path: root/drivers/md/dm-snap.c
2011-08-02dm snapshot: skip reading origin when overwriting complete chunkMikulas Patocka
If we write a full chunk in the snapshot, skip reading the origin device because the whole chunk will be overwritten anyway. This patch changes the snapshot write logic when a full chunk is written. In this case: 1. allocate the exception 2. dispatch the bio (but don't report the bio completion to device mapper) 3. write the exception record 4. report bio completed Callbacks must be done through the kcopyd thread, because callbacks must not race with each other. So we create two new functions: dm_kcopyd_prepare_callback: allocate a job structure and prepare the callback. (This function must not be called from interrupt context.) dm_kcopyd_do_callback: submit callback. (This function may be called from interrupt context.) Performance test (on snapshots with 4k chunk size): without the patch: non-direct-io sequential write (dd): 17.7MB/s direct-io sequential write (dd): 20.9MB/s non-direct-io random write (mkfs.ext2): 0.44s with the patch: non-direct-io sequential write (dd): 26.5MB/s direct-io sequential write (dd): 33.2MB/s non-direct-io random write (mkfs.ext2): 0.27s Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-08-02dm snapshot: style cleanupsJonathan Brassow
Coding style cleanups. Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Jonathan Brassow <jbrassow@redhat.com>
2011-08-02dm snapshot: remove unused definitionsMikulas Patocka
Remove a couple of unused #defines. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-05-29dm kcopyd: return client directly and not through a pointerMikulas Patocka
Return client directly from dm_kcopyd_client_create, not through a parameter, making it consistent with dm_io_client_create. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-05-29dm kcopyd: reserve fewer pagesMikulas Patocka
Reserve just the minimum of pages needed to process one job. Because we allocate pages from page allocator, we don't need to reserve a large number of pages. The maximum job size is SUB_JOB_SIZE and we calculate the number of reserved pages based on this. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-03-24dm: fix opening log and cow devices for read only tablesMilan Broz
If a table is read-only, also open any log and cow devices it uses read-only. Previously, even read-only devices were opened read-write internally. After patch 75f1dc0d076d1c1168f2115f1941ea627d38bd5a block: check bdev_read_only() from blkdev_get() was applied, loading such tables began to fail. The patch was reverted by e51900f7d38cbcfb481d84567fd92540e7e1d23a block: revert block_dev read-only check but this patch fixes this part of the code to work with the original patch. Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-01-13dm snapshot: avoid storing private suspended stateMike Snitzer
Use dm_suspended() rather than having each snapshot target maintain a private 'suspended' flag in struct dm_snapshot. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-01-13dm snapshot: remove unused dm_snapshot queued_bios_workTejun Heo
dm_snapshot->queued_bios_work isn't used. Remove ->queued_bios[_work] from dm_snapshot structure, the flush_queued_bios work function and ksnapd workqueue. The DM snapshot changes that were going to use the ksnapd workqueue were either superseded (fix for origin write races) or never completed (deallocation of invalid snapshot's memory via workqueue). Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-10-22Merge branch 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-block: (46 commits) xen-blkfront: disable barrier/flush write support Added blk-lib.c and blk-barrier.c was renamed to blk-flush.c block: remove BLKDEV_IFL_WAIT aic7xxx_old: removed unused 'req' variable block: remove the BH_Eopnotsupp flag block: remove the BLKDEV_IFL_BARRIER flag block: remove the WRITE_BARRIER flag swap: do not send discards as barriers fat: do not send discards as barriers ext4: do not send discards as barriers jbd2: replace barriers with explicit flush / FUA usage jbd2: Modify ASYNC_COMMIT code to not rely on queue draining on barrier jbd: replace barriers with explicit flush / FUA usage nilfs2: replace barriers with explicit flush / FUA usage reiserfs: replace barriers with explicit flush / FUA usage gfs2: replace barriers with explicit flush / FUA usage btrfs: replace barriers with explicit flush / FUA usage xfs: replace barriers with explicit flush / FUA usage block: pass gfp_mask and flags to sb_issue_discard dm: convey that all flushes are processed as empty ...
2010-09-10Consolidate min_not_zeroMartin K. Petersen
We have several users of min_not_zero, each of them using their own definition. Move the define to kernel.h. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <axboe@carl.home.kernel.dk>
2010-09-10dm: implement REQ_FLUSH/FUA support for bio-based dmTejun Heo
This patch converts bio-based dm to support REQ_FLUSH/FUA instead of now deprecated REQ_HARDBARRIER. * -EOPNOTSUPP handling logic dropped. * Preflush is handled as before but postflush is dropped and replaced with passing down REQ_FUA to member request_queues. This replaces one array wide cache flush w/ member specific FUA writes. * __split_and_process_bio() now calls __clone_and_map_flush() directly for flushes and guarantees all FLUSH bio's going to targets are zero ` length. * It's now guaranteed that all FLUSH bio's which are passed onto dm targets are zero length. bio_empty_barrier() tests are replaced with REQ_FLUSH tests. * Empty WRITE_BARRIERs are replaced with WRITE_FLUSHes. * Dropped unlikely() around REQ_FLUSH tests. Flushes are not unlikely enough to be marked with unlikely(). * Block layer now filters out REQ_FLUSH/FUA bio's if the request_queue doesn't support cache flushing. Advertise REQ_FLUSH | REQ_FUA capability. * Request based dm isn't converted yet. dm_init_request_based_queue() resets flush support to 0 for now. To avoid disturbing request based dm code, dm->flush_error is added for bio based dm while requested based dm continues to use dm->barrier_error. Lightly tested linear, stripe, raid1, snap and crypt targets. Please proceed with caution as I'm not familiar with the code base. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: dm-devel@redhat.com Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-12dm: rename map_info flush_request to target_request_nrMike Snitzer
'target_request_nr' is a more generic name that reflects the fact that it will be used for both flush and discard support. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-08-12dm snapshot: implement mergeMikulas Patocka
Implement merge method for the snapshot origin to improve read performance. Without merge method, dm asks the upper layers to submit smallest possible bios --- one page. Submitting such small bios impacts performance negatively when reading or writing the origin device. Without this patch, CPU consumption when reading the origin on lvm on md-raid0 was 6 to 12%, with this patch, it drops to 1 to 4%. Note: in my testing, it actually degraded performance in some settings, I traced it to Maxtor disks having problems with > 512-sector requests. Reducing the number of sectors to /sys/block/sd*/queue/max_sectors_kb to 256 fixed the read performance. I think we don't have to care about weird disks that actually degrade performance because of large requests being sent to them. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-08-12dm snapshot: test chunk size against both origin and snapshotMikulas Patocka
Validate chunk size against both origin and snapshot sector size Don't allow chunk size smaller than either origin or snapshot logical sector size. Reading or writing data not aligned to sector size is not allowed and causes immediate errors. This requires us to open the origin before initialising the exception store and to export dm_snap_origin. Cc: stable@kernel.org Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Reviewed-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-08-12dm snapshot: iterate origin and cow devicesMikulas Patocka
Iterate both origin and snapshot devices iterate_devices method should call the callback for all the devices where the bio may be remapped. Thus, snapshot_iterate_devices should call the callback for both snapshot and origin underlying devices because it remaps some bios to the snapshot and some to the origin. snapshot_iterate_devices called the callback only for the origin device. This led to badly calculated device limits if snapshot and origin were placed on different types of disks. Cc: stable@kernel.org Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Reviewed-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-03-06dm: eliminate some holes data structuresMike Snitzer
Eliminate a 4-byte hole in 'struct dm_io_memory' by moving 'offset' above the 'ptr' to which it applies (size reduced from 24 to 16 bytes). And by association, 1-4 byte hole is eliminated in 'struct dm_io_request' (size reduced from 56 to 48 bytes). Eliminate all 6 4-byte holes and 1 cache-line in 'struct dm_snapshot' (size reduced from 392 to 368 bytes). Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2010-03-06dm table: remove unused dm_get_device range parametersNikanth Karthikesan
Remove unused parameters(start and len) of dm_get_device() and fix the callers. Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: use merge origin if snapshot invalidMikulas Patocka
If the snapshot we are merging became invalid (e.g. it ran out of space) redirect all I/O directly to the origin device. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Reviewed-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: report merge failure in statusMike Snitzer
Set 'merge_failed' flag if a snapshot fails to merge. Update snapshot_status() to report "Merge failed" if 'merge_failed' is set. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: merge consecutive chunks togetherMike Snitzer
s->store->type->prepare_merge returns the number of chunks that can be copied linearly working backwards from the returned chunk number. For example, if it returns 3 chunks with old_chunk == 10 and new_chunk == 20, then chunk 20 can be copied to 10, chunk 19 to 9 and 18 to 8. Until now kcopyd only copied one chunk at a time. This patch now copies the full set at once. Consequently, snapshot_merge_process() needs to delay the merging of all chunks if any have writes in progress, not just the first chunk in the region that is to be merged. snapshot-merge's performance is now comparable to the original snapshot-origin target. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: trigger exceptions in remaining snapshots during mergeMikulas Patocka
When there is one merging snapshot and other non-merging snapshots, snapshot_merge_process() must make exceptions in the non-merging snapshots. Use a sequence count to resolve the race between I/O to chunks that are about to be merged. The count increases each time an exception reallocation finishes. Use wait_event() to wait until the count changes. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: delay merging a chunk until writes to it completeMikulas Patocka
Track writes to chunks that are currently being merged and delay merging a chunk until all writes to that chunk finish. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Reviewed-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: queue writes to chunks being mergedMikulas Patocka
While a set of chunks is being merged, any overlapping writes need to be queued. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: add mergingMikulas Patocka
Merging is started when origin is resumed and it is stopped when origin is suspended or when the merging snapshot is destroyed or errors are detected. Merging is not yet interlocked with writes: this will be handled in subsequent patches. The code relies on callbacks from a private kcopyd thread. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: permit only one merge at onceMikulas Patocka
Merging more than one snapshot is not supported, so prevent this happening. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: support barriers in snapshot merge targetMike Snitzer
Sets num_flush_requests=2 to support flushing both the origin and cow devices used by the snapshot-merge target. Also, snapshot_ctr() now gets the origin device using FMODE_WRITE if the target is snapshot-merge (which writes to the origin device). Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: avoid allocating exceptions in mergeMikulas Patocka
The snapshot-merge target should not allocate new exceptions because the intent is to merge all of its exceptions as quickly and safely as possible. This patch introduces the snapshot-merge mapping function and updates __origin_write() so that it doesn't allocate exceptions on any snapshots that are being merged. If a write request to a merging snapshot device is to be dispatched directly to the origin (because the chunk is not remapped or was already merged), snapshot_merge_map() must make exceptions in other snapshots so calls do_origin(). Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: rework writing to originMikulas Patocka
To track the completion of exceptions relating to the same location on the device, the current code selects one exception as primary_pe, links the other exceptions to it and uses reference counting to wait until all the reallocations are complete. It is considered too complicated to extend this code to handle the new snapshot-merge target, where sets of non-overlapping chunks would also need to become linked. Instead, a simpler (but less efficient) approach is taken. Bios are linked to one exception. When it completes, bios are simply retried, and if other related exceptions are still outstanding, they'll get queued again to wait for another one. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: add merge targetMikulas Patocka
The snapshot-merge target allows a snapshot to be merged back into the snapshot's origin device. One anticipated use of snapshot merging is the rollback of filesystems to back out problematic system upgrades. This patch adds snapshot-merge target management to both dm_snapshot_init() and dm_snapshot_exit(). As an initial place-holder, snapshot-merge is identical to the snapshot target. Documentation is provided. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: create function for chunk_is_tracked waitMike Snitzer
Move the __chunk_is_tracked() loop into a separate function as we will also need to call it from the write path in the rare case of conflicting writes to the same chunk. Originally introduced in commit a8d41b59f3f5a7ac19452ef442a7fc1b5fa17366 ("dm snapshot: fix race during exception creation"). Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: make bio optional in __origin_writeMikulas Patocka
To support the merging of snapshots back into their origin we need to trigger exceptions in other snapshots not being merged without any incoming bio on the origin device. The bio parameter to __origin_write() becomes optional and the sector needs supplying separately. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: allow live exception store handover between tablesMike Snitzer
Permit in-use snapshot exception data to be 'handed over' from one snapshot instance to another. This is a pre-requisite for patches that allow the changes made in a snapshot device to be merged back into its origin device and also allows device resizing. The basic call sequence is: dmsetup load new_snapshot (referencing the existing in-use cow device) - the ctr code detects that the cow is already in use and allows the two snapshot target instances to be linked together dmsetup suspend original_snapshot dmsetup resume new_snapshot - the new_snapshot becomes live, and if anything now tries to access the original one it will receive -EIO dmsetup remove original_snapshot (There can only be two snapshot targets referencing the same cow device simultaneously.) Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: track suspended state in targetMike Snitzer
Keep track of whether or not the device is suspended within the snapshot target module, the same as we do in dm-raid1. We will use this later to enforce the correct sequence of ioctls to transfer the in-core exceptions from a snapshot target instance in one table to a replacement one capable of merging them back into the origin. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: move cow ref from exception store to snap coreMike Snitzer
Store the reference to the snapshot cow device in the core snapshot code instead of each exception store. It can be accessed through the new function dm_snap_cow(). Exception stores should each now maintain a reference to their parent snapshot struct. This is cleaner and makes part of the forthcoming snapshot merge code simpler. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Reviewed-by: Jonathan Brassow <jbrassow@redhat.com> Cc: Mikulas Patocka <mpatocka@redhat.com>
2009-12-10dm snapshot: add allocated metadata to snapshot statusMike Snitzer
Add number of sectors used by metadata to the end of the snapshot's status line. Renamed dm_exception_store_type's 'fraction_full' to 'usage'. Renamed arguments to be clearer about what is being returned. Also added 'metadata_sectors'. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: rename exception functionsJon Brassow
Rename exception functions. Preparing to pull them out of dm-snap.c for broader use. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Reviewed-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: rename exception_table to dm_exception_tableJon Brassow
Rename exception_table for broader use outside dm-snap.c Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Reviewed-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: rename dm_snap_exception to dm_exceptionJon Brassow
The exception structure is not necessarily just a snapshot element (especially after we pull it out of dm-snap.c). Renaming appropriately. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Reviewed-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: consolidate insert exception functionsJon Brassow
Consolidate the insert_*exception functions. 'insert_completed_exception' already contains all the logic to handle 'insert_exception' (via check for a hash_shift of 0), so remove redundant function. Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Reviewed-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: abstract minimum_chunk_size fnMikulas Patocka
The origin needs to find minimum chunksize of all snapshots. This logic is moved to a separate function because it will be used at another place in the snapshot merge patches. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Reviewed-by: Mike Snitzer <snitzer@redhat.com> Reviewed-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: cope with chunk size larger than originMikulas Patocka
Under some special conditions the snapshot hash_size is calculated as zero. This patch instead sets a minimum value of 64, the same as for the pending exception table. rounddown_pow_of_two(0) is an undefined operation (it expands to shift by -1). init_exception_table with an argument of 0 would fail with -ENOMEM. The way to trigger the problem is to create a snapshot with a chunk size that is larger than the origin device. Cc: stable@kernel.org Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-12-10dm snapshot: only take lock for statustype info not tableMikulas Patocka
Take snapshot lock only for STATUSTYPE_INFO, not STATUSTYPE_TABLE. Commit 4c6fff445d7aa753957856278d4d93bcad6e2c14 (dm-snapshot-lock-snapshot-while-supplying-status.patch) introduced this use of the lock, but userspace applications using libdevmapper have been found to request STATUSTYPE_TABLE while the device is suspended and the lock is already held, leading to deadlock. Since the lock is not necessary in this case, don't try to take it. Cc: stable@kernel.org Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-10-16dm snapshot: use unsigned integer chunk sizeMikulas Patocka
Use unsigned integer chunk size. Maximum chunk size is 512kB, there won't ever be need to use 4GB chunk size, so the number can be 32-bit. This fixes compiler failure on 32-bit systems with large block devices. Cc: stable@kernel.org Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Reviewed-by: Jonathan Brassow <jbrassow@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-10-16dm snapshot: lock snapshot while supplying statusMikulas Patocka
This patch locks the snapshot when returning status. It fixes a race when it could return an invalid number of free chunks if someone was simultaneously modifying it. Cc: stable@kernel.org Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-10-16dm snapshot: require non zero chunk size by end of ctrMikulas Patocka
If we are creating snapshot with memory-stored exception store, fail if the user didn't specify chunk size. Zero chunk size would probably crash a lot of places in the rest of snapshot code. Cc: stable@kernel.org Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Reviewed-by: Jonathan Brassow <jbrassow@redhat.com> Reviewed-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-10-16dm snapshot: free exception store on init failureJonathan Brassow
While initializing the snapshot module, if we fail to register the snapshot target then we must back-out the exception store module initialization. Cc: stable@kernel.org Signed-off-by: Jonathan Brassow <jbrassow@redhat.com> Reviewed-by: Mikulas Patocka <mpatocka@redhat.com> Reviewed-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-10-16dm snapshot: sort by chunk size to fix raceMikulas Patocka
Avoid a race causing corruption when snapshots of the same origin have different chunk sizes by sorting the internal list of snapshots by chunk size, largest first. https://bugzilla.redhat.com/show_bug.cgi?id=182659 For example, let's have two snapshots with different chunk sizes. The first snapshot (1) has small chunk size and the second snapshot (2) has large chunk size. Let's have chunks A, B, C in these snapshots: snapshot1: ====A==== ====B==== snapshot2: ==========C========== (Chunk size is a power of 2. Chunks are aligned.) A write to the origin at a position within A and C comes along. It triggers reallocation of A, then reallocation of C and links them together using A as the 'primary' exception. Then another write to the origin comes along at a position within B and C. It creates pending exception for B. C already has a reallocation in progress and it already has a primary exception (A), so nothing is done to it: B and C are not linked. If the reallocation of B finishes before the reallocation of C, because there is no link with the pending exception for C it does not know to wait for it and, the second write is dispatched to the origin and causes data corruption in the chunk C in snapshot2. To avoid this situation, we maintain snapshots sorted in descending order of chunk size. This leads to a guaranteed ordering on the links between the pending exceptions and avoids the problem explained above - both A and B now get linked to C. Cc: stable@kernel.org Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-09-04dm snapshot: implement iterate devicesMike Snitzer
Implement the .iterate_devices for the origin and snapshot targets. dm-snapshot's lack of .iterate_devices resulted in the inability to properly establish queue_limits for both targets. With 4K sector drives: an unfortunate side-effect of not establishing proper limits in either targets' DM device was that IO to the devices would fail even though both had been created without error. Commit af4874e03ed82f050d5872d8c39ce64bf16b5c38 ("dm target:s introduce iterate devices fn") in 2.6.31-rc1 should have implemented .iterate_devices for dm-snap.c's origin and snapshot targets. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-06-22dm snapshot: support barriersMikulas Patocka
Flush support for dm-snapshot target. This patch just forwards the flush request to either the origin or the snapshot device. (It doesn't flush exception store metadata.) Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-04-15block: move bio list helpers into bio.hChristoph Hellwig
It's used by DM and MD and generally useful, so move the bio list helpers into bio.h. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
