[ Upstream commit 505bfc2a142f12ce7bc7a878b44abc3496f2e747 ]
clang static analysis reports this problem
tuner-simple.c:714:13: warning: Assigned value is
garbage or undefined
buffer[1] = buffer[3];
In simple_set_radio_freq buffer[3] used to be done
in-function with a switch of tuner type, now done
by a call to simple_radio_bandswitch which has this case
case TUNER_TENA_9533_DI:
case TUNER_YMEC_TVF_5533MF:
tuner_dbg("This tuner doesn't ...
return 0;
which does not set buffer[3]. In the old logic, this case
would have returned 0 from simple_set_radio_freq.
Recover this old behavior by returning an error for this
codition. Since the old simple_set_radio_freq behavior
returned a 0, do the same.
Fixes: c7a9f3aa1e1b ("V4L/DVB (7129): tuner-simple: move device-specific code into three separate functions")
Signed-off-by: Tom Rix <trix@redhat.com>
Signed-off-by: Hans Verkuil <hverkuil-cisco@xs4all.nl>
Signed-off-by: Mauro Carvalho Chehab <mchehab+huawei@kernel.org>
[ Upstream commit e955f959ac52e145f27ff2be9078b646d0352af0 ]
Getting the Xtal trim property to check if running is less error prone.
Reset if_frequency if state is unknown.
Replaces the previous "garbage check".
Signed-off-by: Brad Love <brad@nextdimension.cc>
Signed-off-by: Sean Young <sean@mess.org>
Some users have been having a hard time finding the hidden
menus. A typically case are camera sensor drivers
(e.g IMX219, OV5645, etc), which are common on embedded
platforms and not really "ancillary" devices.
The problem with MEDIA_SUBDRV_AUTOSELECT seems to be related
to the fact that it uses the "visible" syntax to hide
the menus.
This is not obvious and it normally takes some time to
figure out.
To fix the problem, add a comment on each of hidden menus,
which should clarify what option is causing menus to be hidden.
Signed-off-by: Ezequiel Garcia <ezequiel@collabora.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
kmemdup is introduced to duplicate a region of memory in a neat way.
Rather than kmalloc/kzalloc + memcpy, which the programmer needs to
write the size twice (sometimes lead to mistakes), kmemdup improves
readability, leads to smaller code and also reduce the chances of mistakes.
Suggestion to use kmemdup rather than using kmalloc/kzalloc + memcpy.
Signed-off-by: Fuqian Huang <huangfq.daxian@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
- new Atmel microship ISC driver
- coda has gained support for mpeg2 and mpeg4
- cxusb gained support for analog TV
- rockchip staging driver was split into two separate staging drivers
- added a new staging driver for Allegro DVT video IP core
- added a new staging driver for Amlogic Meson video decoder
- lots of improvements and cleanups
* tag 'media/v5.3-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (398 commits)
media: allegro: use new v4l2_m2m_ioctl_try_encoder_cmd funcs
media: doc-rst: Fix typos
media: radio-raremono: change devm_k*alloc to k*alloc
media: stv0297: fix frequency range limit
media: rc: Prefer KEY_NUMERIC_* for number buttons on remotes
media: dvb_frontend: split dvb_frontend_handle_ioctl function
media: mceusb: disable "nonsensical irdata" messages
media: rc: remove redundant dev_err message
media: cec-notifier: add new notifier functions
media: cec: add struct cec_connector_info support
media: cec-notifier: rename variables, check kstrdup and n->conn_name
media: MAINTAINERS: Add maintainers for Media Controller
media: staging: media: tegra-vde: Defer dmabuf's unmapping
media: staging: media: tegra-vde: Add IOMMU support
media: hdpvr: fix locking and a missing msleep
media: v4l2: Test type instead of cfg->type in v4l2_ctrl_new_custom()
media: atmel: atmel-isc: fix i386 build error
media: v4l2-ctrl: Move compound control initialization
media: hantro: Use vb2_get_buffer
media: pci: cx88: Change the type of 'missed' to u64
Based on 2 normalized pattern(s):
the original driver s license is gpl as declared with module_license
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license as published by
the free software foundation under version 2 of the license this
program is distributed in the hope that it will be useful but
without any warranty without even the implied warranty of
merchantability or fitness for a particular purpose see the gnu
general public license for more details
[copyright] [c] [2010] [2012] [mauro] [carvalho] [chehab] [driver]
[modified] [by] [in] [order] [to] [work] [with] [upstream] [drxk]
[driver] [and] [tons] [of] [bugs] [got] [fixed] [and] [converted]
[to] [use] [dvb] [usb] [v2] this program is free software you can
redistribute it and or modify it under the terms of the gnu general
public license as published by the free software foundation under
version 2 of the license this program is distributed in the hope
that it will be useful but without any warranty without even the
implied warranty of merchantability or fitness for a particular
purpose see the gnu general public license for more details
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 2 file(s).
Reviewed-by: Allison Randal <allison@lohutok.net>
Reviewed-by: Enrico Weigelt <info@metux.net>
Reviewed-by: Alexios Zavras <alexios.zavras@intel.com>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190602204654.186977917@linutronix.de
Works in ATSC and QAM as is, DVB is completely untested.
Firmware required.
Reviewed-by: Sean Young <sean@mess.org>
There are some conflicts due to SPDX changes. We also have more
patches being merged via media tree touching them.
So, let's merge back from upstream and address those.
Linux 5.2-rc4
* tag 'v5.2-rc4': (767 commits)
Linux 5.2-rc4
MAINTAINERS: Karthikeyan Ramasubramanian is MIA
i2c: xiic: Add max_read_len quirk
lockref: Limit number of cmpxchg loop retries
uaccess: add noop untagged_addr definition
x86/insn-eval: Fix use-after-free access to LDT entry
kbuild: use more portable 'command -v' for cc-cross-prefix
s390/unwind: correct stack switching during unwind
block, bfq: add weight symlink to the bfq.weight cgroup parameter
cgroup: let a symlink too be created with a cftype file
drm/nouveau/secboot/gp10[2467]: support newer FW to fix SEC2 failures on some boards
drm/nouveau/secboot: enable loading of versioned LS PMU/SEC2 ACR msgqueue FW
drm/nouveau/secboot: split out FW version-specific LS function pointers
drm/nouveau/secboot: pass max supported FW version to LS load funcs
drm/nouveau/core: support versioned firmware loading
drm/nouveau/core: pass subdev into nvkm_firmware_get, rather than device
block: free sched's request pool in blk_cleanup_queue
pktgen: do not sleep with the thread lock held.
net: mvpp2: Use strscpy to handle stat strings
net: rds: fix memory leak in rds_ib_flush_mr_pool
Based on 3 normalized pattern(s):
the free software foundation either version 2 of the license or at
your option any later version this program is distributed in the
hope that it will be useful but without any warranty without even
the implied warranty of merchantability or fitness for a particular
your option any later version [author] [kishon] [vijay] [abraham]
[i] [kishon]@[ti] [com] this program is distributed in the hope that
it will be useful but without any warranty without even the implied
warranty of merchantability or fitness for a particular purpose see
your option any later version [author] [graeme] [gregory]
[gg]@[slimlogic] [co] [uk] [author] [kishon] [vijay] [abraham] [i]
[kishon]@[ti] [com] [based] [on] [twl6030]_[usb] [c] [author] [hema]
[hk] [hemahk]@[ti] [com] this program is distributed in the hope
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 1105 file(s).
Reviewed-by: Richard Fontana <rfontana@redhat.com>
Link: https://lkml.kernel.org/r/20190527070033.202006027@linutronix.de
Merge back from upstream into media tree, as there are some
patches merged upstream that has pontential of causing
conflicts (one actually rised a conflict already).
Linux 5.2-rc2
* tag 'v5.2-rc2': (377 commits)
Linux 5.2-rc2
random: fix soft lockup when trying to read from an uninitialized blocking pool
tracing: Silence GCC 9 array bounds warning
ext4: fix dcache lookup of !casefolded directories
locking/lock_events: Use this_cpu_add() when necessary
KVM: x86: fix return value for reserved EFER
tools/kvm_stat: fix fields filter for child events
KVM: selftests: Wrap vcpu_nested_state_get/set functions with x86 guard
kvm: selftests: aarch64: compile with warnings on
kvm: selftests: aarch64: fix default vm mode
kvm: selftests: aarch64: dirty_log_test: fix unaligned memslot size
KVM: s390: fix memory slot handling for KVM_SET_USER_MEMORY_REGION
KVM: x86/pmu: do not mask the value that is written to fixed PMUs
KVM: x86/pmu: mask the result of rdpmc according to the width of the counters
x86/kvm/pmu: Set AMD's virt PMU version to 1
KVM: x86: do not spam dmesg with VMCS/VMCB dumps
kvm: Check irqchip mode before assign irqfd
kvm: svm/avic: fix off-by-one in checking host APIC ID
KVM: selftests: do not blindly clobber registers in guest asm
KVM: selftests: Remove duplicated TEST_ASSERT in hyperv_cpuid.c
Based on 1 normalized pattern(s):
purpose see the gnu general public license for more details you
should have received a copy of the gnu general public license along
with this program if not write to the free software foundation inc
675 mass ave cambridge ma 02139 usa
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 441 file(s).
Reviewed-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Link: https://lkml.kernel.org/r/20190520071858.739733335@linutronix.de
Embedded systems often connect to sensors or other multimedia
subdevices directly. Currently, to be able to select such a
subdevice (e.g. CONFIG_VIDEO_OV5640) disabling of the auto-
select config option is needed (CONFIG_MEDIA_SUBDRV_AUTOSELECT).
This is inconvenient as the ancillary drivers for a particular
device then need to be selected manually.
Allow to select drivers manually while keeping the auto-select
feature in case EXPERT (selected by EMBEDDED) is enabled.
Signed-off-by: Stefan Agner <stefan@agner.ch>
51 franklin street fifth floor boston ma 02110 1301 usa
your option [no]_[pad]_[ctrl] any later version this program is
distributed in the hope that it will be useful but without any
warranty without even the implied warranty of merchantability or
fitness for a particular purpose see the gnu general public license
for more details you should have received a copy of the gnu general
public license along with this program if not write to the free
software foundation inc 51 franklin street fifth floor boston ma
02110 1301 usa
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 176 file(s).
Reviewed-by: Jilayne Lovejoy <opensource@jilayne.com>
Reviewed-by: Steve Winslow <swinslow@gmail.com>
Link: https://lkml.kernel.org/r/20190519154040.652910950@linutronix.de
Add SPDX license identifiers to all Make/Kconfig files which:
- Have no license information of any form
These files fall under the project license, GPL v2 only. The resulting SPDX
license identifier is:
GPL-2.0-only
Add SPDX license identifiers to all files which:
- Have MODULE_LICENCE("GPL*") inside which was used in the initial
scan/conversion to ignore the file
GPL-2.0-only
Use codespell to fix lots of typos over frontends.
Manually verified to avoid false-positives.
As we don't need anymore to share pad numbers with similar
drivers, use its own pad definition instead of a global
model.
Acked-by: Hans Verkuil <hans.verkuil@cisco.com>
Consumer devices are provided with a wide different range of types
supported by the same driver, allowing different configutations.
In order to make easier to setup media controller links, "taint"
pads with the signal type it carries.
While here, get rid of DEMOD_PAD_VBI_OUT, as the signal it carries
is actually the same as the normal video output.
The difference happens at the video/VBI interface:
- for VBI, only the hidden lines are streamed;
- for video, the stream is usually cropped to hide the
vbi lines.
The implementation of strscpy() is more robust and safer.
That's now the recommended way to copy NUL terminated strings.
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c updates from Wolfram Sang:
- the core has now a lockless variant of i2c_smbus_xfer. Some open
coded versions of this got removed in drivers. This also enables
proper SCCB support in regmap.
- locking got a more precise naming. i2c_{un}lock_adapter() had to go,
and we know use i2c_lock_bus() consistently with flags like
I2C_LOCK_ROOT_ADAPTER and I2C_LOCK_SEGMENT to avoid ambiguity.
- the gpio fault injector got a new delicate testcase
- the bus recovery procedure got fixed to handle the new testcase
correctly
- a new quirk flag for controllers not able to handle zero length
messages together with driver updates to use it
- new drivers: FSI bus attached I2C masters, GENI I2C controller, Owl
family S900
- and a good set of driver improvements and bugfixes
* 'i2c/for-4.19' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (77 commits)
i2c: rcar: implement STOP and REP_START according to docs
i2c: rcar: refactor private flags
i2c: core: ACPI: Make acpi_gsb_i2c_read_bytes() check i2c_transfer return value
i2c: core: ACPI: Properly set status byte to 0 for multi-byte writes
dt-bindings: i2c: rcar: Add r8a774a1 support
dt-bindings: i2c: sh_mobile: Add r8a774a1 support
i2c: imx: Simplify stopped state tracking
i2c: imx: Fix race condition in dma read
i2c: pasemi: remove hardcoded bus numbers on smbus
i2c: designware: Add SPDX license tag
i2c: designware: Convert to use struct i2c_timings
i2c: core: Parse SDA hold time from firmware
i2c: designware-pcidrv: Mark expected switch fall-through
i2c: amd8111: Mark expected switch fall-through
i2c: sh_mobile: use core to detect 'no zero length read' quirk
i2c: xlr: use core to detect 'no zero length' quirk
i2c: rcar: use core to detect 'no zero length' quirk
i2c: stu300: use core to detect 'no zero length' quirk
i2c: pmcmsp: use core to detect 'no zero length' quirk
i2c: mxs: use core to detect 'no zero length' quirk
Instead of doing casts, use %zd to print sizes, in order to make
smatch happier:
drivers/media/tuners/xc4000.c:818 xc4000_fwupload() warn: argument 4 to %d specifier is cast from pointer
Makes smatch happier by using %zd instead of casting sizes:
drivers/media/tuners/tuner-xc2028.c:378 load_all_firmwares() warn: argument 4 to %d specifier is cast from pointer
drivers/media/tuners/tuner-xc2028.c:619 load_firmware() warn: argument 6 to %d specifier is cast from pointer
Right now, satellite frontend drivers specify frequencies in kHz,
while terrestrial/cable ones specify in Hz. That's confusing
for developers.
However, the main problem is that universal frontends capable
of handling both satellite and non-satelite delivery systems
are appearing. We end by needing to hack the drivers in
order to support such hybrid frontends.
So, convert everything to specify frontend frequencies in Hz.
Tested-by: Katsuhiro Suzuki <suzuki.katsuhiro@socionext.com>
Right now, satellite tuner drivers specify frequencies in kHz,
for developers.
However, the main problem is that universal tuners capable
order to support such hybrid tuners.
So, convert everything to specify tuner frequencies in Hz.
Plese notice that a similar patch is also needed for frontends.
Acked-by: Michael Büsch <m@bues.ch>
Locking the root adapter for __i2c_transfer will deadlock if the
device sits behind a mux-locked I2C mux. Switch to the finer-grained
i2c_lock_bus with the I2C_LOCK_SEGMENT flag. If the device does not
sit behind a mux-locked mux, the two locking variants are equivalent.
Signed-off-by: Peter Rosin <peda@axentia.se>
Acked-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
For some types of tuners (Philips FMD1216ME(X) MK3 currently) we know that
letting TDA9887 output port 1 remain high (inactive) will switch FM radio
to mono mode.
Let's make use of this functionality - nothing changes for the default
stereo radio mode.
Tested on a Medion 95700 board which has a FMD1216ME tuner.
Signed-off-by: Maciej S. Szmigiero <mail@maciej.szmigiero.name>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Linux 4.17-rc4
* tag 'v4.17-rc4': (920 commits)
Linux 4.17-rc4
KVM: x86: remove APIC Timer periodic/oneshot spikes
genksyms: fix typo in parse.tab.{c,h} generation rules
kbuild: replace hardcoded bison in cmd_bison_h with $(YACC)
gcc-plugins: fix build condition of SANCOV plugin
MAINTAINERS: Update Kbuild entry with a few paths
Revert "usb: host: ehci: Use dma_pool_zalloc()"
platform/x86: Kconfig: Fix dell-laptop dependency chain.
platform/x86: asus-wireless: Fix NULL pointer dereference
arm64: vgic-v2: Fix proxying of cpuif access
KVM: arm/arm64: vgic_init: Cleanup reference to process_maintenance
KVM: arm64: Fix order of vcpu_write_sys_reg() arguments
MAINTAINERS & files: Canonize the e-mails I use at files
media: imx-media-csi: Fix inconsistent IS_ERR and PTR_ERR
tools: power/acpi, revert to LD = gcc
bdi: Fix oops in wb_workfn()
RDMA/cma: Do not query GID during QP state transition to RTR
IB/mlx4: Fix integer overflow when calculating optimal MTT size
IB/hfi1: Fix memory leak in exception path in get_irq_affinity()
IB/{hfi1, rdmavt}: Fix memory leak in hfi1_alloc_devdata() upon failure
As warned by gcc:
drivers/media/tuners/qm1d1b0004.c:62:39: warning: 'default_cfg' defined but not used [-Wunused-const-variable=]
static const struct qm1d1b0004_config default_cfg = {
This var is currently unused. So, comment it out.
The tuner is used in Earthsoft PT1/PT2 DVB boards,
and the driver was extraced from (the former) va1j5jf8007s.c of PT1.
it might contain PT1 specific configs.
Signed-off-by: Akihiro Tsukada <tskd08@gmail.com>
From now on, I'll start using my @kernel.org as my development e-mail.
As such, let's remove the entries that point to the old
mchehab@s-opensource.com at MAINTAINERS file.
For the files written with a copyright with mchehab@s-opensource,
let's keep Samsung on their names, using mchehab+samsung@kernel.org,
in order to keep pointing to my employer, with sponsors the work.
For the files written before I join Samsung (on July, 4 2013),
let's just use mchehab@kernel.org.
For bug reports, we can simply point to just kernel.org, as
this will reach my mchehab+samsung inbox anyway.
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
Signed-off-by: Brian Warner <brian.warner@samsung.com>
As pointed by smatch:
drivers/media/tuners/r820t.c:2374 r820t_attach() error: potential null dereference 'priv'. (kzalloc returns null)
The current function with prints error assumes that the attach
succeeds. So, don't use it in case of failures.
The v4l2_subdev core s_power op was used for two different things: power on/off
sensors or video decoders/encoders and to put a tuner in standby (and only the
tuner!). There is no 'tuner wakeup' op, that's done automatically when the tuner
is accessed.
The danger with calling (s_power, 0) to put a tuner into standby is that it is
usually broadcast for all subdevs. So a video receiver subdev that supports
s_power will also be powered off, and since there is no corresponding (s_power, 1)
they will never be powered on again.
In addition, this is specifically meant for tuners only since they draw the most
current.
This patch adds a new tuner op called 'standby' and replaces all calls to
(core, s_power, 0) by (tuner, standby). This prevents confusion between the two
uses of s_power. Note that there is no overlap: bridge drivers either just want
to put the tuner into standby, or they deal with powering on/off sensors. Never
both.
This also makes it easier to replace s_power for the remaining bridge drivers
with some PM code later.
Whether we want something cleaner for tuners in the future is a separate topic.
There is a lot of legacy code surrounding tuners, and I am very hesitant about
making changes there.
There are a lot of places where sequences of space/tabs are
found. Get rid of all spaces before tabs.
On several places, whitespaces are being used for indentation,
or even at the end of the line.
Fix them.
Except for DVB, all media kAPI headers are at include/media.
Move the headers to it.
With CONFIG_KASAN, we get an overly long stack frame due to inlining
the register access functions:
drivers/media/tuners/r820t.c: In function 'generic_set_freq.isra.7':
drivers/media/tuners/r820t.c:1334:1: error: the frame size of 2880 bytes is larger than 2048 bytes [-Werror=frame-larger-than=]
This is caused by a gcc bug that has now been fixed in gcc-8.
To work around the problem, we can pass the register data
through a local variable that older gcc versions can optimize
out as well.
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=81715
With CONFIG_KASAN enabled, we get a relatively large stack frame in one function
drivers/media/tuners/tda8290.c: In function 'tda8290_set_params':
drivers/media/tuners/tda8290.c:310:1: warning: the frame size of 1520 bytes is larger than 1024 bytes [-Wframe-larger-than=]
With CONFIG_KASAN_EXTRA this goes up to
drivers/media/tuners/tda8290.c:310:1: error: the frame size of 3200 bytes is larger than 3072 bytes [-Werror=frame-larger-than=]
We can significantly reduce this by marking local arrays as 'static const', and
this should result in better compiled code for everyone.
[mchehab@s-opensource.com: fix a trivial merge conflict]
Reviewed-by: Michael Ira Krufky <mkrufky@linuxtv.org>
NXP TDA18250 silicon tuner driver.
Version 4 includes some checkpatch fixes.
Signed-off-by: Olli Salonen <olli.salonen@iki.fi>
As warned by smatch, there are several places where the I2C
transfer may fail, leading into inconsistent behavior:
drivers/media/tuners/xc5000.c:689 xc_debug_dump() error: uninitialized symbol 'regval'.
drivers/media/tuners/xc5000.c:841 xc5000_is_firmware_loaded() error: uninitialized symbol 'id'.
drivers/media/tuners/xc5000.c:939 xc5000_set_tv_freq() error: uninitialized symbol 'pll_lock_status'.
drivers/media/tuners/xc5000.c:1195 xc_load_fw_and_init_tuner() error: uninitialized symbol 'pll_lock_status'.
Handle the return codes from the I2C transfer, in order to
address those issues.
If, for some reason, reading the hwmodel register on
xc4000 fails, it will cause the following logig to
use a random value, as reported by smatch:
drivers/media/tuners/xc4000.c:1047 check_firmware() error: uninitialized symbol 'hwmodel'.
drivers/media/tuners/xc4000.c:1060 check_firmware() error: uninitialized symbol 'hwmodel'.
drivers/media/tuners/xc4000.c:1064 check_firmware() error: uninitialized symbol 'hwmodel'.
The logic at qt1010_init_meas1() and qt1010_init_meas2()
are too complex for static analizers to identify that
some vars are always be initialized.
That causes smatch to produce the following warnings:
drivers/media/tuners/qt1010.c:248 qt1010_init_meas1() error: uninitialized symbol 'val2'.
drivers/media/tuners/qt1010.c:282 qt1010_init_meas2() error: uninitialized symbol 'val'.
So, add annotations to prevent those bogus warnings.
The tuning logic at tda8290 relies on agc_stat and
adc_sat to be initialized. However, as warned by smatch:
drivers/media/tuners/tda8290.c:261 tda8290_set_params() error: uninitialized symbol 'agc_stat'.
drivers/media/tuners/tda8290.c:261 tda8290_set_params() error: uninitialized symbol 'adc_sat'.
drivers/media/tuners/tda8290.c:262 tda8290_set_params() error: uninitialized symbol 'adc_sat'.
That could cause an erratic behavior if PLL is not locked,
as the code will only work if
!(pll_stat & 0x80) && (adc_sat < 20)
So, initialize it to zero, in order to let the code below
to be called, with should give more chances to adjust the
tuner gain, in order to get a PLL lock.
As we're now using SPDX identifiers, on the several
media drivers I wrote, add the proper SPDX, identifying
the license I meant.
As we're now using the short license, it doesn't make sense to
keep the original license text.
Also, fix MODULE_LICENSE to properly identify GPL v2.
Don't populate the arrays RegAddr on the stack, instead make them static
const. Makes the object code smaller by over 980 bytes:
Before:
64923 304 0 65227 fecb drivers/media/tuners/mxl5005s.o
After:
63779 464 0 64243 faf3 drivers/media/tuners/mxl5005s.o
Fix those warnings:
drivers/media/tuners/mt2063.c:1413: warning: No description found for parameter 'f_ref'
drivers/media/tuners/mt2063.c:1413: warning: Excess function parameter 'f_Ref' description in 'MT2063_fLO_FractionalTerm'
drivers/media/tuners/mt2063.c:1476: warning: Excess function parameter 'f_Avoid' description in 'MT2063_CalcLO2Mult'
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Since commit 29d2fef8be11 ("usb: catch attempts to submit urbs
with a vmalloc'd transfer buffer"), the AverMedia AverTV DVB-T
USB 2.0 (a800) fails to probe.
Cc: stable@vger.kernel.org
Make these const as they are only used during a copy operation.
Done using Coccinelle.
Signed-off-by: Bhumika Goyal <bhumirks@gmail.com>
