Move the tuners one level up, as the "common" directory will be used
by drivers that are shared between more than one driver.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Create a macro to report the number of instances of the tuner driver
currently in use. This will allow drivers to perform specific cleanups
before destroying the last instance of a tuner.
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
There were several issues in the past, caused by the hybrid tuner design, since
now, the same tuner can be used by drivers/media/dvb and drivers/media/video.
Kconfig items were rearranged, to split V4L/DVB core from their drivers.
