path: root/drivers/media/Makefile
2012-09-06[media] move i2c files into drivers/media/i2cMauro Carvalho Chehab
Based on a patch from Sylvester Nawrocki This fixes regression introduced with commmit cb7a01ac324bf2ee2, "[media] move i2c files into drivers/media/i2c". The linked order affect what drivers will be initialized first, when they're built-in at Kernel. While there are macros that allow changing the init order, like subsys_initcall(), late_initcall() & friends, when all drivers linked belong to the same subsystem, it is easier to change the order at the Makefile. All I2C modules must be linked before any drivers that actually use it, in order to ensure proper module initialization order. Also, the core drivers should be initialized before the drivers that use them. This patch reorders the drivers init, in order to fulfill the above requirements. Reported-by: Sylwester Nawrocki <sylvester.nawrocki@gmail.com> Acked-by: Sylwester Nawrocki <sylvester.nawrocki@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-15[media] rename drivers/media/video as .../platformMauro Carvalho Chehab
The remaining drivers are mostly platform drivers. Name the dir to reflect it. It makes sense to latter break it into a few other dirs. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-15[media] move i2c files into drivers/media/i2cMauro Carvalho Chehab
Move ancillary I2C drivers into drivers/media/i2c, in order to better organize them. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-15[media] move parallel port/isa video drivers to drivers/media/parport/Mauro Carvalho Chehab
We should keep just the I2C drivers under drivers/media/video, and then rename it to drivers/media/i2c. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-13[media] siano: break it into common, mmc and usbMauro Carvalho Chehab
siano is, in fact, 2 drivers: one for MMC and one for USB, plus a common bus-independent code. Break it accordingly. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-13[media] common: move media/common/tuners to media/tunersMauro Carvalho Chehab
Move the tuners one level up, as the "common" directory will be used by drivers that are shared between more than one driver. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-13[media] Rename media/dvb as media/pciMauro Carvalho Chehab
The remaining dvb drivers are pci, so rename them to match the bus. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-13[media] dvb-usb: move it to drivers/media/usb/dvb-usbMauro Carvalho Chehab
As media/dvb will be removed, move it to a proper place. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-13[media] firewire: move it one level upMauro Carvalho Chehab
Move firewire to one level up, as the dvb subdirectory will be removed. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-13[media] move the dvb/frontends to drivers/media/dvb-frontendsMauro Carvalho Chehab
Raise the DVB frontends one level up, as the intention is to remove the drivers/media/dvb directory. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-13[media] dvb: move the dvb core one level upMauro Carvalho Chehab
just like the V4L2 core, move the DVB core to drivers/media, as the intention is to get rid of both "video" and "dvb" directories. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-13[media] v4l: move v4l2 core into a separate directoryMauro Carvalho Chehab
Currently, the v4l2 core is mixed together with other non-core drivers. Move them into a separate directory. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] media: Entities, pads and linksLaurent Pinchart
As video hardware pipelines become increasingly complex and configurable, the current hardware description through v4l2 subdevices reaches its limits. In addition to enumerating and configuring subdevices, video camera drivers need a way to discover and modify at runtime how those subdevices are connected. This is done through new elements called entities, pads and links. An entity is a basic media hardware building block. It can correspond to a large variety of logical blocks such as physical hardware devices (CMOS sensor for instance), logical hardware devices (a building block in a System-on-Chip image processing pipeline), DMA channels or physical connectors. A pad is a connection endpoint through which an entity can interact with other entities. Data (not restricted to video) produced by an entity flows from the entity's output to one or more entity inputs. Pads should not be confused with physical pins at chip boundaries. A link is a point-to-point oriented connection between two pads, either on the same entity or on different entities. Data flows from a source pad to a sink pad. Links are stored in the source entity. To make backwards graph walk faster, a copy of all links is also stored in the sink entity. The copy is known as a backlink and is only used to help graph traversal. The entity API is made of three functions: - media_entity_init() initializes an entity. The caller must provide an array of pads as well as an estimated number of links. The links array is allocated dynamically and will be reallocated if it grows beyond the initial estimate. - media_entity_cleanup() frees resources allocated for an entity. It must be called during the cleanup phase after unregistering the entity and before freeing it. - media_entity_create_link() creates a link between two entities. An entry in the link array of each entity is allocated and stores pointers to source and sink pads. When a media device is unregistered, all its entities are unregistered automatically. The code is based on Hans Verkuil <hverkuil@xs4all.nl> initial work. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] media: Media deviceLaurent Pinchart
The media_device structure abstracts functions common to all kind of media devices (v4l2, dvb, alsa, ...). It manages media entities and offers a userspace API to discover and configure the media device internal topology. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] media: Media device node supportLaurent Pinchart
The media_devnode structure provides support for registering and unregistering character devices using a dynamic major number. Reference counting is handled internally, making device drivers easier to write without having to solve the open/disconnect race condition issue over and over again. The code is based on video/v4l2-dev.c. [mchehab@redhat.com: Remove linux/smp_lock.h include to not break compilation on bisect] Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] rename drivers/media/IR to drives/media/rcMauro Carvalho Chehab
2009-12-16V4L/DVB (13612): IR: Move common IR code to drivers/media/IRMauro Carvalho Chehab
This is the first step of creating a common code for IR that can be used by other input devices. For now, keep IR dir at drivers/media, to easy the movement of the IR files, but later patches may move it to drivers/IR or drivers/input/IR. No functional changes is done on this patch. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-06-05V4L/DVB (7908): always enter drivers/media/video/Adrian Bunk
After commit 039d40019f3c5e26ea50ec5af4270189f63365e1 (V4L/DVB (7898): Fix VIDEO_MEDIA Kconfig logic) VIDEO_MEDIA is no longer usable in Makefile's for deciding which directories we enter, resulting in compile errors like the following with CONFIG_VIDEO_DEV=y, CONFIG_DVB_CORE=m: <-- snip --> ... MODPOST 187 modules ... make[2]: *** [__modpost] Error 1 <-- snip --> The easiest solution is to always enter video/ Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-08Fix drivers/media build for modular buildsIngo Molnar
Fix allmodconfig build bug introduced in latest -git by commit 7c91f0624a9 ("V4L/DVB(7767): Move tuners to common/tuners"): LD kernel/built-in.o LD drivers/built-in.o ld: drivers/media/built-in.o: No such file: No such file or directory which happens if all media drivers are modular: http://redhat.com/~mingo/misc/config-Wed_Apr_30_09_24_48_CEST_2008.bad In that case there's no obj-y rule connecting all the built-in.o files and the link tree breaks. The fix is to add a guaranteed obj-y rule for the core vmlinux to build. (which results in an empty object file if all media drivers are modular) Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29V4L/DVB(7767): Move tuners to common/tunersMauro Carvalho Chehab
There were several issues in the past, caused by the hybrid tuner design, since now, the same tuner can be used by drivers/media/dvb and drivers/media/video. Kconfig items were rearranged, to split V4L/DVB core from their drivers. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-06V4L/DVB (7499): v4l/dvb Kconfig: Fix bugzilla #10067Mauro Carvalho Chehab
tda8290 breaks if tuner is selected, but CONFIG_DVB=n. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-12-13V4L/DVB (6814): Makefile: always enter video/Adrian Bunk
Since not all code under drivers/media/video/ depends on CONFIG_VIDEO_DEV we cannot only enter it depending on CONFIG_VIDEO_DEV. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-05-09V4L/DVB (5599): Use menuconfig objects II - DVBJan Engelhardt
Change Kconfig objects from "menu, config" into "menuconfig" so that the user can disable the whole feature without having to enter the menu first. Also remove one indirection (CONFIG_DVB) that does not seem to be really used inside the kernel. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2005-09-09[PATCH] dvb: avoid building empty built-in.oJohannes Stezenbach
Don't build empty built-in.o when DVB/V4L is not configured. Thanks to Sam Ravnborg and Keith Owens. Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
