation are: - The tasklet used for Tx is replaced with the state machine from the generic mailbox framework. The workqueue used for processing the received messages stays intact for minimizing the effects on the OMAP mailbox clients. - The existing exported client API, omap_mbox_get, omap_mbox_put and omap_mbox_send_msg are deleted, as the framework provides equivalent functionality. A OMAP-specific omap_mbox_request_channel is added though to support non-DT way of requesting mailboxes. - The OMAP mailbox driver is integrated with the mailbox framework through the proper implementations of mbox_chan_ops, except for .last_tx_done and .peek_data. The OMAP mailbox driver does not need these ops, as it is completely interrupt driven. - The OMAP mailbox driver uses a custom of_xlate controller ops that allows phandles for the pargs specifier instead of indexing to avoid any channel registration order dependencies. - The new framework does not support multiple clients operating on a single channel, so the reference counting logic is simplified. - The remoteproc driver (current client) is adapted to use the new API. The notifier callbacks used within this client is replaced with the regular callbacks from the newer framework. - The exported OMAP mailbox API are limited to omap_mbox_save_ctx, omap_mbox_restore_ctx, omap_mbox_enable_irq & omap_mbox_disable_irq, with the signature modified to take in the new mbox_chan handle instead of the OMAP specific omap_mbox handle. The first 2 will be removed when the OMAP mailbox driver is adapted to runtime_pm. The other exported API omap_mbox_request_channel will be removed once existing legacy users are converted to DT. Signed-off-by: Suman Anna <s-anna@ti.com> Cc: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Jassi Brar <jaswinder.singh@linaro.org>
2014-11-27mailbox: add tx_prepare client callbackSudeep Holla
If the mailbox controller expects the payload is in place before initiating the transmit, then it's impossible to reuse the list maintained by core mailbox code currently. Maintaining another list for sending the message in the controller seems totally unnecessary as core mailbox library already provides that feature. This patch introduces tx_prepare callback in mbox_client which can be used by the core mailbox library before initiating the transaction through mbox->ops->send_data. The client driver can implement this callback to ensure the payload is copied to the shared memory. Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jassi Brar <jaswinder.singh@linaro.org>
2014-11-27mailbox: Don't unnecessarily re-arm the polling timerAndrew Bresticker
poll_txdone() will unconditionally re-arm the polling timer if there was an active request, even if the active request completed and no other requests were submitted. This is fixed by: - only re-arming the timer if the controller reported that the current transmission has not completed, and, - moving the call to poll_txdone() into msg_submit() so that the controller gets polled (and the timer re-armed, if necessary) whenever a new message is submitted. Signed-off-by: Andrew Bresticker <abrestic@chromium.org> Reviewed-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Jassi Brar <jaswinder.singh@linaro.org>
2014-11-03Merge branch 'platform/remove_owner' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux into driver-core-next Remove all .owner fields from platform drivers
2014-10-21Merge branch 'mailbox-for-linus' of ↵Linus Torvalds
git://git.linaro.org/landing-teams/working/fujitsu/integration Pull mailbox framework from Jassi Brar: "A framework for Mailbox controllers and clients have been cooking for more than a year now. Everybody in the CC list had been copied on patchset revisions and most of them have made sounds of approval, though just one concrete Reviewed-by. The patchset has also been in linux-next for a couple of weeks now and no conflict has been reported. The framework has the backing of at least 5 platforms, though I can't say if/when they upstream their drivers (some businesses have 'changed')" (Further acked-by by Arnd Bergmann and Suman Anna in the pull request thread) * 'mailbox-for-linus' of git://git.linaro.org/landing-teams/working/fujitsu/integration: dt: mailbox: add generic bindings doc: add documentation for mailbox framework mailbox: Introduce framework for mailbox mailbox: rename pl320-ipc specific mailbox.h
2014-10-20mailbox: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-10-08mailbox: Introduce framework for mailboxJassi Brar
Introduce common framework for client/protocol drivers and controller drivers of Inter-Processor-Communication (IPC). Client driver developers should have a look at include/linux/mailbox_client.h to understand the part of the API exposed to client drivers. Similarly controller driver developers should have a look at include/linux/mailbox_controller.h Reviewed-by: Mark Brown <broonie@linaro.org> Signed-off-by: Jassi Brar <jaswinder.singh@linaro.org>
2014-10-08mailbox: rename pl320-ipc specific mailbox.hSuman Anna
The patch 30058677 "ARM / highbank: add support for pl320 IPC" added a pl320 IPC specific header file as a generic mailbox.h. This file has been renamed appropriately to allow the introduction of the generic mailbox API framework. Acked-by: Mark Langsdorf <mark.langsdorf@calxeda.com> Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Suman Anna <s-anna@ti.com> Reviewed-by: Mark Brown <broonie@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2014-09-11mailbox/omap: add support for parsing dt devicesSuman Anna
Logic has been added to the OMAP2+ mailbox code to parse the mailbox dt nodes and construct the different sub-mailboxes associated with the instance. The DT representation of the sub-mailbox devices is different from legacy platform data representation to allow flexibility of interrupt configuration between Tx and Rx fifos (to also possibly allow simplex devices in the future). The DT representation gathers similar information that was being passed previously through the platform data, except for the interrupt type information, which is gathered through driver compatible match data. The non-DT support has to be maintained for now to not break OMAP3 legacy boot, and the legacy-style code will be cleaned up once OMAP3 is also converted to DT-boot only. Cc: Jassi Brar <jassisinghbrar@gmail.com> Cc: Rob Herring <robh+dt@kernel.org> Signed-off-by: Suman Anna <s-anna@ti.com> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-07-29mailbox/omap: add a parent structure for every IP instanceSuman Anna
A new structure, omap_mbox_device, is added to contain the global variables pertinent to a mailbox h/w IP block. This enables the support for having multiple instances of the same h/w IP block in the SoC. This is in preparation to support the DRA7 SoC, which is the first SoC in the OMAP family to have multiple mailbox IP instances. The changes include enhancements to the sub-mailbox registration logic and mbox startup sequencing, removing the usage of single global configuration variables for all h/w instances, and storing the registered sub-mailboxes with the parent mailbox device structure. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-07-29mailbox/omap: remove the private mailbox structureSuman Anna
The structure omap_mbox_priv is used previously to store arch specific (OMAP1 vs OMAP2+) data, and is no longer required to be maintained separately. Instead, absorb its elements into either the sub-mailbox device structure, omap_mbox, or the individual fifo descriptor structure, omap_mbox_fifo. The newmsg_bit and notfull_bit used on Rx and Tx fifos respectively are represented by the new intr_bit field in the fifo descriptor structure. The interrupt configuration registers are also moved into the fifo descriptor structure to allow the Rx and Tx fifos to use different interrupt lines/users. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-07-29mailbox/omap: consolidate OMAP mailbox driverSuman Anna
There is no need for a separate common OMAP mailbox module now that the OMAP1 mailbox driver has been removed. So, consolidate the two individual OMAP mailbox modules into a single driver. This streamlines the driver for converting to mailbox framework. The following are the main changes: - collapse mailbox-omap2.c into omap-mailbox.c - remove omap_mbox_ops and replace the ops calls with the equivalent functionality. - simplify the sub-mailbox startup/shutdown functionality, the one-time operations are moved into probe, and the pm_runtime_get_sync and pm_runtime_put_sync can be invoked without using a configuration counter. - move all definitions from private omap_mbox.h into the source code, and eliminate this internal header. - rename some variables that used the omap2_mbox prefix with a generic omap_mbox prefix. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-07-29mailbox/omap: simplify the fifo assignment by using macrosSuman Anna
The OMAP mailbox IP has two different type of interrupt configuration registers between OMAP4+ SoCs and OMAP2/3 SoCs. Simplify the current interrupt configuration by using a single macro that translates the two variants. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-07-29mailbox/omap: remove omap_mbox_type_t from mailbox opsSuman Anna
The type definition omap_mbox_type_t used for distinguishing OMAP1 from OMAP2+ mailboxes is no longer needed after the removal of OMAP1 mailbox driver, and has therefore been cleaned up. This cleanup also eliminates the need for the polling logic used for checking the transmit readiness. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-07-29mailbox/omap: remove OMAP1 mailbox driverSuman Anna
There are no existing users for OMAP1 mailbox driver in kernel. Commit ab6f775 "Removing dead OMAP_DSP" has cleaned up all the dead code related to the only possible user, including the creation of the mailbox platform device. Remove this stale driver so that the OMAP mailbox driver can be simplified and streamlined better for converting to mailbox framework. Signed-off-by: Suman Anna <s-anna@ti.com> Acked-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-07-29mailbox/omap: use devm_* interfacesSuman Anna
Use the various devm_ interfaces to simplify the cleanup in probe and remove functions in OMAP2+ mailbox driver. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-01-23drivers/mailbox/omap: make mbox->irq signed for error handlingDan Carpenter
There is a bug in omap2_mbox_probe() where we try do: mbox->irq = platform_get_irq(pdev, info->irq_id); if (mbox->irq < 0) { The problem is that mbox->irq is unsigned so the error handling doesn't work. I've changed it to a signed integer. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: Suman Anna <s-anna@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Omar Ramirez Luna <omar.ramirez@copitl.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-18mailbox: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure. Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Suman Anna <s-anna@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-06-11mailbox/omap: move the OMAP mailbox framework to driversSuman Anna
The mailbox hardware (in OMAP) uses a queued mailbox interrupt mechanism that provides a communication channel between processors through a set of registers and their associated interrupt signals by sending and receiving messages. The OMAP mailbox framework/driver code is moved to be under drivers/mailbox, in preparation for adapting to a common mailbox driver framework. This allows the build for OMAP mailbox to be enabled (it was disabled during the multi-platform support). As part of the migration from plat and mach code: - Kconfig symbols have been renamed to build OMAP1 or OMAP2+ drivers. - mailbox.h under plat-omap/plat/include has been split into a public and private header files. The public header has only the API related functions and types. - The module name mailbox.ko from plat-omap is changed to omap-mailbox.ko - The module name mailbox_mach.ko from mach-omapX is changed as mailbox_omap1.ko for OMAP1 mailbox_omap2.ko for OMAP2+ Cc: Tony Lindgren <tony@atomide.com> [gregkh@linuxfoundation.org: ack for staging part] Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Omar Ramirez Luna <omar.ramirez@copitl.com> Signed-off-by: Suman Anna <s-anna@ti.com>
2013-03-04mailbox, pl320-ipc: remove __init from probe functionMark Langsdorf
Avoids a section mismatch. Signed-off-by: Mark Langsdorf <mark.langsdorf@calxeda.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-02-02ARM / highbank: add support for pl320 IPCRob Herring
The pl320 IPC allows for interprocessor communication between the highbank A9 and the EnergyCore Management Engine. The pl320 implements a straightforward mailbox protocol. Signed-off-by: Mark Langsdorf <mark.langsdorf@calxeda.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
