Raise the DVB frontends one level up, as the intention is to remove
the drivers/media/dvb directory.
Now that this field is deprecated, and core generates it for
DVBv3 calls, remove it from the drivers.
It also adds .delsys on the few drivers where this were missed.
Just like set_frontend, use the dvb cache properties for get_frontend.
This is more consistent, as both functions are now symetric. Also,
at the places get_frontend is called, it makes sense to update the
cache.
Most of this patch were generated by this small perl script:
while (<>) { $file .= $_; }
if ($file =~ m/\.get_frontend\s*=\s*([\d\w_]+)/) {
my $get = $1;
$file =~ s/($get)(\s*\([^\,\)]+)\,\s*struct\s+dtv_frontend_properties\s*\*\s*([_\d\w]+)\)\s*\{/\1\2)\n{\n\tstruct dtv_frontend_properties *\3 = &fe->dtv_property_cache;/g;
print $file;
Of course, the changes at dvb_frontend.[ch] were made by hand,
as well as the changes on a few other places, where get_frontend()
is called internally inside the driver.
On some places, get_frontend() were just a void function. Those
occurrences were removed, as the DVB core handles such cases.
Instead of using dvb_frontend_parameters struct, that were
designed for a subset of the supported standards, use the DVBv5
cache information.
Also, fill the supported delivery systems at dvb_frontend_ops
struct.
Creates a DVBv5 get_frontend call, renaming the DVBv3 one to
get_frontend_legacy(), while not all frontends are converted.
After the conversion for all drivers, get_frontend_legacy()
will be removed.
Passing DVBv3 parameters to set_frontend is not fun, as the
core doesn't have any way to know if the driver is using the
v3 or v5 parameters. So, rename the callback and add a new
one to allow distinguish between a mixed v3/v5 paramenter call
from a pure v5 call.
After having all frontends to use the new way, the legacy
call can be removed.
This is a big patch, yet trivial: now that all tuners use the DVBv5
way to pass parameters (e. g. via fe->dtv_property_cache), the
extra parameter can be removed from set_params() call.
After this change, very few DVBv3 specific stuff are left at the
tuners.
properly
This patch changes most frontend drivers to allocate their state structure via
kzalloc and not kmalloc. This is done to properly initialize the
embedded "struct dvb_frontend frontend" field, that they all have.
The visible effect of this struct being uninitalized is, that the member "id"
that is used to set the name of kernel thread is totally random.
Some board drivers (for example cx88-dvb) set this "id" via
videobuf_dvb_alloc_frontend but most do not.
So I at least get random id values for saa7134, flexcop and ttpci based cards.
It looks like this in dmesg:
DVB: registering adapter 1 frontend -10551321 (ST STV0299 DVB-S)
The related kernel thread then also gets a strange name
like "kdvb-ad-1-fe--1".
Cc: Michael Krufky <mkrufky@linuxtv.org>
Cc: Steven Toth <stoth@linuxtv.org>
Cc: Timothy Lee <timothy.lee@siriushk.com>
Cc: Igor M. Liplianin <liplianin@me.by>
Signed-off-by: Matthias Schwarzott <zzam@gentoo.org>
Acked-by: Andreas Oberritter <obi@linuxtv.org>
Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com>
Use the physical device rather than the i2c adapter as the reference
device when loading firmwares. This will prevent the sysfs name
collision with i2c-dev that has been reported many times.
I may have missed other drivers which need the same fix.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Acked-by: Oliver Endriss <o.endriss@gmx.de>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
The C99 specification states in section 6.11.5:
The placement of a storage-class specifier other than at the
beginning of the declaration specifiers in a declaration is an
obsolescent feature.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
state is already NULL.
Reviewed-by: Trent Piepho <xyzzy@speakeasy.org>
Since at least kernel 2.6.12-rc2, module.h includes moduleparm.h. This
patch removes all occurences of moduleparm.h from drivers/media files.
These sources do not need to #include "dvb-pll.h"
The code the i2c transactions was leftover from the old V4L-based ATSC
driver. It did too little with too much code. It is re-written to
remove unnecessary parameters and be more efficient. A demod register
can now be read with one function call, instead of repeating a dozen line
block of code each time.
There were msleep()'s, which appear to be unnecessary, spread around all
the I2C transactions. These have been removed. Reading SNR used to take
about 130 ms, now it's down to 1.8 ms.
Reads from the demodulator's registers do not return correct results
sometimes. Adding or removing the delays in the I2C transactions did not
appear to effect the probability of failure. If anything, the
transactions without delays were less likely to fail, but since far more
transactions could be made per second the number of failures per hour was
greater.
To increase reliability, the SNR and get_params functions will now retry
once if they get bad data back. This appears to have reduced the
probability of failure to effectively zero.
Some error messages are cleaned up or given KERN_* levels when they were
missing.
or51132_setmode() wasn't returning correct error codes, which is fixed as
well.
CC: Rusty Scott <rustys@ieee.org>
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
Removes embedded log functions and makes use of the DVB math functions
to provide SNR in dB. The changes are modeled after recent changes made
to the LGDT330x frontends in lgdt330x.c
Signed-off-by: Rusty Scott <rustys@ieee.org>
pointer field inside dvb_frontend
The dvb_frontend_ops is a pointer inside dvb_frontend. That's why every demod-driver
is having a field of dvb_frontend_ops in its private-state-struct and
using the reference for filling the pointer-field in dvb_frontend.
- It saves at least two lines of code per demod-driver,
- reduces object size (one less dereference per frontend_ops-access),
- be coherent with dvb_tuner_ops,
- makes it a little bit easier for newbies to understand how it works and
- avoids stupid mistakes because you would have to copy the dvb_frontend_ops
always, before you could assign the static pointer directly, which was
dangerous.
Signed-off-by: Patrick Boettcher <pb@linuxtv.org>
Convert to tuner_ops calls.
Remove pll function pointers from structure.
Remove dvb-pll code - done elsewhere now.
Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net>
Adds the FE_GET_FRONTEND ioctl to the or51132 frontend. Current modulation is
read from the hardware, while frequency is taken from the driver's state.
A few lines that do nothing in the or51132 frontend, removed.
As QAM_64, QAM_256, and QAM_AUTO all use the same firmware, switching
between these modulations doesn't require a firmware re-load. This also
fixes a mishandled error condition, in which the firmware file is loaded
into the kernel, the clock mode is changed, but then the firmware upload
to the device fails. The modulation change is aborted, but the clock
mode would still be changed.
There is some old code in the or51133 firmware loading function that
has no effect. Left a comment to in case it helps someone trying
to reverse engineer the chip.
Clean up whitespaces at v4l/dvb files
Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
Fix integer overflow bug in read_signal_strength() reported by Anthony
Leclerc.
Signed-off-by: Johannes Stezenbach <js@linuxtv.org>
This is the drivers/media/ part of the big kfree cleanup patch.
Remove pointless checks for NULL prior to calling kfree() in drivers/media/.
Cc: Johannes Stezenbach <js@linuxtv.org>
Cc: Michael Krufky <mkrufky@m1k.net>
Cc: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
Acked-by : Manu Abraham <manu@linuxtv.org>
Acked-by: Wilson Michaels <wilsonmichaels@earthlink.net>
I recently picked up my older work to remove unnecessary #includes of
sched.h, starting from a patch by Dave Jones to not include sched.h
from module.h. This reduces the number of indirect includes of sched.h
by ~300. Another ~400 pointless direct includes can be removed after
this disentangling (patch to follow later).
However, quite a few indirect includes need to be fixed up for this.
In order to feed the patches through -mm with as little disturbance as
possible, I've split out the fixes I accumulated up to now (complete for
i386 and x86_64, more archs to follow later) and post them before the real
patch. This way this large part of the patch is kept simple with only
adding #includes, and all hunks are independent of each other. So if any
hunk rejects or gets in the way of other patches, just drop it. My scripts
will pick it up again in the next round.
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
This fix has also been applied to lgdt330x. There is an optimization that
keeps track of the frequency tuned by the digital decoder. The digital driver
does not set the frequency if it has not changed since it was tuned. The
analog tuner driver knows nothing about the frequency saved by the digital
driver. When the frequency is set using the video4linux code with tvtime, the
hardware get changed but the digital driver's state does not get updated.
Switch back to the same digital channel and the driver finds no change in
frequency so the tuner is not reset to the digital frequency. The work around
is to remove the check and always set the tuner to the specified frequency.
Signed-off-by: Mac Michaels <wmichaels1@earthlink.net>
Signed-off-by: Michael Krufky <mkrufky@m1k.net>
remove unnecessary casts in frontends (Kenneth Aafloy)
infrastructure for it.
Let it rip!
