path: root/drivers/media/video/Makefile
2012-08-15[media] rename drivers/media/video as .../platformMauro Carvalho Chehab
The remaining drivers are mostly platform drivers. Name the dir to reflect it. It makes sense to latter break it into a few other dirs. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-15[media] move soc_camera i2c drivers into its own dirMauro Carvalho Chehab
Move all soc_camera i2c drivers into drivers/media/i2c/soc_camera/. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-15[media] move i2c files into drivers/media/i2cMauro Carvalho Chehab
Move ancillary I2C drivers into drivers/media/i2c, in order to better organize them. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-15[media] move parallel port/isa video drivers to drivers/media/parport/Mauro Carvalho Chehab
We should keep just the I2C drivers under drivers/media/video, and then rename it to drivers/media/i2c. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-15[media] move the remaining PCI devices to drivers/media/pciMauro Carvalho Chehab
Move meye and sta2x11_vip into the drivers/media/pci subdirs. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-15[media] move analog PCI saa7146 drivers to its own dirMauro Carvalho Chehab
Instead of having them under drivers/media/video, move them to their own directory. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-15[media] rename most media/video pci drivers to media/pciMauro Carvalho Chehab
Rename all PCI drivers with their own directory under drivers/media/video into drivers/media/pci and update the building system. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-15[media] bt8xx: move analog TV part to be together with DTV oneMauro Carvalho Chehab
2012-08-15[media] move the remaining USB drivers to drivers/media/usbMauro Carvalho Chehab
Move the 3 remaining usb drivers to their proper space. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-15[media] rename most media/video usb drivers to media/usbMauro Carvalho Chehab
Rename all USB drivers with their own directory under drivers/media/video into drivers/media/usb and update the building system. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-13[media] common: move media/common/tuners to media/tunersMauro Carvalho Chehab
Move the tuners one level up, as the "common" directory will be used by drivers that are shared between more than one driver. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-13[media] move the dvb/frontends to drivers/media/dvb-frontendsMauro Carvalho Chehab
Raise the DVB frontends one level up, as the intention is to remove the drivers/media/dvb directory. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-13[media] dvb: move the dvb core one level upMauro Carvalho Chehab
just like the V4L2 core, move the DVB core to drivers/media, as the intention is to get rid of both "video" and "dvb" directories. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-13[media] v4l: move v4l2 core into a separate directoryMauro Carvalho Chehab
Currently, the v4l2 core is mixed together with other non-core drivers. Move them into a separate directory. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-12[media] media: Add stk1160 new driver (easycap replacement)Ezequiel García
This driver adds support for stk1160 usb bridge as used in some video/audio usb capture devices. It is a complete rewrite of staging/media/easycap driver and it's meant as a replacement. As stk1160 allows communication with an ac97 codec chip, this driver allows to register a control-only sound card to allow the user to access ac97 controls. Two devices have been used for testing: * 1-cvbs video and 1-audio ac97 input, * 4-cvbs inputs Both of these devices reports with the same id [05e1:0408], so the driver tries to support a superset of the capabilities. By using keep_buffers module parameter it's possible to prevent the driver from releasing urb buffers when streaming is stopped. The usage of this parameter can avoid memory fragmentation that may cause the driver to stop working on low memory systems. A similar mechanism is implemented in em28xx driver (see commit 86d38d). Signed-off-by: Ezequiel Garcia <elezegarcia@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-06[media] media: Add mem2mem deinterlacing driverJavier Martin
Some video decoders such as tvp5150 provide separate video fields (V4L2_FIELD_SEQ_TB/BT). This driver uses dmaengine to convert this format to V4L2_FIELD_INTERLACED_TB/BT (weaving) or V4L2_FIELD_NONE (line doubling) so that the image can be displayed or processed. Of course there will be combing effect in the image but this can be accepted for some low quality applications. Currently only YUV420 and YUYV formats are supported but it can be extended later. Signed-off-by: Javier Martin <javier.martin@vista-silicon.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-06[media] media: coda: Add driver for Coda video codecJavier Martin
Coda is a range of video codecs from Chips&Media that support H.264, H.263, MPEG4 and other video standards. Currently only support for the codadx6 included in the i.MX27 SoC is added. H.264 and MPEG4 video encoding are the only supported capabilities by now. [mchehab@redhat.com: Add missing include linux/of.h] Signed-off-by: Javier Martin <javier.martin@vista-silicon.com> Reviewed-by: Philipp Zabel<p.zabel@pengutronix.de> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-07-06[PATCH] media: add Analog Devices ADV7393 video encoder driverBenoît Thébaudeau
Add ADV7393 I²C-based video encoder driver. This driver has been tested on custom hardware. It has been tested for composite output. It is derived from the ADV7343 driver. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-20[media] STA2X11 VIP: new V4L2 driverFederico Vaga
V4L2 driver for the Video Input Port within STA2X11 board Signed-off-by: Federico Vaga <federico.vaga@gmail.com> Acked-by: Giancarlo Asnaghi <giancarlo.asnaghi@st.com> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-14[media] smiapp: Add driverSakari Ailus
Add driver for SMIA++/SMIA image sensors. The driver exposes the sensor as three subdevs, pixel array, binner and scaler --- in case the device has a scaler. Currently it relies on the board code for external clock handling. There is no fast way out of this dependency before the ISP drivers (omap3isp) among others will be able to export that clock through the clock framework instead. Signed-off-by: Sakari Ailus <sakari.ailus@maxwell.research.nokia.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-14[media] smiapp: Generic SMIA++/SMIA PLL calculatorSakari Ailus
Calculate PLL configuration based on input data: sensor configuration, board properties and sensor-specific limits. [mchehab@redhat.com: Fix a Kconfig conflict affecting APTINA_PLL] Signed-off-by: Sakari Ailus <sakari.ailus@maxwell.research.nokia.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-07[media] media/video/et61x251: Remove this deprecated driverHans de Goede
The et61x251 has been deprecated for a couple of releases now, as all devices it supports are also supported by gspca_etoms, and it has not seen any maintenance in years. So now it is time to remove it. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-19[media] v4l: Add driver for Micron MT9M032 camera sensorMartin Hostettler
The MT9M032 is a parallel 1.6MP sensor from Micron controlled through I2C. The driver creates a V4L2 subdevice. It currently supports cropping, gain, exposure and v/h flipping controls in monochrome mode with an external pixel clock. [Lots of clean up, fixes and enhancements] Signed-off-by: Martin Hostettler <martin@neutronstar.dyndns.org> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Acked-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-19[media] v4l: Aptina-style sensor PLL supportLaurent Pinchart
Add a generic helper function to compute PLL parameters for PLL found in several Aptina sensors. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-19[media] add blackfin capture bridge driverScott Jiang
This is a v4l2 bridge driver for Blackfin video capture device, support ppi and eppi interface. Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-19[media] vs6624: add vs6624 sensor driverScott Jiang
This is a v4l2 sensor-level driver for the ST VS6624 camera. Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-19[media] adv7183: add adv7183 decoder driverScott Jiang
This driver is a v4l2 subdevice driver to support Analog Devices ADV7183 SDTV video decoder. Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-19[media] v4l: Add custom compat_ioctl32 operationLaurent Pinchart
Drivers implementing custom ioctls need to handle 32-bit/64-bit compatibility themselves. Provide them with a way to do so. To avoid circular module dependencies, merge the v4l2-compat-ioctl32 module into videodev. There is no point in keeping them separate, as the v4l2_compat_ioctl32() function is required by videodev if CONFIG_COMPAT is set anyway. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Reviewed-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-08[media] media: video: append $(srctree) to -I parametersAndy Shevchenko
Without this we have got the warnings like following if build with "make W=1 O=/var/tmp": CHECK drivers/media/video/videobuf-vmalloc.c CC [M] drivers/media/video/videobuf-vmalloc.o +cc1: warning: drivers/media/dvb/dvb-core: No such file or directory [enabled by default] +cc1: warning: drivers/media/dvb/frontends: No such file or directory [enabled by default] +cc1: warning: drivers/media/dvb/dvb-core: No such file or directory [enabled by default] +cc1: warning: drivers/media/dvb/frontends: No such file or directory [enabled by default] LD drivers/media/built-in.o Some details could be found in [1] as well. [1] http://comments.gmane.org/gmane.linux.kbuild.devel/7733 Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-02-28[media] MEM2MEM: Add support for eMMa-PrP mem2mem operationsJavier Martin
i.MX2x SoCs have a PrP which is capable of resizing and format conversion of video frames. This driver provides support for resizing and format conversion from YUYV to YUV420. This operation is of the utmost importance since some of these SoCs like i.MX27 include an H.264 video codec which only accepts YUV420 as input. Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Javier Martin <javier.martin@vista-silicon.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-01-10[media] Exynos4 JPEG codec v4l2 driverAndrzej Pietrasiewicz
Add driver for the JPEG codec IP block available in Samsung Exynos SoC series. The driver is implemented as a V4L2 mem-to-mem device. It exposes two video nodes to user space, one for the encoding part, and one for the decoding part. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Sakari Ailus <sakari.ailus@iki.fi> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Reviewed-by: Tomasz Stanislawski <t.stanislaws@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-12-20[media] as3645a: Add driver for LED flash controllerLaurent Pinchart
This patch adds the driver for the as3645a LED flash controller. This controller supports a high power led in flash and torch modes and an indicator light, sometimes also called privacy light. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Nayden Kanchev <nkanchev@mm-sol.com> Signed-off-by: Tuukka Toivonen <tuukkat76@gmail.com> Signed-off-by: Antti Koskipaa <antti.koskipaa@gmail.com> Signed-off-by: Stanimir Varbanov <svarbanov@mm-sol.com> Signed-off-by: Vimarsh Zutshi <vimarsh.zutshi@gmail.com> Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Ivan T. Ivanov <iivanov@mm-sol.com> Signed-off-by: Mika Westerberg <ext-mika.1.westerberg@nokia.com> Signed-off-by: David Cohen <dacohen@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-08[media] v4l: add G2D driver for s5p device familyKamil Debski
G2D is a 2D graphics accelerator engine present in the s5p family of Samsung SoCs. It is capable of bitblt and raster operations on images having dimensions of up to 8000x8000. Signed-off-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-03[media] v4l: Add v4l2 subdev driver for S5K6AAFX sensorSylwester Nawrocki
This driver exposes preview mode operation of the S5K6AAFX sensor with embedded SoC ISP. The native capture (snapshot) operation mode is not supported. Following controls are available: manual/auto exposure and gain, power line frequency (anti-flicker), saturation, sharpness, brightness, contrast, white balance temperature, color effects, horizontal/vertical image flip, frame interval, auto white balance. RGB component gains are currently exposed through private controls. Reviewed-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-03[media] move cx25821 out of stagingMauro Carvalho Chehab
This driver had the major issues already fixed. Move it out of staging. Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-23[media] move tm6000 to drivers/media/videoMauro Carvalho Chehab
The serious bugs got fixed already. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-21[media] mt9t001: Aptina (Micron) MT9T001 3MP sensor driverLaurent Pinchart
The MT9T001 is a parallel 3MP sensor from Aptina (formerly Micron) controlled through I2C. The driver creates a V4L2 subdevice. It currently supports binning and cropping, and the gain, exposure, test pattern and black level controls. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-11[media] mt9p031: Aptina (Micron) MT9P031 5MP sensor driverJavier Martin
The MT9P031 is a parallel 12-bit 5MP sensor from Aptina (formerly Micron) controlled through I2C. The driver creates a V4L2 subdevice. It currently supports skipping, cropping, automatic binning, and gain, exposure, h/v flip and test pattern controls. Signed-off-by: Javier Martin <javier.martin@vista-silicon.com> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-03[media] drivers/media: do not use EXTRA_CFLAGSArnaud Lacombe
Usage of these flags has been deprecated for nearly 4 years by: commit f77bf01425b11947eeb3b5b54685212c302741b8 Author: Sam Ravnborg <sam@neptun.(none)> Date: Mon Oct 15 22:25:06 2007 +0200 kbuild: introduce ccflags-y, asflags-y and ldflags-y Moreover, these flags (at least EXTRA_CFLAGS) have been documented for command line use. By default, gmake(1) do not override command line setting, so this is likely to result in build failure or unexpected behavior. Replace their usage by Kbuild's `{as,cc,ld}flags-y'. Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: linux-media@vger.kernel.org Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] V4L: initial driver for ov5642 CMOS sensorBastian Hecht
This is an initial driver release for the Omnivision 5642 CMOS sensor. Signed-off-by: Bastian Hecht <hechtb@gmail.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] v4l: s5p-tv: add drivers for HDMI on Samsung S5P platformTomasz Stanislawski
Add drivers for HDMI outputs on Samsung platforms from S5P family. Drivers are using: - v4l2 framework - runtime PM Signed-off-by: Tomasz Stanislawski <t.stanislaws@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] MFC: Add MFC 5.1 V4L2 driverKamil Debski
Multi Format Codec 5.1 is a hardware video coding acceleration module found in the S5PV210 and Exynos4 Samsung SoCs. It is capable of handling a range of video codecs and this driver provides a V4L2 interface for video decoding and encoding. Signed-off-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Jeongtae Park <jtp.park@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] adp1653: Add driver for LED flash controllerSakari Ailus
This patch adds the driver for the adp1653 LED flash controller. This controller supports a high power led in flash and torch modes and an indicator light, sometimes also called privacy light. The adp1653 is used on the Nokia N900. Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Tuukka Toivonen <tuukkat76@gmail.com> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: David Cohen <dacohen@gmail.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] V4L: at91: add Atmel Image Sensor Interface (ISI) supportJosh Wu
This patch is to enable Atmel Image Sensor Interface (ISI) driver support. Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] marvell-cam: Basic working MMP camera driverJonathan Corbet
Now we have a camera working over the marvell cam controller core. It works like the cafe driver and has all the same limitations, contiguous DMA only being one of them. But it's a start. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] marvell-cam: Move cafe-ccic into its own directoryJonathan Corbet
This driver will soon become a family of drivers, so let's give it its own place to live. This move requires putting ov7670.h into include/media, but there are no code changes. Cc: Daniel Drake <dsd@laptop.org> Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-25[media] Add support for M-5MOLS 8 Mega Pixel camera ISPHeungJun, Kim
Add I2C/V4L2 subdev driver for M-5MOLS integrated image signal processor with 8 Mega Pixel sensor. Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com> Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-20[media] v4l: Move s5p-fimc driver into Video capture devicesSylwester Nawrocki
s5p-fimc now also implements a camera capture video node so move it under the "Video capture devices" Kconfig menu. Also update the entry to reflect the driver's coverage of EXYNOS4 SoCs and separate the Makefile entry from the soc-camera drivers set. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-20[media] v4l: Add mt9v032 sensor driverDetlev Casanova
The MT9V032 is a parallel wide VGA sensor from Aptina (formerly Micron) controlled through I2C. The driver creates a V4L2 subdevice. It currently supports binning and cropping, and the gain, auto gain, exposure, auto exposure and test pattern controls. Signed-off-by: Detlev Casanova <detlev.casanova@gmail.com> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] omap3isp: Kconfig and MakefileLaurent Pinchart
Add the OMAP3 ISP driver to the kernel build system. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
