commit 3b35fc81e7ec552147a4fd843d0da0bbbe4ef253 upstream.
timestamps in v4l2 buffers returned to userspace are updated in
uvc_video_clock_update() which uses timestamps fetched from
uvc_video_clock_decode() by calling unconditionally ktime_get_ts().
Hence setting the module clock param to realtime has no effect before
this patch.
This has been tested with ffmpeg:
ffmpeg -y -f v4l2 -input_format yuyv422 -video_size 640x480 -framerate 30 -i /dev/video0 \
-f alsa -acodec pcm_s16le -ar 16000 -ac 1 -i default \
-c:v libx264 -preset ultrafast \
-c:a libfdk_aac \
out.mkv
and inspecting the v4l2 input starting timestamp.
Signed-off-by: Olivier Langlois <olivier@trillion01.com>
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
commit b1e43f232698274871e1358c276d7b0242a7d607 upstream.
The UVC specification uses alternate setting selection to notify devices
of stream start/stop. This breaks when using bulk-based devices, as the
video streaming interface has a single alternate setting in that case,
making video stream start and video stream stop events to appear
identical to the device. Bulk-based devices are thus not well supported
by UVC.
The webcam built in the Asus Zenbook UX302LA ignores the set interface
request and will keep the video stream enabled when the driver tries to
stop it. If USB autosuspend is enabled the device will then be suspended
and will crash, requiring a cold reboot.
USB trace capture showed that Windows sends a CLEAR_FEATURE(HALT)
request to the bulk endpoint when stopping the stream instead of
selecting alternate setting 0. The camera then behaves correctly, and
thus seems to require that behaviour.
Replace selection of alternate setting 0 with clearing of the endpoint
halt feature at video stream stop for bulk-based devices. Let's refrain
from blaming Microsoft this time, as it's not clear whether this
Windows-specific but USB-compliant behaviour was specifically developed
to handle bulkd-based UVC devices, or if the camera just took advantage
of it.
Signed-off-by: Oleksij Rempel <linux@rempel-privat.de>
Fix various spelling errors in strings and comments throughout the media
tree. The majority of these were found using Lucas De Marchi's codespell
tool.
[m.chehab@samsung.com: discard hunks with conflicts]
Signed-off-by: Jonathan McCrohan <jmccrohan@gmail.com>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
On this arch, usec is not unsigned long. So, we need to typecast,
in order to remove those warnings:
drivers/media/usb/uvc/uvc_video.c: In function 'uvc_video_clock_update':
drivers/media/usb/uvc/uvc_video.c:678:2: warning: format '%lu' expects argument of type 'long unsigned int', but argument 9 has type '__kernel_suseconds_t' [-Wformat]
drivers/staging/media/lirc/lirc_serial.c: In function 'irq_handler':
drivers/staging/media/lirc/lirc_serial.c:707:5: warning: format '%lx' expects argument of type 'long unsigned int', but argument 6 has type '__kernel_suseconds_t' [-Wformat]
drivers/staging/media/lirc/lirc_serial.c:707:5: warning: format '%lx' expects argument of type 'long unsigned int', but argument 7 has type '__kernel_suseconds_t' [-Wformat]
drivers/staging/media/lirc/lirc_serial.c:719:5: warning: format '%lx' expects argument of type 'long unsigned int', but argument 6 has type '__kernel_suseconds_t' [-Wformat]
drivers/staging/media/lirc/lirc_serial.c:719:5: warning: format '%lx' expects argument of type 'long unsigned int', but argument 7 has type '__kernel_suseconds_t' [-Wformat]
drivers/staging/media/lirc/lirc_serial.c:728:6: warning: format '%lx' expects argument of type 'long unsigned int', but argument 6 has type '__kernel_suseconds_t' [-Wformat]
drivers/staging/media/lirc/lirc_serial.c:728:6: warning: format '%lx' expects argument of type 'long unsigned int', but argument 7 has type '__kernel_suseconds_t' [-Wformat]
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Reviewed-by: Hans Verkuil <hans.verkuil@cisco.com>
Return the default format in that case.
This issue was found by the v4l2-compliance tool.
Acked-by: Hans Verkuil <hans.verkuil@cisco.com>
This function returns an integer and it's mandatory
to check the return code.
Signed-off-by: Ezequiel Garcia <elezegarcia@gmail.com>
Rename all USB drivers with their own directory under
drivers/media/video into drivers/media/usb and update the
building system.
