path: root/drivers/mcb
2015-04-03mcb: request_mem_region() returns NULL on errorDan Carpenter
The code here is checking for IS_ERR() when request_mem_region() only returns NULL on error and never an ERR_PTR. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-02-03mcb: Fix error path of mcb_pci_probeJohannes Thumshirn
If a MCB PCI Carrier device is IO mapped insted of memory-mapped (which is currently unsupported by the upstream driver) the probe function bails out with -ENOTSUPP. In this case the memory of the PCI device was not unmapped. Also rename error label to reflect what will happen at the destination (suggested by Julia Lawall <julia.lawall@lip6.fr>. Signed-off-by: Johannes Thumshirn <johannes.thumshirn@men.de> Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-09mcb: mcb-pci: Only remap the 1st 0x200 bytes of BAR 0Johannes Thumshirn
Currently it is not possible to have a kernel with built-in MCB attached devices. This results out of the fact that mcb-pci requests PCI BAR 0, then parses the chameleon table and calls the driver's probe function before releasing BAR 0 again. When building the kernel with modules this is not a problem (and therefore it wasn't detected by my tests yet). A solution is to only remap the 1st 0x200 bytes of a Chameleon PCI device. 0x200 bytes is the maximum size of a Chameleon v2 Table. Also this patch stops disabling the PCI device on successful registration of MCB devices. Signed-off-by: Johannes Thumshirn <johannes.thumshirn@men.de> Suggested-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-27mcb: Add support for shared PCI IRQsJohannes Thumshirn
Add support for shared PCI IRQs to mcb and mcb-pci. Signed-off-by: Johannes Thumshirn <johannes.thumshirn@men.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-16drivers: mcb: fix memory leak in chameleon_parse_cells() error pathChristoph Jaeger
chameleon_parse_cells() bails out if chameleon descriptor type is invalid but does not free the storage 'header' points to. Signed-off-by: Christoph Jaeger <christophjaeger@linux.com> Signed-off-by: Johannes Thumshirn <johannes.thumshirn@men.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-09drivers: mcb: Fix build error discovered by 0-day botJohannes Thumshirn
Make mcb depend on HAS_IOMEM and mcb-pci depend on PCI. This fixes build errors discovered by the 0-day kernel build testing system. Signed-off-by: Johannes Thumshirn <johannes.thumshirn@men.de> Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-08drivers/mcb: do not set default Kconfig variable to modularPaul Gortmaker
Coverage builds found this build fail in ARM ebsa110_defconfig: drivers/mcb/mcb-parse.c: In function 'chameleon_parse_cells': drivers/mcb/mcb-parse.c:105:2: error: implicit declaration of function 'memcpy_fromio' [-Werror=implicit-function-declaration] cc1: some warnings being treated as errors make[2]: *** [drivers/mcb/mcb-parse.o] Error 1 A simple bisect will output this: 3764e82e5150d87b205c10cd78a9c9ab86fbfa51 is the first bad commit commit 3764e82e5150d87b205c10cd78a9c9ab86fbfa51 Author: Johannes Thumshirn <johannes.thumshirn@men.de> Date: Wed Feb 26 17:29:05 2014 +0100 drivers: Introduce MEN Chameleon Bus The above commit used "default m" which is wrong. New drivers should never be globally enabled with "default y/m". Whether this driver makes sense to build on ARM is an independent issue. Here we delete the "default m" line, which is the equivalent of "default n". Cc: Johannes Thumshirn <johannes.thumshirn@men.de> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-28mcb: Add PCI carrier for MEN Chameleon BusJohannes Thumshirn
Add support for MCB over PCI devices. Both PCI attached on-board Chameleon FPGAs as well as CompactPCI based MCB carrier cards are supported with this driver. Signed-off-by: Johannes Thumshirn <johannes.thumshirn@men.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-28drivers: Introduce MEN Chameleon BusJohannes Thumshirn
The MCB (MEN Chameleon Bus) is a Bus specific to MEN Mikroelektronik FPGA based devices. It is used to identify MCB based IP-Cores within an FPGA and provide the necessary framework for instantiating drivers for these devices. Signed-off-by: Johannes Thumshirn <johannes.thumshirn@men.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
