path: root/drivers/md/dm-snap-transient.c
2016-01-08dm snapshot: fix hung bios when copy error occursMikulas Patocka
When there is an error copying a chunk dm-snapshot can incorrectly hold associated bios indefinitely, resulting in hung IO. The function copy_callback sets pe->error if there was error copying the chunk, and then calls complete_exception. complete_exception calls pending_complete on error, otherwise it calls commit_exception with commit_callback (and commit_callback calls complete_exception). The persistent exception store (dm-snap-persistent.c) assumes that calls to prepare_exception and commit_exception are paired. persistent_prepare_exception increases ps->pending_count and persistent_commit_exception decreases it. If there is a copy error, persistent_prepare_exception is called but persistent_commit_exception is not. This results in the variable ps->pending_count never returning to zero and that causes some pending exceptions (and their associated bios) to be held forever. Fix this by unconditionally calling commit_exception regardless of whether the copy was successful. A new "valid" parameter is added to commit_exception -- when the copy fails this parameter is set to zero so that the chunk that failed to copy (and all following chunks) is not recorded in the snapshot store. Also, remove commit_callback now that it is merely a wrapper around pending_complete. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Cc: stable@vger.kernel.org
2015-10-09dm snapshot: add new persistent store option to support overflowMike Snitzer
Commit 76c44f6d80 introduced the possibly for "Overflow" to be reported by the snapshot device's status. Older userspace (e.g. lvm2) does not handle the "Overflow" status response. Fix this incompatibility by requiring newer userspace code, that can cope with "Overflow", request the persistent store with overflow support by using "PO" (Persistent with Overflow) for the snapshot store type. Reported-by: Zdenek Kabelac <zkabelac@redhat.com> Fixes: 76c44f6d80 ("dm snapshot: don't invalidate on-disk image on snapshot write overflow") Reviewed-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com>
2011-10-31md: Add in export.h for files using EXPORT_SYMBOLPaul Gortmaker
These files were getting the defines for EXPORT_SYMBOL because device.h was including module.h. But we are going to put an end to that. So add the proper export.h include now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2009-12-10dm snapshot: move cow ref from exception store to snap coreMike Snitzer
Store the reference to the snapshot cow device in the core snapshot code instead of each exception store. It can be accessed through the new function dm_snap_cow(). Exception stores should each now maintain a reference to their parent snapshot struct. This is cleaner and makes part of the forthcoming snapshot merge code simpler. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Reviewed-by: Jonathan Brassow <jbrassow@redhat.com> Cc: Mikulas Patocka <mpatocka@redhat.com>
2009-12-10dm snapshot: add allocated metadata to snapshot statusMike Snitzer
Add number of sectors used by metadata to the end of the snapshot's status line. Renamed dm_exception_store_type's 'fraction_full' to 'usage'. Renamed arguments to be clearer about what is being returned. Also added 'metadata_sectors'. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: rename dm_snap_exception to dm_exceptionJon Brassow
The exception structure is not necessarily just a snapshot element (especially after we pull it out of dm-snap.c). Renaming appropriately. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Reviewed-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-04-02dm snapshot: move status to exception storeJonathan Brassow
Let the exception store types print out their status through the new API, rather than having the snapshot code do it. Adjust the buffer position to allow for the preceding DMEMIT in the arguments to type->status(). Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-04-02dm snapshot: remove dm_snap header useJonathan Brassow
Move useful functions out of dm-snap.h and stop using dm-snap.h. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-04-02dm exception store: move cow pointerJonathan Brassow
Move COW device from snapshot to exception store. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-04-02dm exception store: move chunk_fieldsJonathan Brassow
Move chunk fields from snapshot to exception store. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-04-02dm exception store: introduce registryJonathan Brassow
Move exception stores into a registry. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-04-02dm exception store: separate type from instanceJonathan Brassow
Introduce struct dm_exception_store_type. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-01-06dm snapshot: extend exception store functionsJonathan Brassow
Supply dm_add_exception as a callback to the read_metadata function. Add a status function ready for a later patch and name the functions consistently. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-01-06dm snapshot: split out exception store implementationsAlasdair G Kergon
Move the existing snapshot exception store implementations out into separate files. Later patches will place these behind a new interface in preparation for alternative implementations. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
