path: root/drivers/md/multipath.c
2011-05-11md: make error_handler functions more uniform and correct.NeilBrown
- there is no need to test_bit Faulty, as that was already done in md_error which is the only caller of these functions. - MD_CHANGE_DEVS should be set *after* faulty is set to ensure metadata is updated correctly. - spinlock should be held while updating ->degraded. Signed-off-by: NeilBrown <neilb@suse.de>
2011-05-11md/multipath: discard ->working_disks in favour of ->degradedNeilBrown
conf->working_disks duplicates information already available in mddev->degraded. So remove working_disks. Signed-off-by: NeilBrown <neilb@suse.de>
2011-03-17block: Require subsystems to explicitly allocate bio_set integrity mempoolMartin K. Petersen
MD and DM create a new bio_set for every metadevice. Each bio_set has an integrity mempool attached regardless of whether the metadevice is capable of passing integrity metadata. This is a waste of memory. Instead we defer the allocation decision to MD and DM since we know at metadevice creation time whether integrity passthrough is needed or not. Automatic integrity mempool allocation can then be removed from bioset_create() and we make an explicit integrity allocation for the fs_bio_set. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reported-by: Zdenek Kabelac <zkabelac@redhat.com> Acked-by: Mike Snitzer <snizer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10Merge branch 'for-2.6.39/stack-plug' into for-2.6.39/coreJens Axboe
Conflicts: block/blk-core.c block/blk-flush.c drivers/md/raid1.c drivers/md/raid10.c drivers/md/raid5.c fs/nilfs2/btnode.c fs/nilfs2/mdt.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-02-21md: avoid spinlock problem in blk_throtl_exitNeilBrown
blk_throtl_exit assumes that ->queue_lock still exists, so make sure that it does. To do this, we stop redirecting ->queue_lock to conf->device_lock and leave it pointing where it is initialised - __queue_lock. As the blk_plug functions check the ->queue_lock is held, we now take that spin_lock explicitly around the plug functions. We don't need the locking, just the warning removal. This is needed for any kernel with the blk_throtl code, which is which is 2.6.37 and later. Cc: stable@kernel.org Signed-off-by: NeilBrown <neilb@suse.de>
2010-09-10md: implment REQ_FLUSH/FUA supportTejun Heo
This patch converts md to support REQ_FLUSH/FUA instead of now deprecated REQ_HARDBARRIER. In the core part (md.c), the following changes are notable. * Unlike REQ_HARDBARRIER, REQ_FLUSH/FUA don't interfere with processing of other requests and thus there is no reason to mark the queue congested while FLUSH/FUA is in progress. * REQ_FLUSH/FUA failures are final and its users don't need retry logic. Retry logic is removed. * Preflush needs to be issued to all member devices but FUA writes can be handled the same way as other writes - their processing can be deferred to request_queue of member devices. md_barrier_request() is renamed to md_flush_request() and simplified accordingly. For linear, raid0 and multipath, the core changes are enough. raid1, 5 and 10 need the following conversions. * raid1: Handling of FLUSH/FUA bio's can simply be deferred to request_queues of member devices. Barrier related logic removed. * raid5: Queue draining logic dropped. FUA bit is propagated through biodrain and stripe resconstruction such that all the updated parts of the stripe are written out with FUA writes if any of the dirtying writes was FUA. preread_active_stripes handling in make_request() is updated as suggested by Neil Brown. * raid10: FUA bit needs to be propagated to write clones. linear, raid0, 1, 5 and 10 tested. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Neil Brown <neilb@suse.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: unify flags for struct bio and struct requestChristoph Hellwig
Remove the current bio flags and reuse the request flags for the bio, too. This allows to more easily trace the type of I/O from the filesystem down to the block driver. There were two flags in the bio that were missing in the requests: BIO_RW_UNPLUG and BIO_RW_AHEAD. Also I've renamed two request flags that had a superflous RW in them. Note that the flags are in bio.h despite having the REQ_ name - as blkdev.h includes bio.h that is the only way to go for now. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-05-22Merge commit '3ff195b011d7decf501a4d55aeed312731094796' into for-linusNeilBrown
Conflicts: drivers/md/md.c - Resolved conflict in md_update_sb - Added extra 'NULL' arg to new instance of sysfs_get_dirent. Signed-off-by: NeilBrown <neilb@suse.de>
2010-05-18md: pass mddev to make_request functions rather than request_queueNeilBrown
We used to pass the personality make_request function direct to the block layer so the first argument had to be a queue. But now we have the intermediary md_make_request so it makes at lot more sense to pass a struct mddev_s. It makes it possible to have an mddev without its own queue too. Signed-off-by: NeilBrown <neilb@suse.de>
2010-05-18md: move io accounting out of personalities into md_make_requestNeilBrown
While I generally prefer letting personalities do as much as possible, given that we have a central md_make_request anyway we may as well use it to simplify code. Also this centralises knowledge of ->gendisk which will help later. Signed-off-by: NeilBrown <neilb@suse.de>
2010-05-18drivers/md: Remove unnecessary casts of void *H Hartley Sweeten
void pointers do not need to be cast to other pointer types. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: NeilBrown <neilb@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-16md: deal with merge_bvec_fn in component devices better.NeilBrown
If a component device has a merge_bvec_fn then as we never call it we must ensure we never need to. Currently this is done by setting max_sector to 1 PAGE, however this does not stop a bio being created with several sub-page iovecs that would violate the merge_bvec_fn. So instead set max_segments to 1 and set the segment boundary to the same as a page boundary to ensure there is only ever one single-page segment of IO requested at a time. This can particularly be an issue when 'xen' is used as it is known to submit multiple small buffers in a single bio. Signed-off-by: NeilBrown <neilb@suse.de> Cc: stable@kernel.org
2010-02-26block: Rename blk_queue_max_sectors to blk_queue_max_hw_sectorsMartin K. Petersen
The block layer calling convention is blk_queue_<limit name>. blk_queue_max_sectors predates this practice, leading to some confusion. Rename the function to appropriately reflect that its intended use is to set max_hw_sectors. Also introduce a temporary wrapper for backwards compability. This can be removed after the merge window is closed. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-12-14md: add MODULE_DESCRIPTION for all md related modules.NeilBrown
Suggested by Oren Held <orenhe@il.ibm.com> Signed-off-by: NeilBrown <neilb@suse.de>
2009-12-14md: support barrier requests on all personalities.NeilBrown
Previously barriers were only supported on RAID1. This is because other levels requires synchronisation across all devices and so needed a different approach. Here is that approach. When a barrier arrives, we send a zero-length barrier to every active device. When that completes - and if the original request was not empty - we submit the barrier request itself (with the barrier flag cleared) and then submit a fresh load of zero length barriers. The barrier request itself is asynchronous, but any subsequent request will block until the barrier completes. The reason for clearing the barrier flag is that a barrier request is allowed to fail. If we pass a non-empty barrier through a striping raid level it is conceivable that part of it could succeed and part could fail. That would be way too hard to deal with. So if the first run of zero length barriers succeed, we assume all is sufficiently well that we send the request and ignore errors in the second run of barriers. RAID5 needs extra care as write requests may not have been submitted to the underlying devices yet. So we flush the stripe cache before proceeding with the barrier. Note that the second set of zero-length barriers are submitted immediately after the original request is submitted. Thus when a personality finds mddev->barrier to be set during make_request, it should not return from make_request until the corresponding per-device request(s) have been queued. That will be done in later patches. Signed-off-by: NeilBrown <neilb@suse.de> Reviewed-by: Andre Noll <maan@systemlinux.org>
2009-09-23md: remove unnecessary memset from multipath.NeilBrown
Recent commit bbba809e96539672f775a3d70102657d05816a5b replaced mempool_create_kzalloc_pool with mempool_create_kmalloc_pool plus a memset. This memset is not needed (and we didn't need kzalloc in the first place). Ever field of the allocated structure (struct multipath_bh) is initialised immediately except retry_list, and memset does not initial a list_head anyway. To remove the memset. Signed-off-by: NeilBrown <neilb@suse.de>
2009-09-23md: report device as congested when suspendedNeilBrown
This should writeback from coming when the device is temporarily suspended. Signed-off-by: NeilBrown <neilb@suse.de>
2009-09-23md: Improve name of threads created by md_register_threadNeilBrown
The management thread for raid4,5,6 arrays are all called mdX_raid5, independent of the actual raid level, which is wrong and can be confusion. So change md_register_thread to use the name from the personality unless no alternate name (like 'resync' or 'reshape') is given. This is simpler and more correct. Cc: Jinzc <zhenchengjin@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de>
2009-09-22md: avoid use of broken kzalloc mempoolSage Weil
The kzalloc mempool does not re-zero items that have been used and then returned to the pool. Manually zero the allocated multipath_bh instead. Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-11bio: first step in sanitizing the bio->bi_rw flag testingJens Axboe
Get rid of any functions that test for these bits and make callers use bio_rw_flagged() directly. Then it is at least directly apparent what variable and flag they check. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-08-03md: Push down data integrity code to personalities.Andre Noll
This patch replaces md_integrity_check() by two new public functions: md_integrity_register() and md_integrity_add_rdev() which are both personality-independent. md_integrity_register() is called from the ->run and ->hot_remove methods of all personalities that support data integrity. The function iterates over the component devices of the array and determines if all active devices are integrity capable and if their profiles match. If this is the case, the common profile is registered for the mddev via blk_integrity_register(). The second new function, md_integrity_add_rdev() is called from the ->hot_add_disk methods, i.e. whenever a new device is being added to a raid array. If the new device does not support data integrity, or has a profile different from the one already registered, data integrity for the mddev is disabled. For raid0 and linear, only the call to md_integrity_register() from the ->run method is necessary. Signed-off-by: Andre Noll <maan@systemlinux.org> Signed-off-by: NeilBrown <neilb@suse.de>
2009-07-01md: Use new topology calls to indicate alignment and I/O sizesMartin K. Petersen
Switch MD over to the new disk_stack_limits() function which checks for aligment and adjusts preferred I/O sizes when stacking. Also indicate preferred I/O sizes where applicable. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: NeilBrown <neilb@suse.de>
2009-06-18md: Move check for bitmap presence to personality code.Andre Noll
If the superblock of a component device indicates the presence of a bitmap but the corresponding raid personality does not support bitmaps (raid0, linear, multipath, faulty), then something is seriously wrong and we'd better refuse to run such an array. Currently, this check is performed while the superblocks are examined, i.e. before entering personality code. Therefore the generic md layer must know which raid levels support bitmaps and which do not. This patch avoids this layer violation without adding identical code to various personalities. This is accomplished by introducing a new public function to md.c, md_check_no_bitmap(), which replaces the hard-coded checks in the superblock loading functions. A call to md_check_no_bitmap() is added to the ->run method of each personality which does not support bitmaps and assembly is aborted if at least one component device contains a bitmap. Signed-off-by: Andre Noll <maan@systemlinux.org> Signed-off-by: NeilBrown <neilb@suse.de>
2009-06-16md: remove mddev_to_conf "helper" macroNeilBrown
Having a macro just to cast a void* isn't really helpful. I would must rather see that we are simply de-referencing ->private, than have to know what the macro does. So open code the macro everywhere and remove the pointless cast. Signed-off-by: NeilBrown <neilb@suse.de>
2009-05-22block: Use accessor functions for queue limitsMartin K. Petersen
Convert all external users of queue limits to using wrapper functions instead of poking the request queue variables directly. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-31md: centralize ->array_sectors modificationsDan Williams
Get personalities out of the business of directly modifying ->array_sectors. Lays groundwork to introduce policy on when ->array_sectors can be modified. Reviewed-by: Andre Noll <maan@systemlinux.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-03-31md: add 'size' as a personality methodDan Williams
In preparation for giving userspace control over ->array_sectors we need to be able to retrieve the 'default' size, and the 'anticipated' size when a reshape is requested. For personalities that do not reshape emit a warning if anything but the default size is requested. In the raid5 case we need to update ->previous_raid_disks to make the new 'default' size available. Reviewed-by: Andre Noll <maan@systemlinux.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-03-31md: Make mddev->size sector-based.Andre Noll
This patch renames the "size" field of struct mddev_s to "dev_sectors" and stores the number of 512-byte sectors instead of the number of 1K-blocks in it. All users of that field, including raid levels 1,4-6,10, are adjusted accordingly. This simplifies the code a bit because it allows to get rid of a couple of divisions/multiplications by two. In order to make checkpatch happy, some minor coding style issues have also been addressed. In particular, size_store() now uses strict_strtoull() instead of simple_strtoull(). Signed-off-by: Andre Noll <maan@systemlinux.org> Signed-off-by: NeilBrown <neilb@suse.de>
2009-03-31md: move md_k.h from include/linux/raid/ to drivers/md/NeilBrown
It really is nicer to keep related code together.. Signed-off-by: NeilBrown <neilb@suse.de>
2009-03-31md: move lots of #include lines out of .h files and into .cNeilBrown
This makes the includes more explicit, and is preparation for moving md_k.h to drivers/md/md.h Remove include/raid/md.h as its only remaining use was to #include other files. Signed-off-by: NeilBrown <neilb@suse.de>
2009-03-31md: move headers out of include/linux/raid/Christoph Hellwig
Move the headers with the local structures for the disciplines and bitmap.h into drivers/md/ so that they are more easily grepable for hacking and not far away. md.h is left where it is for now as there are some uses from the outside. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: NeilBrown <neilb@suse.de>
2009-01-09md: use list_for_each_entry macro directlyCheng Renquan
The rdev_for_each macro defined in <linux/raid/md_k.h> is identical to list_for_each_entry_safe, from <linux/list.h>, it should be defined to use list_for_each_entry_safe, instead of reinventing the wheel. But some calls to each_entry_safe don't really need a safe version, just a direct list_for_each_entry is enough, this could save a temp variable (tmp) in every function that used rdev_for_each. In this patch, most rdev_for_each loops are replaced by list_for_each_entry, totally save many tmp vars; and only in the other situations that will call list_del to delete an entry, the safe version is used. Signed-off-by: Cheng Renquan <crquan@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de>
2008-10-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (39 commits) [SCSI] sd: fix compile failure with CONFIG_BLK_DEV_INTEGRITY=n libiscsi: fix locking in iscsi_eh_device_reset libiscsi: check reason why we are stopping iscsi session to determine error value [SCSI] iscsi_tcp: return a descriptive error value during connection errors [SCSI] libiscsi: rename host reset to target reset [SCSI] iscsi class: fix endpoint id handling [SCSI] libiscsi: Support drivers initiating session removal [SCSI] libiscsi: fix data corruption when target has to resend data-in packets [SCSI] sd: Switch kernel printing level for DIF messages [SCSI] sd: Correctly handle all combinations of DIF and DIX [SCSI] sd: Always print actual protection_type [SCSI] sd: Issue correct protection operation [SCSI] scsi_error: fix target reset handling [SCSI] lpfc 8.2.8 v2 : Add statistical reporting control and additional fc vendor events [SCSI] lpfc 8.2.8 v2 : Add sysfs control of target queue depth handling [SCSI] lpfc 8.2.8 v2 : Revert target busy in favor of transport disrupted [SCSI] scsi_dh_alua: remove REQ_NOMERGE [SCSI] lpfc 8.2.8 : update driver version to 8.2.8 [SCSI] lpfc 8.2.8 : Add MSI-X support [SCSI] lpfc 8.2.8 : Update driver to use new Host byte error code DID_TRANSPORT_DISRUPTED ...
2008-10-13[SCSI] block: separate failfast into multiple bits.Mike Christie
Multipath is best at handling transport errors. If it gets a device error then there is not much the multipath layer can do. It will just access the same device but from a different path. This patch breaks up failfast into device, transport and driver errors. The multipath layers (md and dm mutlipath) only ask the lower levels to fast fail transport errors. The user of failfast, read ahead, will ask to fast fail on all errors. Note that blk_noretry_request will return true if any failfast bit is set. This allows drivers that do not support the multipath failfast bits to continue to fail on any failfast error like before. Drivers like scsi that are able to fail fast specific errors can check for the specific fail fast type. In the next patch I will convert scsi. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-13md: Remove unnecessary #includes, #defines, and function declarations.NeilBrown
A lot of cruft has gathered over the years. Time to remove it. Signed-off-by: NeilBrown <neilb@suse.de>
2008-10-09block: move stats from disk to part0Tejun Heo
Move stats related fields - stamp, in_flight, dkstats - from disk to part0 and unify stat handling such that... * part_stat_*() now updates part0 together if the specified partition is not part0. ie. part_stat_*() are now essentially all_stat_*(). * {disk|all}_stat_*() are gone. * part_round_stats() is updated similary. It handles part0 stats automatically and disk_round_stats() is killed. * part_{inc|dec}_in_fligh() is implemented which automatically updates part0 stats for parts other than part0. * disk_map_sector_rcu() is updated to return part0 if no part matches. Combined with the above changes, this makes NULL special case handling in callers unnecessary. * Separate stats show code paths for disk are collapsed into part stats show code paths. * Rename disk_stat_lock/unlock() to part_stat_lock/unlock() While at it, reposition stat handling macros a bit and add missing parentheses around macro parameters. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: fix diskstats accessTejun Heo
There are two variants of stat functions - ones prefixed with double underbars which don't care about preemption and ones without which disable preemption before manipulating per-cpu counters. It's unclear whether the underbarred ones assume that preemtion is disabled on entry as some callers don't do that. This patch unifies diskstats access by implementing disk_stat_lock() and disk_stat_unlock() which take care of both RCU (for partition access) and preemption (for per-cpu counter access). diskstats access should always be enclosed between the two functions. As such, there's no need for the versions which disables preemption. They're removed and double underbars ones are renamed to drop the underbars. As an extra argument is added, there's no danger of using the old version unconverted. disk_stat_lock() uses get_cpu() and returns the cpu index and all diskstat functions which access per-cpu counters now has @cpu argument to help RT. This change adds RCU or preemption operations at some places but also collapses several preemption ops into one at others. Overall, the performance difference should be negligible as all involved ops are very lightweight per-cpu ones. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-21md: Make mddev->array_size sector-based.Andre Noll
This patch renames the array_size field of struct mddev_s to array_sectors and converts all instances to use units of 512 byte sectors instead of 1k blocks. Signed-off-by: Andre Noll <maan@systemlinux.org> Signed-off-by: NeilBrown <neilb@suse.de>
2008-06-28rationalise return value for ->hot_add_disk method.Neil Brown
For all array types but linear, ->hot_add_disk returns 1 on success, 0 on failure. For linear, it returns 0 on success and -errno on failure. This doesn't cause a functional problem because the ->hot_add_disk function of linear is used quite differently to the others. However it is confusing. So convert all to return 0 for success or -errno on failure and fix call sites to match. Signed-off-by: Neil Brown <neilb@suse.de>
2008-06-28Support adding a spare to a live md array with external metadata.Neil Brown
i.e. extend the 'md/dev-XXX/slot' attribute so that you can tell a device to fill an vacant slot in an and md array. Signed-off-by: Neil Brown <neilb@suse.de>
2008-05-24md: restart recovery cleanly after device failure.NeilBrown
When we get any IO error during a recovery (rebuilding a spare), we abort the recovery and restart it. For RAID6 (and multi-drive RAID1) it may not be best to restart at the beginning: when multiple failures can be tolerated, the recovery may be able to continue and re-doing all that has already been done doesn't make sense. We already have the infrastructure to record where a recovery is up to and restart from there, but it is not being used properly. This is because: - We sometimes abort with MD_RECOVERY_ERR rather than just MD_RECOVERY_INTR, which causes the recovery not be be checkpointed. - We remove spares and then re-added them which loses important state information. The distinction between MD_RECOVERY_ERR and MD_RECOVERY_INTR really isn't needed. If there is an error, the relevant drive will be marked as Faulty, and that is enough to ensure correct handling of the error. So we first remove MD_RECOVERY_ERR, changing some of the uses of it to MD_RECOVERY_INTR. Then we cause the attempt to remove a non-faulty device from an array to fail (unless recovery is impossible as the array is too degraded). Then when remove_and_add_spares attempts to remove the devices on which recovery can continue, it will fail, they will remain in place, and recovery will continue on them as desired. Issue: If we are halfway through rebuilding a spare and another drive fails, and a new spare is immediately available, do we want to: 1/ complete the current rebuild, then go back and rebuild the new spare or 2/ restart the rebuild from the start and rebuild both devices in parallel. Both options can be argued for. The code currently takes option 2 as a/ this requires least code change b/ this results in a minimally-degraded array in minimal time. Cc: "Eivind Sarto" <ivan@kasenna.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14Remove blkdev warning triggered by using mdNeil Brown
As setting and clearing queue flags now requires that we hold a spinlock on the queue, and as blk_queue_stack_limits is called without that lock, get the lock inside blk_queue_stack_limits. For blk_queue_stack_limits to be able to find the right lock, each md personality needs to set q->queue_lock to point to the appropriate lock. Those personalities which didn't previously use a spin_lock, us q->__queue_lock. So always initialise that lock when allocated. With this in place, setting/clearing of the QUEUE_FLAG_PLUGGED bit will no longer cause warnings as it will be clear that the proper lock is held. Thanks to Dan Williams for review and fixing the silly bugs. Signed-off-by: NeilBrown <neilb@suse.de> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Alistair John Strachan <alistair@devzero.co.uk> Cc: Nick Piggin <npiggin@suse.de> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Jacek Luczak <difrost.kernel@gmail.com> Cc: Prakash Punnoor <prakash@punnoor.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28raid: remove leading TAB on printk messagesNick Andrew
MD drivers use one printk() call to print 2 log messages and the second line may be prefixed by a TAB character. It may also output a trailing space before newline. klogd (I think) turns the TAB character into the 2 characters '^I' when logging to a file. This looks ugly. Instead of a leading TAB to indicate continuation, prefix both output lines with 'raid:' or similar. Also remove any trailing space in the vicinity of the affected code and consistently end the sentences with a period. Signed-off-by: Nick Andrew <nick@nick-andrew.net> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06md: change ITERATE_RDEV to rdev_for_eachNeilBrown
As this is more in line with common practice in the kernel. Also swap the args around to be more like list_for_each. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-09Add UNPLUG traces to all appropriate placesAlan D. Brunelle
Added blk_unplug interface, allowing all invocations of unplugs to result in a generated blktrace UNPLUG. Signed-off-by: Alan D. Brunelle <Alan.Brunelle@hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-16block: convert blkdev_issue_flush() to use empty barriersJens Axboe
Then we can get rid of ->issue_flush_fn() and all the driver private implementations of that. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-10Drop 'size' argument from bio_endio and bi_end_ioNeilBrown
As bi_end_io is only called once when the reqeust is complete, the 'size' argument is now redundant. Remove it. Now there is no need for bio_endio to subtract the size completed from bi_size. So don't do that either. While we are at it, change bi_end_io to return void. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-24[BLOCK] Get rid of request_queue_t typedefJens Axboe
Some of the code has been gradually transitioned to using the proper struct request_queue, but there's lots left. So do a full sweet of the kernel and get rid of this typedef and replace its uses with the proper type. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
