[ Upstream commit 4843a543fad3bf8221cf14e5d5f32d15cee89e84 ]
If reg_r() fails, then gspca_dev->usb_buf was left uninitialized,
and some drivers used the contents of that buffer in logic.
This caused several syzbot errors:
https://syzkaller.appspot.com/bug?extid=397fd082ce5143e2f67d
https://syzkaller.appspot.com/bug?extid=1a35278dd0ebfb3a038a
https://syzkaller.appspot.com/bug?extid=06ddf1788cfd048c5e82
I analyzed the gspca drivers and zeroed the buffer where needed.
Reported-and-tested-by: syzbot+1a35278dd0ebfb3a038a@syzkaller.appspotmail.com
Reported-and-tested-by: syzbot+397fd082ce5143e2f67d@syzkaller.appspotmail.com
Reported-and-tested-by: syzbot+06ddf1788cfd048c5e82@syzkaller.appspotmail.com
Signed-off-by: Hans Verkuil <hverkuil-cisco@xs4all.nl>
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
Drop the FSF's postal address from the source code files that typically
contain mostly the license text. Of the 628 removed instances, 578 are
outdated.
The patch has been created with the following command without manual edits:
git grep -l "675 Mass Ave\|59 Temple Place\|51 Franklin St" -- \
drivers/media/ include/media|while read i; do i=$i perl -e '
open(F,"< $ENV{i}");
$a=join("", <F>);
$a =~ s/[ \t]*\*\n.*You should.*\n.*along with.*\n.*(\n.*USA.*$)?\n//m
&& $a =~ s/(^.*)Or, (point your browser to) /$1To obtain the license, $2\n$1/m;
close(F);
open(F, "> $ENV{i}");
print F $a;
close(F);'; done
Signed-off-by: Sakari Ailus <sakari.ailus@linux.intel.com>
Store complete current mode (struct v4l2_pix_format) in struct gspca_dev
instead of separate pixfmt, width and height parameters.
This is a preparation for variable resolution support.
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
replace:
#if defined(CONFIG_INPUT) || \
defined(CONFIG_INPUT_MODULE)
with:
#if IS_ENABLED(CONFIG_INPUT)
This change was made for: CONFIG_INPUT
Reported-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com>
Rename all USB drivers with their own directory under
drivers/media/video into drivers/media/usb and update the
building system.
