path: root/drivers/media/dvb/dvb-usb/dib0700_devices.c
2012-08-13[media] dvb-usb: move it to drivers/media/usb/dvb-usbMauro Carvalho Chehab
As media/dvb will be removed, move it to a proper place. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-04-19[media] dib0700: add new USB PID for the Elgato EyeTV DTT stickGianluca Gennari
Reported working here: http://ubuntuforums.org/archive/index.php/t-1510188.html http://ubuntuforums.org/archive/index.php/t-1756828.html https://sites.google.com/site/slackwarestuff/home/elgato-eyetv Signed-off-by: Gianluca Gennari <gennarone@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-01-17[media] DVB: dib0700, add support for Nova-TD LEDsJiri Slaby
Add an override of read_status to intercept lock status. This allows us to switch LEDs appropriately on and off with signal un/locked. The second phase is to override sleep to properly turn off both. This is a hackish way to achieve that. Thanks to Mike Krufky for his help. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-01-17[media] DVB: dib0700, add corrected Nova-TD frontend_attachJiri Slaby
This means cut & paste from the former f. attach. But while at it write to the right GPIO to turn on the right LED. Also turn the other two off jsut for sure. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-01-17[media] DVB: dib0700, separate stk7070pd initializationJiri Slaby
The start is common for both stk7070pd and novatd specific routine. This is just a preparation for the next patch. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-01-17[media] DVB: dib0700, move Nova-TD Stick to a separate setJiri Slaby
To properly support the three LEDs which are on the stick, we need a special handling in the ->frontend_attach function. Thus let's have a separate ->frontend_attach instead of ifs in the common one. The hadnling itself will be added in further patches. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-12-31[media] tuners: remove dvb_frontend_parameters from set_params()Mauro Carvalho Chehab
This is a big patch, yet trivial: now that all tuners use the DVBv5 way to pass parameters (e. g. via fe->dtv_property_cache), the extra parameter can be removed from set_params() call. After this change, very few DVBv3 specific stuff are left at the tuners. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-12-31[media] dib0700_devices: use DVBv5 parameters on set_params()Mauro Carvalho Chehab
Instead of using DVBv3 parameters, rely on DVBv5 parameters to set the tuner Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-24[media] dib9090: limit the I2C speedOlivier Grenie
The intend of this patch is to limit the maximum I2C speed. Signed-off-by: Olivier Grenie <olivier.grenie@dibcom.fr> Signed-off-by: Patrick Boettcher <patrick.boettcher@dibcom.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-24[media] dib8096P: add the reference board TFE8096POlivier Grenie
The intend of this patch is to add the support for the DiBcom reference board TFE8096P. Signed-off-by: Olivier Grenie <olivier.grenie@dibcom.fr> Signed-off-by: Patrick Boettcher <patrick.boettcher@dibcom.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-24[media] add the support for DiBcom dib8096POlivier Grenie
The purpose of this patch is to support the DiBcom chip dib8096P. Signed-off-by: Olivier Grenie <olivier.grenie@dibcom.fr> Signed-off-by: Patrick Boettcher <patrick.boettcher@dibcom.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-24[media] dib7090: add the reference board TFE7790EOlivier Grenie
The intend of this patch is to add the support for the DiBcom reference board TFE7790E. Signed-off-by: Olivier Grenie <olivier.grenie@dibcom.fr> Signed-off-by: Patrick Boettcher <patrick.boettcher@dibcom.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-24[media] DiBcom: correct warningsOlivier Grenie
The intend of this patch is to correct some warnings given. Signed-off-by: Olivier Grenie <olivier.grenie@dibcom.fr> Signed-off-by: Patrick Boettcher <patrick.boettcher@dibcom.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-24[media] dib7090: add the reference board TFE7090EOlivier Grenie
The intend of this patch is to add the support for the DiBcom reference board TFE7090E. Signed-off-by: Olivier Grenie <olivier.grenie@dibcom.fr> Signed-off-by: Patrick Boettcher <patrick.boettcher@dibcom.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-24[media] dib7000p/dib0090: update the driverOlivier Grenie
This patch intends to update the dib7000p and dib0090 driver in order to improve the performances. Signed-off-by: Olivier Grenie <olivier.grenie@dibcom.fr> Signed-off-by: Patrick Boettcher <patrick.boettcher@dibcom.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-21[media] dib0700: fix ERROR: space required after that ','Michael Krufky
Signed-off-by: Michael Krufky <mkrufky@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-21[media] dib0700: fix ERROR: space required before that '&'Michael Krufky
2011-09-21[media] dib0700: fix WARNING: suspect code indent for conditional statementsMichael Krufky
2011-09-21[media] dib0700: fix WARNING: please, no spaces at the start of a lineMichael Krufky
2011-09-06[media] dvb-usb: refactor MFE code for individual streaming config per frontendMichael Krufky
refactor MFE code to allow for individual streaming configuration for each frontend Signed-off-by: Michael Krufky <mkrufky@kernellabs.com> Reviewed-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-31[media] dvb-usb: prepare for multi-frontend support (MFE)Antti Palosaari
Change adapter FE pointer as array of FE pointers. Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] xc4000: make checkpatch.pl happyMauro Carvalho Chehab
Solve the ./scripts/checkpatch.pl compliants for the patches that added xc4000 support, including a few changes at dib0700. While here, remove a few printk noise by converting some msgs into debug ones. Cc: Istvan Varga <istvan_v@mailbox.hu> Cc: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] xc4000: removed card_typeistvan_v@mailbox.hu
Removed the use of 'card_type' from the tuner configuration structure, and replaced it with separate parameters to set board-specific configuration. Signed-off-by: Istvan Varga <istvan_v@mailbox.hu> Cc: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] xc4000: code cleanupistvan_v@mailbox.hu
Various coding style changes: - removed unused / commented out code - changed C++ style comments to C format - renamed functions and variables that included upper case letters in the name - removed tabs from module parameter descriptions - replaced the use of XC_RESULT_* with standard error codes Signed-off-by: Istvan Varga <istvan_v@mailbox.hu> Cc: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] dib0700: remove notes from bringup of PCTV 340eDevin Heitmueller
Remove some inline comments I had written from when I was computing the proper dib7000p configuration to work with the xc4000. Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com> Cc: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] dib0700: make PCTV 340e work!Devin Heitmueller
Fixup the PLL and AGC configs so that the 340e works (correcting errors I made when I did the original config blindly). Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com> Cc: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] dib0700: fixup PLL config for PCTV 340eDevin Heitmueller
Based on a reference trace under Windows, reverse engineer the PLL config. Note that the xtal is not yet setup, and the timf cannot be determined yet because my reference trace doesn't actually achieve a signal lock. Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com> Cc: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] xc4000: setup dib7000p AGC config for PCTV 340eDevin Heitmueller
Setup a proper AGC config for the 340e, based on the Windows USB trace Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] dib0700: add a sleep before attempting to detect dib7000pDevin Heitmueller
Add a sleep since in some cases the dib7000p wasn't online when being probed. The optimal timing has not yet been determined. Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com> Cc: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] dib0700: successfully connect to xc4000 over i2c for PCTV 340eDevin Heitmueller
Use the correct i2c bus to communicate with the tuner, and properly setup the reset GPIO and i2c address. Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com> Cc: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] dib0700: properly setup GPIOs for PCTV 340eDevin Heitmueller
Provide a frontend setup routine for the PCTV 340e which takes into account the specific GPIO setup of the board. Note that this patch does *not* take into account the xc4000 reset pin, which is attached to the dib7000. Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com> Cc: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] dib0700: add USB id for PCTV 340eSEDevin Heitmueller
Add the board profile for the PCTV 340eSE, since that's what I have here for development. [mchehab@redhat.com: rebased on the top of the current tree] Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com> Cc: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] dib0700: add initial code for PCTV 340e by Davide FerriDavide Ferri
This is initial code written by Davide Ferri for the PCTV 340e, including a new xc4000 driver. I am checking in all the code unmodified, and making no assertions about its quality (other than confirming it compiles). [mchehab@redhat.com: rebased on the top of the current tree] Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com> Signed-off-by: Davide Ferri <davidef1986@gmail.com> Cc: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-21[media] support for medion dvb stick 1660:1921Stéphane Elmaleh
[mchehab@redhat.com: The same patch were sent by Alf and by Randoslaw. I've applied the oldest version, just fixing the entry index] Cc: Patrick Boettcher <pboettcher@kernellabs.com> Tested-by: James Huk <huk256@gmail.com> Tested-by: Alf Fahland <alf-f@gmx.de> Signed-off-by: Radoslaw Warowny <radoslaww@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-20[media] dib0700: fix possible NULL pointer dereferenceMariusz Kozlowski
Seems like 'adap->fe' test for NULL was meant to be before we dereference that pointer. Signed-off-by: Mariusz Kozlowski <mk@lab.zgora.pl> Acked-by: Patrick Boettcher <patrick.boettcher@dibcom.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-04[media] dib0700: fix possible NULL pointer dereferencePatrick Boettcher
Seems like 'adap->fe' test for NULL was meant to be before we dereference that pointer. Signed-off-by: Mariusz Kozlowski <mk@lab.zgora.pl> Signed-off-by: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-04[media] DIB0700: fix typo in dib0700_devices.cPatrick Boettcher
Fix typo introduced in b4d6046e841955be9cc49164b03b91c9524f9c2e. Spotted by Dr. David Alan Gilbert. Thanks for that. Signed-off-by: Patrick Boettcher <pboettcher@kernellabs.com> Cc: Dr. David Alan Gilbert <linux@treblig.org> Cc: stable@kernel.org Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] Technisat AirStar TeleStick 2Lukas Max Fisch
Based on staging 2.6.39. This patch is based on Veit Berwig's work. Signed-off-by: Lukas Fisch <lukas.fisch@gmail.com> Thanks-to: Veit Berwig <veit.Berwig@fimi.landsh.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] DiBxxxx: Codingstype updatesOlivier Grenie
This patchs fix several conding-style violations. Signed-off-by: Olivier Grenie <olivier.grenie@dibcom.fr> Signed-off-by: Patrick Boettcher <patrick.boettcher@dibcom.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] DiB0700: add support for several board-layoutsOlivier Grenie
This patchs adds support for DiBcom's NIM8096MD, NIM9090M, NIM9090MD, NIM7090, TFE7090PVR (no diversity) reference designs. Signed-off-by: Olivier Grenie <olivier.grenie@dibcom.fr> Signed-off-by: Patrick Boettcher <patrick.boettcher@dibcom.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-02[media] DiB7000M: add pid filteringOlivier Grenie
This patch adds the pid filtering for the dib7000M demod. It also corrects the pid filtering for the dib7700 based board. It should prevent an oops, when using dib7700p based board. References: https://bugzilla.novell.com/show_bug.cgi?id=644807 Signed-off-by: Olivier Grenie <olivier.grenie@dibcom.fr> Signed-off-by: Patrick Boettcher <patrick.boettcher@dibcom.fr> Tested-by: Pavel SKARKA <paul.sp@seznam.cz> Cc: stable@kernel.org Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] rc: Rename remote controller type to rc_type instead of ir_typeMauro Carvalho Chehab
for i in `find drivers/staging -type f -name *.[ch]` `find include/media -type f -name *.[ch]` `find drivers/media -type f -name *.[ch]`; do sed s,IR_TYPE,RC_TYPE,g <$i >a && mv a $i; done for i in `find drivers/staging -type f -name *.[ch]` `find include/media -type f -name *.[ch]` `find drivers/media -type f -name *.[ch]`; do sed s,ir_type,rc_type,g <$i >a && mv a $i; done Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] Rename all public generic RC functions from ir_ to rc_Mauro Carvalho Chehab
Those functions are not InfraRed specific. So, rename them to properly reflect it. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] ir-core: make struct rc_dev the primary interfaceDavid Härdeman
This patch merges the ir_input_dev and ir_dev_props structs into a single struct called rc_dev. The drivers and various functions in rc-core used by the drivers are also changed to use rc_dev as the primary interface when dealing with rc-core. This means that the input_dev is abstracted away from the drivers which is necessary if we ever want to support multiple input devs per rc device. The new API is similar to what the input subsystem uses, i.e: rc_device_alloc() rc_device_free() rc_device_register() rc_device_unregister() [mchehab@redhat.com: Fix compilation on mceusb and cx231xx, due to merge conflicts] Signed-off-by: David Härdeman <david@hardeman.nu> Acked-by: Jarod Wilson <jarod@redhat.com> Tested-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-09-27V4L/DVB: dib7000p: add disable sample and hold, and diversity delay parameterOlivier Grenie
This patch improves the overall driver performance in diversity-reception scenarios. Signed-off-by: Olivier Grenie <olivier.grenie@dibcom.fr> Signed-off-by: Patrick Boettcher <patrick.boettcher@dibcom.fr> Cc: stable@kernel.org Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-09-27V4L/DVB: dib7770: enable the current mirrorOlivier Grenie
To improve performance on DiB7770-devices enabling the current mirror is needed. This patch adds an option to the dib7000p-driver to do that and it creates a separate device-entry in dib0700-device to use those changes on hardware which is using the DiB7770. Signed-off-by: Olivier Grenie <olivier.grenie@dibcom.fr> Signed-off-by: Patrick Boettcher <patrick.boettcher@dibcom.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-09-27V4L/DVB: Don't identify PV SBTVD Hybrid as a DibCom deviceMauro Carvalho Chehab
As reported by Carlos, Prolink Pixelview SBTVD Hybrid is based on Conexant cx231xx + Fujitsu 86A20S demodulator. However, both shares the same USB ID. So, we need to use USB bcdDevice, in order to properly discover what's the board. We know for sure that bcd 0x100 is used for a dib0700 device, while bcd 0x4001 is used for a cx23102 device. This patch reserves two ranges, the first one from 0x0000-0x3f00 for dib0700, and the second from 0x4000-0x4fff for cx231xx devices. This may need fixes in the future, as we get access to other devices. Thanks-to: Carlos Americo Domiciano <c_domiciano@yahoo.com.br> Cc: stable@kernel.org Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-02V4L/DVB: dib0700: properly implement IR change_protocolMauro Carvalho Chehab
This patch implements change_protocol callback. With this change, there's no need for an extra modprobe parameter to specify the protocol. When a table is loaded (either from in-kernel rc-map tables or via ir-keytable program), the driver will automatically change the protocol, in order to work with the given table. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-02V4L/DVB: dib0700: break keytable into NEC and RC-5 variantsMauro Carvalho Chehab
Instead of having one big keytable with 2 protocols inside, break it into two separate tables, being one for NEC and another for RC-5 variants, and properly identify what variant should be used at the boards entries. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-02V4L/DVB: Port dib0700 to rc-coreMauro Carvalho Chehab
Use the new rc-core handler at dvb-usb-remote for dib0700 driver. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
