path: root/drivers/md/dm-log-userspace-transfer.c
2011-03-03netlink: kill eff_cap from struct netlink_skb_parmsPatrick McHardy
Netlink message processing in the kernel is synchronous these days, capabilities can be checked directly in security_netlink_recv() from the current process. Signed-off-by: Patrick McHardy <kaber@trash.net> Reviewed-by: James Morris <jmorris@namei.org> [chrisw: update to include pohmelfs and uvesafb] Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-13dm log userspace: add version number to commsJonathan Brassow
This patch adds a 'version' field to the 'dm_ulog_request' structure. The 'version' field is taken from a portion of the unused 'padding' field in the 'dm_ulog_request' structure. This was done to avoid changing the size of the structure and possibly disrupting backwards compatibility. The version number will help notify user-space daemons when a change has been made to the kernel/userspace log API. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-16dm log: userspace fix overhead_size calcuationsJonathan Brassow
This patch fixes two bugs that revolve around the miscalculation and misuse of the variable 'overhead_size'. 'overhead_size' is the size of the various header structures used during communication. The first bug is the use of 'sizeof' with the pointer of a structure instead of the structure itself - resulting in the wrong size being computed. This is then used in a check to see if the payload (data_size) would be to large for the preallocated structure. Since the bug produces a smaller value for the overhead, it was possible for the structure to be breached. (Although the current users of the code do not currently send enough data to trigger this bug.) The second bug is that the 'overhead_size' value is used to compute how much of the preallocated space should be cleared before populating it with fresh data. This should have simply been 'sizeof(struct cn_msg)' not overhead_size. The fact that 'overhead_size' was computed incorrectly made this problem "less bad" - leaving only a pointer's worth of space at the end uncleared. Thus, this bug was never producing a bad result, but still needs to be fixed - especially now that the value is computed correctly. Cc: stable@kernel.org Signed-off-by: Jonathan Brassow <jbrassow@redhat.com Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-10-02dm/connector: Only process connector packages from privileged processesPhilipp Reisner
Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-02connector/dm: Fixed a compilation warningPhilipp Reisner
Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Acked-by: Lars Ellenberg <lars.ellenberg@linbit.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-02connector: Provide the sender's credentials to the callbackPhilipp Reisner
2009-09-04dm log: userspace add luid to distinguish between concurrent log instancesJonathan Brassow
Device-mapper userspace logs (like the clustered log) are identified by a universally unique identifier (UUID). This identifier is used to associate requests from the kernel to a specific log in userspace. The UUID must be unique everywhere, since multiple machines may use this identifier when communicating about a particular log, as is the case for cluster logs. Sometimes, device-mapper/LVM may re-use a UUID. This is the case during pvmoves, when moving from one segment of an LV to another, or when resizing a mirror, etc. In these cases, a new log is created with the same UUID and loaded in the "inactive" slot. When a device-mapper "resume" is issued, the "live" table is deactivated and the new "inactive" table becomes "live". (The "inactive" table can also be removed via a device-mapper 'clear' command.) The above two issues were colliding. More than one log was being created with the same UUID, and there was no way to distinguish between them. So, sometimes the wrong log would be swapped out during the exchange. The solution is to create a locally unique identifier, 'luid', to go along with the UUID. This new identifier is used to determine exactly which log is being referenced by the kernel when the log exchange is made. The identifier is not universally safe, but it does not need to be, since create/destroy/suspend/resume operations are bound to a specific machine; and these are the operations that make up the exchange. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-08-16dm-log-userspace: fix printk format warningRandy Dunlap
drivers/md/dm-log-userspace-transfer.c:110: warning: format '%lu' expects type 'long unsigned int', but argument 4 has type 'size_t' Previously posted and acked, but apparently lost. http://lkml.indiana.edu/hypermail/linux/kernel/0906.2/02074.html Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: dm-devel@redhat.com Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-22dm raid1: add userspace logJonthan Brassow
This patch contains a device-mapper mirror log module that forwards requests to userspace for processing. The structures used for communication between kernel and userspace are located in include/linux/dm-log-userspace.h. Due to the frequency, diversity, and 2-way communication nature of the exchanges between kernel and userspace, 'connector' was chosen as the interface for communication. The first log implementations written in userspace - "clustered-disk" and "clustered-core" - support clustered shared storage. A userspace daemon (in the LVM2 source code repository) uses openAIS/corosync to process requests in an ordered fashion with the rest of the nodes in the cluster so as to prevent log state corruption. Other implementations with no association to LVM or openAIS/corosync, are certainly possible. (Imagine if two machines are writing to the same region of a mirror. They would both mark the region dirty, but you need a cluster-aware entity that can handle properly marking the region clean when they are done. Otherwise, you might clear the region when the first machine is done, not the second.) Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
