path: root/drivers/mcb
2018-03-14mcb: add Altera PCI ID to mcb-pciJohannes Thumshirn
Some older PCI attached MEN FPGAs use an Altera PCI Vendor ID instead of the MEN one. Add it to the PCI ID table so the driver automatically attaches to it. Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Reported-by: Ben Turner <ben.turner@21net.com> Tested-by: Ben Turner <ben.turner@21net.com> Cc: Andreas Geißler <andreas.geissler@men.de> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-05Merge tag 'char-misc-4.14-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver updates from Greg KH: "Here is the big char/misc driver update for 4.14-rc1. Lots of different stuff in here, it's been an active development cycle for some reason. Highlights are: - updated binder driver, this brings binder up to date with what shipped in the Android O release, plus some more changes that happened since then that are in the Android development trees. - coresight updates and fixes - mux driver file renames to be a bit "nicer" - intel_th driver updates - normal set of hyper-v updates and changes - small fpga subsystem and driver updates - lots of const code changes all over the driver trees - extcon driver updates - fmc driver subsystem upadates - w1 subsystem minor reworks and new features and drivers added - spmi driver updates Plus a smattering of other minor driver updates and fixes. All of these have been in linux-next with no reported issues for a while" * tag 'char-misc-4.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (244 commits) ANDROID: binder: don't queue async transactions to thread. ANDROID: binder: don't enqueue death notifications to thread todo. ANDROID: binder: Don't BUG_ON(!spin_is_locked()). ANDROID: binder: Add BINDER_GET_NODE_DEBUG_INFO ioctl ANDROID: binder: push new transactions to waiting threads. ANDROID: binder: remove proc waitqueue android: binder: Add page usage in binder stats android: binder: fixup crash introduced by moving buffer hdr drivers: w1: add hwmon temp support for w1_therm drivers: w1: refactor w1_slave_show to make the temp reading functionality separate drivers: w1: add hwmon support structures eeprom: idt_89hpesx: Support both ACPI and OF probing mcb: Fix an error handling path in 'chameleon_parse_cells()' MCB: add support for SC31 to mcb-lpc mux: make device_type const char: virtio: constify attribute_group structures. Documentation/ABI: document the nvmem sysfs files lkdtm: fix spelling mistake: "incremeted" -> "incremented" perf: cs-etm: Fix ETMv4 CONFIGR entry in perf.data file nvmem: include linux/err.h from header ...
2017-08-31mcb: Fix an error handling path in 'chameleon_parse_cells()'Christophe JAILLET
If 'chameleon_get_bar()' fails, we will return 0, which mean success. We should return the corresponding error code instead. Remove the useless initialisation of 'ret' which was hiding the issue. (if 'ret' is not set, gcc generates a warning ("warning: ‘ret’ may be used uninitialized in this function")) Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr> Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-31MCB: add support for SC31 to mcb-lpcMichael Moese
This patch adds the resources and DMI ID's for the MEN SC31, which uses a different address region to map the LPC bus than the one used for the existing SC24. Signed-off-by: Michael Moese <michael.moese@men.de> [jth add stable tag] Cc: <stable@vger.kernel.org> (v4.9+) Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-28mcb: introduce mcb_get_resource()Johannes Thumshirn
Introduce mcb_get_resource() as a common accessor to a mcb device's memory or IRQ resources. Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-15mcb: fix compiler warning logical-op in mcb-parse.cMichael Moese
The expression was clearly wrong, the logical AND of expressions must be changed to a logical OR. Reported-by: David Binderman <dcb314@hotmail.com> Signed-off-by: Michael Moese <michael.moese@men.de> Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-27mcb: Add a dma_device to mcb_deviceMichael Moese
When performing DMA operations on a MCB device, the device needed for using the DMA API is "mcb_device->bus_carrier". This is rather lengthy, so a shortcut is introduced to struct mcb_device in order to ensure the MCB device driver uses the correct device for DMA operations. Signed-off-by: Michael Moese <michael.moese@men.de> Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-27mcb: Enable PCI bus mastering by defaultMichael Moese
In order to successfully perform DMA operations on PCI devices, it is necessary to enble PCI bus mastering, so enable it by default. Signed-off-by: Michael Moese <michael.moese@men.de> Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-31mcb: remove sub-device handling codeJohannes Thumshirn
The MEN Chameleon specification states that a chameleon FPGA can include a bridge descriptor, which then opens up a new bus behind this bridge. MCB included subdevice handling code in the core, but no support for bus descriptors in the parser, due to a lack of hardware access. As this is technically dead code, but it gets executed on a device add, I've decided to remove it. Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-31mcb: Added bar descriptor support for non PCI bus MCB carrierAndreas Werner
Added support for the bar descriptor. This type is used for FPGAs connect to the LPC or to a non PCI bus. The Bar descriptor could have a maximum of 6 BARs. Each of the devices within the FPGA could be mapped to a different BAR. The BAR descriptor is comparable to the PCI header. Signed-off-by: Andreas Werner <andreas.werner@men.de> [ free bar descriptor in the non-error case ] Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-31mcb: Added support for LPC or non PCI based MCB carrierAndreas Werner
Add support for MCB bases FPGAs connected to the LPC or non PCI Bus. This driver currently supports the SC24 board. The FPGA is connected to the LPC bus and is identified using the BIOS DMI string. Signed-off-by: Andreas Werner <andreas.werner@men.de> Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-13mcb: Acquire reference to carrier module in coreJohannes Thumshirn
Acquire a reference to the carrier's kernel module in bus code, so it can't be removed from the kernel while it still has a bus and thus possibly devices attached to it. Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Reported-by: Andreas Werner <andreas.werner@men.de> Tested-by: Andreas Werner <andreas.werner@men.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-13mcb: Acquire reference to device in probeJohannes Thumshirn
mcb_probe() does not aqcuire a reference to the probed device but drops one when removing the device. As it is actually using the device, it should grab a reference via get_device(). This could lead to a panic found with a rmmod/modprobe stress test Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Reported-by: Andreas Werner <andreas.werner@men.de> Tested-by: Andreas Werner <andreas.werner@men.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-03mcb: Delete num_cells variable which is not requiredAndreas Werner
The num_cells variable is only used in the dev_dbg print, but we can directly use the ret variable which also includes the same value. Signed-off-by: Andreas Werner <andreas.werner@men.de> Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-03mcb: Fixed bar number assignment for the gddAndreas Werner
The bar number is found in reg2 within the gdd. Therefore we need to change the assigment from reg1 to reg2 which is the correct location. Signed-off-by: Andreas Werner <andreas.werner@men.de> Fixes: '3764e82e5' drivers: Introduce MEN Chameleon Bus Cc: stable@vger.kernel.org # v3.15+ Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-03mcb: Replace ioremap and request_region with the devm versionAndreas Werner
Replaced ioremap with devm_ioremap and request_mem_region with devm_request_mem_region. This makes the code much more cleaner. Signed-off-by: Andreas Werner <andreas.werner@men.de> Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-03mcb: Implement bus->dev.release callbackJohannes Thumshirn
The mcb_bus structure previously was released in mcb_release_bus. This lead to the following warning on module unload: ------------[ cut here ]------------ WARNING: CPU: 1 PID: 2032 at drivers/base/core.c:251 device_release+0x73/0x90 Device 'mcb:0' does not have a release() function, it is broken and must be fixed. Modules linked in: men_z135_uart mcb_pci(-) mcb CPU: 1 PID: 2032 Comm: rmmod Not tainted 4.6.0-rc4+ #3 Hardware name: N/A N/A/COMe-mBTi10, BIOS MVV1R921 X64 10/14/2015 00000286 00000286 c0117de4 c12d6f16 c0117e2c c18be0d3 c0117dfc c104f6e1 000000fb f5ccbe08 f5ccbe00 f5c64600 c0117e18 c104f728 00000009 00000000 c0117e10 c18db674 c0117e2c c0117e3c c13ce5c3 c18be0d3 000000fb c18db674 Call Trace: [<c12d6f16>] dump_stack+0x47/0x61 [<c104f6e1>] __warn+0xc1/0xe0 [<c104f728>] warn_slowpath_fmt+0x28/0x30 [<c13ce5c3>] device_release+0x73/0x90 [<c12d92e4>] kobject_release+0x34/0x80 [<c12d929d>] ? kobject_del+0x2d/0x40 [<c12d9205>] kobject_put+0x25/0x50 [<c13ce77f>] put_device+0xf/0x20 [<c13d114b>] klist_devices_put+0xb/0x10 [<c1752673>] klist_next+0x73/0xf0 [<c13d1140>] ? unbind_store+0x100/0x100 [<f8a23370>] ? mcb_bus_add_devices+0x30/0x30 [mcb] [<c13d0a81>] bus_for_each_dev+0x51/0x80 [<f8a23319>] mcb_release_bus+0x19/0x40 [mcb] [<f8a23370>] ? mcb_bus_add_devices+0x30/0x30 [mcb] [<f8a2b033>] mcb_pci_remove+0x13/0x20 [mcb_pci] [<c130d358>] pci_device_remove+0x28/0xb0 [<c13d201b>] __device_release_driver+0x7b/0x110 [<c13d2847>] driver_detach+0x87/0x90 [<c13d1b9b>] bus_remove_driver+0x3b/0x80 [<c13d2ed0>] driver_unregister+0x20/0x50 [<c130be53>] pci_unregister_driver+0x13/0x60 [<f8a2b1f4>] mcb_pci_driver_exit+0xd/0xf [mcb_pci] [<c10be588>] SyS_delete_module+0x138/0x200 [<c1159208>] ? ____fput+0x8/0x10 [<c1068054>] ? task_work_run+0x74/0x90 [<c1001879>] do_fast_syscall_32+0x69/0x120 [<c1757597>] sysenter_past_esp+0x40/0x6a ---[ end trace 1ed34c2aa3019875 ]--- Release a mcb_bus' memory on the device's release callback, to avoid above warning. Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Reported-by: Andreas Werner <andreas.werner@men.de> Tested-by: Andreas Werner <andreas.werner@men.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-03mcb: export bus information via sysfsJohannes Thumshirn
Export information about the bus stored in the FPGA's header to userspace via sysfs, instead of hiding it in pr_debug()s from everyone. Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Andreas Werner <andreas.werner@men.de> Tested-by: Andreas Werner <andreas.werner@men.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-03mcb: Correctly initialize the bus's deviceJohannes Thumshirn
The mcb bus' device member wasn't correctly initialized and thus wasn't placed correctly into the driver model. Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Andreas Werner <andreas.werner@men.de> Tested-by: Andreas Werner <andreas.werner@men.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-29mcb: Destroy IDA on module unloadJohannes Thumshirn
Destroy mcb_ida on module_unload Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-29mcb: Do not return zero on error path in mcb_pci_probe()Alexey Khoroshilov
There is an error path in mcb_pci_probe() where it returns zero instead of error code. Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru> Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-05mcb: Fix error handling in mcb_pci_probe()Alexey Khoroshilov
If a MCB PCI Carrier device is IO mapped insted of memory-mapped, the memory of the PCI device is still not unmapped. Also the patch adds deallocation of the bus if chameleon_parse_cells() fails. Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru> Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-03mcb: request_mem_region() returns NULL on errorDan Carpenter
The code here is checking for IS_ERR() when request_mem_region() only returns NULL on error and never an ERR_PTR. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-02-03mcb: Fix error path of mcb_pci_probeJohannes Thumshirn
If a MCB PCI Carrier device is IO mapped insted of memory-mapped (which is currently unsupported by the upstream driver) the probe function bails out with -ENOTSUPP. In this case the memory of the PCI device was not unmapped. Also rename error label to reflect what will happen at the destination (suggested by Julia Lawall <julia.lawall@lip6.fr>. Signed-off-by: Johannes Thumshirn <johannes.thumshirn@men.de> Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-09mcb: mcb-pci: Only remap the 1st 0x200 bytes of BAR 0Johannes Thumshirn
Currently it is not possible to have a kernel with built-in MCB attached devices. This results out of the fact that mcb-pci requests PCI BAR 0, then parses the chameleon table and calls the driver's probe function before releasing BAR 0 again. When building the kernel with modules this is not a problem (and therefore it wasn't detected by my tests yet). A solution is to only remap the 1st 0x200 bytes of a Chameleon PCI device. 0x200 bytes is the maximum size of a Chameleon v2 Table. Also this patch stops disabling the PCI device on successful registration of MCB devices. Signed-off-by: Johannes Thumshirn <johannes.thumshirn@men.de> Suggested-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-27mcb: Add support for shared PCI IRQsJohannes Thumshirn
Add support for shared PCI IRQs to mcb and mcb-pci. Signed-off-by: Johannes Thumshirn <johannes.thumshirn@men.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-16drivers: mcb: fix memory leak in chameleon_parse_cells() error pathChristoph Jaeger
chameleon_parse_cells() bails out if chameleon descriptor type is invalid but does not free the storage 'header' points to. Signed-off-by: Christoph Jaeger <christophjaeger@linux.com> Signed-off-by: Johannes Thumshirn <johannes.thumshirn@men.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-09drivers: mcb: Fix build error discovered by 0-day botJohannes Thumshirn
Make mcb depend on HAS_IOMEM and mcb-pci depend on PCI. This fixes build errors discovered by the 0-day kernel build testing system. Signed-off-by: Johannes Thumshirn <johannes.thumshirn@men.de> Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-08drivers/mcb: do not set default Kconfig variable to modularPaul Gortmaker
Coverage builds found this build fail in ARM ebsa110_defconfig: drivers/mcb/mcb-parse.c: In function 'chameleon_parse_cells': drivers/mcb/mcb-parse.c:105:2: error: implicit declaration of function 'memcpy_fromio' [-Werror=implicit-function-declaration] cc1: some warnings being treated as errors make[2]: *** [drivers/mcb/mcb-parse.o] Error 1 A simple bisect will output this: 3764e82e5150d87b205c10cd78a9c9ab86fbfa51 is the first bad commit commit 3764e82e5150d87b205c10cd78a9c9ab86fbfa51 Author: Johannes Thumshirn <johannes.thumshirn@men.de> Date: Wed Feb 26 17:29:05 2014 +0100 drivers: Introduce MEN Chameleon Bus The above commit used "default m" which is wrong. New drivers should never be globally enabled with "default y/m". Whether this driver makes sense to build on ARM is an independent issue. Here we delete the "default m" line, which is the equivalent of "default n". Cc: Johannes Thumshirn <johannes.thumshirn@men.de> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-28mcb: Add PCI carrier for MEN Chameleon BusJohannes Thumshirn
Add support for MCB over PCI devices. Both PCI attached on-board Chameleon FPGAs as well as CompactPCI based MCB carrier cards are supported with this driver. Signed-off-by: Johannes Thumshirn <johannes.thumshirn@men.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-28drivers: Introduce MEN Chameleon BusJohannes Thumshirn
The MCB (MEN Chameleon Bus) is a Bus specific to MEN Mikroelektronik FPGA based devices. It is used to identify MCB based IP-Cores within an FPGA and provide the necessary framework for instantiating drivers for these devices. Signed-off-by: Johannes Thumshirn <johannes.thumshirn@men.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
