path: root/drivers/media/dvb/cinergyT2/cinergyT2.c
2008-10-12V4L/DVB (9107): Alternative version of Terratec Cinergy T2 driverTomi Orava
Alternative version of the Terratec Cinergy T2 driver that uses the dvb framework. Signed-off-by: Tomi Orava <tomimo@ncircle.nullnet.fi> Signed-off-by: Thierry MERLE <thierry.merle@free.fr> [mchehab@redhat.com: fix dvb Makefile] Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-06-05V4L/DVB (7956): cinergyT2: endianness annotations, endianness and race fixesAl Viro
Endianness annotations and fixes + fixing the handling of ->uncorrected_block_count Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7538): Adds selectable adapter numbers as per module optionJanne Grunau
The adapter_nr module options can be used to allocate static adapter numbers on a driver level. It avoids problems with changing DVB apapter numbers after warm/cold boot or device unplugging and repluging. Each driver holds DVB_MAX_ADAPTER long array of the preferred order of adapter numbers. options dvb-usb-dib0700 adapter_nr=7,6,5,4,3,2,1,0 would result in a reversed allocation of adapter numbers. With adapter_nr=2,5 it tries first to get adapter number 2 and 5. If both are already in use it will allocate the lowest free adapter number. Signed-off-by: Janne Grunau <janne-dvb@grunau.be> Acked-by: Hermann Pitton <hermann.pitton@arcor.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7511): media/dvb/cinergyT2 replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-22V4L/DVB (6323): V4L: cinergyT2, remove bad usage of ERESTARTSYSJiri Slaby
cinergyT2, remove bad usage of ERESTARTSYS test of cinergyt2->disconnect_pending doesn't ensure pending signal and so ERESTARTSYS would reach userspace, which is not permitted. Change it to EAGAIN. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19get rid of input BIT* duplicate definesJiri Slaby
get rid of input BIT* duplicate defines use newly global defined macros for input layer. Also remove includes of input.h from non-input sources only for BIT macro definiton. Define the macro temporarily in local manner, all those local definitons will be removed further in this patchset (to not break bisecting). BIT macro will be globally defined (1<<x) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: <dtor@mail.ru> Acked-by: Jiri Kosina <jkosina@suse.cz> Cc: <lenb@kernel.org> Acked-by: Marcel Holtmann <marcel@holtmann.org> Cc: <perex@suse.cz> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: <vernux@us.ibm.com> Cc: <malattia@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-09V4L/DVB (6125): whitespace cleanup: replace leading spaces with tabsMichael Krufky
There were many instances of 7-space indents spread throughout the v4l-dvb tree. This patch replaces the 7-space indents with tabs. The whitespace cleaner script doesn't catch these, because it assumes that all indents are 8-space. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5990): cinergyt2_suspend: don't forget to unlock cinergyt2->wq_semOleg Nesterov
Restore unlock of cinergyt2->wq_sem, was deleted by accident. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-18V4L/DVB (5820): Cleanup on cinergyT2: Remove unneeded if(1)Mauro Carvalho Chehab
Before kernel 2.6.14, the driver checked for status before stopping the thread. So, a compatibility test did exist. After 2.6.14, the if (state) were replaced by: if (1) However, it makes no sense to keep the if(1). Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5698): Input: drivers/media - switch to using input_dev->dev.parentDmitry Torokhov
In preparation for struct class_device -> struct device input core conversion switch to using input_dev->dev.parent when specifying device position in sysfs tree. Signed-off-by: Dmitry Torokhov <dtor at mail.ru> Acked-by: Thierry Merle <thierry.merle@free.fr> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-03V4L/DVB (5818): CinergyT2: fix flush_workqueue() vs work->func() deadlockOleg Nesterov
Spotted and tested by Thomas Sattler <tsattler@gmx.de>. cinergyT2.c does cancel_delayed_work() + flush_scheduled_work() while holding cinergyt2->sem. This leads to deadlock because work->func() needs the same mutex to complete. Another bug is that this code in fact can't reliably stop the re-arming delayed_work. Convert this code to use cancel_rearming_delayed_work() and move it out of ->sem. Another mutex, ->wq_sem, was added to protect against the concurrent open/resume. This patch is a horrible hack to fix the lockup which happens in practice. As Dmitry Torokhov pointed out this driver has other problems and needs further changes. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-06-08V4L/DVB (5699): Cinergyt2: fix file release handlerAndrew Morton
If this mutex_lock_interruptible() does fail due to signal_pending() then the state of the driver will get trashed in interesting ways, because userspace cannot and will not retry the close(). Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-05-02PCI: Cleanup the includes of <linux/pci.h>Jean Delvare
I noticed that many source files include <linux/pci.h> while they do not appear to need it. Here is an attempt to clean it all up. In order to find all possibly affected files, I searched for all files including <linux/pci.h> but without any other occurence of "pci" or "PCI". I removed the include statement from all of these, then I compiled an allmodconfig kernel on both i386 and x86_64 and fixed the false positives manually. My tests covered 66% of the affected files, so there could be false positives remaining. Untested files are: arch/alpha/kernel/err_common.c arch/alpha/kernel/err_ev6.c arch/alpha/kernel/err_ev7.c arch/ia64/sn/kernel/huberror.c arch/ia64/sn/kernel/xpnet.c arch/m68knommu/kernel/dma.c arch/mips/lib/iomap.c arch/powerpc/platforms/pseries/ras.c arch/ppc/8260_io/enet.c arch/ppc/8260_io/fcc_enet.c arch/ppc/8xx_io/enet.c arch/ppc/syslib/ppc4xx_sgdma.c arch/sh64/mach-cayman/iomap.c arch/xtensa/kernel/xtensa_ksyms.c arch/xtensa/platform-iss/setup.c drivers/i2c/busses/i2c-at91.c drivers/i2c/busses/i2c-mpc.c drivers/media/video/saa711x.c drivers/misc/hdpuftrs/hdpu_cpustate.c drivers/misc/hdpuftrs/hdpu_nexus.c drivers/net/au1000_eth.c drivers/net/fec_8xx/fec_main.c drivers/net/fec_8xx/fec_mii.c drivers/net/fs_enet/fs_enet-main.c drivers/net/fs_enet/mac-fcc.c drivers/net/fs_enet/mac-fec.c drivers/net/fs_enet/mac-scc.c drivers/net/fs_enet/mii-bitbang.c drivers/net/fs_enet/mii-fec.c drivers/net/ibm_emac/ibm_emac_core.c drivers/net/lasi_82596.c drivers/parisc/hppb.c drivers/sbus/sbus.c drivers/video/g364fb.c drivers/video/platinumfb.c drivers/video/stifb.c drivers/video/valkyriefb.c include/asm-arm/arch-ixp4xx/dma.h sound/oss/au1550_ac97.c I would welcome test reports for these files. I am fine with removing the untested files from the patch if the general opinion is that these changes aren't safe. The tested part would still be nice to have. Note that this patch depends on another header fixup patch I submitted to LKML yesterday: [PATCH] scatterlist.h needs types.h http://lkml.org/lkml/2007/3/01/141 Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-21V4L/DVB (5121): Proper vendor/device ID for the CinergyT2 input deviceTino Keitel
I noticed that udev does not create a symlink for the CinergyT2 remote input device in /dev/input/by-id, which is required if I want to have a unique device name for lircd. The attached patch tries to achive this. However, udev still omits the input device for /dev/input/by-id symlinks. I think something is still not reported correctly. Signed-off-by: Tino Keitel <tino.keitel@tikei.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4854): Handle errors from input_register_device()Dmitry Torokhov
Also sprinkled some input_sync() throughout the code. Acked-by: Ricardo Cerqueira <v4l@cerqueira.org> Acked-by: Oliver Endriss <o.endriss@gmx.de> Acked-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-05Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/ata/libata-scsi.c include/linux/libata.h Futher merge of Linus's head and compilation fixups. Signed-Off-By: David Howells <dhowells@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/infiniband/core/iwcm.c drivers/net/chelsio/cxgb2.c drivers/net/wireless/bcm43xx/bcm43xx_main.c drivers/net/wireless/prism54/islpci_eth.c drivers/usb/core/hub.h drivers/usb/input/hid-core.c net/core/netpoll.c Fix up merge failures with Linus's head and fix new compilation failures. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-12-04[PATCH] severing poll.h -> mm.hAl Viro
2006-12-01usb: cinergyT2 free kill urb cleanupMariusz Kozlowski
- usb_free_urb() cleanup - usb_kill_urb() cleanup Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-25fix broken/dubious driver suspend() methodsDavid Brownell
Small driver suspend() fixes in preparation for the PRETHAW events: - Only compare message events for equality against PM_EVENT_* codes; not against integers, or using greater/less-than comparisons. (PM_EVENT_* should really become a __bitwise thing.) - Explicitly test for SUSPEND events (rather than not-something-else) before suspending devices. - Removes more of the confusion between a pm_message_t (wraps event code) and a "state" ... suspend() originally took a target system state. These updates are correct and appropriate even without new PM_EVENT codes. benh: "I think in the Mesh case, we should handle the freeze case as well or we might get wild DMA." Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Greg KH <greg@kroah.com> Cc: Paul Mackerras <paulus@samba.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-25V4L/DVB (4096): CinergyT2: whitespace cleanupMichael Krufky
2006-06-25V4L/DVB (4090): Fix cinergyt2_poll() to allow non-blocking IO on frontendDyks, Axel (XL)
cinergyt2_poll()" shouldn't return (POLLIN | POLLRDNORM | POLLPRI) when there are no pending events. User space programs that do non-bocking IO using "select()" and/or "poll()" would otherwise produce high system load. Acked-by: Andreas Oberritter <obi@linuxtv.org> Signed-off-by: Axel Dyks <xl@xlsigned.net> Acked-by: Andreas Oberritter <obi@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (3762): Add sysfs device links to dvb devicesAndrew de Quincey
Currently in /sys/class/dvb/dvbX.demuxY/ we have: dev uevent With the patch, we have (for a PCI DVB device): dev device -> ../../../devices/pci0000:00/0000:00:1e.0/0000:03:0d.0 uevent So userspace tools can (finally) work out which physical device a DVB adapter refers to. Previously you had to kinda look through dmesg and hope that it hadn't been dumped out of the buffer. This makes debugging a lot easier if the system has been up for a long time! This is done by adding an extra 'struct device *' parameter to dvb_register_adapter(). It will work with any kind of standard linux 'device'. Additionally, if someone has an embedded system which does things differently, they can simply supply 'NULL' and the behaviour will be as before - the link will simply not appear. Ack'd-by: Manu Abraham <manu@linuxtv.org> Acked-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-05-12V4L/DVB (3743): Fix some more potential oopsesAndrew de Quincey
Spotted a couple more places where it fails to check if dvb_register_adapter() fails. Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-21V4L/DVB (3506): Cinergy T2 dmx cleanup on disconnectMarkus Rechberger
Detaching the device didn't clean up several device files in /dev/dvb, after applying that patch all dvb devices disappeared as expected. Signed-off-by: Markus Rechberger <mrechberger@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-02-07V4L/DVB (3318b): sem2mutex: drivers/media/, #2Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-09DVB (2401): USB hot unplug Oops fix.Deti Fliegl
- USB hot unplug Oops fix. Signed-off-by: Deti Fliegl <deti@fliegl.de> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3129): correct FE_READ_UNCORRECTED_BLOCKSStephen Williams
- Make FE_READ_UNCORRECTED_BLOCKS reset the count after each call, thus returning a momentary value like all other demods do, instead of an absolute, ever increasing count. Signed-off-by: Stephen Williams <stephen.williams@gmail.com> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-06kbuild: un-stringnify KBUILD_MODNAMESam Ravnborg
Now when kbuild passes KBUILD_MODNAME with "" do not __stringify it when used. Remove __stringnify for all users. This also fixes the output of: $ ls -l /sys/module/ drwxr-xr-x 4 root root 0 2006-01-05 14:24 pcmcia drwxr-xr-x 4 root root 0 2006-01-05 14:24 pcmcia_core drwxr-xr-x 3 root root 0 2006-01-05 14:24 "processor" drwxr-xr-x 3 root root 0 2006-01-05 14:24 "psmouse" The quoting of the module names will be gone again. Thanks to GregKH + Kay Sievers for reproting this. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-01-04[PATCH] USB: remove .owner field from struct usb_driverGreg Kroah-Hartman
It is no longer needed, so let's remove it, saving a bit of memory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-20[PATCH] Fix an OOPS is CinergyT2Dmitry Torokhov
Fix an OOPS is CinergyT2 driver when registering IR remote Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-16[DVB] cinergyT2: cinergyt2_register_rc() should return 0 on successDavid S. Miller
Currently, the version when ENABLE_RC is defined, falls through to the end of the function without returning anything. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-16[SPARC64]: Oops in pci_alloc_consistent with cingergyT2Guido Guenther
From: Guido Guenther <agx@sigxcpu.org> - Use correct API for allocating and freeing DMA buffers. Acked-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-28[PATCH] drivers/media: convert to dynamic input_dev allocationDmitry Torokhov
Input: convert drivers/media to dynamic input_dev allocation This is required for input_dev sysfs integration Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-09[PATCH] dvb: cinergyT2: remote control fixesJohannes Stezenbach
IR RC fixes: - EVIOCSKEYCODE is not supported by this driver, fix potential crash when it is used by not setting rc_input_dev->keycodesize - fix key repeat handling (hopefully) - reduce default poll internal to 50msec (necessary for key repeat handling) Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] dvb: remove version.h dependenciesOlaf Hering
Remove all #include <linux/version.h> and all references to LINUX_VERSION_CODE and KERNEL_VERSION. Based on patch by Olaf Hering. Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] swsusp: switch pm_message_t to structPavel Machek
This adds type-checking to pm_message_t, so that people can't confuse it with int or u32. It also allows us to fix "disk yoyo" during suspend (disk spinning down/up/down). [We've tried that before; since that cpufreq problems were fixed and I've tried make allyes config and fixed resulting damage.] Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Alexander Nyberg <alexn@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] dvb: cinergyT2: endianness fix for raw remote-control keysMartin Loschwitz
Fixed litte/big-endian conversion for raw remote-control keys. Signed-off-by: Martin Loschwitz <madkiss@madkiss.org> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] dvb: modified dvb_register_adapter() to avoid kmalloc/kfreeJohannes Stezenbach
Modified dvb_register_adapter() to avoid kmalloc/kfree. Drivers have to embed struct dvb_adapter into their private data struct from now on. (Andreas Oberritter) Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] fix u32 vs. pm_message_t in drivers/mediaPavel Machek
Here are fixes for drivers/media. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
