Fix the following compilation failure:
linux-2.6/drivers/media/video/mt9m032.c: In function '__mt9m032_get_pad_crop':
linux-2.6/drivers/media/video/mt9m032.c:337: error: implicit declaration of function 'v4l2_subdev_get_try_crop'
linux-2.6/drivers/media/video/mt9m032.c:337: warning: return makes pointer from integer without a cast
linux-2.6/drivers/media/video/mt9m032.c: In function '__mt9m032_get_pad_format':
linux-2.6/drivers/media/video/mt9m032.c:359: error: implicit declaration of function 'v4l2_subdev_get_try_format'
linux-2.6/drivers/media/video/mt9m032.c:359: warning: return makes pointer from integer without a cast
linux-2.6/drivers/media/video/mt9m032.c: In function 'mt9m032_probe':
linux-2.6/drivers/media/video/mt9m032.c:767: error: 'struct v4l2_subdev' has no member named 'entity'
linux-2.6/drivers/media/video/mt9m032.c:826: error: 'struct v4l2_subdev' has no member named 'entity'
linux-2.6/drivers/media/video/mt9m032.c: In function 'mt9m032_remove':
linux-2.6/drivers/media/video/mt9m032.c:842: error: 'struct v4l2_subdev' has no member named 'entity'
make[4]: *** [drivers/media/video/mt9m032.o] Error 1
by adding a dependency on VIDEO_V4L2_SUBDEV_API.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
The MT9M032 is a parallel 1.6MP sensor from Micron controlled through I2C.
The driver creates a V4L2 subdevice. It currently supports cropping, gain,
exposure and v/h flipping controls in monochrome mode with an
external pixel clock.
[Lots of clean up, fixes and enhancements]
Signed-off-by: Martin Hostettler <martin@neutronstar.dyndns.org>
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Acked-by: Sakari Ailus <sakari.ailus@iki.fi>
Compute the PLL parameters at runtime using the generic Aptina PLL
helper.
Add a generic helper function to compute PLL parameters for PLL found in
several Aptina sensors.
Fix the following build error:
LD .tmp_vmlinux1
drivers/built-in.o: In function `mx2_camera_init_videobuf':
clkdev.c:(.text+0xcfaf4): undefined reference to `vb2_dma_contig_memops'
drivers/built-in.o: In function `mx2_camera_probe':
clkdev.c:(.devinit.text+0x5734): undefined reference to `vb2_dma_contig_init_ctx'
clkdev.c:(.devinit.text+0x5778): undefined reference to `vb2_dma_contig_cleanup_ctx'
drivers/built-in.o: In function `mx2_camera_remove':
clkdev.c:(.devexit.text+0x89c): undefined reference to `vb2_dma_contig_cleanup_ctx'
commit c6a41e3271 ([media] media i.MX27 camera: migrate driver to videobuf2)
missed to select VIDEOBUF2_DMA_CONTIG in Kconfig.
This is a v4l2 bridge driver for Blackfin video capture device, support ppi and eppi interface.
Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com>
This is a v4l2 sensor-level driver for the ST VS6624 camera.
This driver is a v4l2 subdevice driver to support Analog Devices ADV7183 SDTV video decoder.
The driver used the regulator API so it should depend on REGULATOR.
[mchehab@redhat.com: break depends on on two lines, instead of using a \]
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
i.MX2x SoCs have a PrP which is capable of resizing and format
conversion of video frames. This driver provides support for
resizing and format conversion from YUYV to YUV420.
This operation is of the utmost importance since some of these
SoCs like i.MX27 include an H.264 video codec which only
accepts YUV420 as input.
Signed-off-by: Javier Martin <javier.martin@vista-silicon.com>
Add driver for the JPEG codec IP block available in Samsung Exynos SoC series.
The driver is implemented as a V4L2 mem-to-mem device. It exposes two video
nodes to user space, one for the encoding part, and one for the decoding part.
Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com>
Reviewed-by: Sakari Ailus <sakari.ailus@iki.fi>
Reviewed-by: Tomasz Stanislawski <t.stanislaws@samsung.com>
This patch adds the driver for the as3645a LED flash controller. This
controller supports a high power led in flash and torch modes and an
indicator light, sometimes also called privacy light.
Signed-off-by: Nayden Kanchev <nkanchev@mm-sol.com>
Signed-off-by: Tuukka Toivonen <tuukkat76@gmail.com>
Signed-off-by: Antti Koskipaa <antti.koskipaa@gmail.com>
Signed-off-by: Stanimir Varbanov <svarbanov@mm-sol.com>
Signed-off-by: Vimarsh Zutshi <vimarsh.zutshi@gmail.com>
Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi>
Signed-off-by: Ivan T. Ivanov <iivanov@mm-sol.com>
Signed-off-by: Mika Westerberg <ext-mika.1.westerberg@nokia.com>
Signed-off-by: David Cohen <dacohen@gmail.com>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Thanks to Guennadi Liakhovetski <g.liakhovetski@gmx.de> for pointing this
out to me.
These are really, really old drivers. These are really no longer experimental...
USB webcams are some of the most used V4L devices, so move it to a more
prominent place in the menu instead of being at the end.
G2D is a 2D graphics accelerator engine present in the s5p family
of Samsung SoCs. It is capable of bitblt and raster operations on
images having dimensions of up to 8000x8000.
Signed-off-by: Kamil Debski <k.debski@samsung.com>
This driver exposes preview mode operation of the S5K6AAFX sensor with
embedded SoC ISP. The native capture (snapshot) operation mode is not
supported.
Following controls are available:
manual/auto exposure and gain, power line frequency (anti-flicker),
saturation, sharpness, brightness, contrast, white balance temperature,
color effects, horizontal/vertical image flip, frame interval,
auto white balance.
RGB component gains are currently exposed through private controls.
This driver had the major issues already fixed. Move it out
of staging.
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (348 commits)
[media] pctv452e: Remove bogus code
[media] adv7175: Make use of media bus pixel codes
[media] media: vb2: fix incorrect return value
[media] em28xx: implement VIDIOC_ENUM_FRAMESIZES
[media] cx23885: Stop the risc video fifo before reconfiguring it
[media] cx23885: Avoid incorrect error handling and reporting
[media] cx23885: Avoid stopping the risc engine during buffer timeout
[media] cx23885: Removed a spurious function cx23885_set_scale()
[media] cx23885: v4l2 api compliance, set the audioset field correctly
[media] cx23885: hook the audio selection functions into the main driver
[media] cx23885: add generic functions for dealing with audio input selection
[media] cx23885: fixes related to maximum number of inputs and range checking
[media] cx23885: Initial support for the MPX-885 mini-card
[media] cx25840: Ensure AUDIO6 and AUDIO7 trigger line-in baseband use
[media] cx23885: Enable audio line in support from the back panel
[media] cx23885: Allow the audio mux config to be specified on a per input basis
[media] cx25840: Enable support for non-tuner LR1/LR2 audio inputs
[media] cx23885: Name an internal i2c part and declare a bitfield by name
[media] cx23885: Ensure VBI buffers timeout quickly - bugfix for vbi hangs during streaming
[media] cx23885: remove channel dump diagnostics when a vbi buffer times out
Fix up trivial conflicts in drivers/misc/altera-stapl/altera.c (header
file rename vs add)
Both mt9t001.c and mt9p031.c have two identical issues, those
being that they will need module.h inclusion for the upcoming
cleanup going on there, and that their dependencies don't limit
selection of configs that will fail to compile as follows:
The related config options are CONFIG_MEDIA_CONTROLLER and
CONFIG_VIDEO_V4L2_SUBDEV_API. Looking at the code, it appears
that the driver was never intended to work without these enabled,
so add a dependency on CONFIG_VIDEO_V4L2_SUBDEV_API, which in
turn already has a dependency on CONFIG_MEDIA_CONTROLLER.
Reported-by: Randy Dunlap <rdunlap@xenotime.net>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
The serious bugs got fixed already.
The MT9T001 is a parallel 3MP sensor from Aptina (formerly Micron)
The driver creates a V4L2 subdevice. It currently supports binning and
cropping, and the gain, exposure, test pattern and black level controls.
SR030PC30, NOON010PC30, M5MOLS are camera sensors so better place
for them is under the "Camera sensors" Kconfig section.
Replace g/s_mbus_fmt ops with the pad level get/set_fmt operations.
Add media entity initialization and set subdev flags so the host driver
creates a subdev device node for the driver.
A mutex was added for serializing the subdev operations. When setting
format is attempted during streaming an (EBUSY) error will be returned.
After the device is powered up it will now remain in "power sleep"
mode until s_stream(1) is called. The "power sleep" mode is used
to suspend/resume frame generation at the sensor's output through
s_stream op.
Without this patch it is possible to select the VIDEO_OMAP3
driver which then selects OMAP_IOVMM. But the omap iommu
driver is not compiled without IOMMU_SUPPORT enabled. Fix
that by forcing OMAP_IOMMU and OMAP_IOVMM are enabled before
VIDEO_OMAP3 can be selected.
Cc: Ohad Ben-Cohen <ohad@wizery.com>
Cc: iommu@lists.linux-foundation.org
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
The MT9P031 is a parallel 12-bit 5MP sensor from Aptina (formerly
Micron) controlled through I2C.
The driver creates a V4L2 subdevice. It currently supports skipping,
cropping, automatic binning, and gain, exposure, h/v flip and test
pattern controls.
Add a top level media device driver aggregating FIMC video devnodes,
MIPI-CSIS and sensor subdevs. This driver gathers all media entities
and creates the possible links between them during initialization. By
default some links will be activated to enable access to all available
sensors in the system. For example if there are sensors S0, S1 listed
in the media device platform data definition they will be by default
assigned to FIMC0, FIMC1 respectively, which in turn will corresponds
to separate /dev/video?.
There is enough FIMC H/W entities to cover all available physical camera
interfaces in the system.
The fimc media device driver is bound to the "s5p-fimc-md" platform device.
Such platform device should be created by board initialization code
and camera sensors description array need to be specified as its
platform data.
The media device driver also implements various video pipeline operations,
for enabling subdevs power, streaming, etc., which will be used by the
capture video node driver.
Add runtime PM and system sleep support in the memory-to-memory
driver. It's required to enable the FIMC operation on Exynos4
SoCs. This patch prevents system boot failure when the driver
is compiled in, as it now tries to access its I/O memory without
first enabling the corresponding power domain.
The camera capture device suspend/resume is not fully covered,
the capture device is just powered on/off during the video
node open/close. However this enables it's normal operation
on Exynos4 SoCs.
[mchehab@redhat.com: fix a small checkpatch error]
Move OMAP's iommu drivers to the dedicated iommu drivers folder.
While OMAP's iovmm (virtual memory manager) driver does not strictly
belong to the iommu drivers folder, move it there as well, because
it's by no means OMAP-specific (in concept. technically it is still
coupled with OMAP's iommu).
Eventually, iovmm will be completely replaced with the generic,
iommu-based, dma-mapping API.
Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
Acked-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
This is an initial driver release for the Omnivision 5642 CMOS sensor.
Signed-off-by: Bastian Hecht <hechtb@gmail.com>
Add drivers for HDMI outputs on Samsung platforms from S5P family.
Drivers are using:
- v4l2 framework
- runtime PM
Signed-off-by: Tomasz Stanislawski <t.stanislaws@samsung.com>
Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com>
Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl>
Multi Format Codec 5.1 is a hardware video coding acceleration
module found in the S5PV210 and Exynos4 Samsung SoCs. It is
capable of handling a range of video codecs and this driver
provides a V4L2 interface for video decoding and encoding.
Cc: Jeongtae Park <jtp.park@samsung.com>
This patch adds the driver for the adp1653 LED flash controller. This
The adp1653 is used on the Nokia N900.
This patch is to enable Atmel Image Sensor Interface (ISI) driver support.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
This driver will soon become a family of drivers, so let's give it its own
place to live. This move requires putting ov7670.h into include/media, but
there are no code changes.
Cc: Daniel Drake <dsd@laptop.org>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
s5p-csis is to be built only on S5P SoC platforms.
Fix kconfig unmet dependency warning:
warning: (VIDEO_TIMBERDALE) selects TIMB_DMA which has unmet direct dependencies (DMADEVICES && (MFD_TIMBERDALE || HAS_IOMEM))
Cc: Pelagicore AB <info@pelagicore.com>
Add I2C/V4L2 subdev driver for M-5MOLS integrated image signal processor
with 8 Mega Pixel sensor.
Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com>
The helper chips are classified by their function. Unfortunaltely,
with time, developers added their stuff into the wrong places.
Fix it by moving itens to be at the right place. Also add a new
category for sensors and for misc devices that are found only on
a certain specific board.
While here, fix two bad whitespaces at Kconfig.
Add the subdev driver for the MIPI CSIS units available in S5P and
Exynos4 SoC series. This driver supports both CSIS0 and CSIS1
MIPI-CSI2 receivers.
The driver requires Runtime PM to be enabled for proper operation.
s5p-fimc now also implements a camera capture video node so move
it under the "Video capture devices" Kconfig menu. Also update
the entry to reflect the driver's coverage of EXYNOS4 SoCs and
separate the Makefile entry from the soc-camera drivers set.
Signed-off-by: Oliver Endriss <o.endriss@gmx.de>
The MT9V032 is a parallel wide VGA sensor from Aptina (formerly Micron)
cropping, and the gain, auto gain, exposure, auto exposure and test
pattern controls.
Signed-off-by: Detlev Casanova <detlev.casanova@gmail.com>
VIDEOBUF_DMA_CONTIG
Since commit
379fa5d ([media] V4L: mx3_camera: convert to videobuf2)
mx3_camera uses videobuf2, but that commit didn't upgrade the select
resulting in the following build failure:
drivers/built-in.o: In function `mx3_camera_init_videobuf':
clkdev.c:(.text+0x86580): undefined reference to `vb2_dma_contig_memops'
drivers/built-in.o: In function `mx3_camera_probe':
clkdev.c:(.devinit.text+0x3548): undefined reference to `vb2_dma_contig_init_ctx'
clkdev.c:(.devinit.text+0x3578): undefined reference to `vb2_dma_contig_cleanup_ctx'
drivers/built-in.o: In function `mx3_camera_remove':
clkdev.c:(.devexit.text+0x674): undefined reference to `vb2_dma_contig_cleanup_ctx'
make[2]: *** [.tmp_vmlinux1] Error 1
make[1]: *** [sub-make] Error 2
make: *** [all] Error 2
Add the OMAP3 ISP driver to the kernel build system.
Acked-by: Hans Verkuil <hverkuil@xs4all.nl>
This soc_camera driver is for Omnivision's OV9740 sensor. This initial
submission provides support for YUV422 output at 1280x720 (720p), which is
the sensor's native resolution. 640x480 (VGA) is also supported, with
cropping and scaling performed by the sensor's ISP.
This driver is heavily based off of the existing OV9640 driver.
Signed-off-by: Andrew Chew <achew@nvidia.com>
