Just a few fixes for problems found after updating v4l2-compliance to check
the frequency band enumeration.
Note that the i2c driver doesn't fill in bus_info, but since I can't test that
driver I've decided not to fix that.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
The previous value made hardware freq seek not work for me, despite having
good reception of almost all Dutch radio stations.
Since USB receives STATUS_RSSI updates through the interrupt endpoint,
there is no need to poll with USB, so get rid of the polling.
Note this also changes the order in which the probing of USB devices is done,
to avoid si470x_set_chan getting called before the interrupt endpoint is being
monitored.
Reading registers from the pcear USB dongles with the si470x causes a
loud pop (and an alsa buffer overrun). Since most radio apps periodically
call G_TUNER to update mono/stereo, signal and afc status this leads
to the music . pop . music . pop . music -> not good.
On the internet there is an howto for flashing the pcear with a newer
firmware from the silabs reference boardto fix this, but:
1) This howto relies on a special version of the driver which allows
firmware flashing
2) We should try to avoid the answer to a bug report being upgrade your
firmware, if at all possible
3) Windows does not suffer from the pop sounds
After a quick look at the driver I found at that the register reads are
not necessary at all, as the device gives us the necessary status through
usb interrupt packets, and the driver already uses these!
EAGAIN
Set the new capability flags in G_TUNER and return ENODATA if no channels
were found.
Acked-by: Hans de Goede <hdegoede@redhat.com>
The radio-si470x-usb driver supported both autosuspend and it stopped the
radio the moment the last user of the radio device closed it. However, that
was very confusing since if you play the audio from the device (e.g. through
arecord -D ... | aplay) then no sound would play unless you had the radio
device open at the same time, even though there is no need to do anything
with that node.
On the other hand, the actual suspend/resume functions didn't do anything,
which would fail if you *did* have the radio node open at that time.
So:
- remove autosuspend (bad idea in general for USB radio devices)
- move the start/stop out of the open/release functions into the resume/suspend
functions.
Acked-by: Tobias Lorenz <tobias.lorenz@gmx.net>
There is no need to report an error in the log, you are already returning
that error to userspace after all.
This cleans up the code and si470x now uses the proper v4l2 frameworks
and passes most of the v4l2-compliance tests.
Currently we use busy waiting to seek and tune, it can replace to
interrupt way. SI470X I2C driver supports interrupt way to week and tune
via this patch.
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
KERNEL_VERSION: 2.6.37
common.c in function ssize_t si470x_fops_read.
1. First mutex_lock on &radio->lock in line 441
2. Second in line 462
I think that mutex in line 462 is not needed.
433static ssize_t si470x_fops_read(struct file *file, char __user *buf,
434 size_t count, loff_t *ppos)
435{
441 mutex_lock(&radio->lock);
442 if ((radio->registers[SYSCONFIG1] & SYSCONFIG1_RDS) == 0)
443 si470x_rds_on(radio);
444
445 /* block if no new data available */
446 while (radio->wr_index == radio->rd_index) {
447 if (file->f_flags & O_NONBLOCK) {
448 retval = -EWOULDBLOCK;
449 goto done;
450 }
451 if (wait_event_interruptible(radio->read_queue,
452 radio->wr_index != radio->rd_index) < 0) {
453 retval = -EINTR;
454 goto done;
455 }
456 }
457
458 /* calculate block count from byte count */
459 count /= 3;
460
461 /* copy RDS block out of internal buffer and to user buffer */
462 mutex_lock(&radio->lock);
Found by Linux Device Drivers Verification Project
Remove second mutex.
Signed-off-by: Alexander Strakh <strakh@ispras.ru>
The si470x i2c and usb driver support the RDS, so this ifdef statement
doesn't need more.
[mchehab@redhat.com: Fix a conflict on it]
instead of always setting de-emphasis.
Reported-by: Tobias Lorenz <tobias.lorenz@gmx.net>
This patch to the si470x_vidioc_s_tuner function was developed in
cooperation with Roel Kluin <roel.kluin@gmail.com>. It sets the default
retval to 0 instead of -EINVAL, identical to what is done in all other
set/get functions of v4l2_ioctl_ops. This is just as cosmetic change, as
retval is directly overwritten by the si470x_disconnect_check() anyway.
Signed-off-by: Tobias Lorenz <tobias.lorenz@gmx.net>
This cosmetic patch corrects a wrong unicode "micro" character in a comment.
The read and poll file operations of the si470x usb driver can be used
also equally on the si470x i2c driver, so they go to the common file.
Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com>
This patch supports i2c interface of si470x. The i2c specific part
exists in radio-si470x-i2c.c file and the common part uses
radio-si470x-common.c file. The '#if defined' is inserted inevitably
because of parts used only si470x usb in the common file.
The current driver version doesn't support the RDS.
The si470x_disconnect_check is function to check disconnect state of
radio in common file. The function is implemented in each interface
file.
This patch is for using dev_* macro instead of printk.
This patch is a preceding work to add the i2c interface of si470x.
The si470x directory includes a common file and usb specific file and
header file.
The part unrelated with usb interface and i2c interface exists in
radio-si470x-common.c file, and The usb specific part exists in
radio-si470x-usb.c file.
[tobias.lorenz@gmx.net: Small changes, due to new include "linux/smp_lock.h"]
