This is the 4.19.59 stable release
[ Upstream commit 9642fa73d073527b0cbc337cc17a47d545d82cd2 ]
Stopping external metadata arrays during resync/recovery causes
retries, loop of interrupting and starting reconstruction, until it
hit at good moment to stop completely. While these retries
curr_mark_cnt can be small- especially on HDD drives, so subtraction
result can be smaller than 0. However it is casted to uint without
checking. As a result of it the status bar in /proc/mdstat while stopping
is strange (it jumps between 0% and 99%).
The real problem occurs here after commit 72deb455b5ec ("block: remove
CONFIG_LBDAF"). Sector_div() macro has been changed, now the
divisor is casted to uint32. For db = -8 the divisior(db/32-1) becomes 0.
Check if db value can be really counted and replace these macro by
div64_u64() inline.
Signed-off-by: Mariusz Tkaczyk <mariusz.tkaczyk@intel.com>
Signed-off-by: Song Liu <songliubraving@fb.com>
This patch is not on mainline and is meant to 4.19 stable *only*.
After the patch description there's a reasoning about that.
Commit cd4a4ae4683d ("block: don't use blocking queue entered for
recursive bio submits") introduced the flag BIO_QUEUE_ENTERED in order
split bios bypass the blocking queue entering routine and use the live
non-blocking version. It was a result of an extensive discussion in
a linux-block thread[0], and the purpose of this change was to prevent
a hung task waiting on a reference to drop.
Happens that md raid0 split bios all the time, and more important,
it changes their underlying device to the raid member. After the change
introduced by this flag's usage, we experience various crashes if a raid0
member is removed during a large write. This happens because the bio
reaches the live queue entering function when the queue of the raid0
member is dying.
A simple reproducer of this behavior is presented below:
a) Build kernel v4.19.56-stable with CONFIG_BLK_DEV_THROTTLING=y.
b) Create a raid0 md array with 2 NVMe devices as members, and mount
it with an ext4 filesystem.
c) Run the following oneliner (supposing the raid0 is mounted in /mnt):
(dd of=/mnt/tmp if=/dev/zero bs=1M count=999 &); sleep 0.3;
echo 1 > /sys/block/nvme1n1/device/device/remove
(whereas nvme1n1 is the 2nd array member)
This will trigger the following warning/oops:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000155
PGD 0 P4D 0
Oops: 0000 [#1] SMP PTI
RIP: 0010:blk_throtl_bio+0x45/0x970
Call Trace:
generic_make_request_checks+0x1bf/0x690
generic_make_request+0x64/0x3f0
raid0_make_request+0x184/0x620 [raid0]
? raid0_make_request+0x184/0x620 [raid0]
md_handle_request+0x126/0x1a0
md_make_request+0x7b/0x180
generic_make_request+0x19e/0x3f0
submit_bio+0x73/0x140
This patch changes raid0 driver to fallback to the "old" blocking queue
entering procedure, by clearing the BIO_QUEUE_ENTERED from raid0 bios.
This prevents the crashes and restores the regular behavior of raid0
arrays when a member is removed during a large write.
[0] lore.kernel.org/linux-block/343bbbf6-64eb-879e-d19e-96aebb037d47@I-love.SAKURA.ne.jp
Why this is not on mainline?
The patch was originally submitted upstream in linux-raid and
linux-block mailing-lists - it was initially accepted by Song Liu,
but Christoph Hellwig[1] observed that there was a clean-up series
ready to be accepted from Ming Lei[2] that fixed the same issue.
The accepted patches from Ming's series in upstream are: commit
47cdee29ef9d ("block: move blk_exit_queue into __blk_release_queue") and
commit fe2008640ae3 ("block: don't protect generic_make_request_checks
with blk_queue_enter"). Those patches basically do a clean-up in the
block layer involving:
1) Putting back blk_exit_queue() logic into __blk_release_queue(); that
path was changed in the past and the logic from blk_exit_queue() was
added to blk_cleanup_queue().
2) Removing the guard/protection in generic_make_request_checks() with
blk_queue_enter().
The problem with Ming's series for -stable is that it relies in the
legacy request IO path removal. So it's "backport-able" to v5.0+,
but doing that for early versions (like 4.19) would incur in complex
code changes. Hence, it was suggested by Christoph and Song Liu that
this patch was submitted to stable only; otherwise merging it upstream
would add code to fix a path removed in a subsequent commit.
[1] lore.kernel.org/linux-block/20190521172258.GA32702@infradead.org
[2] lore.kernel.org/linux-block/20190515030310.20393-1-ming.lei@redhat.com
Cc: Ming Lei <ming.lei@redhat.com>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Fixes: cd4a4ae4683d ("block: don't use blocking queue entered for recursive bio submits")
Signed-off-by: Guilherme G. Piccoli <gpiccoli@canonical.com>
Acked-by: Song Liu <songliubraving@fb.com>
commit 211ad4b733037f66f9be0a79eade3da7ab11cbb8 upstream.
Currently, although we submit super bios in order (and super.nr_entries
is incremented by each logged entry), submit_bio() is async so each
super sector may not be written to log device in order and then the
final nr_entries may be smaller than it should be.
This problem can be reproduced by the xfstests generic/455 with ext4:
QA output created by 455
-Silence is golden
+mark 'end' does not exist
Fix this by serializing submission of super sectors to make sure each
is written to the log disk in order.
Fixes: 0e9cebe724597 ("dm: add log writes target")
Cc: stable@vger.kernel.org
Signed-off-by: zhangyi (F) <yi.zhang@huawei.com>
Suggested-by: Josef Bacik <josef@toxicpanda.com>
Reviewed-by: Josef Bacik <josef@toxicpanda.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit 1f0ffa67349c56ea54c03ccfd1e073c990e7411e upstream.
When people set a writeback percent via sysfs file,
/sys/block/bcache<N>/bcache/writeback_percent
current code directly sets BCACHE_DEV_WB_RUNNING to dc->disk.flags
and schedules kworker dc->writeback_rate_update.
If there is no cache set attached to, the writeback kernel thread is
not running indeed, running dc->writeback_rate_update does not make
sense and may cause NULL pointer deference when reference cache set
pointer inside update_writeback_rate().
This patch checks whether the cache set point (dc->disk.c) is NULL in
sysfs interface handler, and only set BCACHE_DEV_WB_RUNNING and
schedule dc->writeback_rate_update when dc->disk.c is not NULL (it
means the cache device is attached to a cache set).
This problem might be introduced from initial bcache commit, but
commit 3fd47bfe55b0 ("bcache: stop dc->writeback_rate_update properly")
changes part of the original code piece, so I add 'Fixes: 3fd47bfe55b0'
to indicate from which commit this patch can be applied.
Fixes: 3fd47bfe55b0 ("bcache: stop dc->writeback_rate_update properly")
Reported-by: Bjørn Forsman <bjorn.forsman@gmail.com>
Signed-off-by: Coly Li <colyli@suse.de>
Reviewed-by: Bjørn Forsman <bjorn.forsman@gmail.com>
commit 31b90956b124240aa8c63250243ae1a53585c5e2 upstream.
Recently people report bcache code compiled with gcc9 is broken, one of
the buggy behavior I observe is that two adjacent 4KB I/Os should merge
into one but they don't. Finally it turns out to be a stack corruption
caused by macro PRECEDING_KEY().
See how PRECEDING_KEY() is defined in bset.h,
437 #define PRECEDING_KEY(_k) \
438 ({ \
439 struct bkey *_ret = NULL; \
440 \
441 if (KEY_INODE(_k) || KEY_OFFSET(_k)) { \
442 _ret = &KEY(KEY_INODE(_k), KEY_OFFSET(_k), 0); \
443 \
444 if (!_ret->low) \
445 _ret->high--; \
446 _ret->low--; \
447 } \
448 \
449 _ret; \
450 })
At line 442, _ret points to address of a on-stack variable combined by
KEY(), the life range of this on-stack variable is in line 442-446,
once _ret is returned to bch_btree_insert_key(), the returned address
points to an invalid stack address and this address is overwritten in
the following called bch_btree_iter_init(). Then argument 'search' of
bch_btree_iter_init() points to some address inside stackframe of
bch_btree_iter_init(), exact address depends on how the compiler
allocates stack space. Now the stack is corrupted.
Fixes: 0eacac22034c ("bcache: PRECEDING_KEY()")
Reviewed-by: Rolf Fokkens <rolf@rolffokkens.nl>
Reviewed-by: Pierre JUHEN <pierre.juhen@orange.fr>
Tested-by: Shenghui Wang <shhuiw@foxmail.com>
Tested-by: Pierre JUHEN <pierre.juhen@orange.fr>
Cc: Kent Overstreet <kent.overstreet@gmail.com>
Cc: Nix <nix@esperi.org.uk>
This is the 4.19.47 stable release
drivers/char/random.c
kernel/irq_work.c
Issues with kernel/irq/manage.c
A use after free bug was fixed in stable. But it requires a backport of changes
from rt-devel. The bug still exists in this tree for PREEMPT_RT, but will be
fixed when backporting the rt-devel patches.
[ Upstream commit 78d4eb8ad9e1d413449d1b7a060f50b6efa81ebd ]
clang has identified a code path in which it thinks a
variable may be unused:
drivers/md/bcache/alloc.c:333:4: error: variable 'bucket' is used uninitialized whenever 'if' condition is false
[-Werror,-Wsometimes-uninitialized]
fifo_pop(&ca->free_inc, bucket);
drivers/md/bcache/util.h:219:27: note: expanded from macro 'fifo_pop'
#define fifo_pop(fifo, i) fifo_pop_front(fifo, (i))
drivers/md/bcache/util.h:189:6: note: expanded from macro 'fifo_pop_front'
if (_r) { \
drivers/md/bcache/alloc.c:343:46: note: uninitialized use occurs here
allocator_wait(ca, bch_allocator_push(ca, bucket));
drivers/md/bcache/alloc.c:287:7: note: expanded from macro 'allocator_wait'
if (cond) \
drivers/md/bcache/alloc.c:333:4: note: remove the 'if' if its condition is always true
drivers/md/bcache/util.h:189:2: note: expanded from macro 'fifo_pop_front'
if (_r) { \
drivers/md/bcache/alloc.c:331:15: note: initialize the variable 'bucket' to silence this warning
long bucket;
This cannot happen in practice because we only enter the loop
if there is at least one element in the list.
Slightly rearranging the code makes this clearer to both the
reader and the compiler, which avoids the warning.
Reviewed-by: Nathan Chancellor <natechancellor@gmail.com>
[ Upstream commit ce3e4cfb59cb382f8e5ce359238aa580d4ae7778 ]
Currently run_cache_set() has no return value, if there is failure in
bch_journal_replay(), the caller of run_cache_set() has no idea about
such failure and just continue to execute following code after
run_cache_set(). The internal failure is triggered inside
bch_journal_replay() and being handled in async way. This behavior is
inefficient, while failure handling inside bch_journal_replay(), cache
register code is still running to start the cache set. Registering and
unregistering code running as same time may introduce some rare race
condition, and make the code to be more hard to be understood.
This patch adds return value to run_cache_set(), and returns -EIO if
bch_journal_rreplay() fails. Then caller of run_cache_set() may detect
such failure and stop registering code flow immedidately inside
register_cache_set().
If journal replay fails, run_cache_set() can report error immediately
to register_cache_set(). This patch makes the failure handling for
bch_journal_replay() be in synchronized way, easier to understand and
debug, and avoid poetential race condition for register-and-unregister
in same time.
[ Upstream commit 631207314d88e9091be02fbdd1fdadb1ae2ed79a ]
journal replay failed with messages:
Sep 10 19:10:43 ceph kernel: bcache: error on
bb379a64-e44e-4812-b91d-a5599871a3b1: bcache: journal entries
2057493-2057567 missing! (replaying 2057493-2076601), disabling
caching
The reason is in journal_reclaim(), when discard is enabled, we send
discard command and reclaim those journal buckets whose seq is old
than the last_seq_now, but before we write a journal with last_seq_now,
the machine is restarted, so the journal with the last_seq_now is not
written to the journal bucket, and the last_seq_wrote in the newest
journal is old than last_seq_now which we expect to be, so when we doing
replay, journals from last_seq_wrote to last_seq_now are missing.
It's hard to write a journal immediately after journal_reclaim(),
and it harmless if those missed journal are caused by discarding
since those journals are already wrote to btree node. So, if miss
seqs are started from the beginning journal, we treat it as normal,
and only print a message to show the miss journal, and point out
it maybe caused by discarding.
Patch v2 add a judgement condition to ignore the missed journal
only when discard enabled as Coly suggested.
(Coly Li: rebase the patch with other changes in bch_journal_replay())
Signed-off-by: Tang Junhui <tang.junhui.linux@gmail.com>
Tested-by: Dennis Schridde <devurandom@gmx.net>
[ Upstream commit 68d10e6979a3b59e3cd2e90bfcafed79c4cf180a ]
When failure happens inside bch_journal_replay(), calling
cache_set_err_on() and handling the failure in async way is not a good
idea. Because after bch_journal_replay() returns, registering code will
continue to execute following steps, and unregistering code triggered
by cache_set_err_on() is running in same time. First it is unnecessary
to handle failure and unregister cache set in an async way, second there
might be potential race condition to run register and unregister code
for same cache set.
So in this patch, if failure happens in bch_journal_replay(), we don't
call cache_set_err_on(), and just print out the same error message to
kernel message buffer, then return -EIO immediately caller. Then caller
can detect such failure and handle it in synchrnozied way.
Reviewed-by: Hannes Reinecke <hare@suse.com>
CACHE_SYNC branch of run_cache_set
[ Upstream commit 95f18c9d1310730d075499a75aaf13bcd60405a7 ]
In the CACHE_SYNC branch of run_cache_set(), LIST_HEAD(journal) is used
to collect journal_replay(s) and filled by bch_journal_read().
If all goes well, bch_journal_replay() will release the list of
jounal_replay(s) at the end of the branch.
If something goes wrong, code flow will jump to the label "err:" and leave
the list unreleased.
This patch will release the list of journal_replay(s) in the case of
error detected.
v1 -> v2:
* Move the release code to the location after label 'err:' to
simply the change.
Signed-off-by: Shenghui Wang <shhuiw@foxmail.com>
commit b2176a1dfb518d870ee073445d27055fea64dfb8 upstream.
The problem is that any 'uptodate' vs 'disks' check is not precise
in this path. Put a "WARN_ON(!test_bit(R5_UPTODATE, &dev->flags)" on the
device that might try to kick off writes and then skip the action.
Better to prevent the raid driver from taking unexpected action *and* keep
the system alive vs killing the machine with BUG_ON.
Note: fixed warning reported by kbuild test robot <lkp@intel.com>
Signed-off-by: Nigel Croxon <ncroxon@redhat.com>
commit a25d8c327bb41742dbd59f8c545f59f3b9c39983 upstream.
This reverts commit 4f4fd7c5798bbdd5a03a60f6269cf1177fbd11ef.
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Nigel Croxon <ncroxon@redhat.com>
Cc: Xiao Ni <xni@redhat.com>
commit 940bc471780b004a5277c1931f52af363c2fc9da upstream.
Commit b592211c33f7 ("dm mpath: fix attached_handler_name leak and
dangling hw_handler_name pointer") fixed a memory leak for the case
where setup_scsi_dh() returns failure. But setup_scsi_dh may return
success and not "use" attached_handler_name if the
retain_attached_hwhandler flag is not set on the map. As setup_scsi_sh
properly "steals" the pointer by nullifying it, freeing it
unconditionally in parse_path() is safe.
Fixes: b592211c33f7 ("dm mpath: fix attached_handler_name leak and dangling hw_handler_name pointer")
Reported-by: Yufen Yu <yuyufen@huawei.com>
Signed-off-by: Martin Wilck <mwilck@suse.com>
commit 30bba430ddf737978e40561198693ba91386dac1 upstream.
When we use separate devices for data and metadata, dm-integrity would
incorrectly calculate the size of the metadata device as if it had
512-byte block size - and it would refuse activation with larger block
size and smaller metadata device.
Fix this so that it takes actual block size into account, which fixes
the following reported issue:
https://gitlab.com/cryptsetup/cryptsetup/issues/450
Fixes: 356d9d52e122 ("dm integrity: allow separate metadata device")
Cc: stable@vger.kernel.org # v4.19+
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
commit 81bc6d150ace6250503b825d9d0c10f7bbd24095 upstream.
When the target line contains an invalid device, delay_ctr() will call
delay_dtr() with NULL workqueue. Attempting to destroy the NULL
workqueue causes a crash.
commit 7aedf75ff740a98f3683439449cd91c8662d03b2 upstream.
The function blkdev_report_zones() returns success even if no zone
information is reported (empty report). Empty zone reports can only
happen if the report start sector passed exceeds the device capacity.
The conditions for this to happen are either a bug in the caller code,
or, a change in the device that forced the low level driver to change
the device capacity to a value that is lower than the report start
sector. This situation includes a failed disk revalidation resulting in
the disk capacity being changed to 0.
If this change happens while dm-zoned is in its initialization phase
executing dmz_init_zones(), this function may enter an infinite loop
and hang the system. To avoid this, add a check to disallow empty zone
reports and bail out early. Also fix the function dmz_update_zone() to
make sure that the report for the requested zone was correctly obtained.
Fixes: 3b1a94c88b79 ("dm zoned: drive-managed zoned block device target")
Signed-off-by: Damien Le Moal <damien.lemoal@wdc.com>
Reviewed-by: Shaun Tancheff <shaun@tancheff.com>
commit e28adc3bf34e434b30e8d063df4823ba0f3e0529 upstream.
Add missing dm_bitset_cursor_next() to properly advance the bitset
cursor.
Otherwise, the discarded state of all blocks is set according to the
discarded state of the first block.
Fixes: ae4a46a1f6 ("dm cache metadata: use bitset cursor api to load discard bitset")
Signed-off-by: Nikos Tsironis <ntsironis@arrikto.com>
commit ee37e62191a59d253fc916b9fc763deb777211e2 upstream.
When doing re-add, we need to ensure rdev->mddev->pers is not NULL,
which can avoid potential NULL pointer derefence in fallowing
add_bound_rdev().
Fixes: a6da4ef85cef ("md: re-add a failed disk")
Cc: NeilBrown <neilb@suse.com>
Cc: <stable@vger.kernel.org> # 4.4+
Reviewed-by: NeilBrown <neilb@suse.com>
Signed-off-by: Yufen Yu <yuyufen@huawei.com>
commit 2bc13b83e6298486371761de503faeffd15b7534 upstream.
Currently if many flush requests are submitted to an md device is quick
succession, they are serialized and can take a long to process them all.
We don't really need to call flush all those times - a single flush call
can satisfy all requests submitted before it started.
So keep track of when the current flush started and when it finished,
allow any pending flush that was requested before the flush started
to complete without waiting any more.
Test results from Xiao:
Test is done on a raid10 device which is created by 4 SSDs. The tool is
dbench.
1. The latest linux stable kernel
Operation Count AvgLat MaxLat
Deltree 768 10.509 78.305
Flush 2078376 0.013 10.094
Close 21787697 0.019 18.821
LockX 96580 0.007 3.184
Mkdir 384 0.008 0.062
Rename 1255883 0.191 23.534
ReadX 46495589 0.020 14.230
WriteX 14790591 7.123 60.706
Unlink 5989118 0.440 54.551
UnlockX 96580 0.005 2.736
FIND_FIRST 10393845 0.042 12.079
SET_FILE_INFORMATION 2415558 0.129 10.088
QUERY_FILE_INFORMATION 4711725 0.005 8.462
QUERY_PATH_INFORMATION 26883327 0.032 21.715
QUERY_FS_INFORMATION 4929409 0.010 8.238
NTCreateX 29660080 0.100 53.268
Throughput 1034.88 MB/sec (sync open) 128 clients 128 procs
max_latency=60.712 ms
2. With patch1 "Revert "MD: fix lock contention for flush bios""
Deltree 256 8.326 36.761
Flush 693291 3.974 180.269
Close 7266404 0.009 36.929
LockX 32160 0.006 0.840
Mkdir 128 0.008 0.021
Rename 418755 0.063 29.945
ReadX 15498708 0.007 7.216
WriteX 4932310 22.482 267.928
Unlink 1997557 0.109 47.553
UnlockX 32160 0.004 1.110
FIND_FIRST 3465791 0.036 7.320
SET_FILE_INFORMATION 805825 0.015 1.561
QUERY_FILE_INFORMATION 1570950 0.005 2.403
QUERY_PATH_INFORMATION 8965483 0.013 14.277
QUERY_FS_INFORMATION 1643626 0.009 3.314
NTCreateX 9892174 0.061 41.278
Throughput 345.009 MB/sec (sync open) 128 clients 128 procs
max_latency=267.939 m
3. With patch1 and patch2
Deltree 768 9.570 54.588
Flush 2061354 0.666 15.102
Close 21604811 0.012 25.697
LockX 95770 0.007 1.424
Mkdir 384 0.008 0.053
Rename 1245411 0.096 12.263
ReadX 46103198 0.011 12.116
WriteX 14667988 7.375 60.069
Unlink 5938936 0.173 30.905
UnlockX 95770 0.005 4.147
FIND_FIRST 10306407 0.041 11.715
SET_FILE_INFORMATION 2395987 0.048 7.640
QUERY_FILE_INFORMATION 4672371 0.005 9.291
QUERY_PATH_INFORMATION 26656735 0.018 19.719
QUERY_FS_INFORMATION 4887940 0.010 7.654
NTCreateX 29410811 0.059 28.551
Throughput 1026.21 MB/sec (sync open) 128 clients 128 procs
max_latency=60.075 ms
Cc: <stable@vger.kernel.org> # v4.19+
Tested-by: Xiao Ni <xni@redhat.com>
Signed-off-by: NeilBrown <neilb@suse.com>
commit 4bc034d35377196c854236133b07730a777c4aba upstream.
This reverts commit 5a409b4f56d50b212334f338cb8465d65550cd85.
This patch has two problems.
1/ it make multiple calls to submit_bio() from inside a make_request_fn.
The bios thus submitted will be queued on current->bio_list and not
submitted immediately. As the bios are allocated from a mempool,
this can theoretically result in a deadlock - all the pool of requests
could be in various ->bio_list queues and a subsequent mempool_alloc
could block waiting for one of them to be released.
2/ It aims to handle a case when there are many concurrent flush requests.
It handles this by submitting many requests in parallel - all of which
are identical and so most of which do nothing useful.
It would be more efficient to just send one lower-level request, but
allow that to satisfy multiple upper-level requests.
Fixes: 5a409b4f56d5 ("MD: fix lock contention for flush bios")
commit 1bee2addc0c8470c8aaa65ef0599eeae96dd88bc upstream.
In journal_reclaim() ja->cur_idx of each cache will be update to
reclaim available journal buckets. Variable 'int n' is used to count how
many cache is successfully reclaimed, then n is set to c->journal.key
by SET_KEY_PTRS(). Later in journal_write_unlocked(), a for_each_cache()
loop will write the jset data onto each cache.
The problem is, if all jouranl buckets on each cache is full, the
following code in journal_reclaim(),
529 for_each_cache(ca, c, iter) {
530 struct journal_device *ja = &ca->journal;
531 unsigned int next = (ja->cur_idx + 1) % ca->sb.njournal_buckets;
532
533 /* No space available on this device */
534 if (next == ja->discard_idx)
535 continue;
536
537 ja->cur_idx = next;
538 k->ptr[n++] = MAKE_PTR(0,
539 bucket_to_sector(c, ca->sb.d[ja->cur_idx]),
540 ca->sb.nr_this_dev);
541 }
542
543 bkey_init(k);
544 SET_KEY_PTRS(k, n);
If there is no available bucket to reclaim, the if() condition at line
534 will always true, and n remains 0. Then at line 544, SET_KEY_PTRS()
will set KEY_PTRS field of c->journal.key to 0.
Setting KEY_PTRS field of c->journal.key to 0 is wrong. Because in
journal_write_unlocked() the journal data is written in following loop,
649 for (i = 0; i < KEY_PTRS(k); i++) {
650-671 submit journal data to cache device
672 }
If KEY_PTRS field is set to 0 in jouranl_reclaim(), the journal data
won't be written to cache device here. If system crahed or rebooted
before bkeys of the lost journal entries written into btree nodes, data
corruption will be reported during bcache reload after rebooting the
system.
Indeed there is only one cache in a cache set, there is no need to set
KEY_PTRS field in journal_reclaim() at all. But in order to keep the
for_each_cache() logic consistent for now, this patch fixes the above
problem by not setting 0 KEY_PTRS of journal key, if there is no bucket
available to reclaim.
commit a4b732a248d12cbdb46999daf0bf288c011335eb upstream.
There is a race between cache device register and cache set unregister.
For an already registered cache device, register_bcache will call
bch_is_open to iterate through all cachesets and check every cache
there. The race occurs if cache_set_free executes at the same time and
clears the caches right before ca is dereferenced in bch_is_open_cache.
To close the race, let's make sure the clean up work is protected by
the bch_register_lock as well.
This issue can be reproduced as follows,
while true; do echo /dev/XXX> /sys/fs/bcache/register ; done&
while true; do echo 1> /sys/block/XXX/bcache/set/unregister ; done &
and results in the following oops,
[ +0.000053] BUG: unable to handle kernel NULL pointer dereference at 0000000000000998
[ +0.000457] #PF error: [normal kernel read fault]
[ +0.000464] PGD 800000003ca9d067 P4D 800000003ca9d067 PUD 3ca9c067 PMD 0
[ +0.000388] Oops: 0000 [#1] SMP PTI
[ +0.000269] CPU: 1 PID: 3266 Comm: bash Not tainted 5.0.0+ #6
[ +0.000346] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.11.0-2.fc28 04/01/2014
[ +0.000472] RIP: 0010:register_bcache+0x1829/0x1990 [bcache]
[ +0.000344] Code: b0 48 83 e8 50 48 81 fa e0 e1 10 c0 0f 84 a9 00 00 00 48 89 c6 48 89 ca 0f b7 ba 54 04 00 00 4c 8b 82 60 0c 00 00 85 ff 74 2f <49> 3b a8 98 09 00 00 74 4e 44 8d 47 ff 31 ff 49 c1 e0 03 eb 0d
[ +0.000839] RSP: 0018:ffff92ee804cbd88 EFLAGS: 00010202
[ +0.000328] RAX: ffffffffc010e190 RBX: ffff918b5c6b5000 RCX: ffff918b7d8e0000
[ +0.000399] RDX: ffff918b7d8e0000 RSI: ffffffffc010e190 RDI: 0000000000000001
[ +0.000398] RBP: ffff918b7d318340 R08: 0000000000000000 R09: ffffffffb9bd2d7a
[ +0.000385] R10: ffff918b7eb253c0 R11: ffffb95980f51200 R12: ffffffffc010e1a0
[ +0.000411] R13: fffffffffffffff2 R14: 000000000000000b R15: ffff918b7e232620
[ +0.000384] FS: 00007f955bec2740(0000) GS:ffff918b7eb00000(0000) knlGS:0000000000000000
[ +0.000420] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ +0.000801] CR2: 0000000000000998 CR3: 000000003cad6000 CR4: 00000000001406e0
[ +0.000837] Call Trace:
[ +0.000682] ? _cond_resched+0x10/0x20
[ +0.000691] ? __kmalloc+0x131/0x1b0
[ +0.000710] kernfs_fop_write+0xfa/0x170
[ +0.000733] __vfs_write+0x2e/0x190
[ +0.000688] ? inode_security+0x10/0x30
[ +0.000698] ? selinux_file_permission+0xd2/0x120
[ +0.000752] ? security_file_permission+0x2b/0x100
[ +0.000753] vfs_write+0xa8/0x1a0
[ +0.000676] ksys_write+0x4d/0xb0
[ +0.000699] do_syscall_64+0x3a/0xf0
[ +0.000692] entry_SYSCALL_64_after_hwframe+0x44/0xa9
Signed-off-by: Liang Chen <liangchen.linux@gmail.com>
commit 4f4fd7c5798bbdd5a03a60f6269cf1177fbd11ef upstream.
Changing state from check_state_check_result to
check_state_compute_result not only is unsafe but also doesn't
appear to serve a valid purpose. A raid6 check should only be
pushing out extra writes if doing repair and a mis-match occurs.
The stripe dev management will already try and do repair writes
for failing sectors.
This patch makes the raid6 check_state_check_result handling
work more like raid5's. If somehow too many failures for a
check, just quit the check operation for the stripe. When any
checks pass, don't try and use check_state_compute_result for
a purpose it isn't needed for and is unsafe for. Just mark the
stripe as in sync for passing its parity checks and let the
stripe dev read/write code and the bad blocks list do their
job handling I/O errors.
Repro steps from Xiao:
These are the steps to reproduce this problem:
1. redefined OPT_MEDIUM_ERR_ADDR to 12000 in scsi_debug.c
2. insmod scsi_debug.ko dev_size_mb=11000 max_luns=1 num_tgts=1
3. mdadm --create /dev/md127 --level=6 --raid-devices=5 /dev/sde1 /dev/sde2 /dev/sde3 /dev/sde5 /dev/sde6
sde is the disk created by scsi_debug
4. echo "2" >/sys/module/scsi_debug/parameters/opts
5. raid-check
It panic:
[ 4854.730899] md: data-check of RAID array md127
[ 4854.857455] sd 5:0:0:0: [sdr] tag#80 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 4854.859246] sd 5:0:0:0: [sdr] tag#80 Sense Key : Medium Error [current]
[ 4854.860694] sd 5:0:0:0: [sdr] tag#80 Add. Sense: Unrecovered read error
[ 4854.862207] sd 5:0:0:0: [sdr] tag#80 CDB: Read(10) 28 00 00 00 2d 88 00 04 00 00
[ 4854.864196] print_req_error: critical medium error, dev sdr, sector 11656 flags 0
[ 4854.867409] sd 5:0:0:0: [sdr] tag#100 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 4854.869469] sd 5:0:0:0: [sdr] tag#100 Sense Key : Medium Error [current]
[ 4854.871206] sd 5:0:0:0: [sdr] tag#100 Add. Sense: Unrecovered read error
[ 4854.872858] sd 5:0:0:0: [sdr] tag#100 CDB: Read(10) 28 00 00 00 2e e0 00 00 08 00
[ 4854.874587] print_req_error: critical medium error, dev sdr, sector 12000 flags 4000
[ 4854.876456] sd 5:0:0:0: [sdr] tag#101 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 4854.878552] sd 5:0:0:0: [sdr] tag#101 Sense Key : Medium Error [current]
[ 4854.880278] sd 5:0:0:0: [sdr] tag#101 Add. Sense: Unrecovered read error
[ 4854.881846] sd 5:0:0:0: [sdr] tag#101 CDB: Read(10) 28 00 00 00 2e e8 00 00 08 00
[ 4854.883691] print_req_error: critical medium error, dev sdr, sector 12008 flags 4000
[ 4854.893927] sd 5:0:0:0: [sdr] tag#166 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 4854.896002] sd 5:0:0:0: [sdr] tag#166 Sense Key : Medium Error [current]
[ 4854.897561] sd 5:0:0:0: [sdr] tag#166 Add. Sense: Unrecovered read error
[ 4854.899110] sd 5:0:0:0: [sdr] tag#166 CDB: Read(10) 28 00 00 00 2e e0 00 00 10 00
[ 4854.900989] print_req_error: critical medium error, dev sdr, sector 12000 flags 0
[ 4854.902757] md/raid:md127: read error NOT corrected!! (sector 9952 on sdr1).
[ 4854.904375] md/raid:md127: read error NOT corrected!! (sector 9960 on sdr1).
[ 4854.906201] ------------[ cut here ]------------
[ 4854.907341] kernel BUG at drivers/md/raid5.c:4190!
raid5.c:4190 above is this BUG_ON:
handle_parity_checks6()
BUG_ON(s->uptodate < disks - 1); /* We don't need Q to recover */
Cc: <stable@vger.kernel.org> # v3.16+
OriginalAuthor: David Jeffery <djeffery@redhat.com>
Tested-by: David Jeffery <djeffery@redhat.com>
Signed-off-by: David Jeffy <djeffery@redhat.com>
This is the 4.19.37 stable release
include/linux/sched/mm.h
kernel/sched/fair.c
commit 4ed319c6ac08e9a28fca7ac188181ac122f4de84 upstream.
dm-integrity will deadlock if overlapping I/O is issued to it, the bug
was introduced by commit 724376a04d1a ("dm integrity: implement fair
range locks"). Users rarely use overlapping I/O so this bug went
undetected until now.
Fix this bug by correcting, likely cut-n-paste, typos in
ranges_overlap() and also remove a flawed ranges_overlap() check in
remove_range_unlocked(). This condition could leave unprocessed bios
hanging on wait_list forever.
Fixes: 724376a04d1a ("dm integrity: implement fair range locks")
commit eb40c0acdc342b815d4d03ae6abb09e80c0f2988 upstream.
Some devices don't use blk_integrity but still want stable pages
because they do their own checksumming. Examples include rbd and iSCSI
when data digests are negotiated. Stacking DM (and thus LVM) on top of
these devices results in sporadic checksum errors.
Set BDI_CAP_STABLE_WRITES if any underlying device has it set.
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
PAGE_SIZE")
commit 75ae193626de3238ca5fb895868ec91c94e63b1b upstream.
The limit was already incorporated to dm-crypt with commit 4e870e948fba
("dm crypt: fix error with too large bios"), so we don't need to apply
it globally to all targets. The quantity BIO_MAX_PAGES * PAGE_SIZE is
wrong anyway because the variable ti->max_io_len it is supposed to be in
the units of 512-byte sectors not in bytes.
Reduction of the limit to 1048576 sectors could even cause data
corruption in rare cases - suppose that we have a dm-striped device with
stripe size 768MiB. The target will call dm_set_target_max_io_len with
the value 1572864. The buggy code would reduce it to 1048576. Now, the
dm-core will errorneously split the bios on 1048576-sector boundary
insetad of 1572864-sector boundary and pass these stripe-crossing bios
to the striped target.
Cc: stable@vger.kernel.org # v4.16+
Fixes: 8f50e358153d ("dm: limit the max bio size as BIO_MAX_PAGES * PAGE_SIZE")
Acked-by: Ming Lei <ming.lei@redhat.com>
commit 0d74e6a3b6421d98eeafbed26f29156d469bc0b5 upstream.
If the string opt_string is small, the function memcmp can access bytes
that are beyond the terminating nul character. In theory, it could cause
segfault, if opt_string were located just below some unmapped memory.
Change from memcmp to strncmp so that we don't read bytes beyond the end
of the string.
Cc: stable@vger.kernel.org # v4.12+
[ Upstream commit 5b5fd3c94eef69dcfaa8648198e54c92e5687d6d ]
Current code already uses d_strtoul_nonzero() to convert input string
to an unsigned integer, to make sure writeback_rate_p_term_inverse
won't be zero value. But overflow may happen when converting input
string to an unsigned integer value by d_strtoul_nonzero(), then
dc->writeback_rate_p_term_inverse can still be set to 0 even if the
sysfs file input value is not zero, e.g. 4294967296 (a.k.a UINT_MAX+1).
If dc->writeback_rate_p_term_inverse is set to 0, it might cause a
dev-zero error in following code from __update_writeback_rate(),
int64_t proportional_scaled =
div_s64(error, dc->writeback_rate_p_term_inverse);
This patch replaces d_strtoul_nonzero() by sysfs_strtoul_clamp() and
limit the value range in [1, UINT_MAX]. Then the unsigned integer
overflow and dev-zero error can be avoided.
[ Upstream commit 596b5a5dd1bc2fa019fdaaae522ef331deef927f ]
Currently sysfs_strtoul_clamp() is defined as,
82 #define sysfs_strtoul_clamp(file, var, min, max) \
83 do { \
84 if (attr == &sysfs_ ## file) \
85 return strtoul_safe_clamp(buf, var, min, max) \
86 ?: (ssize_t) size; \
87 } while (0)
The problem is, if bit width of var is less then unsigned long, min and
max may not protect var from integer overflow, because overflow happens
in strtoul_safe_clamp() before checking min and max.
To fix such overflow in sysfs_strtoul_clamp(), to make min and max take
effect, this patch adds an unsigned long variable, and uses it to macro
strtoul_safe_clamp() to convert an unsigned long value in range defined
by [min, max]. Then assign this value to var. By this method, if bit
width of var is less than unsigned long, integer overflow won't happen
before min and max are checking.
Now sysfs_strtoul_clamp() can properly handle smaller data type like
unsigned int, of cause min and max should be defined in range of
unsigned int too.
[ Upstream commit c3b75a2199cdbfc1c335155fe143d842604b1baa ]
dc->writeback_rate_i_term_inverse can be set via sysfs interface. It is
in type unsigned int, and convert from input string by d_strtoul(). The
problem is d_strtoul() does not check valid range of the input, if
4294967296 is written into sysfs file writeback_rate_i_term_inverse,
an overflow of unsigned integer will happen and value 0 is set to
dc->writeback_rate_i_term_inverse.
In writeback.c:__update_writeback_rate(), there are following lines of
code,
integral_scaled = div_s64(dc->writeback_rate_integral,
dc->writeback_rate_i_term_inverse);
If dc->writeback_rate_i_term_inverse is set to 0 via sysfs interface,
a div-zero error might be triggered in the above code.
Therefore we need to add a range limitation in the sysfs interface,
this is what this patch does, use sysfs_stroul_clamp() to replace
d_strtoul() and restrict the input range in [1, UINT_MAX].
[ Upstream commit 8c27a3953e92eb0b22dbb03d599f543a05f9574e ]
People may set sequential_cutoff of a cached device via sysfs file,
but current code does not check input value overflow. E.g. if value
4294967295 (UINT_MAX) is written to file sequential_cutoff, its value
is 4GB, but if 4294967296 (UINT_MAX + 1) is written into, its value
will be 0. This is an unexpected behavior.
This patch replaces d_strtoi_h() by sysfs_strtoul_clamp() to convert
input string to unsigned integer value, and limit its range in
[0, UINT_MAX]. Then the input overflow can be fixed.
[ Upstream commit a91fbda49f746119828f7e8ad0f0aa2ab0578f65 ]
Cache set sysfs entry io_error_halflife is used to set c->error_decay.
c->error_decay is in type unsigned int, and it is converted by
strtoul_or_return(), therefore overflow to c->error_decay is possible
for a large input value.
This patch fixes the overflow by using strtoul_safe_clamp() to convert
input string to an unsigned long value in range [0, UINT_MAX], then
divides by 88 and set it to c->error_decay.
[ Upstream commit 70de2cbda8a5d788284469e755f8b097d339c240 ]
Invoking dm_get_device() twice on the same device path with different
modes is dangerous. Because in that case, upgrade_mode() will alloc a
new 'dm_dev' and free the old one, which may be referenced by a previous
caller. Dereferencing the dangling pointer will trigger kernel NULL
pointer dereference.
The following two cases can reproduce this issue. Actually, they are
invalid setups that must be disallowed, e.g.:
1. Creating a thin-pool with read_only mode, and the same device as
both metadata and data.
dmsetup create thinp --table \
"0 41943040 thin-pool /dev/vdb /dev/vdb 128 0 1 read_only"
BUG: unable to handle kernel NULL pointer dereference at 0000000000000080
Call Trace:
new_read+0xfb/0x110 [dm_bufio]
dm_bm_read_lock+0x43/0x190 [dm_persistent_data]
? kmem_cache_alloc_trace+0x15c/0x1e0
__create_persistent_data_objects+0x65/0x3e0 [dm_thin_pool]
dm_pool_metadata_open+0x8c/0xf0 [dm_thin_pool]
pool_ctr.cold.79+0x213/0x913 [dm_thin_pool]
? realloc_argv+0x50/0x70 [dm_mod]
dm_table_add_target+0x14e/0x330 [dm_mod]
table_load+0x122/0x2e0 [dm_mod]
? dev_status+0x40/0x40 [dm_mod]
ctl_ioctl+0x1aa/0x3e0 [dm_mod]
dm_ctl_ioctl+0xa/0x10 [dm_mod]
do_vfs_ioctl+0xa2/0x600
? handle_mm_fault+0xda/0x200
? __do_page_fault+0x26c/0x4f0
ksys_ioctl+0x60/0x90
__x64_sys_ioctl+0x16/0x20
do_syscall_64+0x55/0x150
2. Creating a external snapshot using the same thin-pool device.
"0 41943040 thin-pool /dev/vdc /dev/vdb 128 0 2 ignore_discard"
dmsetup message /dev/mapper/thinp 0 "create_thin 0"
dmsetup create snap --table \
"0 204800 thin /dev/mapper/thinp 0 /dev/mapper/thinp"
BUG: unable to handle kernel NULL pointer dereference at 0000000000000000
Call Trace:
? __alloc_pages_nodemask+0x13c/0x2e0
retrieve_status+0xa5/0x1f0 [dm_mod]
? dm_get_live_or_inactive_table.isra.7+0x20/0x20 [dm_mod]
table_status+0x61/0xa0 [dm_mod]
? ksys_write+0x4f/0xb0
Signed-off-by: Jason Cai (Xiang Feng) <jason.cai@linux.alibaba.com>
This is the 4.19.31 stable release
mm/swap.c
commit dc7292a5bcb4c878b076fca2ac3fc22f81b8f8df upstream.
In 'commit 752f66a75aba ("bcache: use REQ_PRIO to indicate bio for
metadata")' REQ_META is replaced by REQ_PRIO to indicate metadata bio.
This assumption is not always correct, e.g. XFS uses REQ_META to mark
metadata bio other than REQ_PRIO. This is why Nix noticed that bcache
does not cache metadata for XFS after the above commit.
Thanks to Dave Chinner, he explains the difference between REQ_META and
REQ_PRIO from view of file system developer. Here I quote part of his
explanation from mailing list,
REQ_META is used for metadata. REQ_PRIO is used to communicate to
the lower layers that the submitter considers this IO to be more
important that non REQ_PRIO IO and so dispatch should be expedited.
IOWs, if the filesystem considers metadata IO to be more important
that user data IO, then it will use REQ_PRIO | REQ_META rather than
just REQ_META.
Then it seems bios with REQ_META or REQ_PRIO should both be cached for
performance optimation, because they are all probably low I/O latency
demand by upper layer (e.g. file system).
So in this patch, when we want to decide whether to bypass the cache,
REQ_META and REQ_PRIO are both checked. Then both metadata and
high priority I/O requests will be handled properly.
Reported-by: Nix <nix@esperi.org.uk>
Reviewed-by: Andre Noll <maan@tuebingen.mpg.de>
Tested-by: Nix <nix@esperi.org.uk>
commit e406f12dde1a8375d77ea02d91f313fb1a9c6aec upstream.
mddev->sync_thread can be set to NULL on kzalloc failure downstream.
The patch checks for such a scenario and frees allocated resources.
Committer node:
Added similar fix to raid5.c, as suggested by Guoqing.
Cc: stable@vger.kernel.org # v3.16+
Acked-by: Guoqing Jiang <gqjiang@suse.com>
Signed-off-by: Aditya Pakki <pakki001@umn.edu>
commit 9951379b0ca88c95876ad9778b9099e19a95d566 upstream.
Some users see panics like the following when performing fstrim on a
bcached volume:
[ 529.803060] BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
[ 530.183928] #PF error: [normal kernel read fault]
[ 530.412392] PGD 8000001f42163067 P4D 8000001f42163067 PUD 1f42168067 PMD 0
[ 530.750887] Oops: 0000 [#1] SMP PTI
[ 530.920869] CPU: 10 PID: 4167 Comm: fstrim Kdump: loaded Not tainted 5.0.0-rc1+ #3
[ 531.290204] Hardware name: HP ProLiant DL360 Gen9/ProLiant DL360 Gen9, BIOS P89 12/27/2015
[ 531.693137] RIP: 0010:blk_queue_split+0x148/0x620
[ 531.922205] Code: 60 38 89 55 a0 45 31 db 45 31 f6 45 31 c9 31 ff 89 4d 98 85 db 0f 84 7f 04 00 00 44 8b 6d 98 4c 89 ee 48 c1 e6 04 49 03 70 78 <8b> 46 08 44 8b 56 0c 48
8b 16 44 29 e0 39 d8 48 89 55 a8 0f 47 c3
[ 532.838634] RSP: 0018:ffffb9b708df39b0 EFLAGS: 00010246
[ 533.093571] RAX: 00000000ffffffff RBX: 0000000000046000 RCX: 0000000000000000
[ 533.441865] RDX: 0000000000000200 RSI: 0000000000000000 RDI: 0000000000000000
[ 533.789922] RBP: ffffb9b708df3a48 R08: ffff940d3b3fdd20 R09: 0000000000000000
[ 534.137512] R10: ffffb9b708df3958 R11: 0000000000000000 R12: 0000000000000000
[ 534.485329] R13: 0000000000000000 R14: 0000000000000000 R15: ffff940d39212020
[ 534.833319] FS: 00007efec26e3840(0000) GS:ffff940d1f480000(0000) knlGS:0000000000000000
[ 535.224098] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 535.504318] CR2: 0000000000000008 CR3: 0000001f4e256004 CR4: 00000000001606e0
[ 535.851759] Call Trace:
[ 535.970308] ? mempool_alloc_slab+0x15/0x20
[ 536.174152] ? bch_data_insert+0x42/0xd0 [bcache]
[ 536.403399] blk_mq_make_request+0x97/0x4f0
[ 536.607036] generic_make_request+0x1e2/0x410
[ 536.819164] submit_bio+0x73/0x150
[ 536.980168] ? submit_bio+0x73/0x150
[ 537.149731] ? bio_associate_blkg_from_css+0x3b/0x60
[ 537.391595] ? _cond_resched+0x1a/0x50
[ 537.573774] submit_bio_wait+0x59/0x90
[ 537.756105] blkdev_issue_discard+0x80/0xd0
[ 537.959590] ext4_trim_fs+0x4a9/0x9e0
[ 538.137636] ? ext4_trim_fs+0x4a9/0x9e0
[ 538.324087] ext4_ioctl+0xea4/0x1530
[ 538.497712] ? _copy_to_user+0x2a/0x40
[ 538.679632] do_vfs_ioctl+0xa6/0x600
[ 538.853127] ? __do_sys_newfstat+0x44/0x70
[ 539.051951] ksys_ioctl+0x6d/0x80
[ 539.212785] __x64_sys_ioctl+0x1a/0x20
[ 539.394918] do_syscall_64+0x5a/0x110
[ 539.568674] entry_SYSCALL_64_after_hwframe+0x44/0xa9
We have observed it where both:
1) LVM/devmapper is involved (bcache backing device is LVM volume) and
2) writeback cache is involved (bcache cache_mode is writeback)
On one machine, we can reliably reproduce it with:
# echo writeback > /sys/block/bcache0/bcache/cache_mode
(not sure whether above line is required)
# mount /dev/bcache0 /test
# for i in {0..10}; do
file="$(mktemp /test/zero.XXX)"
dd if=/dev/zero of="$file" bs=1M count=256
sync
rm $file
done
# fstrim -v /test
Observing this with tracepoints on, we see the following writes:
fstrim-18019 [022] .... 91107.302026: bcache_write: 73f95583-561c-408f-a93a-4cbd2498f5c8 inode 0 DS 4260112 + 196352 hit 0 bypass 1
fstrim-18019 [022] .... 91107.302050: bcache_write: 73f95583-561c-408f-a93a-4cbd2498f5c8 inode 0 DS 4456464 + 262144 hit 0 bypass 1
fstrim-18019 [022] .... 91107.302075: bcache_write: 73f95583-561c-408f-a93a-4cbd2498f5c8 inode 0 DS 4718608 + 81920 hit 0 bypass 1
fstrim-18019 [022] .... 91107.302094: bcache_write: 73f95583-561c-408f-a93a-4cbd2498f5c8 inode 0 DS 5324816 + 180224 hit 0 bypass 1
fstrim-18019 [022] .... 91107.302121: bcache_write: 73f95583-561c-408f-a93a-4cbd2498f5c8 inode 0 DS 5505040 + 262144 hit 0 bypass 1
fstrim-18019 [022] .... 91107.302145: bcache_write: 73f95583-561c-408f-a93a-4cbd2498f5c8 inode 0 DS 5767184 + 81920 hit 0 bypass 1
fstrim-18019 [022] .... 91107.308777: bcache_write: 73f95583-561c-408f-a93a-4cbd2498f5c8 inode 0 DS 6373392 + 180224 hit 1 bypass 0
<crash>
Note the final one has different hit/bypass flags.
This is because in should_writeback(), we were hitting a case where
the partial stripe condition was returning true and so
should_writeback() was returning true early.
If that hadn't been the case, it would have hit the would_skip test, and
as would_skip == s->iop.bypass == true, should_writeback() would have
returned false.
Looking at the git history from 'commit 72c270612bd3 ("bcache: Write out
full stripes")', it looks like the idea was to optimise for raid5/6:
* If a stripe is already dirty, force writes to that stripe to
writeback mode - to help build up full stripes of dirty data
To fix this issue, make sure that should_writeback() on a discard op
never returns true.
More details of debugging:
https://www.spinics.net/lists/linux-bcache/msg06996.html
Previous reports:
- https://bugzilla.kernel.org/show_bug.cgi?id=201051
- https://bugzilla.kernel.org/show_bug.cgi?id=196103
- https://www.spinics.net/lists/linux-bcache/msg06885.html
(Coly Li: minor modification to follow maximum 75 chars per line rule)
Cc: Kent Overstreet <koverstreet@google.com>
Fixes: 72c270612bd3 ("bcache: Write out full stripes")
Signed-off-by: Daniel Axtens <dja@axtens.net>
commit 225557446856448039a9e495da37b72c20071ef2 upstream.
When using dm-integrity underneath md-raid, some tests with raid
auto-correction trigger large amounts of integrity failures - and all
these failures print an error message. These messages can bring the
system to a halt if the system is using serial console.
Fix this by limiting the rate of error messages - it improves the speed
of raid recovery and avoids the hang.
Fixes: 7eada909bfd7a ("dm: add integrity target")
commit b761dcf1217760a42f7897c31dcb649f59b2333e upstream.
In reshape_request it already adds len to sector_nr already. It's wrong to add len to
sector_nr again after adding pages to bio. If there is bad block it can't copy one chunk
at a time, it needs to goto read_more. Now the sector_nr is wrong. It can cause data
corruption.
Signed-off-by: Xiao Ni <xni@redhat.com>
This is the 4.19.25 stable release
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
commit 4ae280b4ee3463fa57bbe6eede26b97daff8a0f1 upstream.
When provisioning a new data block for a virtual block, either because
the block was previously unallocated or because we are breaking sharing,
if the whole block of data is being overwritten the bio that triggered
the provisioning is issued immediately, skipping copying or zeroing of
the data block.
When this bio completes the new mapping is inserted in to the pool's
metadata by process_prepared_mapping(), where the bio completion is
signaled to the upper layers.
This completion is signaled without first committing the metadata. If
the bio in question has the REQ_FUA flag set and the system crashes
right after its completion and before the next metadata commit, then the
write is lost despite the REQ_FUA flag requiring that I/O completion for
this request must only be signaled after the data has been committed to
non-volatile storage.
Fix this by deferring the completion of overwrite bios, with the REQ_FUA
flag set, until after the metadata has been committed.
Acked-by: Joe Thornber <ejt@redhat.com>
Acked-by: Mikulas Patocka <mpatocka@redhat.com>
commit ff0c129d3b5ecb3df7c8f5e2236582bf745b6c5f upstream.
bio_sectors() returns the value in the units of 512-byte sectors (no
matter what the real sector size of the device). dm-crypt multiplies
bio_sectors() by on_disk_tag_size to calculate the space allocated for
integrity tags. If dm-crypt is running with sector size larger than
512b, it allocates more data than is needed.
Device Mapper trims the extra space when passing the bio to
dm-integrity, so this bug didn't result in any visible misbehavior.
But it must be fixed to avoid wasteful memory allocation for the block
integrity payload.
Fixes: ef43aa38063a6 ("dm crypt: add cryptographic data integrity protection (authenticated encryption)")
Cc: stable@vger.kernel.org # 4.12+
Reported-by: Milan Broz <mbroz@redhat.com>
commit dfcc34c99f3ebc16b787b118763bf9cb6b1efc7a upstream.
sync_request_write no longer submits writes to a Faulty device. This has
the unfortunate side effect that bitmap bits can be incorrectly cleared
if a recovery is interrupted (previously, end_sync_write would have
prevented this). This means the next recovery may not copy everything
it should, potentially corrupting data.
Add a function for doing the proper md_bitmap_end_sync, called from
end_sync_write and the Faulty case in sync_request_write.
backport note to 4.14: s/md_bitmap_end_sync/bitmap_end_sync
Cc: stable@vger.kernel.org 4.14+
Fixes: 0c9d5b127f69 ("md/raid1: avoid reusing a resync bio after error handling.")
Reviewed-by: Jack Wang <jinpu.wang@cloud.ionos.com>
Tested-by: Jack Wang <jinpu.wang@cloud.ionos.com>
Signed-off-by: Nate Dailey <nate.dailey@stratus.com>
This is the 4.19.23 stable release
[ Upstream commit e820d55cb99dd93ac2dc949cf486bb187e5cd70d ]
When both regular IO and resync IO happen at the same time,
and if we also need to split regular. Then we can see tasks
hang due to barrier.
1. resync thread
[ 1463.757205] INFO: task md1_resync:5215 blocked for more than 480 seconds.
[ 1463.757207] Not tainted 4.19.5-1-default #1
[ 1463.757209] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 1463.757212] md1_resync D 0 5215 2 0x80000000
[ 1463.757216] Call Trace:
[ 1463.757223] ? __schedule+0x29a/0x880
[ 1463.757231] ? raise_barrier+0x8d/0x140 [raid10]
[ 1463.757236] schedule+0x78/0x110
[ 1463.757243] raise_barrier+0x8d/0x140 [raid10]
[ 1463.757248] ? wait_woken+0x80/0x80
[ 1463.757257] raid10_sync_request+0x1f6/0x1e30 [raid10]
[ 1463.757265] ? _raw_spin_unlock_irq+0x22/0x40
[ 1463.757284] ? is_mddev_idle+0x125/0x137 [md_mod]
[ 1463.757302] md_do_sync.cold.78+0x404/0x969 [md_mod]
[ 1463.757311] ? wait_woken+0x80/0x80
[ 1463.757336] ? md_rdev_init+0xb0/0xb0 [md_mod]
[ 1463.757351] md_thread+0xe9/0x140 [md_mod]
[ 1463.757358] ? _raw_spin_unlock_irqrestore+0x2e/0x60
[ 1463.757364] ? __kthread_parkme+0x4c/0x70
[ 1463.757369] kthread+0x112/0x130
[ 1463.757374] ? kthread_create_worker_on_cpu+0x40/0x40
[ 1463.757380] ret_from_fork+0x3a/0x50
2. regular IO
[ 1463.760679] INFO: task kworker/0:8:5367 blocked for more than 480 seconds.
[ 1463.760683] Not tainted 4.19.5-1-default #1
[ 1463.760684] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 1463.760687] kworker/0:8 D 0 5367 2 0x80000000
[ 1463.760718] Workqueue: md submit_flushes [md_mod]
[ 1463.760721] Call Trace:
[ 1463.760731] ? __schedule+0x29a/0x880
[ 1463.760741] ? wait_barrier+0xdd/0x170 [raid10]
[ 1463.760746] schedule+0x78/0x110
[ 1463.760753] wait_barrier+0xdd/0x170 [raid10]
[ 1463.760761] ? wait_woken+0x80/0x80
[ 1463.760768] raid10_write_request+0xf2/0x900 [raid10]
[ 1463.760774] ? wait_woken+0x80/0x80
[ 1463.760778] ? mempool_alloc+0x55/0x160
[ 1463.760795] ? md_write_start+0xa9/0x270 [md_mod]
[ 1463.760801] ? try_to_wake_up+0x44/0x470
[ 1463.760810] raid10_make_request+0xc1/0x120 [raid10]
[ 1463.760816] ? wait_woken+0x80/0x80
[ 1463.760831] md_handle_request+0x121/0x190 [md_mod]
[ 1463.760851] md_make_request+0x78/0x190 [md_mod]
[ 1463.760860] generic_make_request+0x1c6/0x470
[ 1463.760870] raid10_write_request+0x77a/0x900 [raid10]
[ 1463.760875] ? wait_woken+0x80/0x80
[ 1463.760879] ? mempool_alloc+0x55/0x160
[ 1463.760895] ? md_write_start+0xa9/0x270 [md_mod]
[ 1463.760904] raid10_make_request+0xc1/0x120 [raid10]
[ 1463.760910] ? wait_woken+0x80/0x80
[ 1463.760926] md_handle_request+0x121/0x190 [md_mod]
[ 1463.760931] ? _raw_spin_unlock_irq+0x22/0x40
[ 1463.760936] ? finish_task_switch+0x74/0x260
[ 1463.760954] submit_flushes+0x21/0x40 [md_mod]
So resync io is waiting for regular write io to complete to
decrease nr_pending (conf->barrier++ is called before waiting).
The regular write io splits another bio after call wait_barrier
which call nr_pending++, then the splitted bio would continue
with raid10_write_request -> wait_barrier, so the splitted bio
has to wait for barrier to be zero, then deadlock happens as
follows.
resync io regular io
raise_barrier
wait_barrier
wait_barrier
To resolve the issue, we need to call allow_barrier to decrease
nr_pending before generic_make_request since regular IO is not
issued to underlying devices, and wait_barrier is called again
to ensure no internal IO happening.
Fixes: fc9977dd069e ("md/raid10: simplify the splitting of requests.")
Reported-and-tested-by: Siniša Bandin <sinisa@4net.rs>
Signed-off-by: Guoqing Jiang <gqjiang@suse.com>
Signed-off-by: Shaohua Li <shli@fb.com>
commit 483cbbeddd5fe2c80fd4141ff0748fa06c4ff146 upstream.
This fixes the case when md array assembly fails because of raid cache recovery
unable to allocate a stripe, despite attempts to replay stripes and increase
cache size. This happens because stripes released by r5c_recovery_replay_stripes
and raid5_set_cache_size don't become available for allocation immediately.
Released stripes first are placed on conf->released_stripes list and require
md thread to merge them on conf->inactive_list before they can be allocated.
Patch allows final allocation attempt during cache recovery to wait for
new stripes to become availabe for allocation.
Cc: linux-raid@vger.kernel.org
Cc: Shaohua Li <shli@kernel.org>
Cc: linux-stable <stable@vger.kernel.org> # 4.10+
Fixes: b4c625c67362 ("md/r5cache: r5cache recovery: part 1")
Signed-off-by: Alexei Naberezhnov <anaberezhnov@fb.com>
commit 1856b9f7bcc8e9bdcccc360aabb56fbd4dd6c565 upstream.
The dm-crypt cipher specification in a mapping table is defined as:
cipher[:keycount]-chainmode-ivmode[:ivopts]
or (new crypt API format):
capi:cipher_api_spec-ivmode[:ivopts]
For ESSIV, the parameter includes hash specification, for example:
aes-cbc-essiv:sha256
The implementation expected that additional IV option to never include
another dash '-' character.
But, with SHA3, there are names like sha3-256; so the mapping table
parser fails:
dmsetup create test --table "0 8 crypt aes-cbc-essiv:sha3-256 9c1185a5c5e9fc54612808977ee8f5b9e 0 /dev/sdb 0"
dmsetup create test --table "0 8 crypt capi:cbc(aes)-essiv:sha3-256 9c1185a5c5e9fc54612808977ee8f5b9e 0 /dev/sdb 0"
device-mapper: crypt: Ignoring unexpected additional cipher options
device-mapper: table: 253:0: crypt: Error creating IV
device-mapper: ioctl: error adding target to table
Fix the dm-crypt constructor to ignore additional dash in IV options and
also remove a bogus warning (that is ignored anyway).
Signed-off-by: Milan Broz <gmazyland@gmail.com>
