Double mutexlock found by the Linux Driver Verification project and
reported by Alexander Strakh.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
CC: stable@kernel.org
Patch removes empty open and release functions in pci and isa radio
drivers, setting them to NULL. V4L module doesn't call for them due to
previous patch.
Signed-off-by: Alexey Klimov <klimov.linux@gmail.com>
This include isn't needed and so can be removed.
Introduce a struct v4l2_file_operations for v4l2 drivers.
Remove the unnecessary inode argument.
Move compat32 handling (and llseek) into the v4l2-dev core: this is now
handled in the v4l2 core and no longer in the drivers themselves.
Note that this changeset reverts an earlier patch that changed the return
type of__video_ioctl2 from int to long. This change will be reinstated
later in a much improved version.
video_drvdata(filp)
Use the new video_drvdata(filp) function where it is safe to do so.
Remove the priv field and let video_get/set_drvdata use dev_get_drvdata
and dev_set_drvdata instead.
Convert all drivers that still used priv directly.
All drivers that call video_device_register where checked to see if they
set the release callback of struct video_device. Where that callback was
missing it was added.
Move the video_exclusive_open/release functionality into the driver itself.
The type and type2 fields were unused and so could be removed.
Instead add a vfl_type field that contains the type of the video
device.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
According to an old comment this should have been removed in 2.6.15.
Better late than never...
struct
All ioctl callbacks are now stored in a new v4l2_ioctl_ops struct. Drivers fill in
a const struct v4l2_ioctl_ops and video_device just contains a const pointer to it.
This ensures a clean separation between the const ops struct and the non-const
video_device struct.
v4l2-common.h or v4l2-ioctl.h
The functions in a header should not belong to another module. The prio functions
belong to v4l2-common.c, so move them to v4l2-common.h.
The ioctl functions belong to v4l2-ioctl.c, so create a new v4l2-ioctl.h header
and move those functions to it.
Added macro CONFIG_COMPAT for v4l_compat_ioctl32.
Signed-off-by: Douglas Schilling Landgraf <dougsland@gmail.com>
The drivers reads the PCI subsystem ID into its state structure, but it's
never used anywhere.
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
From: Douglas Schilling Landgraf <dougsland@gmail.com>
Instead of all drivers reading pci config space to get the revision
ID, they can now use the pci_device->revision member.
This exposes some issues where drivers where reading a word or a dword
for the revision number, and adding useless error-handling around the
read. Some drivers even just read it for no purpose of all.
In devices where the revision ID is being copied over and used in what
appears to be the equivalent of hotpath, I have left the copy code
and the cached copy as not to influence the driver's performance.
Compile tested with make all{yes,mod}config on x86_64 and i386.
Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
Acked-by: Dave Jones <davej@redhat.com>
Convert radio-gemtek-pci to use video_ioctl2
Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se>
Many struct file_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
[akpm@sdl.org: dvb fix]
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
The module_exit function has return-type void and
pci_unregister_driver() returns void anyway.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
Driver conversion to V4L2 API.
Require some testing, since this obsolete hardware is not
common those days.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
videodev2.h
The videodev.h and videodev2.h describe the public API for V4L and V4L2.
It shouldn't have there any kernel-specific stuff. Those were moved to
v4l2-dev.h.
This patch removes some uneeded headers and include v4l2-common.h on all
V4L driver. This header includes device implementation of V4L2 API provided
on v4l2-dev.h as well as V4L2 internal ioctls that provides connections
between master driver and its i2c devices.
Conversions from kmalloc+memset to k(z|c)alloc.
Signed-off-by: Panagiotis Issaris <takis@issaris.org>
Replace obsolete pci_module_init() with pci_register_driver().
This moves the 32 bit ioctl compatibility handlers for
Video4Linux into a new file and adds explicit calls to them
to each v4l device driver.
Unfortunately, there does not seem to be any code handling
the v4l2 ioctls, so quite often the code goes through two
separate conversions, first from 32 bit v4l to 64 bit v4l,
and from there to 64 bit v4l2. My patch does not change
that, so there is still much room for improvement.
Also, some drivers have additional ioctl numbers, for
which the conversion should be handled internally to
that driver.
Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
infrastructure for it.
Let it rip!
