download is needed
This patch ensures that the xc5000 will have firmware loaded as needed if the
part is powered down or reset via gpio from the host. An example of this, in
some cases, could be after the system resumes from standby or hibernate modes.
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
The current code passes a context pointer in the xc5000_config struct.
This context pointer is used in the tuner_callback function, used to
reset the device after firmware download.
The xc5000_config struct is a static structure, whose .priv member was
being assigned before calling xc5000_attach(). If there are more than
one of the same device type installed on a single system, the last one
to assign xc5000_config.priv will "win", and all others will cease to
function properly.
This patch passes the context pointer in xc5000_attach() rather that
storing it within the static struct xc5000_config.
There were several issues in the past, caused by the hybrid tuner design, since
now, the same tuner can be used by drivers/media/dvb and drivers/media/video.
Kconfig items were rearranged, to split V4L/DVB core from their drivers.
