path: root/drivers/media/dvb/b2c2/flexcop-usb.c
2009-03-30V4L/DVB (11288): Code cleanup (passes checkpatch now) of the ↵Uwe Bugla
b2c2-flexcop-drivers 2/2 This is the second part of the code cleanup changing the usb and pci-driver cores. Signed-off-by: Uwe Bugla <uwe.bugla@gmx.de> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-06-05V4L/DVB (7959): endianness fix in flexcop-usb.cAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7469): Preparation for supporting new devices, cleanup and sanenessPatrick Boettcher
To prepare the support for new device to the flexcop-family some preparation and cleanups was done + some saneness: - created an i2c-adapter for each i2c-port available. Easier usage for devices with several device on different i2c-busses - initialize i2c before doing the eeprom read - changed the way to attach the different frontends, easier to read now - enabled support for i2c-devices having no register address (1-byte access) Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-11-13V4L/DVB (4818): Flexcop-usb: fix debug printkAlexey Dobriyan
.. fix debug printk. Why, oh why, one would want to do (u16 & 0xff) << 8 and print it with %02x format? Acked-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-06-25V4L/DVB (4014): Remove the spagetti code gotos that aren't usefulTrent Piepho
Some code had pointless gotos that just didn't make any sense. They didn't make the code smaller, or faster, or easier to understand. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-24V4L/DVB (3549): Make hotplug automatically load the b2c2-flexcop-usb modulePatrick Boettcher
There was no MODULE_DEVICE_TABLE for the b2c2-flexcop-usb module. This makes it impossible for hotplug to load the module automatically, when such a device is connected. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-04[PATCH] USB: remove .owner field from struct usb_driverGreg Kroah-Hartman
It is no longer needed, so let's remove it, saving a bit of memory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-07-07[PATCH] dvb: usb/pci: correct syntax of driver name fieldsPatrick Boettcher
Change the name-field of the pci_driver and usb_driver structs to the name of the module after compilation. It seems that this field is used in some places where special characters are not allowed. Thanks to Alan Halverson for finding this problem. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] dvb: flexcop: fix module refcount handlingJohannes Stezenbach
Corrected the THIS_MODULE handling for the flexcop-stuff and dvb-usb which lead to oopses because of misorganized module dependencies. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] dvb: flexcop: fix MAC address readingJohannes Stezenbach
read MAC address directly into dvb_adapter->proposed_mac Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] dvb: flexcop: fix USB transfer handlingJohannes Stezenbach
- driver receives many null TS packets (pid=0x1fff). They occupy the limited USB bandwidth and this leads to loss of video packets. Enabling the null packet filter fixes this. - packets that flexcop sends to USB have a 2 byte header that has to be removed. - sometimes a TS packet is split between different urbs. These parts have to be combined in a temporary buffer. Signed-off-by: Vadim Catana <skystar@moldova.cc> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] dvb: b2c2/flexcop driver refactoring part 2: add modular Flexcop driverJohannes Stezenbach
b2c2/flexcop driver refactoring to support PCI and USB based cards part 2: add modular Flexcop driver Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
