path: root/drivers/media/dvb/ttusb-dec/ttusb_dec.c
2010-05-20USB: rename usb_buffer_alloc() and usb_buffer_free() usersDaniel Mack
For more clearance what the functions actually do, usb_buffer_alloc() is renamed to usb_alloc_coherent() usb_buffer_free() is renamed to usb_free_coherent() They should only be used in code which really needs DMA coherency. All call sites have been changed accordingly, except for staging drivers. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Pedro Ribeiro <pedrib@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-05V4L/DVB (13414): ttusb-dec: do not overwrite the first part of phys stringMárton Németh
Use strlcat() to append a string to the previously created first part. The semantic match that finds this kind of problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression dev; expression phys; expression str; expression size; @@ usb_make_path(dev, phys, size); - strlcpy(phys, str, size); + strlcat(phys, str, size); // </smpl> Signed-off-by: Márton Németh <nm127@freemail.hu> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-29V4L/DVB (10248): v4l-dvb: fix a bunch of compile warnings.Hans Verkuil
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-16V4L/DVB (9604): ttusb_dec: fix memory leakDouglas Schilling Landgraf
Free allocated memory Signed-off-by: Douglas Schilling Landgraf <dougsland@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-16V4L/DVB (9601): ttusb_dec: Add NULL pointer validationDouglas Schilling Landgraf
Added validation for NULL pointer Signed-off-by: Douglas Schilling Landgraf <dougsland@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB: follow lspci device/vendor styleBjorn Helgaas
Use "[%04x:%04x]" for PCI vendor/device IDs to follow the format used by lspci(8). Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-07-10ttusb-dec: treat firmware data as constDavid Woodhouse
2008-06-05V4L/DVB (7962): ttusb endianness annotations and fixesAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7538): Adds selectable adapter numbers as per module optionJanne Grunau
The adapter_nr module options can be used to allocate static adapter numbers on a driver level. It avoids problems with changing DVB apapter numbers after warm/cold boot or device unplugging and repluging. Each driver holds DVB_MAX_ADAPTER long array of the preferred order of adapter numbers. options dvb-usb-dib0700 adapter_nr=7,6,5,4,3,2,1,0 would result in a reversed allocation of adapter numbers. With adapter_nr=2,5 it tries first to get adapter number 2 and 5. If both are already in use it will allocate the lowest free adapter number. Signed-off-by: Janne Grunau <janne-dvb@grunau.be> Acked-by: Hermann Pitton <hermann.pitton@arcor.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7517): media/dvb/ttusb-dec replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-19get rid of input BIT* duplicate definesJiri Slaby
get rid of input BIT* duplicate defines use newly global defined macros for input layer. Also remove includes of input.h from non-input sources only for BIT macro definiton. Define the macro temporarily in local manner, all those local definitons will be removed further in this patchset (to not break bisecting). BIT macro will be globally defined (1<<x) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: <dtor@mail.ru> Acked-by: Jiri Kosina <jkosina@suse.cz> Cc: <lenb@kernel.org> Acked-by: Marcel Holtmann <marcel@holtmann.org> Cc: <perex@suse.cz> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: <vernux@us.ibm.com> Cc: <malattia@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-09V4L/DVB (6079): Cleanup: remove linux/moduleparam.h from drivers/media filesMauro Carvalho Chehab
Since at least kernel 2.6.12-rc2, module.h includes moduleparm.h. This patch removes all occurences of moduleparm.h from drivers/media files. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5164): Compat: Handle input_register_device() change and some othersTrent Piepho
input_register_device() was changed to return an error code instead of being void in 2.6.15. Handle it with a macro wrapper in config.h. For this to work, linux/input.h must be included before config.h. This required some trivial header re-ordering in budget-ci.c and ttusb_dec.c. In kernel 2.6.15-rc1 a helper function called setup_timer() was added to linux/timer.h. Add to compat.h, but require that linux/timer.h be included first to give the definition of struct timer_list. A new 4GB DMA zone, __GFP_DMA32, was added in 2.6.15-rc2. Alias it to __GFP_DMA on older kernels. Handle another 2.6.15 "input_dev->dev to input_dev->cdev.dev" change for some recently added code in cinergyT2.c. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4854): Handle errors from input_register_device()Dmitry Torokhov
Also sprinkled some input_sync() throughout the code. Acked-by: Ricardo Cerqueira <v4l@cerqueira.org> Acked-by: Oliver Endriss <o.endriss@gmx.de> Acked-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-07[PATCH] slab: remove SLAB_ATOMICChristoph Lameter
SLAB_ATOMIC is an alias of GFP_ATOMIC Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-01usb: ttusb_dec free urb cleanupMariusz Kozlowski
- usb_free_urb() cleanup Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-30Merge master.kernel.org:/pub/scm/linux/kernel/git/mchehab/v4l-dvbLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/mchehab/v4l-dvb: (180 commits) V4L/DVB (4641): Trivial: use lowercase letters in hex subsystem ids V4L/DVB (4639): Cx88: add autodetection for alternate revision of Leadtek PVR V4L/DVB (4638): Basic DVB-T and analog TV support for the HVR1300. V4L/DVB (4637): Add a default method for VIDIOC_G_PARM V4L/DVB (4635): Extend bttv and saa7134 to check for both AGP and PCI PCI failure case V4L/DVB (4634): Zr36120: implement pcipci checks V4L/DVB (4632): Zoran: Implement pcipci failure check V4L/DVB (4631): Av7110: remove V4L2_CAP_VBI_CAPTURE flag V4L/DVB (4630): Av7110: FW_LOADER depemdency fixed V4L/DVB (4629): Saa7134: add card support for Proteus Pro 2309 V4L/DVB (4628): Fix VIDIOC_ENUMSTD ioctl in videodev.c V4L/DVB (4627): Vivi crashes with mplayer V4L/DVB (4626): On saa7111/7113, LUMA_CTRL need a different value V4L/DVB (4624): Tvaudio: Replaced kernel_thread() with kthread_run() V4L/DVB (4622): Copy-paste bug in videodev.c V4L/DVB (4620): Fix AGC configuration for MOD3000P-based boards V4L/DVB (4619): Fixes some I2C dependencies on V4L devices V4L/DVB (4617): Problem with dibusb-mb.c USB IDs V4L/DVB (4616): [PATCH] Nebula DigiTV USB RC support V4L/DVB (4614): Export symbol saa7134_tvaudio_setmute from saa7134 for saa7134-alsa ...
2006-09-27USB: Dealias -110 code (more complete)Pete Zaitcev
The purpose of this patch is to split off the case when a device does not reply on the lower level (which is reported by HC hardware), and a case when the device accepted the request, but does not reply at upper level. This redefinition allows to diagnose issues easier, without asking the user if the -110 happened "immediately". The usbmon splits such cases already thanks to its timestamp, but it's not always available. I adjusted all drivers which I found affected (by searching for "urb"). Out of tree drivers may suffer a little bit, but I do not expect much breakage. At worst they may print a few messages. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-26V4L/DVB (4386): Convert DVB devices to use dvb_attach()Andrew de Quincey
Only devices using > 1 frontend were ported; ones which did not are left using static binding. Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Acked-by: Michael Krufky <mkrufky@linuxtv.org> Acked-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4028): Change dvb_frontend_ops to be a real field instead of a ↵Patrick Boettcher
pointer field inside dvb_frontend The dvb_frontend_ops is a pointer inside dvb_frontend. That's why every demod-driver is having a field of dvb_frontend_ops in its private-state-struct and using the reference for filling the pointer-field in dvb_frontend. - It saves at least two lines of code per demod-driver, - reduces object size (one less dereference per frontend_ops-access), - be coherent with dvb_tuner_ops, - makes it a little bit easier for newbies to understand how it works and - avoids stupid mistakes because you would have to copy the dvb_frontend_ops always, before you could assign the static pointer directly, which was dangerous. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (3762): Add sysfs device links to dvb devicesAndrew de Quincey
Currently in /sys/class/dvb/dvbX.demuxY/ we have: dev uevent With the patch, we have (for a PCI DVB device): dev device -> ../../../devices/pci0000:00/0000:00:1e.0/0000:03:0d.0 uevent So userspace tools can (finally) work out which physical device a DVB adapter refers to. Previously you had to kinda look through dmesg and hope that it hadn't been dumped out of the buffer. This makes debugging a lot easier if the system has been up for a long time! This is done by adding an extra 'struct device *' parameter to dvb_register_adapter(). It will work with any kind of standard linux 'device'. Additionally, if someone has an embedded system which does things differently, they can simply supply 'NULL' and the behaviour will be as before - the link will simply not appear. Ack'd-by: Manu Abraham <manu@linuxtv.org> Acked-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-02-07V4L/DVB (3318b): sem2mutex: drivers/media/, #2Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-11V4L/DVB (3344a): Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
Conversions from kmalloc+memset to k(z|c)alloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-09V4L/DVB (3218): Whitespace cleanupsMichael Krufky
- minor whitespace cleanups Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3154): TTUSB DEC driver patch roundupAlex Woods
- Collection of patches from Peter Beutner addressing: - add symbolrates to the DVB-S frontend description - fix capability flags in DVB-S frontend describtion - remove some void casts - disable zig-zag scanning as it makes no sense for DVB-T - set sensible min_delay value - return an error for requested filter types the driver can't handle Signed-off-by: Peter Beutner <p.beutner@gmx.net> Signed-off-by: Alex Woods <linux-dvb@giblets.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2005-12-12[PATCH] V4L/DVB: (3086a) Whitespaces cleanups part 1Mauro Carvalho Chehab
Clean up whitespaces at v4l/dvb files Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] drivers/media: convert to dynamic input_dev allocationDmitry Torokhov
Input: convert drivers/media to dynamic input_dev allocation This is required for input_dev sysfs integration Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-09[PATCH] dvb: remove version.h dependenciesOlaf Hering
Remove all #include <linux/version.h> and all references to LINUX_VERSION_CODE and KERNEL_VERSION. Based on patch by Olaf Hering. Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] dvb: add missing release_firmware() callsAnssi Hannula
Add missing release_firmware() calls to fix memory leaks. Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] dvb: modified dvb_register_adapter() to avoid kmalloc/kfreeJohannes Stezenbach
Modified dvb_register_adapter() to avoid kmalloc/kfree. Drivers have to embed struct dvb_adapter into their private data struct from now on. (Andreas Oberritter) Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] dvb: make needlessly global code static or drop itJohannes Stezenbach
- make needlessly global code static - #if 0 the following unused global functions: - ttpci/av7110_hw.c: av7110_reset_arm - ttpci/av7110_hw.c: av7110_send_ci_cmd - frontends/mt352.[ch]: drop mt352_read Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
