[ Upstream commit 8d11eb847de7d89c2754988c944d51a4f63e219b ]
The driver may sleep in a interrupt handler.
The function call paths (from bottom to top) in Linux-4.16 are:
[FUNC] kzalloc(GFP_KERNEL)
drivers/media/pci/ivtv/ivtv-yuv.c, 938:
kzalloc in ivtv_yuv_init
drivers/media/pci/ivtv/ivtv-yuv.c, 960:
ivtv_yuv_init in ivtv_yuv_next_free
drivers/media/pci/ivtv/ivtv-yuv.c, 1126:
ivtv_yuv_next_free in ivtv_yuv_setup_stream_frame
drivers/media/pci/ivtv/ivtv-irq.c, 827:
ivtv_yuv_setup_stream_frame in ivtv_irq_dec_data_req
drivers/media/pci/ivtv/ivtv-irq.c, 1013:
ivtv_irq_dec_data_req in ivtv_irq_handler
To fix this bug, GFP_KERNEL is replaced with GFP_ATOMIC.
This bug is found by my static analysis tool DSAC.
Signed-off-by: Jia-Ju Bai <baijiaju1990@gmail.com>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
This removes the 'write' and 'force' use from get_user_pages_unlocked()
and replaces them with 'gup_flags' to make the use of FOLL_FORCE
explicit in callers as use of this flag can result in surprising
behaviour (and hence bugs) within the mm subsystem.
Signed-off-by: Lorenzo Stoakes <lstoakes@gmail.com>
We will soon modify the vanilla get_user_pages() so it can no
longer be used on mm/tasks other than 'current/current->mm',
which is by far the most common way it is called. For now,
we allow the old-style calls, but warn when they are used.
(implemented in previous patch)
This patch switches all callers of:
get_user_pages()
get_user_pages_locked()
to stop passing tsk/mm so they will no longer see the warnings.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Dave Hansen <dave@sr71.net>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: jack@suse.cz
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/20160212210156.113E9407@viggo.jf.intel.com
Convert ivtv_yuv_prep_user_dma() to use get_user_pages_unlocked() so
that we don't unnecessarily leak knowledge about mm locking into drivers
code.
CC: Andy Walls <awalls@md.metrocast.net>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Rename all PCI drivers with their own directory under
drivers/media/video into drivers/media/pci and update the
building system.
