path: root/drivers/media/v4l2-core/videobuf2-memops.c
2016-10-19mm: replace get_vaddr_frames() write/force parameters with gup_flagsLorenzo Stoakes
This removes the 'write' and 'force' from get_vaddr_frames() and replaces them with 'gup_flags' to make the use of FOLL_FORCE explicit in callers as use of this flag can result in surprising behaviour (and hence bugs) within the mm subsystem. Signed-off-by: Lorenzo Stoakes <lstoakes@gmail.com> Acked-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-04-25[media] vb2-memops: Fix over allocation of frame vectorsRicardo Ribalda
On page unaligned frames, create_framevec forces get_vaddr_frames to allocate an extra page at the end of the buffer. Under some circumstances, this leads to -EINVAL on VIDIOC_QBUF. E.g: We have vm_a that vm_area that goes from 0x1000 to 0x3000. And a frame that goes from 0x1800 to 0x2800, i.e. 2 pages. frame_vector_create will be called with the following params: get_vaddr_frames(0x1800, 2, write, 1, vec); get_vaddr will allocate the first page after checking that the memory 0x1800-0x27ff is valid, but it will not allocate the second page because the range 0x2800-0x37ff is out of the vm_a range. This results in create_framevec returning -EFAULT Error Trace: [ 9083.793015] video0: VIDIOC_QBUF: 00:00:00.00000000 index=1, type=vid-cap, flags=0x00002002, field=any, sequence=0, memory=userptr, bytesused=0, offset/userptr=0x7ff2b023ca80, length=5765760 [ 9083.793028] timecode=00:00:00 type=0, flags=0x00000000, frames=0, userbits=0x00000000 [ 9083.793117] video0: VIDIOC_QBUF: error -22: 00:00:00.00000000 index=2, type=vid-cap, flags=0x00000000, field=any, sequence=0, memory=userptr, bytesused=0, offset/userptr=0x7ff2b07bc500, length=5765760 Also use true instead of 1 since that argument is a bool in the get_vaddr_frames() prototype. Fixes: 21fb0cb7ec65 ("[media] vb2: Provide helpers for mapping virtual addresses") Reported-by: Albert Antony <albert@newtec.dk> Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> [hans.verkuil@cisco.com: merged the 'bool' change into this patch] Acked-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: Jan Kara <jack@suse.cz> Cc: <stable@vger.kernel.org> # for v4.3 and up Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-10-01[media] media: videobuf2: Replace videobuf2-core with videobuf2-v4l2Junghak Sung
Make videobuf2-v4l2 as a wrapper of videobuf2-core for v4l2-use. And replace videobuf2-core.h with videobuf2-v4l2.h. This renaming change should be accompanied by the modifications of all device drivers that include videobuf2-core.h. It can be done with just running this shell script. replace() { str1=$1 str2=$2 dir=$3 for file in $(find $dir -name *.h -o -name *.c -o -name Makefile) do echo $file sed "s/$str1/$str2/g" $file > $file.out mv $file.out $file done } replace "videobuf2-core" "videobuf2-v4l2" "include/media/" replace "videobuf2-core" "videobuf2-v4l2" "drivers/media/" replace "videobuf2-core" "videobuf2-v4l2" "drivers/usb/gadget/" replace "videobuf2-core" "videobuf2-v4l2" "drivers/staging/media/" Signed-off-by: Junghak Sung <jh1009.sung@samsung.com> Signed-off-by: Geunyoung Kim <nenggun.kim@samsung.com> Acked-by: Seung-Woo Kim <sw0312.kim@samsung.com> Acked-by: Inki Dae <inki.dae@samsung.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-08-16[media] media: vb2: Remove unused functionsJan Kara
Conversion to the use of pinned pfns made some functions unused. Remove them. Also there's no need to lock mmap_sem in __buf_prepare() anymore. Tested-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-08-16[media] vb2: Provide helpers for mapping virtual addressesJan Kara
Provide simple helper functions to map virtual address range into an array of pfns / pages. Tested-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-04-08Revert "[media] v4l: vb2-memops: use vma slab when vma allocation"Mauro Carvalho Chehab
Please revert this patch: vm_area_cachep is not exported, so you cannot use this in a module. This reverts commit 5ed1c328ea077d70e1ebcd5188dc77cdc754df3a. Reported-by: Hans Verkuil <hverkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-04-08[media] v4l: vb2-memops: use vma slab when vma allocationKyongHo Cho
The slab for vm_area_struct which is vm_area_cachep is already prepared for the general use. Instead of kmalloc() for the vma copy for userptr, allocation from vm_area_cachep is more beneficial. CC: Hans Verkuil <hans.verkuil@cisco.com> CC: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Cho KyongHo <pullip.cho@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2012-11-25[media] v4l: vb2-dma-contig: let mmap method to use dma_mmap_coherent callMarek Szyprowski
Let mmap method to use dma_mmap_coherent call. Moreover, this patch removes vb2_mmap_pfn_range from videobuf2 helpers as it was suggested by Laurent Pinchart. The function is no longer used in vb2 code. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Tomasz Stanislawski <t.stanislaws@samsung.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-10-09mm: kill vma flag VM_RESERVED and mm->reserved_vm counterKonstantin Khlebnikov
A long time ago, in v2.4, VM_RESERVED kept swapout process off VMA, currently it lost original meaning but still has some effects: | effect | alternative flags -+------------------------+--------------------------------------------- 1| account as reserved_vm | VM_IO 2| skip in core dump | VM_IO, VM_DONTDUMP 3| do not merge or expand | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP 4| do not mlock | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP This patch removes reserved_vm counter from mm_struct. Seems like nobody cares about it, it does not exported into userspace directly, it only reduces total_vm showed in proc. Thus VM_RESERVED can be replaced with VM_IO or pair VM_DONTEXPAND | VM_DONTDUMP. remap_pfn_range() and io_remap_pfn_range() set VM_IO|VM_DONTEXPAND|VM_DONTDUMP. remap_vmalloc_range() set VM_DONTEXPAND | VM_DONTDUMP. [akpm@linux-foundation.org: drivers/vfio/pci/vfio_pci.c fixup] Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Eric Paris <eparis@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Venkatesh Pallipadi <venki@google.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-08-13[media] v4l: move v4l2 core into a separate directoryMauro Carvalho Chehab
Currently, the v4l2 core is mixed together with other non-core drivers. Move them into a separate directory. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
