[ Upstream commit ef4bb63dc1f7213c08e13f6943c69cd27f69e4a3 ]
We forgot to set "ret" on this error path.
Fixes: e8454ff7b9a4 ("[media] drivers:media:radio: wl128x: FM Driver Common sources")
Signed-off-by: Hans Verkuil <hverkuil-cisco@xs4all.nl>
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
[ Upstream commit 9c2ccc324b3a6cbc865ab8b3e1a09e93d3c8ade9 ]
Smatch marks skb->data as untrusted so it warns that "evt_hdr->dlen"
can copy up to 255 bytes and we only have room for two bytes. Even
if this comes from the firmware and we trust it, the new policy
generally is just to fix it as kernel hardenning.
I can't test this code so I tried to be very conservative. I considered
not allowing "evt_hdr->dlen == 1" because it doesn't initialize the
whole variable but in the end I decided to allow it and manually
initialized "asic_id" and "asic_ver" to zero.
On mips and parisc:
drivers/bluetooth/btwilink.c: In function 'ti_st_open':
drivers/bluetooth/btwilink.c:174:21: warning: overflow in implicit constant conversion [-Woverflow]
hst->reg_status = -EINPROGRESS;
drivers/nfc/nfcwilink.c: In function 'nfcwilink_open':
drivers/nfc/nfcwilink.c:396:31: warning: overflow in implicit constant conversion [-Woverflow]
drv->st_register_cb_status = -EINPROGRESS;
There are actually two issues:
1. Whether "char" is signed or unsigned depends on the architecture.
As the completion callback data is used to pass a (negative) error
code, it should always be signed.
2. EINPROGRESS is 150 on mips, 245 on parisc.
Hence -EINPROGRESS doesn't fit in a signed 8-bit number.
Change the callback status from "char" to "int" to fix these.
Acked-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
Acked-by: Samuel Ortiz <sameo@linux.intel.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
The module_param() is "default_rds_buf" and the MODULE_PARM_DESC()
should match.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Use kernel.h macro definition.
Thanks to Julia Lawall for Coccinelle scripting support.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
fmdrv_common.c: In function 'fm_download_firmware':
fmdrv_common.c:1259:2: warning: format '%d' expects argument of type 'int', but argument 3 has type 'size_t' [-Wformat=]
fmdbg("Firmware(%s) length : %d bytes\n", fw_name, fw_entry->size);
drivers/media/radio/wl128x/fmdrv_common.c:598:32: warning: cast to restricted __be16
drivers/media/radio/wl128x/fmdrv_common.c:767:38: warning: cast to restricted __be16
drivers/media/radio/wl128x/fmdrv_common.c:992:21: warning: cast to restricted __be16
drivers/media/radio/wl128x/fmdrv_common.c:443:41: warning: incorrect type in assignment (different base types)
drivers/media/radio/wl128x/fmdrv_common.c:1359:17: warning: cast to restricted __be16
drivers/media/radio/wl128x/fmdrv_common.c:1359:39: warning: cast to restricted __be16
drivers/media/radio/wl128x/fmdrv_common.c:1368:25: warning: cast to restricted __be16
drivers/media/radio/wl128x/fmdrv_common.c:1368:47: warning: cast to restricted __be16
drivers/media/radio/wl128x/fmdrv_rx.c:119:20: warning: cast to restricted __be16
drivers/media/radio/wl128x/fmdrv_rx.c:192:20: warning: cast to restricted __be16
drivers/media/radio/wl128x/fmdrv_rx.c:288:28: warning: cast to restricted __be16
drivers/media/radio/wl128x/fmdrv_rx.c:534:20: warning: cast to restricted __be16
drivers/media/radio/wl128x/fmdrv_rx.c:625:17: warning: cast to restricted __be16
drivers/media/radio/wl128x/fmdrv_tx.c:377:20: warning: cast to restricted __be16
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
drivers/media/radio/wl128x/fmdrv_common.c:178:6: warning: symbol 'g_st_write' was not declared. Should it be static?
copy_to_user() must not be called with spinlocks held, but it is in
fmc_transfer_rds_from_internal_buff().
The patch copies data to tmpbuf, releases spinlock and then passes it to userspace.
By the way there is a small unification: replace a couple of hardcoded constants by a macro.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
This kind of memcpy() is error-prone. Its replacement with a struct
assignment is prefered because it's type-safe and much easier to read.
Found by coccinelle. Hand patched and reviewed.
Tested by compilation only.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
identifier struct_name;
struct struct_name to;
struct struct_name from;
expression E;
-memcpy(&(to), &(from), E);
+to = from;
// </smpl>
Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com>
Signed-off-by: Ezequiel Garcia <elezegarcia@gmail.com>
drivers/media/radio/wl128x/fmdrv_common.c:745:3: warning: comparison is always false due to limited range of data type [-Wtype-limits]
drivers/media/radio/wl128x/fmdrv_rx.c:308:2: warning: comparison is always false due to limited range of data type [-Wtype-limits]
Message-Id: <1322820073-19347-2-git-send-email-xi.wang@gmail.com>
The error handling with (ret < 0) didn't work where ret is a u32.
Use int instead. To be consistent we also change the functions to
return an int.
Signed-off-by: Xi Wang <xi.wang@gmail.com>
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6:
Fix common misspellings
As underlying ST driver registration API's have changed with
latest 2.6.38-rc8 kernel this patch will update the FM driver
accordingly.
Signed-off-by: Manjunatha Halli <manjunatha_halli@ti.com>
drivers/media/radio/wl128x/fmdrv_common.c: In function 'recv_tasklet':
drivers/media/radio/wl128x/fmdrv_common.c:274:4: warning: format '%d' expects type 'int', but argument 4 has type 'long unsigned int'
The result of sizeof() should be printed with %zu.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
These are the sources for the common interfaces required by the
FM V4L2 driver for TI WL127x and WL128x chips.
These implement the FM channel-8 protocol communication with the
chip. This makes use of the Shared Transport as its transport.
Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl>
