path: root/drivers/media/usb/zr364xx
2019-08-14media: media/usb: Use kmemdup rather than duplicating its implementationFuqian Huang
kmemdup is introduced to duplicate a region of memory in a neat way. Rather than kmalloc/kzalloc + memcpy, which the programmer needs to write the size twice (sometimes lead to mistakes), kmemdup improves readability, leads to smaller code and also reduce the chances of mistakes. Suggestion to use kmemdup rather than using kmalloc/kzalloc + memcpy. Signed-off-by: Fuqian Huang <huangfq.daxian@gmail.com> Signed-off-by: Sean Young <sean@mess.org> Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2019-07-22media: media/usb: don't set description in ENUM_FMTHans Verkuil
The V4L2 core sets the description for the driver in order to ensure consistent naming. So drop the strscpy of the description in drivers. Also remove any description strings in driver-internal structures since those are no longer needed. Signed-off-by: Hans Verkuil <hverkuil-cisco@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2019-06-11Merge tag 'v5.2-rc4' into media/masterMauro Carvalho Chehab
There are some conflicts due to SPDX changes. We also have more patches being merged via media tree touching them. So, let's merge back from upstream and address those. Linux 5.2-rc4 * tag 'v5.2-rc4': (767 commits) Linux 5.2-rc4 MAINTAINERS: Karthikeyan Ramasubramanian is MIA i2c: xiic: Add max_read_len quirk lockref: Limit number of cmpxchg loop retries uaccess: add noop untagged_addr definition x86/insn-eval: Fix use-after-free access to LDT entry kbuild: use more portable 'command -v' for cc-cross-prefix s390/unwind: correct stack switching during unwind block, bfq: add weight symlink to the bfq.weight cgroup parameter cgroup: let a symlink too be created with a cftype file drm/nouveau/secboot/gp10[2467]: support newer FW to fix SEC2 failures on some boards drm/nouveau/secboot: enable loading of versioned LS PMU/SEC2 ACR msgqueue FW drm/nouveau/secboot: split out FW version-specific LS function pointers drm/nouveau/secboot: pass max supported FW version to LS load funcs drm/nouveau/core: support versioned firmware loading drm/nouveau/core: pass subdev into nvkm_firmware_get, rather than device block: free sched's request pool in blk_cleanup_queue pktgen: do not sleep with the thread lock held. net: mvpp2: Use strscpy to handle stat strings net: rds: fix memory leak in rds_ib_flush_mr_pool ... Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2019-06-05media: media/usb: set device_caps in struct video_deviceHans Verkuil
Instead of filling in the struct v4l2_capability device_caps field, fill in the struct video_device device_caps field. That way the V4L2 core knows what the capabilities of the video device are. But this only really works if all drivers use this, so convert all usb drivers in this patch. Signed-off-by: Hans Verkuil <hverkuil-cisco@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2019-05-30treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 157Thomas Gleixner
Based on 3 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license as published by the free software foundation either version 2 of the license or at your option any later version this program is distributed in the hope that it will be useful but without any warranty without even the implied warranty of merchantability or fitness for a particular purpose see the gnu general public license for more details this program is free software you can redistribute it and or modify it under the terms of the gnu general public license as published by the free software foundation either version 2 of the license or at your option any later version [author] [kishon] [vijay] [abraham] [i] [kishon]@[ti] [com] this program is distributed in the hope that it will be useful but without any warranty without even the implied warranty of merchantability or fitness for a particular purpose see the gnu general public license for more details this program is free software you can redistribute it and or modify it under the terms of the gnu general public license as published by the free software foundation either version 2 of the license or at your option any later version [author] [graeme] [gregory] [gg]@[slimlogic] [co] [uk] [author] [kishon] [vijay] [abraham] [i] [kishon]@[ti] [com] [based] [on] [twl6030]_[usb] [c] [author] [hema] [hk] [hemahk]@[ti] [com] this program is distributed in the hope that it will be useful but without any warranty without even the implied warranty of merchantability or fitness for a particular purpose see the gnu general public license for more details extracted by the scancode license scanner the SPDX license identifier GPL-2.0-or-later has been chosen to replace the boilerplate/reference in 1105 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Allison Randal <allison@lohutok.net> Reviewed-by: Richard Fontana <rfontana@redhat.com> Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190527070033.202006027@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-28media: usb:zr364xx:Fix KASAN:null-ptr-deref Read in zr364xx_vidioc_querycapVandana BN
SyzKaller hit the null pointer deref while reading from uninitialized udev->product in zr364xx_vidioc_querycap(). ================================================================== BUG: KASAN: null-ptr-deref in read_word_at_a_time+0xe/0x20 include/linux/compiler.h:274 Read of size 1 at addr 0000000000000000 by task v4l_id/5287 CPU: 1 PID: 5287 Comm: v4l_id Not tainted 5.1.0-rc3-319004-g43151d6 #6 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:77 [inline] dump_stack+0xe8/0x16e lib/dump_stack.c:113 kasan_report.cold+0x5/0x3c mm/kasan/report.c:321 read_word_at_a_time+0xe/0x20 include/linux/compiler.h:274 strscpy+0x8a/0x280 lib/string.c:207 zr364xx_vidioc_querycap+0xb5/0x210 drivers/media/usb/zr364xx/zr364xx.c:706 v4l_querycap+0x12b/0x340 drivers/media/v4l2-core/v4l2-ioctl.c:1062 __video_do_ioctl+0x5bb/0xb40 drivers/media/v4l2-core/v4l2-ioctl.c:2874 video_usercopy+0x44e/0xf00 drivers/media/v4l2-core/v4l2-ioctl.c:3056 v4l2_ioctl+0x14e/0x1a0 drivers/media/v4l2-core/v4l2-dev.c:364 vfs_ioctl fs/ioctl.c:46 [inline] file_ioctl fs/ioctl.c:509 [inline] do_vfs_ioctl+0xced/0x12f0 fs/ioctl.c:696 ksys_ioctl+0xa0/0xc0 fs/ioctl.c:713 __do_sys_ioctl fs/ioctl.c:720 [inline] __se_sys_ioctl fs/ioctl.c:718 [inline] __x64_sys_ioctl+0x74/0xb0 fs/ioctl.c:718 do_syscall_64+0xcf/0x4f0 arch/x86/entry/common.c:290 entry_SYSCALL_64_after_hwframe+0x49/0xbe RIP: 0033:0x7f3b56d8b347 Code: 90 90 90 48 8b 05 f1 fa 2a 00 64 c7 00 26 00 00 00 48 c7 c0 ff ff ff ff c3 90 90 90 90 90 90 90 90 90 90 b8 10 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d c1 fa 2a 00 31 d2 48 29 c2 64 RSP: 002b:00007ffe005d5d68 EFLAGS: 00000202 ORIG_RAX: 0000000000000010 RAX: ffffffffffffffda RBX: 0000000000000003 RCX: 00007f3b56d8b347 RDX: 00007ffe005d5d70 RSI: 0000000080685600 RDI: 0000000000000003 RBP: 0000000000000000 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000202 R12: 0000000000400884 R13: 00007ffe005d5ec0 R14: 0000000000000000 R15: 0000000000000000 ================================================================== For this device udev->product is not initialized and accessing it causes a NULL pointer deref. The fix is to check for NULL before strscpy() and copy empty string, if product is NULL Reported-by: syzbot+66010012fd4c531a1a96@syzkaller.appspotmail.com Signed-off-by: Vandana BN <bnvandana@gmail.com> Signed-off-by: Hans Verkuil <hverkuil-cisco@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2019-05-21treewide: Add SPDX license identifier - Makefile/KconfigThomas Gleixner
Add SPDX license identifiers to all Make/Kconfig files which: - Have no license information of any form These files fall under the project license, GPL v2 only. The resulting SPDX license identifier is: GPL-2.0-only Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-03-20media: Kconfig files: use the right help coding styleMauro Carvalho Chehab
Checkpatch wants to use 'help' instead of '---help---': WARNING: prefer 'help' over '---help---' for new help texts Let's change it globally at the media subsystem, as otherwise people would keep using the old way. Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2019-03-01media: usb: fix several typosMauro Carvalho Chehab
Use codespell to fix lots of typos over frontends. Manually verified to avoid false-positives. Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2019-02-07media: videobuf: use u64 for the timestamp internallyHans Verkuil
Just like vb2 does, use u64 internally to store the timestamps of the buffers. Only convert to timeval when interfacing with userspace. Signed-off-by: Hans Verkuil <hverkuil-cisco@xs4all.nl> Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com> Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2018-09-11media: replace strcpy() by strscpy()Mauro Carvalho Chehab
The strcpy() function is being deprecated upstream. Replace it by the safer strscpy(). Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org> Reviewed-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2018-09-11media: use strscpy() instead of strlcpy()Mauro Carvalho Chehab
The implementation of strscpy() is more robust and safer. That's now the recommended way to copy NUL terminated strings. Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org> Reviewed-by: Kees Cook <keescook@chromium.org> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2018-06-15docs: Fix some broken referencesMauro Carvalho Chehab
As we move stuff around, some doc references are broken. Fix some of them via this script: ./scripts/documentation-file-ref-check --fix Manually checked if the produced result is valid, removing a few false-positives. Acked-by: Takashi Iwai <tiwai@suse.de> Acked-by: Masami Hiramatsu <mhiramat@kernel.org> Acked-by: Stephen Boyd <sboyd@kernel.org> Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Acked-by: Mathieu Poirier <mathieu.poirier@linaro.org> Reviewed-by: Coly Li <colyli@suse.de> Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org> Acked-by: Jonathan Corbet <corbet@lwn.net>
2018-03-23media: zr364xx: avoid casting just to print pointer addressMauro Carvalho Chehab
Instead of casting, just use %p. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-11-27media: annotate ->poll() instancesAl Viro
2017-09-23media: drivers: Adjust checks for null pointersMarkus Elfring
The script “checkpatch.pl” pointed information out like the following. Comparison to NULL could be written !… Thus fix the affected source code places. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Hans Verkuil <hansverk@cisco.com>
2017-09-23media: drivers: improve a size determinationMarkus Elfring
Replace the specification of a data structure by a pointer dereference as the parameter for the operator "sizeof" to make the corresponding size determination a bit safer according to the Linux coding style convention. This issue was detected by using the Coccinelle software. [mchehab@s-opensoure.com: merge similar patches into one] Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Hans Verkuil <hansverk@cisco.com>
2017-09-23media: drivers: delete error messages for failed memory allocationMarkus Elfring
Omit an extra message for a memory allocation failure in this function. This issue was detected by using the Coccinelle software. [mchehab@s-opensource.com: fold several similar patches into one] Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Hans Verkuil <hansverk@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-08-27media: usb: make video_device constBhumika Goyal
Make these const as they are only used during a copy operation. Signed-off-by: Bhumika Goyal <bhumirks@gmail.com> Acked-by: Mike Isely <isely@pobox.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-08-20media: zr364xx: constify videobuf_queue_ops structuresJulia Lawall
These videobuf_queue_ops structures are only passed as the second argument to videobuf_queue_vmalloc_init, which is declared as const. Thus the videobuf_queue_ops structures themselves can be const. Done with the help of Coccinelle. // <smpl> @r disable optional_qualifier@ identifier i; position p; @@ static struct videobuf_queue_ops i@p = { ... }; @ok1@ identifier r.i; expression e1; position p; @@ videobuf_queue_vmalloc_init(e1,&i@p,...) @bad@ position p != {r.p,ok1.p}; identifier r.i; struct videobuf_queue_ops e; @@ e@i@p @depends on !bad disable optional_qualifier@ identifier r.i; @@ static +const struct videobuf_queue_ops i = { ... }; // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-08-20media: usb: constify usb_device_idArvind Yadav
usb_device_id are not supposed to change at runtime. All functions working with usb_device_id provided by <linux/usb.h> work with const usb_device_id. So mark the non-const structs as const. 'drivers/media/usb/b2c2/flexcop-usb.c' Fix checkpatch.pl error: ERROR: space prohibited before open square bracket '['. Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com> Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-04-18[media] zr364xx: enforce minimum size when reading headerAlyssa Milburn
This code copies actual_length-128 bytes from the header, which will underflow if the received buffer is too small. Signed-off-by: Alyssa Milburn <amilburn@zall.org> Cc: stable@vger.kernel.org Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-01-27[media] media: Drop FSF's postal address from the source code filesSakari Ailus
Drop the FSF's postal address from the source code files that typically contain mostly the license text. Of the 628 removed instances, 578 are outdated. The patch has been created with the following command without manual edits: git grep -l "675 Mass Ave\|59 Temple Place\|51 Franklin St" -- \ drivers/media/ include/media|while read i; do i=$i perl -e ' open(F,"< $ENV{i}"); $a=join("", <F>); $a =~ s/[ \t]*\*\n.*You should.*\n.*along with.*\n.*(\n.*USA.*$)?\n//m && $a =~ s/(^.*)Or, (point your browser to) /$1To obtain the license, $2\n$1/m; close(F); open(F, "> $ENV{i}"); print F $a; close(F);'; done Signed-off-by: Sakari Ailus <sakari.ailus@linux.intel.com>
2016-10-21[media] zr364xx: don't break long linesMauro Carvalho Chehab
Due to the 80-cols restrictions, and latter due to checkpatch warnings, several strings were broken into multiple lines. This is not considered a good practice anymore, as it makes harder to grep for strings at the source code. As we're right now fixing other drivers due to KERN_CONT, we need to be able to identify what printk strings don't end with a "\n". It is a way easier to detect those if we don't break long lines. So, join those continuation lines. The patch was generated via the script below, and manually adjusted if needed. </script> use Text::Tabs; while (<>) { if ($next ne "") { $c=$_; if ($c =~ /^\s+\"(.*)/) { $c2=$1; $next =~ s/\"\n$//; $n = expand($next); $funpos = index($n, '('); $pos = index($c2, '",'); if ($funpos && $pos > 0) { $s1 = substr $c2, 0, $pos + 2; $s2 = ' ' x ($funpos + 1) . substr $c2, $pos + 2; $s2 =~ s/^\s+//; $s2 = ' ' x ($funpos + 1) . $s2 if ($s2 ne ""); print unexpand("$next$s1\n"); print unexpand("$s2\n") if ($s2 ne ""); } else { print "$next$c2\n"; } $next=""; next; } else { print $next; } $next=""; } else { if (m/\"$/) { if (!m/\\n\"$/) { $next=$_; next; } } } print $_; } </script> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2016-08-24[media] media: usb: zr364xx: zr364xx: don't print error when allocating urb ↵Wolfram Sang
fails kmalloc will print enough information in case of failure. Signed-off-by: Wolfram Sang <wsa-dev@sang-engineering.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2015-06-09[media] usb drivers: use BUG_ON() instead of if () BUGMauro Carvalho Chehab
Some USB drivers have a logic at the VB buffer handling like: if (in_interrupt()) BUG(); Use, instead: BUG_ON(in_interrupt()); Btw, this logic looks weird on my eyes. We should convert them to use VB2, in order to avoid those crappy things. Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Acked-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2014-12-23[media] media: drivers shouldn't touch debug field in video_deviceHans Verkuil
The debug field in struct video_device is for internal use only and drivers should mix that with their own debug module options. It is handled by the V4L2 core and users can set it using /sys/class/video4linux/<devX>/debug. It has been deprecated for some time now, so it is time to remove it completely from the drivers. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2014-07-17[media] v4l: Support extending the v4l2_pix_format structureLaurent Pinchart
The v4l2_pix_format structure has no reserved field. It is embedded in the v4l2_framebuffer structure which has no reserved fields either, and in the v4l2_format structure which has reserved fields that were not previously required to be zeroed out by applications. To allow extending v4l2_pix_format, inline it in the v4l2_framebuffer structure, and use the priv field as a magic value to indicate that the application has set all v4l2_pix_format extended fields and zeroed all reserved fields following the v4l2_pix_format field in the v4l2_format structure. The availability of this API extension is reported to userspace through the new V4L2_CAP_EXT_PIX_FORMAT capability flag. Just checking that the priv field is still set to the magic value at [GS]_FMT return wouldn't be enough, as older kernels don't zero the priv field on return. To simplify the internal API towards drivers zero the extended fields and set the priv field to the magic value for applications not aware of the extensions. Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-04[media] media: remove the setting of the flag V4L2_FL_USE_FH_PRIORamakrishnan Muthukrishnan
Since all the drivers that use `struct v4l2_fh' use the core priority checking, the setting of the flag in the drivers can be removed. Signed-off-by: Ramakrishnan Muthukrishnan <ramakrmu@cisco.com> Reviewed-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2012-12-21[media] v4l: Convert drivers to use monotonic timestampsSakari Ailus
Convert drivers using wall clock time (CLOCK_REALTIME) to timestamp from the monotonic timer (CLOCK_MONOTONIC). Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-10-28[media] zr364xx: urb actual_length is unsignedMauro Carvalho Chehab
drivers/media/usb/zr364xx/zr364xx.c:1010:2: warning: comparison of unsigned expression < 0 is always false [-Wtype-limits] Cc: Antoine Jacquet <royale@zerezo.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-15[media] move the remaining USB drivers to drivers/media/usbMauro Carvalho Chehab
Move the 3 remaining usb drivers to their proper space. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
