path: root/drivers/media/dvb/dvb-usb/m920x.c
2008-06-05V4L/DVB (7969): m920x: unaligned accessAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7538): Adds selectable adapter numbers as per module optionJanne Grunau
The adapter_nr module options can be used to allocate static adapter numbers on a driver level. It avoids problems with changing DVB apapter numbers after warm/cold boot or device unplugging and repluging. Each driver holds DVB_MAX_ADAPTER long array of the preferred order of adapter numbers. options dvb-usb-dib0700 adapter_nr=7,6,5,4,3,2,1,0 would result in a reversed allocation of adapter numbers. With adapter_nr=2,5 it tries first to get adapter number 2 and 5. If both are already in use it will allocate the lowest free adapter number. Signed-off-by: Janne Grunau <janne-dvb@grunau.be> Acked-by: Hermann Pitton <hermann.pitton@arcor.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7513): media/dvb/dvb-usb replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5696): M920x: add missing error handling to prevent syslog spammingAapo Tahkola
Signed-off-by: Aapo Tahkola <aet@rasterburn.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5695): M920x: enable second adapter on LifeView TV Walker TwinAapo Tahkola
Enable second adapter on LifeView TV Walker Twin DVB-T USB2.0 Signed-off-by: Aapo Tahkola <aet@rasterburn.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5694): M920x: fix for Dposh devicesAapo Tahkola
Make sure devices manufactured by Dposh are not affected by previous hw pid filtering changes Doing so might crash it. Signed-off-by: Aapo Tahkola <aet@rasterburn.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5693): M920x: second endpoint also needs to be changed to alt settingAapo Tahkola
Spotted by Jeremy Nysen. Signed-off-by: Aapo Tahkola <aet@rasterburn.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5692): M920x: attempt to fix hw pid filters on second endpointAapo Tahkola
2007-05-09V4L/DVB (5614): M920x: Disable second adapter on LifeView TV Walker TwinNick Andrew
Disable second adapter on LifeView TV Walker Twin while it doesn't work properly. Signed-off-by: Aapo Tahkola <aet@rasterburn.org> Signed-off-by: Nick Andrew <nick@nick-andrew.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-05-09V4L/DVB (5613): M920x: loosen up 80-col limitAapo Tahkola
Do not follow 80-col limit where it would cause inconsistency. Signed-off-by: Aapo Tahkola <aet@rasterburn.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-05-09V4L/DVB (5612): M920x: rename function prefixes from m9206_foo to m920x_fooAapo Tahkola
Signed-off-by: Aapo Tahkola <aet@rasterburn.org> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-05-09V4L/DVB (5611): M920x: replace deb_rc with debAapo Tahkola
deb_rc is used by the dvb-usb core framework. This patch replaces all occurances of deb_rc with deb, in m920x.c, so that its clear that we're not using dvb-usb's deb_rc. Signed-off-by: Aapo Tahkola <aet@rasterburn.org> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-05-09V4L/DVB (5610): M920x: remove duplicated codeMichael Krufky
Some of the devices supported by the m920x driver have identical functions used for tuner_attach and frontend_attach. This patch consolidates the functions in question, and updates the debug code to be generic for each. This patch decreases the size of the kernel. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-05-09V4L/DVB (5609): M920x: group like functions togetherMichael Krufky
- Group the tuner configurations together. - Group the demod configurations together. - Group the device-specific initialization functions together. - Group demod_attach functions together. - Group tuner_attach functions together. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-05-09V4L/DVB (5608): M920x: various whitespace cleanupsMichael Krufky
- 80-column cleanups - spaces between operators - tabbing style Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-05-09V4L/DVB (5607): M920x: Initial support for devices likely manufactured by DposhAapo Tahkola
These devices are sold by various companies and chains not involved in hardware manufacturing business. This particular device owned by winisch (from irc) had a sticker with text "TCM 234292" on it. This device was never opened so it is possible that Dposh did not manufacture this stick. However, the bundled software and their product line points into that direction. Also thanks to Michael Krufky for spotting this hw filtering problem and thus avoiding hair loss. Hardware pid filters and the bundled remote controller are not currently supported on this device. Signed-off-by: Aapo Tahkola <aet@rasterburn.org> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-05-09V4L/DVB (5606): M920x: add "c-basic-offset: 8" to help emacs to enforce tabbingMichael Krufky
2007-05-09V4L/DVB (5605): M920x: Add support for LifeView TV Walker TwinNick Andrew
Add support for "LifeView TV Walker Twin" (USB IDs 10fd:0513, 10fd:0514) Signed-off-by: Nick Andrew <nick@nick-andrew.net> Signed-off-by: Aapo Tahkola <aet@rasterburn.org> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5459): M920x: add support for Anubis Electronics / MSI Digi Vox Mini IIPierre Willenbrock
Add support for Anubis Electronics "Lifeview" (USB-ID: 0x10fd:0x1513) Signed-off-by: Pierre Willenbrock <pierre@pirsoft.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5449): M920x: add error messages for debugging purposesPierre Willenbrock
Signed-off-by: Pierre Willenbrock <pierre@pirsoft.dnsalias.org> Signed-off-by: Aapo Tahkola <aet@rasterburn.org> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5448): M920x: rename megasky_identify_state to m920x_identify_stateAapo Tahkola
This function should work for all m920x-based devices. Signed-off-by: Aapo Tahkola <aet@rasterburn.org> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5428): M920x: Detect zero-length I2C messages and fix a typoTrent Piepho
Change a 00 to just 0 Detect zero-length I2C messages and return not supported. I think I know how to send one, but the problem is getting the slave's ack. The only point of a zero-length message is for probing; too see if the slave will ack its address. Since we don't know how to get the ack, we can't support zero-length messages in a useful way, so it's probably best to just return not supported for them. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5427): M920x: Improve I2C operationsTrent Piepho
Write some better documentation about what might be known about how the m920x I2C works, since a datasheet is lacking. The I2C xfer function should now handle more types of I2C transactions than it could before. Those it can't, will return error codes instead of being executed incorrectly. Multi-byte reads were not being done correctly, which should be fixed. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5426): M920x: remove unneeded codeAapo Tahkola
2007-04-27V4L/DVB (5425): M920x: rework driver code to allow for different devicesAapo Tahkola
2007-04-27V4L/DVB (5423): M920x: i2c cleanupsAapo Tahkola
- Implement m920x i2c as suggested by Pierre Willenbrock - remove "magic" hack - r/w bit is not part of the i2c address - move hardware remarks to header file Signed-off-by: Aapo Tahkola <aet@rasterburn.org> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5142): M920x: move filter caps from device caps to adapter capsMichael Krufky
Move filter caps from device caps to adapter caps for the megasky driver. This fixes usb1.1 operation. Signed-off-by: Aapo Tahkola <aet@rasterburn.org> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5141): M920x: group tuner / demod callback functions togetherMichael Krufky
2007-02-21V4L/DVB (5140): Whitespace / 80-column cleanupsMichael Krufky
2007-02-21V4L/DVB (5139): M920x: Fix tuner identification bug with qt1010 moduleAapo Tahkola
Fixes qt1010 identification bug with megasky caused by the Quantek QT1010 tuner module patch. Signed-off-by: Aapo Tahkola <aet@rasterburn.org> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5137): Dvb: add new qt1010 tuner moduleAntti Palosaari
QT1010: - old qt1010-code totally rewritten and put in own kernel module - same enhancements as my earlier QT1010 125kHz patch - tuner initialization - register 1f calculation - register 20 calculation - register 25 calculation m920x: (MSI Megasky) - use new QT1010 module instead of old code Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5136): M920x: correct oops when loading moduleMichael Krufky
move .caps from the adapter properties to the device properties. Thanks to Martin Schwier for confirming this fix. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5134): M920x: fix build in hg tree / other trivial fixesMichael Krufky
- removed extra newline - removed NULL entry - fixed versions.txt Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5133): M920x: move qt1010_tuner_attach function into qt1010.hMichael Krufky
The megasky_tuner_attach function is not specific to this device. This patch renames it to qt1010_tuner_attach and moves it into the qt1010 header file. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5132): M920x: more trivial cleanupsPatrick Boettcher
- Removed some needless brances - Removed an unneeded check for adapter[0] - Removed unneeded declaration of .generic_bulk_ctrl_endpoint = 0x01 Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5131): M920x: more cleanupsMichael Krufky
Some cleanups and suggestions from Patrick Boettcher. Dropped the mutex in m9206_rc_query using #if 0, because M9206_CORE, M9206_I2C, M9206_FILTER and M9206_FW can be accessed concurrently. Thanks to both Aapo Tahkola and Patrick Boettcher. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5130): M920x: misc updates and fixesAapo Tahkola
- hardware pid filtering no longer enabled unless in usb 1.x mode - more responsive rc handling - some minor bug fixes and code refolding - m9206_write delay dropped (doesn't seem to be needed) Signed-off-by: Aapo Tahkola <aet@rasterburn.org> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5129): M920x: break out qt1010 tuner code into a separate fileMichael Krufky
qt1010 is a tuner used in some other devices, so this code should be put into a separate file so that it could be reused by other drivers. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5128): M920x: trivial cleanupsMichael Krufky
2007-02-21V4L/DVB (5127): M920x: update megasky driver for recent changes in the dvb treeMichael Krufky
update code to use dvb_attach() update code to reflect recent changes to the dvb_usb framework Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5126): M920x: cleanups after rename from megasky.[ch]Michael Krufky
2007-02-21V4L/DVB (5125): Dvb-usb: rename megasky.[ch] to m920x.[ch]Michael Krufky
