path: root/drivers/media/common/tuners/Kconfig
2012-08-13[media] common: move media/common/tuners to media/tunersMauro Carvalho Chehab
Move the tuners one level up, as the "common" directory will be used by drivers that are shared between more than one driver. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-07-05[media] media: Remove VIDEO_MEDIA Kconfig optionMauro Carvalho Chehab
In the past, it was possible to have either DVB or V4L2 core as module and the other as builtin. Such config never make much sense, and created several issues in order to make the Kconfig dependency to work, as all drivers that depend on both (most TV drivers) would need to be compiled as 'm'. Due to that, the VIDEO_MEDIA config option were added. Instead of such weird approach, let's just use the MEDIA_SUPPORT =y or =m to select if the media subsystem core will be either builtin or module, simplifying the building system logic. Also, fix the tuners configuration, by enabling them only if a tuner is required. So, if just webcam/grabbers support is selected, no tuner option will be selected. Also, if only digital TV is selected, no analog tuner support is selected. That removes the need of using EXPERT customise options, when analog TV is not selected. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-07-05[media] media: reorganize the main Kconfig itemsMauro Carvalho Chehab
Change the main items to: <m> Multimedia support ---> [ ] Cameras/video grabbers support [ ] Analog TV support [ ] Digital TV support [ ] AM/FM radio receivers/transmitters support [ ] Remote Controller support This provides an interface that is clearer to end users that are compiling the Kernel, and will allow the building system to automatically unselect drivers for unused functions. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-20[media] fc001x: tuner driver for FC0013Hans-Frieder Vogt
Support for tuner Fitipower FC0013 Signed-off-by: Hans-Frieder Vogt <hfvogt@gmx.net> Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-20[media] fc001x: tuner driver for FC0012, version 0.5Hans-Frieder Vogt
Support for tuner Fitipower FC0012 Signed-off-by: Hans-Frieder Vogt <hfvogt@gmx.net> Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-04-09[media] Add fc0011 tuner driverMichael Büsch
This adds support for the Fitipower fc0011 DVB-t tuner. Signed-off-by: Michael Buesch <m@bues.ch> Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-04-09[media] Infineon TUA 9001 silicon tuner driverAntti Palosaari
2012-01-06[media] drivers: media: tuners: Fix dependency for MEDIA_TUNER_TEA5761Fabio Estevam
Fix the following build warning: warning: (MEDIA_TUNER) selects MEDIA_TUNER_TEA5761 which has unmet direct dependencies (MEDIA_SUPPORT && VIDEO_MEDIA && I2C && EXPERIMENTAL) Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-01-04[media] mt2063: Add it to the building systemMauro Carvalho Chehab
2011-07-27[media] dib0700: add initial code for PCTV 340e by Davide FerriDavide Ferri
This is initial code written by Davide Ferri for the PCTV 340e, including a new xc4000 driver. I am checking in all the code unmodified, and making no assertions about its quality (other than confirming it compiles). [mchehab@redhat.com: rebased on the top of the current tree] Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com> Signed-off-by: Davide Ferri <davidef1986@gmail.com> Cc: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-20[media] NXP TDA18212HN silicon tuner driverAntti Palosaari
New silicon tuner driver. Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-22[media] Fix Kconfig errors due to two visible menusMauro Carvalho Chehab
Use the new visible Kconfig keyword to avoid producing error for two menus that are visible only if Tuner/frontend customise options are enabled. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: NXP TDA18218 silicon tuner driverAntti Palosaari
2010-08-08V4L/DVB: V4L: do not autoselect components on embedded systemsGuennadi Liakhovetski
Tuner, DVB frontend and video helper chip drivers are by default autoselected by their respective host cards, this, however, doesn't make much sense on SoC-based systems. Disable autoselection on EMBEDDED systems. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13373): Maxium MAX2165 silicon tunerDavid T.L. Wong
Adds support for Maxim MAX2165 silicon tuner. It is tested on Mygica X8558Pro, which has MAX2165, ATBM8830 and CX23885 Signed-off-by: David T. L. Wong <davidtlwong@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (28 commits) trivial: Update my email address trivial: NULL noise: drivers/mtd/tests/mtd_*test.c trivial: NULL noise: drivers/media/dvb/frontends/drx397xD_fw.h trivial: Fix misspelling of "Celsius". trivial: remove unused variable 'path' in alloc_file() trivial: fix a pdlfush -> pdflush typo in comment trivial: jbd header comment typo fix for JBD_PARANOID_IOFAIL trivial: wusb: Storage class should be before const qualifier trivial: drivers/char/bsr.c: Storage class should be before const qualifier trivial: h8300: Storage class should be before const qualifier trivial: fix where cgroup documentation is not correctly referred to trivial: Give the right path in Documentation example trivial: MTD: remove EOL from MODULE_DESCRIPTION trivial: Fix typo in bio_split()'s documentation trivial: PWM: fix of #endif comment trivial: fix typos/grammar errors in Kconfig texts trivial: Fix misspelling of firmware trivial: cgroups: documentation typo and spelling corrections trivial: Update contact info for Jochen Hein trivial: fix typo "resgister" -> "register" ...
2009-03-30V4L/DVB (11127): Kconfig: replace all occurrences of CUSTOMIZE to CUSTOMISEMauro Carvalho Chehab
There are several Kconfig items using CUSTOMIZE. Yet, most use the English writing CUSTOMISE. This generates lots of trouble, because people sometimes type the Kbuild item different. Let's standardise every occurrence using the same syntax. The changes were generated by this small shell script: for i in `find linux -type f`; do sed s,CUSTOMIZE,CUSTOMISE,g $i >/tmp/a && mv /tmp/a $i; done Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10897): Fix Kbuild MEDIA_TUNER_CUSTOMIZE dependenciesMauro Carvalho Chehab
2009-03-30V4L/DVB (10452): Add Freescale MC44S803 tuner driverJochen Friedrich
Add Freescale MC44S803 tuner driver. Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30trivial: fix typos/grammar errors in Kconfig textsMatt LaPlante
Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-07-27V4L/DVB (8534): remove select's of FW_LOADERAdrian Bunk
After commit d9b19199e4894089456aaad295023263b5225c1a (always enable FW_LOADER unless EMBEDDED=y) we can remove the FW_LOADER select's and corresponding dependencies on HOTPLUG. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-27V4L/DVB (8528): add support for MaxLinear MxL5007T silicon tunerMichael Krufky
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Asaf Fishov <afishov@maxlinear.com> Signed-off-by: Charles Kim <ckim@maxlinear.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-20V4L/DVB (8060): Kconfig: MEDIA_TUNER_CUSTOMIZE should be disabled by defaultMichael Krufky
The build option, MEDIA_TUNER_CUSTOMIZE, allows us to disable tuner drivers that would have otherwise been selected by default. This is an advanced customization option that should be disabled by default. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-06-05V4L/DVB (7974): fix MEDIA_TUNER && FW_LOADER build errorIngo Molnar
-tip testing found the following build failure: LD .tmp_vmlinux1 drivers/built-in.o: In function `generic_set_freq': tuner-xc2028.c:(.text+0xbd896): undefined reference to `request_firmware' tuner-xc2028.c:(.text+0xbdd7a): undefined reference to `release_firmware' drivers/built-in.o: In function `xc_load_fw_and_init_tuner': xc5000.c:(.text+0xc68e6): undefined reference to `request_firmware' xc5000.c:(.text+0xc6abe): undefined reference to `release_firmware' with this config: http://redhat.com/~mingo/misc/config-Tue_May_20_18_11_34_CEST_2008.bad the reason is another kconfig tool bug that has to be worked around in the driver's Kconfig file: if FW_LOADER is selected in a second dependency, that is not properly propagated up the dependencies. in this case, FW_LOADER is selected from MEDIA_TUNER_XC2028: config MEDIA_TUNER_XC2028 tristate "XCeive xc2028/xc3028 tuners" depends on VIDEO_MEDIA && I2C depends on HOTPLUG select FW_LOADER which got selected by MEDIA_TUNER: config MEDIA_TUNER tristate default VIDEO_MEDIA && I2C depends on VIDEO_MEDIA && I2C select FW_LOADER if !MEDIA_TUNER_CUSTOMIZE && HOTPLUG but the kconfig tool did not pick up this second-order dependency and allowed CONFIG_FW_LOADER=m to be selected - in which case the build fails. the workaround i found was to move the select of FW_LOADER one level up, so that the buggy kconfig tool can notice it and can act appropriately. This problem can probably be worked around in other ways as well, i went for the minimal fix. Obviously, the kconfig tool should be fixed, it is not reasonable to expect driver authors to do manual dependency resolution (that kconfig itself already does) and uglify the Kconfig files. The kconfig tool did nothing to warn about this situation and did not prevent this faulty .config from being constructed. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7899): Fixes a few remaining Kbuild issues at common/tunersMauro Carvalho Chehab
- MEDIA_ATTACH now applies also for V4L; - select a FW_LOADER dependent driver should happen only if HOTPLUG; - apply the common tuner dependency to all tuners. This helps to avoid latter issues. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB(7878): mxl55005s: Makefile and Kconfig additionsSteven Toth
Makefile and Kconfig additions Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7851): Fix FW_LOADER depencency at v4l/dvbMauro Carvalho Chehab
Since: 1) FW_LOADER is defined as: config FW_LOADER tristate "Userspace firmware loading support" depends on HOTPLUG 2) several V4L/DVB driver just selects it; 3) select is not smart enough to auto-select HOTPLUG, if select FW_LOADER. So, All drivers that select FW_LOADER should also depend on HOTPLUG. An easier solution (for the end-user perspective) would be to "select HOTPLUG". However, live is not simple. This would cause recursive dependency issues like this one: drivers/usb/Kconfig:62:error: found recursive dependency: USB -> USB_OHCI_HCD -> I2C -> MEDIA_TUNER -> MEDIA_TUNER_XC2028 -> HOTPLUG -> PCCARD -> PCMCIA -> USB_ARCH_HAS_HCD -> MOUSE_APPLETOUCH -> USB Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7848): Fix dependencies for tuner-xc2028 and em28xx-dvbMauro Carvalho Chehab
em28xx-dvb doesn't need FW_LOADER. Instead, tuner-xc2028 needs to select FW_LOADER. Also, this can happen only if HOTPLUG is selected, since FW_LOADER is dependent on HOTPLUG. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7847): Simplifies Kconfig rulesMauro Carvalho Chehab
Since all tuners are dependent of I2C, move I2C dependency to MEDIA_TUNER. Also, simplifies the dependencies for the other Kconfig items. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7832): xc5000: MEDIA_TUNER_XC5000 must select FW_LOADERMichael Krufky
Fix the following build error: drivers/built-in.o: In function `xc_load_fw_and_init_tuner': xc5000.c:(.text+0x2dacd): undefined reference to `request_firmware' xc5000.c:(.text+0x2daf0): undefined reference to `release_firmware' xc5000.c:(.text+0x2db85): undefined reference to `release_firmware' make[1]: *** [.tmp_vmlinux1] Error 1 Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-30V4L/DVB (7798): tuners/Kconfig: Change config name and help to reflect ↵Mauro Carvalho Chehab
dynamic load for tuners Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-29Rename common tuner Kconfig names to use the sameMauro Carvalho Chehab
namespace for all of them.
2008-04-29V4L/DVB (7769): Move other terrestrial tuners to common/tunersMauro Carvalho Chehab
Those tuners are currently used only under media/dvb. However, they can support also analog TV. Better to move them to the same place as the other hybrid tuners. This would make easier to use those tuners also by analog drivers. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-29V4L/DVB(7767): Move tuners to common/tunersMauro Carvalho Chehab
There were several issues in the past, caused by the hybrid tuner design, since now, the same tuner can be used by drivers/media/dvb and drivers/media/video. Kconfig items were rearranged, to split V4L/DVB core from their drivers. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
