path: root/drivers/media/dvb/bt8xx/Kconfig
2012-08-13[media] Rename media/dvb as media/pciMauro Carvalho Chehab
The remaining dvb drivers are pci, so rename them to match the bus. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (11127): Kconfig: replace all occurrences of CUSTOMIZE to CUSTOMISEMauro Carvalho Chehab
There are several Kconfig items using CUSTOMIZE. Yet, most use the English writing CUSTOMISE. This generates lots of trouble, because people sometimes type the Kbuild item different. Let's standardise every occurrence using the same syntax. The changes were generated by this small shell script: for i in `find linux -type f`; do sed s,CUSTOMIZE,CUSTOMISE,g $i >/tmp/a && mv /tmp/a $i; done Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-16V4L/DVB (9885): drivers/media Kconfig's: fix bugzilla #12204Mauro Carvalho Chehab
When the tuner modules were moved to common/tuners, a separate customize option were added for tuners. However, the automatic selection of the tuners were still using the older option. This causes that the automatic selection to fail, if DVB_FE_CUSTOMISE is selected. Also, since those tuners are now under MEDIA_TUNER_CUSTOMIZE menu, if you unset MEDIA_TUNER_CUSTOMIZE, you can't manually select the tuners. This patch fixes this error by replacing DVB_FE_CUSTOMISE by MEDIA_TUNER_CUSTOMIZE on all places were a tuner is selected. The patch were generated by this small script: for i in `find drivers/media -name Kconfig`; do cat $i|perl -ne 's/(MEDIA_TUNER.*)DVB_FE_CUSTOMISE/\1MEDIA_TUNER_CUSTOMIZE/; print $_' >a mv a $i done Also, manually reordered the tuner entries. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-07-27V4L/DVB (8534): remove select's of FW_LOADERAdrian Bunk
After commit d9b19199e4894089456aaad295023263b5225c1a (always enable FW_LOADER unless EMBEDDED=y) we can remove the FW_LOADER select's and corresponding dependencies on HOTPLUG. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7851): Fix FW_LOADER depencency at v4l/dvbMauro Carvalho Chehab
Since: 1) FW_LOADER is defined as: config FW_LOADER tristate "Userspace firmware loading support" depends on HOTPLUG 2) several V4L/DVB driver just selects it; 3) select is not smart enough to auto-select HOTPLUG, if select FW_LOADER. So, All drivers that select FW_LOADER should also depend on HOTPLUG. An easier solution (for the end-user perspective) would be to "select HOTPLUG". However, live is not simple. This would cause recursive dependency issues like this one: drivers/usb/Kconfig:62:error: found recursive dependency: USB -> USB_OHCI_HCD -> I2C -> MEDIA_TUNER -> MEDIA_TUNER_XC2028 -> HOTPLUG -> PCCARD -> PCMCIA -> USB_ARCH_HAS_HCD -> MOUSE_APPLETOUCH -> USB Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-29Rename common tuner Kconfig names to use the sameMauro Carvalho Chehab
namespace for all of them.
2008-04-24V4L/DVB (7441): kconfig fixes for tuner-simpleMichael Krufky
Update Kconfig for the hybrid devices recently converted to use tuner-simple rather than dvb-pll. dvb-bt8xx no longer uses dvb-pll at all, so remove all references to dvb-pll within that driver. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5780): Dvb: Remove static dependencies on dvb-pllMichael Krufky
This patch removes all static dependencies on the dvb-pll module. All exported dvb_pll_desc's have been UNexported, and the caller will reference the individual dvb_pll_desc by it's index in the pll_list array. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Acked-by: Oliver Endriss <o.endriss@gmx.de> Acked-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5363): Dvb: Remove lgh06xf driverTrent Piepho
The code of the dvb-pll driver and the lgh06xf driver is nearly identical. The main difference is that the lgh06xf driver would set the AGC TOP value on every tune call. The dvb-pll driver now has the ability to set the AGC TOP when the front-end device is opened, which is a better way to go about it. By using this ability of dvb-pll, the lgh06xf driver is made unnecessary. There is one other difference. dvb-pll will probe for the presence of an I2C pll chip by doing a one byte read, the lgh06xf driver did not do this. In some devices the PLL is not reachable over I2C at the timer the tuner is attached. Some more initialization, such as firmware loading, must take place first. None of the devices using a LG-H06xF should have this problem. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Acked-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4846): Create new lgh06xf atsc tuner moduleMichael Krufky
This patch creates a new atsc tuner module for the LG TDVS-H06xF ATSC tuners, called lgh06xf. The purpose of this change is to reduce some duplicated code, and to allow the lgh06xf tuner code to take advantage of dvb_attach(). As a side effect, the dependency of dvb-bt8xx on dvb-pll has been removed, since the lgh06xf module itself will use dvb-pll, while remaining optional for the dvb-bt8xx driver through the use of DVB_FE_CUSTOMISE Acked-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4424): Add missing dvb-pll Kconfig infrastructureAndrew de Quincey
Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-10V4L/DVB (4608b): i2c deps fix on DVBAndrew de Quincey
Several DVB modules depends on I2C Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-05-23V4L/DVB (4037): Make the bridge devices that depend on I2C dependant on I2CManu Abraham
Ref: Bugzilla 6179, 6589 Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-05-12V4L/DVB (3792): Kbuild: DVB_BT8XX must select DVB_ZL10353Michael Krufky
2006-04-02V4L/DVB (3616): Bt8xx: select FW_LOADERmaximilian attems
The bt8xx drivers uses request_firmware() and thus needs to select FW_LOADER. Signed-off-by: maximilian attems <maks@sternwelten.at> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2005-11-09[PATCH] dvb: Add ATSC support for DViCO FusionHDTV5 LiteMichael Krufky
Added ATSC support for DViCO FusionHDTV5 Lite. Signed-off-by: Michael Krufky <mkrufky@m1k.net> Cc: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] DVB: Clarify description text for dvb-bt8xx in KconfigMichael Krufky
Patrick Keene wrote to the linux-dvb list, asking where in menuconfig he can enable dvb-bt8xx for his AVerMedia DVB card. I pointed the following out to him: config DVB_BT8XX tristate "Nebula/Pinnacle PCTV/Twinhan PCI cards" It has been agreed upon that this description is extremely misleading. This patch changes the one-liner description text of dvb-bt8xx to something more meaningful, and adds AVerMedia to the detailed description. Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] dvb: DST: reorganize Twinhan DST driver to support CIJohannes Stezenbach
- reorganize Twinhan DST driver to support CI - add support for more cards (Manu Abraham) Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
