Conversions from kmalloc+memset to k(z|c)alloc.
Signed-off-by: Panagiotis Issaris <takis@issaris.org>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
- minor whitespace cleanups
Signed-off-by: Michael Krufky <mkrufky@m1k.net>
Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
- Collection of patches from Peter Beutner addressing:
- add symbolrates to the DVB-S frontend description
- fix capability flags in DVB-S frontend describtion
- remove some void casts
- disable zig-zag scanning as it makes no sense for DVB-T
- set sensible min_delay value
- return an error for requested filter types the driver can't handle
Signed-off-by: Peter Beutner <p.beutner@gmx.net>
Signed-off-by: Alex Woods <linux-dvb@giblets.org>
Clean up whitespaces at v4l/dvb files
Input: convert drivers/media to dynamic input_dev allocation
This is required for input_dev sysfs integration
Remove all #include <linux/version.h> and all references to LINUX_VERSION_CODE
and KERNEL_VERSION. Based on patch by Olaf Hering.
Signed-off-by: Olaf Hering <olh@suse.de>
Signed-off-by: Johannes Stezenbach <js@linuxtv.org>
Add missing release_firmware() calls to fix memory leaks.
Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com>
Modified dvb_register_adapter() to avoid kmalloc/kfree. Drivers have to embed
struct dvb_adapter into their private data struct from now on. (Andreas
Oberritter)
- make needlessly global code static
- #if 0 the following unused global functions:
- ttpci/av7110_hw.c: av7110_reset_arm
- ttpci/av7110_hw.c: av7110_send_ci_cmd
- frontends/mt352.[ch]: drop mt352_read
infrastructure for it.
Let it rip!
