[ Upstream commit e950267ab802c8558f1100eafd4087fd039ad634 ]
Some devices have invalid baSourceID references, causing uvc_scan_chain()
to fail, but if we just take the entities we can find and put them
together in the most sensible chain we can think of, turns out they do
work anyway. Note: This heuristic assumes there is a single chain.
At the time of writing, devices known to have such a broken chain are
- Acer Integrated Camera (5986:055a)
- Realtek rtl157a7 (0bda:57a7)
Signed-off-by: Henrik Ingo <henrik.ingo@avoinelama.fi>
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
struct media_devnode is currently embedded at struct media_device.
While this works fine during normal usage, it leads to a race
condition during devnode unregister. the problem is that drivers
assume that, after calling media_device_unregister(), the struct
that contains media_device can be freed. This is not true, as it
can't be freed until userspace closes all opened /dev/media devnodes.
In other words, if the media devnode is still open, and media_device
gets freed, any call to an ioctl will make the core to try to access
struct media_device, with will cause an use-after-free and even GPF.
Fix this by dynamically allocating the struct media_devnode and only
freeing it when it is safe.
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Add support for Intel R200 depth camera in uvc driver.
This includes adding new uvc GUIDs for the new pixel formats,
adding new V4L pixel format definition to user api headers,
and updating the uvc driver GUID-to-4cc tables with the new formats.
Tested-by: Greenberg, Aviv D <aviv.d.greenberg@intel.com>
Signed-off-by: Aviv Greenberg <aviv.d.greenberg@intel.com>
Signed-off-by: Sakari Ailus <sakari.ailus@linux.intel.com>
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
The media device node is registered and so made visible to user-space
before entities are registered and links created which means that the
media graph obtained by user-space could be only partially enumerated
if that happens too early before all the graph has been created.
To avoid this race condition, split the media init and registration
in separate functions and only register the media device node when
all the pending subdevices have been registered, either explicitly
by the driver or asynchronously using v4l2_async_register_subdev().
The media_device_register() had a check for drivers not filling dev
and model fields but all drivers in mainline set them and not doing
it will be a driver bug so change the function return to void and
add a BUG_ON() for dev being NULL instead.
Also, add a media_device_cleanup() function that will destroy the
graph_mutex that is initialized in media_device_init().
[mchehab@osg.samsung.com: Fix compilation if !CONFIG_MEDIA_CONTROLLER
and remove two warnings added by this changeset]
Suggested-by: Sakari Ailus <sakari.ailus@linux.intel.com>
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com>
This reverts commit 120c41d3477a23c6941059401db63677736f1935.
The patch doesn't add the corresponding documentation bits to the
media infrastructure uAPI DocBook. Also, they're for 3D formats,
with requre further discussions.
Requested-by: Hans Verkuil <hverkuil@xs4all.nl>
Requested-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Add support for Intel DS4 depth camera in uvc driver.
Change-Id: If240d95a7d4edc8dcc3e02d58cd8267a6bbf6fcb
UVC 1.5 devices report a bInterfaceProtocol value set to 1 in their
interface descriptors. The uvcvideo driver only matches on
bInterfaceProtocol 0, preventing those devices from being detected.
More changes to the driver are needed for full UVC 1.5 compatibility.
However, at least the UVC 1.5 Microsoft Surface Pro 3 cameras have been
reported to work out of the box with the driver with an updated match
table.
Enable UVC 1.5 support in the match table to support the devices that
can work with the current driver implementation. Devices that can't will
fail, but that's hardly a regression as they're currently not detected
at all anyway.
The hardware timestamping implementation has been reported as not
working correctly on at least the Logitech C920. Until this can be
fixed, disable it by default.
Reported-by: Peter Rabbitson <rabbit@rabbit.us>
The UVC_DEV_DISCONNECTED flag is set when the USB device is
disconnected, and checked in the open() handler to refuse opening a
device that has been disconnected.
This is inherently racy, but the race condition is taken care of in the
V4L2 core, which also fails open() calls when the V4L2 device node has
been unregistered. As the uvcvideo USB disconnect handler unregisters
all its video device nodes, the UVC_DEV_DISCONNECTED flag doesn't serve
any purpose anymore and can be removed.
Embed the video_device struct to simplify the error handling and in
order to (eventually) get rid of video_device_alloc/release.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
The device is based on an Aveo chipset, implements UVC but advertises a
vendor-specific class on all interfaces.
Support it by listing the USB VID:PID explicitly.
The Magewell XI100DUSB-HDMI[1] video capture device reports the pixel
format "e436eb7d-524f-11ce-9f53-0020af0ba770". This is its GUID for
BGR 8:8:8.
The UVC 1.5 spec[2] only defines GUIDs for YUY2, NV12, M420 and I420.
This seems to be an extension documented in the Microsoft Windows Media
Format SDK[3] - or at least the Media Format SDK was the only hit that
Google gave when searching for the GUID. This Media Format SDK defines
this GUID as corresponding to `MEDIASUBTYPE_RGB24`. Note though, the
XI100DUSB outputs BGR e.g. byte-reversed. I don't know if its the
capture device in error or Microsoft mean BGR when they say RGB.
[1]: http://www.magewell.com/hardware/dongles/xi100dusb-hdmi/xi100dusb-hdmi_features.html?lang=en
[2]: http://www.usb.org/developers/docs/devclass_docs/USB_Video_Class_1_5.zip
[3]: http://msdn.microsoft.com/en-gb/library/windows/desktop/dd757532(v=vs.85).aspx
Signed-off-by: William Manley <will@williammanley.net>
This brings the function name in line with the V4L2 API terminology and
allows removing the duplicate queue type check.
In order to make use of the vb2 queue start/stop_streaming operations
the video and queue enable/disable operations need to be split, as the
vb2 queue will need to enable and disable video instead of the other way
around.
Also move buffer queue disable outside of uvc_video_resume() to remove
all queue disable operations out of uvc_video.c.
Simplify ioctl handling by using video_ioctl2.
We've got a bug report at disconnecting a Webcam, where the kernel
spews warnings like below:
WARNING: CPU: 0 PID: 8385 at ../fs/sysfs/group.c:219 sysfs_remove_group+0x87/0x90()
sysfs group c0b2350c not found for kobject 'event3'
CPU: 0 PID: 8385 Comm: queue2:src Not tainted 3.16.2-1.gdcee397-default #1
Hardware name: ASUSTeK Computer INC. A7N8X-E/A7N8X-E, BIOS ASUS A7N8X-E Deluxe ACPI BIOS Rev 1013 11/12/2004
c08d0705 ddc75cbc c0718c5b ddc75ccc c024b654 c08c6d44 ddc75ce8 000020c1
c08d0705 000000db c03d1ec7 c03d1ec7 00000009 00000000 c0b2350c d62c9064
ddc75cd4 c024b6a3 00000009 ddc75ccc c08c6d44 ddc75ce8 ddc75cfc c03d1ec7
Call Trace:
[<c0205ba6>] try_stack_unwind+0x156/0x170
[<c02046f3>] dump_trace+0x53/0x180
[<c0205c06>] show_trace_log_lvl+0x46/0x50
[<c0204871>] show_stack_log_lvl+0x51/0xe0
[<c0205c67>] show_stack+0x27/0x50
[<c0718c5b>] dump_stack+0x3e/0x4e
[<c024b654>] warn_slowpath_common+0x84/0xa0
[<c024b6a3>] warn_slowpath_fmt+0x33/0x40
[<c03d1ec7>] sysfs_remove_group+0x87/0x90
[<c05a2c54>] device_del+0x34/0x180
[<c05e3989>] evdev_disconnect+0x19/0x50
[<c05e06fa>] __input_unregister_device+0x9a/0x140
[<c05e0845>] input_unregister_device+0x45/0x80
[<f854b1d6>] uvc_delete+0x26/0x110 [uvcvideo]
[<f84d66f8>] v4l2_device_release+0x98/0xc0 [videodev]
[<c05a25bb>] device_release+0x2b/0x90
[<c04ad8bf>] kobject_cleanup+0x6f/0x1a0
[<f84d5453>] v4l2_release+0x43/0x70 [videodev]
[<c0372f31>] __fput+0xb1/0x1b0
[<c02650c1>] task_work_run+0x91/0xb0
[<c024d845>] do_exit+0x265/0x910
[<c024df64>] do_group_exit+0x34/0xa0
[<c025a76f>] get_signal_to_deliver+0x17f/0x590
[<c0201b6a>] do_signal+0x3a/0x960
[<c02024f7>] do_notify_resume+0x67/0x90
[<c071ebb5>] work_notifysig+0x30/0x3b
[<b7739e60>] 0xb7739e5f
---[ end trace b1e56095a485b631 ]---
The cause is that uvc_status_cleanup() is called after usb_put_*() in
uvc_delete(). usb_put_*() removes the sysfs parent and eventually
removes the children recursively, so the later device_del() can't find
its sysfs. The fix is simply rearrange the call orders in
uvc_delete() so that the child is removed before the parent.
Bugzilla: https://bugzilla.suse.com/show_bug.cgi?id=897736
Reported-and-tested-by: Martin Pluskal <mpluskal@suse.com>
Cc: <stable@vger.kernel.org>
This patch adds a quirk to force Y8 pixel format even if the camera reports
half-width YUYV.
Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com>
As reported on [1], this device needs this quirk to be able to
reliably initialise the webcam.
[1] http://ubuntuforums.org/showthread.php?t=2145996
Cc: stable@vger.kernel.org
Signed-off-by: Paul Fertser <fercerpav@gmail.com>
The uvcvideo webcam driver exposes the v4l2 control "Exposure (Absolute)"
which allows the user to control the exposure time of the webcam,
essentially controlling the brightness of the received image. By default
the webcam automatically adjusts the exposure time automatically but the
if you set the control "Exposure, Auto"="Manual Mode" the user can fix
the exposure time.
Unfortunately it seems that the Logitech C920 has a firmware bug where
it will forget that it's in manual mode temporarily during initialisation.
This means that the camera doesn't respect the exposure time that the user
requested if they request it before starting to stream video. They end up
with a video stream which is either too bright or too dark and must reset
the controls after video starts streaming.
This patch introduces the quirk UVC_QUIRK_RESTORE_CTRLS_ON_INIT which
causes the cached controls to be re-uploaded to the camera immediately
after initialising the camera. This quirk is applied to the C920 to work
around this camera bug.
Since all the drivers that use `struct v4l2_fh' use the core
priority checking, the setting of the flag in the drivers can
be removed.
Signed-off-by: Ramakrishnan Muthukrishnan <ramakrmu@cisco.com>
Reviewed-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
Add bayer 8-bit GUIDs to uvcvideo and associated them with the
corresponding V4L2 pixel formats.
Signed-off-by: Edgar Thier <info@edgarthier.net>
x < constant implies x + unsigned < constant
That check just obfuscates the code
Signed-off-by: Oliver Neukum <oneukum@suse.de>
The camera doesn't implement GET_DEF on the video probe control and
can crash when it receives the request depending on timings. Set the
PROBE_DEF quirk to work around the problem.
Reported-by: Jürgen Liebmann <info@pirna-esw6.de>
BugLink: http://bugs.launchpad.net/bugs/1217957
Add quirk for Dell SP2008WFP monitor: 05a9:2641
Signed-off-by: Joseph Salisbury <joseph.salisbury@canonical.com>
Tested-by: Christopher Townsend <christopher.townsend@canonical.com>
Maintaining the users count using an atomic variable makes sure that
access to the counter won't be racy, but doesn't serialize access to the
operations protected by the counter. This creates a race condition that
could result in the status URB being submitted multiple times.
Use a mutex to protect the users count and serialize access to the
status start and stop operations.
Reported-by: Shawn Nematbakhsh <shawnn@chromium.org>
BugLink: http://bugs.launchpad.net/bugs/1180409
OminiVision webcam 0x05a9:0x2643 needs the same UVC_QUIRK_PROBE_DEF
as other OmniVision models to work properly.
BugLink: https://bugs.launchpad.net/bugs/1168430
OminiVision webcam 0x05a9:0x264a (in Dell Studio Hybrid 140g) needs the
same UVC_QUIRK_PROBE_DEF as other OmniVision model to be recognized
consistently.
Signed-off-by: Kamal Mostafa <kamal@canonical.com>
The MEDIA_ENT_FL_DEFAULT identifies entities that are considered as
default for their group and type. For video nodes, it identifies the
node that application should use by default.
UVC devices don't report which output terminal should be considered as
the default, use the first one. Most devices have a single output
terminal anyway.
Acked-by: Hans Verkuil <hans.verkuil@cisco.com>
Set the capabilities field to global capabilities, and the device_caps
field to the video node capabilities.
This issue was found by the v4l2-compliance tool.
Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Acked-by: Sakari Ailus <sakari.ailus@iki.fi>
The uvcvideo driver now supports USERPTR, and isn't limited to YUYV and
MJPEG anymore.
Rename all USB drivers with their own directory under
drivers/media/video into drivers/media/usb and update the
building system.
