path: root/drivers/media/dvb/dvb-usb/dvb-usb-firmware.c
2012-08-13[media] dvb-usb: move it to drivers/media/usb/dvb-usbMauro Carvalho Chehab
As media/dvb will be removed, move it to a proper place. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-06-05V4L/DVB (7971): usb: unalignedAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-10-03V4L/DVB (4650): Misc fixes for dib0700 downloadPatrick Boettcher
Several fixes for dib0700-module. (Firmware error checking, dependency) Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-10-03V4L/DVB (4648): Hauppauge Nova-T 500 support addedPatrick Boettcher
This changeset finalizes the support of the Hauppauge Nova-T 500 (Dual DVB-T). It adds correct AGC setting for the 3000P, correct firmware download state detection. Additionally it fixes the mt2060-driver to be able to be used with dvb_attach. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-10-03V4L/DVB (4646): Misc. changes, DiB3000MC, MT2060Patrick Boettcher
Changed the attach-function of the dib3000mc-driver to return only one frontend. In case of multiple dib3000-chips on one board, one has to call the i2c-enumeration manually before. Added a field to Microtune 2060 config to output the clock to other tuners/device on a board. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-10-03V4L/DVB (4643): Multi-input patch for DVB-USB devicePatrick Boettcher
This patch is the first commit of the Multiple Input Patch for the DVB-USB frame work. It changes the DVB-USB-device to be able to have more than one streaming input (e.g. multiple DVB-T sources) on one device. This is a necessary feature for the upcoming DiB7700 driven devices. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-23V4L/DVB (3428): drivers/media/dvb/ possible cleanupsAdrian Bunk
- Make needlessly global code static - #if 0 the following unused global functions: - b2c2/flexcop-dma.c: flexcop_dma_control_packet_irq() - b2c2/flexcop-dma.c: flexcop_dma_config_packet_count() Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-09V4L/DVB (3327): Remove DViCO specific firmware hacks from the generic code.Patrick Boettcher
- Move the code that patches bluebird firmware before upload from the generic code into the cxusb driver itself. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Chris Pascoe <c.pascoe@itee.uq.edu.au> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3310): DViCO Dual Digital DVB-T / USB bluebird updatesChris Pascoe
- Add support for the USB portion of the DViCO Dual Digital board. Patch correct "warm" USB IDs into bluebird firmware before download. Signed-off-by: Chris Pascoe <c.pascoe@itee.uq.edu.au> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3145): syncronizes some changes between v4l and dvbMauro Carvalho Chehab
- digitv_ctrl_msg() if (wo) test is reversed. fixed. - usb timeout is in Hz, not in jiffies. - NULL replaced by 0 to be coherent. - removed uneeded headers. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09DVB (2420): Makes integration of future devices easierPatrick Boettcher
- To make the integration of future devices easier - modified the dvb-usb-part to allow a device-specific firmware download - added an option to specify whether a device reconnects after a firmware download or not. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2005-06-24[PATCH] dvb: Add generalized dvb-usb driverJohannes Stezenbach
Add generalized dvb-usb driver which supports a wide variety of devices. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
