path: root/drivers/md/faulty.c
2010-10-28md: use separate bio pool for each md device.NeilBrown
bio_clone and bio_alloc allocate from a common bio pool. If an md device is stacked with other devices that use this pool, or under something like swap which uses the pool, then the multiple calls on the pool can cause deadlocks. So allocate a local bio pool for each md array and use that rather than the common pool. This pool is used both for regular IO and metadata updates. Signed-off-by: NeilBrown <neilb@suse.de>
2010-05-22Merge commit '3ff195b011d7decf501a4d55aeed312731094796' into for-linusNeilBrown
Conflicts: drivers/md/md.c - Resolved conflict in md_update_sb - Added extra 'NULL' arg to new instance of sysfs_get_dirent. Signed-off-by: NeilBrown <neilb@suse.de>
2010-05-18md: pass mddev to make_request functions rather than request_queueNeilBrown
We used to pass the personality make_request function direct to the block layer so the first argument had to be a queue. But now we have the intermediary md_make_request so it makes at lot more sense to pass a struct mddev_s. It makes it possible to have an mddev without its own queue too. Signed-off-by: NeilBrown <neilb@suse.de>
2010-05-18drivers/md: Remove unnecessary casts of void *H Hartley Sweeten
void pointers do not need to be cast to other pointer types. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: NeilBrown <neilb@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-14md: add MODULE_DESCRIPTION for all md related modules.NeilBrown
Suggested by Oren Held <orenhe@il.ibm.com> Signed-off-by: NeilBrown <neilb@suse.de>
2009-06-18md: Move check for bitmap presence to personality code.Andre Noll
If the superblock of a component device indicates the presence of a bitmap but the corresponding raid personality does not support bitmaps (raid0, linear, multipath, faulty), then something is seriously wrong and we'd better refuse to run such an array. Currently, this check is performed while the superblocks are examined, i.e. before entering personality code. Therefore the generic md layer must know which raid levels support bitmaps and which do not. This patch avoids this layer violation without adding identical code to various personalities. This is accomplished by introducing a new public function to md.c, md_check_no_bitmap(), which replaces the hard-coded checks in the superblock loading functions. A call to md_check_no_bitmap() is added to the ->run method of each personality which does not support bitmaps and assembly is aborted if at least one component device contains a bitmap. Signed-off-by: Andre Noll <maan@systemlinux.org> Signed-off-by: NeilBrown <neilb@suse.de>
2009-06-18md: merge reconfig and check_reshape methods.NeilBrown
The difference between these two methods is artificial. Both check that a pending reshape is valid, and perform any aspect of it that can be done immediately. 'reconfig' handles chunk size and layout. 'check_reshape' handles raid_disks. So make them just one method. Signed-off-by: NeilBrown <neilb@suse.de>
2009-06-18md: remove unnecessary arguments from ->reconfig method.NeilBrown
Passing the new layout and chunksize as args is not necessary as the mddev has fields for new_check and new_layout. This is preparation for combining the check_reshape and reconfig methods Signed-off-by: NeilBrown <neilb@suse.de>
2009-03-31md: centralize ->array_sectors modificationsDan Williams
Get personalities out of the business of directly modifying ->array_sectors. Lays groundwork to introduce policy on when ->array_sectors can be modified. Reviewed-by: Andre Noll <maan@systemlinux.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-03-31md: add 'size' as a personality methodDan Williams
In preparation for giving userspace control over ->array_sectors we need to be able to retrieve the 'default' size, and the 'anticipated' size when a reshape is requested. For personalities that do not reshape emit a warning if anything but the default size is requested. In the raid5 case we need to update ->previous_raid_disks to make the new 'default' size available. Reviewed-by: Andre Noll <maan@systemlinux.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-03-31md: Make mddev->size sector-based.Andre Noll
This patch renames the "size" field of struct mddev_s to "dev_sectors" and stores the number of 512-byte sectors instead of the number of 1K-blocks in it. All users of that field, including raid levels 1,4-6,10, are adjusted accordingly. This simplifies the code a bit because it allows to get rid of a couple of divisions/multiplications by two. In order to make checkpatch happy, some minor coding style issues have also been addressed. In particular, size_store() now uses strict_strtoull() instead of simple_strtoull(). Signed-off-by: Andre Noll <maan@systemlinux.org> Signed-off-by: NeilBrown <neilb@suse.de>
2009-03-31md: move md_k.h from include/linux/raid/ to drivers/md/NeilBrown
It really is nicer to keep related code together.. Signed-off-by: NeilBrown <neilb@suse.de>
2009-03-31md: move lots of #include lines out of .h files and into .cNeilBrown
This makes the includes more explicit, and is preparation for moving md_k.h to drivers/md/md.h Remove include/raid/md.h as its only remaining use was to #include other files. Signed-off-by: NeilBrown <neilb@suse.de>
2009-01-09md: use list_for_each_entry macro directlyCheng Renquan
The rdev_for_each macro defined in <linux/raid/md_k.h> is identical to list_for_each_entry_safe, from <linux/list.h>, it should be defined to use list_for_each_entry_safe, instead of reinventing the wheel. But some calls to each_entry_safe don't really need a safe version, just a direct list_for_each_entry is enough, this could save a temp variable (tmp) in every function that used rdev_for_each. In this patch, most rdev_for_each loops are replaced by list_for_each_entry, totally save many tmp vars; and only in the other situations that will call list_del to delete an entry, the safe version is used. Signed-off-by: Cheng Renquan <crquan@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de>
2008-10-16md: check for memory allocation failure in faulty personalitySven Wegener
It's a fault injection module, but I don't think we should oops here. Signed-off-by: Sven Wegener <sven.wegener@stealer.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Neil Brown <neilb@suse.de>
2008-07-21md: Make mddev->array_size sector-based.Andre Noll
This patch renames the array_size field of struct mddev_s to array_sectors and converts all instances to use units of 512 byte sectors instead of 1k blocks. Signed-off-by: Andre Noll <maan@systemlinux.org> Signed-off-by: NeilBrown <neilb@suse.de>
2008-02-06md: change ITERATE_RDEV to rdev_for_eachNeilBrown
As this is more in line with common practice in the kernel. Also swap the args around to be more like list_for_each. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10Drop 'size' argument from bio_endio and bi_end_ioNeilBrown
As bi_end_io is only called once when the reqeust is complete, the 'size' argument is now redundant. Remove it. Now there is no need for bio_endio to subtract the size completed from bi_size. So don't do that either. While we are at it, change bi_end_io to return void. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-24[BLOCK] Get rid of request_queue_t typedefJens Axboe
Some of the code has been gradually transitioned to using the proper struct request_queue, but there's lots left. So do a full sweet of the kernel and get rid of this typedef and replace its uses with the proper type. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-13[PATCH] md: Don't assume that READ==0 and WRITE==1 - use the names explicitlyNeilBrown
Thanks Jens for alerting me to this. Cc: Jens Axboe <jens.axboe@oracle.com> Cc: <raziebe@gmail.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: allow array level to be set textually via sysfsNeilBrown
Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: remove personality numbering from mdNeilBrown
md supports multiple different RAID level, each being implemented by a 'personality' (which is often in a separate module). These personalities have fairly artificial 'numbers'. The numbers are use to: 1- provide an index into an array where the various personalities are recorded 2- identify the module (via an alias) which implements are particular personality. Neither of these uses really justify the existence of personality numbers. The array can be replaced by a linked list which is searched (array lookup only happens very rarely). Module identification can be done using an alias based on level rather than 'personality' number. The current 'raid5' modules support two level (4 and 5) but only one personality. This slight awkwardness (which was handled in the mapping from level to personality) can be better handled by allowing raid5 to register 2 personalities. With this change in place, the core md module does not need to have an exhaustive list of all possible personalities, so other personalities can be added independently. This patch also moves the check for chunksize being non-zero into the ->run routines for the personalities that need it, rather than having it in core-md. This has a side effect of allowing 'faulty' and 'linear' not to have a chunk-size set. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
