commit bff469f4167fdabfe15294f375577d7eadbaa1bb upstream.
This patch protects the common buffer access inside the dib0700 in order
to manage concurrent access. This protection is done using mutex.
Cc: Mauro Carvalho Chehab <mchehab@redhat.com>
Cc: Florian Mickler <florian@mickler.org>
Signed-off-by: Javier Marcet <javier@marcet.info>
Signed-off-by: Olivier Grenie <olivier.grenie@dibcom.fr>
Signed-off-by: Patrick Boettcher <patrick.boettcher@dibcom.fr>
[mchehab@redhat.com: dprint requires 3 arguments. Replaced by dib_info]
commit 79fcce3230b140f7675f8529ee53fe2f9644f902 upstream.
This patch protects the I2C buffer access in order to manage concurrent
Furthermore, for the dib9000, if a pid filtering command is
received during the tuning, this pid filtering command is delayed to
avoid any concurrent access issue.
Signed-off-by: Patrick Boettcher <Patrick.Boettcher@dibcom.fr>
dvb_usb_device_init calls the frontend_attach method of this driver which
uses vp7045_usb_ob. In order to have a buffer ready in vp7045_usb_op, it has to
be allocated before that happens.
Luckily we can use the whole private data as the buffer as it gets separately
allocated on the heap via kzalloc in dvb_usb_device_init and is thus apt for
use via usb_control_msg.
This fixes a
BUG: unable to handle kernel paging request at 0000000000001e78
reported by Tino Keitel and diagnosed by Dan Carpenter.
Cc: stable@kernel.org # For v3.0 and upper
Tested-by: Tino Keitel <tino.keitel@tikei.de>
Signed-off-by: Florian Mickler <florian@mickler.org>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (430 commits)
[media] ir-mce_kbd-decoder: include module.h for its facilities
[media] ov5642: include module.h for its facilities
[media] em28xx: Fix DVB-C maxsize for em2884
[media] tda18271c2dd: Fix saw filter configuration for DVB-C @6MHz
[media] v4l: mt9v032: Fix Bayer pattern
[media] V4L: mt9m111: rewrite set_pixfmt
[media] V4L: mt9m111: fix missing return value check mt9m111_reg_clear
[media] V4L: initial driver for ov5642 CMOS sensor
[media] V4L: sh_mobile_ceu_camera: fix Oops when USERPTR mapping fails
[media] V4L: soc-camera: remove soc-camera bus and devices on it
[media] V4L: soc-camera: un-export the soc-camera bus
[media] V4L: sh_mobile_csi2: switch away from using the soc-camera bus notifier
[media] V4L: add media bus configuration subdev operations
[media] V4L: soc-camera: group struct field initialisations together
[media] V4L: soc-camera: remove now unused soc-camera specific PM hooks
[media] V4L: pxa-camera: switch to using standard PM hooks
[media] NetUP Dual DVB-T/C CI RF: force card hardware revision by module param
[media] Don't OOPS if videobuf_dvb_get_frontend return NULL
[media] NetUP Dual DVB-T/C CI RF: load firmware according card revision
[media] omap3isp: Support configurable HS/VS polarities
Fix up conflicts:
- arch/arm/mach-omap2/board-rx51-peripherals.c:
cleanup regulator supply definitions in mach-omap2
vs
OMAP3: RX-51: define vdds_csib regulator supply
- drivers/staging/tm6000/tm6000-alsa.c (trivial)
Currently, the driver assumes that all QAM carriers are spaced with
8MHz. This is wrong, and may decrease QoS on Countries like Brazil,
that have DVB-C carriers with 6MHz-spaced.
Fortunately, both ITU-T J-83 and EN 300 429 specifies a way to
associate the symbol rate with the bandwidth needed for it.
For ITU-T J-83 2007 annex A, the maximum symbol rate for 6 MHz is:
6 MHz / 1.15 = 5217391 Bauds
For ITU-T J-83 2007 annex C, the maximum symbol rate for 6 MHz is:
6 MHz / 1.13 = 5309735 Bauds.
As this tuner is currently used only for DRX-K, and it is currently
hard-coded to annex A, I've opted to use the roll-off factor of 0.15,
instead of 0.13.
If we ever support annex C, the better would be to add a DVB S2API
call to allow changing between Annex A and C, and add the 0.13 roll-off
factor to it.
This code is currently being used on other frontends, so I think we
should later add a core function with this code, to warrant that
it will be properly implemented everywhere.
The signal state field in G_TUNER is typically scaled from 0-100%. Since we
don't know the signal level, we really would prefer the field to contain 100%
than 1/256, which in many utilities (such as v4l2-ctl) rounds to 0% even when
a signal is actually present.
This patch makes the behavior consistent with other drivers.
Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com>
Fix the DRX-K logic that selects between DVB-C annex A and C
Fix a typo where DVB-C annex type is set via setEnvParameters, but
the driver, uses, instead, setParamParameters[2].
While here, cleans up the code, fixing a bad identation at the fallback
code for other types of firmware, and put the multiple-line comments
into the Linux CodingStyle.
Acked-by: Oliver Endriss <o.endriss@gmx.de>
After return, we don't need any other statement to change the
function flux ;)
Reported-by: Oliver Endriss <o.endriss@gmx.de>
The error propagation changeset c23bf4402 broke the DVB-T
code.
The legacy way for propagate errors was:
do {
status = foo_func()
if (status < 0)
break;
} while (0);
return status;
However, on a few places, it was doing:
do {
switch(foo) {
case bar:
status = foo_func()
if (status < 0)
break;
break;
switch(foo2) {
case bar:
status = foo_func()
if (status < 0)
break;
break;
} while (0);
return (status)
The inner error break were not working, as it were breaking only
the switch, instead of the do. The solution used were to do a
s/break/goto error/ at the inner breaks, but preserving the last
break. Onfortunately, on a few switches, the replacement were
applied also to the final break for the case statements.
Fix the broken logic, by reverting them to break, where pertinent,
in order to fix DVB-T support.
Both ngene and ddbrige calls dvb_attach once for drxk_attach.
The logic used there, and by tda18271c2dd driver is different
from similar logic on other frontends.
The right fix is to change them to use the same logic, but,
while we don't do that, we need to patch em28xx-dvb in order
to do cope with ngene/ddbridge magic.
While here, document why drxk_t_release should do nothing.
This reverts commit a3e4adf274f86b2363fedaa964297cb38526cef0.
As pointed by Andread Oberritter <obi@linuxtv.org>:
That's wrong, because the array size is DTV_MAX_COMMAND + 1.
Using the ARRAY_SIZE macro instead might reduce the confusion.
Also, changeset 3995223038 already fixed this issue.
Reported-by: Andread Oberritter <obi@linuxtv.org>
Signed-off-by: Emilio David Diaus Lopez <reality_es@yahoo.es>
Signed-off-by: Antti Palosaari <crope@iki.fi>
It is useless. There is only one physical I2C-adapter.
2nd adapter was added originally due to some plans for allowing only one
demod to access bus at time. But I never implemented proper locking...
Remove old code which is not used anymore since IR code is read
directly from memory nowadays.
Return EOPNOTSUPP for too long messages.
Reported-by: Jacek M. Holeczek <jacek.m.holeczek@gmail.com>
That's this tuner:
The credit card sized remote more or less works if I set remote=4,
so I added the hash to get it autodetected. (`more or less' there
meaning sometimes buttons are `stuck on repeat', i.e. ir-keytable -t
keeps repeating the same scancode until i press another button.)
Signed-off-by: Juergen Lock <nox@jelal.kn-bremen.de>
spelling
In drivers/media/dvb/frontends/drxd_hard.c::load_firmware() I see 3
small issues:
1) When the 'fw' variable goes out of scope we'll leak the memory
allocated to it by request_firmware() by neglecting to call
release_firmware().
2) After a successful request_firmware() we allocate fw->size bytes
of memory using kzalloc() only to immediately overwrite all that
memory with memcpy(), so asking for zeroed memory seems like wasted
effort - just use kmalloc().
3) In one of the error messages "no memory" lacks a space and is
written as "nomemory".
This patch fixes all 3 issues.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
If the tvp->cmd == DTV_MAX_COMMAND then we read past the end of the
array.
Should be folded with the next patch when sending upstream
If those demods are unselected, but a bridge driver requires them,
produce a runtime message, instead of missing symbols.
The QAM standard is set using this scu_command:
SCU_RAM_COMMAND_STANDARD_QAM |
SCU_RAM_COMMAND_CMD_DEMOD_SET_PARAM
The driver implements a version that has 4 parameters, however,
Terratec H5 needs to break this into two separate commands, otherwise,
DVB-C doesn't work.
With this fix, scan is now properly working and getting the
channel list:
>>> tune to: 609000000:INVERSION_AUTO:5217000:FEC_3_4:QAM_256
>>> tuning status == 0x00
>>> tuning status == 0x07
>>> tuning status == 0x1f
0x0093 0x0026: pmt_pid 0x0758 (null) -- SporTV2 (running, scrambled)
0x0093 0x0027: pmt_pid 0x0748 (null) -- SporTV (running, scrambled)
0x0093 0x0036: pmt_pid 0x0768 (null) -- FX (running, scrambled)
0x0093 0x0052: pmt_pid 0x0788 (null) -- The History Channel (running, scrambled)
Now, it outputs:
[10927.639641] drxk: SCU_RESULT_INVPAR while sending cmd 0x0203 with params:
[10927.646283] drxk: 02 00 00 00 10 00 07 00 03 02 ..........
Better than ERROR -3. This happens with Terratec H5 firmware.
It adds 2 new error conditions, and something useful to track
what the heck is that.
I suspect that the scu_command is dependent on the firmware
revision.
The driver is too limited: it assumes that UIO is used only for
controlling the antenna, and that only UIO-1 is in usage. However,
from Terratec H7 driver [1], 3 UIO's can be used. In fact, it seems
that H7 needs to use all 3. So, make the code generic enough to handle
the most complex scenario. For now, only antena GPIO can be specified,
but is is easier now to add the other GPIO/UIO needs.
DRX-K configuration is interesting when writing/testing
new devices. Add an info line showing the discovered info.
Terratec H5 doesn't require to switch mode, but generates
an error due to this logic. Also, GPIO's are board-dependent.
So, add it at the board config struct.
The set mode routines assume that state were changed to the
new mode, otherwise, they'll fail.
This driver is very big and complex. An error happening in the middle
of any initialization may cause the frontend to not work. So, it
needs to properly propagate error codes internally and to userspace.
Also, printing the error codes at the places it happened helps to
discover were's a bug at the code.
Before this change, a do { } while (0) loop and lots of breaks inside
were used to propagate errors. While this works, if there are
loops inside other loops, it could be easy to forget to add another
break, causing the error to not abort the function.
Also, as not all functions were reporting errors, it is hard to
discover why something failed.
On em28xx, tda18271C2 is accessible when the i2c port
is not touched. Touching on it breaks the driver.
The microcode firmware provided on Terratec H5 seems to be
different. Add a parameter to allow specifying a different
firmware per-device.
If something bad happens during firmware load, an error
should be printed at dmesg.
Don't read paste the buffer, if the firmware is corrupted.
Instead, print an error message.
Instead of using #ifdef I2C_LONG_ADR for some devices, convert
it into a parameter. Terratec H5 logs from the original driver
seems to need this mode.
Currently, the only parameter to be configured is the I2C
address. However, Terratec H5 logs shows that it needs a different
setting for some things, and it has its own firmware.
So, move the addr into a config structure, in order to allow adding
the required configuration bits.
The normal 16-bits read routine is called as "Read16_0". This is
due to a flags that could optionally be passed. Yet, on no places
at the code, a flag is passed there.
The same happens with 16-bits write and 32-read/write routines,
and with WriteBlock.
Also, using flags, is an exception: there's no place currently using
flags, except for an #ifdef at WriteBlock.
Rename the function as just "read16", and the one that requires flags,
as "read16_flags".
This helps to see where the flags are used, and also avoid using
CamelCase on Kernel.
This is a complex driver. Adding support for other devices with drxk
requires to be able to debug it and see where it is failing. So, add
optional printk messages to allow debugging it.
It is hard to identify the origin for those errors without a
prefix to indicate which driver produced them:
[ 1390.220984] i2c_write error
[ 1390.224133] I2C Write error
[ 1391.284202] i2c_read error
[ 1392.288685] i2c_read error
WARNING: Use #include <linux/io.h> instead of <asm/io.h>
+#include <asm/io.h>
drivers/media/dvb/ddbridge/built-in.o: In function `my_dvb_dmx_ts_card_init':
/home/v4l/v4l/patchwork/drivers/media/dvb/ddbridge/ddbridge-core.c:718: multiple definition of `my_dvb_dmx_ts_card_init'
drivers/media/dvb/ngene/built-in.o:/home/v4l/v4l/patchwork/drivers/media/dvb/ngene/ngene-dvb.c:227: first defined here
drivers/media/dvb/ddbridge/built-in.o: In function `my_dvb_dmxdev_ts_card_init':
/home/v4l/v4l/patchwork/drivers/media/dvb/ddbridge/ddbridge-core.c:737: multiple definition of `my_dvb_dmxdev_ts_card_init'
drivers/media/dvb/ngene/built-in.o:/home/v4l/v4l/patchwork/drivers/media/dvb/ngene/ngene-dvb.c:246: first defined here
Driver added to Makefile and Kconfig.
Signed-off-by: Oliver Endriss <o.endriss@gmx.de>
Codingstyle fixes
Driver support for Digital Devices ddbridge-based cards:
Octopus, Octopus mini, Octopus LE, cineS2(v6)
with DuoFlex S2 and/or DuoFlex CT tuners.
Driver was taken from ddbridge-0.6.1.tar.bz2.
Signed-off-by: Ralph Metzler <rmetzler@digitaldevices.de>
