path: root/drivers/media/video/Makefile
2012-03-19[media] v4l: Add driver for Micron MT9M032 camera sensorMartin Hostettler
The MT9M032 is a parallel 1.6MP sensor from Micron controlled through I2C. The driver creates a V4L2 subdevice. It currently supports cropping, gain, exposure and v/h flipping controls in monochrome mode with an external pixel clock. [Lots of clean up, fixes and enhancements] Signed-off-by: Martin Hostettler <martin@neutronstar.dyndns.org> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Acked-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-19[media] v4l: Aptina-style sensor PLL supportLaurent Pinchart
Add a generic helper function to compute PLL parameters for PLL found in several Aptina sensors. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-19[media] add blackfin capture bridge driverScott Jiang
This is a v4l2 bridge driver for Blackfin video capture device, support ppi and eppi interface. Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-19[media] vs6624: add vs6624 sensor driverScott Jiang
This is a v4l2 sensor-level driver for the ST VS6624 camera. Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-19[media] adv7183: add adv7183 decoder driverScott Jiang
This driver is a v4l2 subdevice driver to support Analog Devices ADV7183 SDTV video decoder. Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-19[media] v4l: Add custom compat_ioctl32 operationLaurent Pinchart
Drivers implementing custom ioctls need to handle 32-bit/64-bit compatibility themselves. Provide them with a way to do so. To avoid circular module dependencies, merge the v4l2-compat-ioctl32 module into videodev. There is no point in keeping them separate, as the v4l2_compat_ioctl32() function is required by videodev if CONFIG_COMPAT is set anyway. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Reviewed-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-08[media] media: video: append $(srctree) to -I parametersAndy Shevchenko
Without this we have got the warnings like following if build with "make W=1 O=/var/tmp": CHECK drivers/media/video/videobuf-vmalloc.c CC [M] drivers/media/video/videobuf-vmalloc.o +cc1: warning: drivers/media/dvb/dvb-core: No such file or directory [enabled by default] +cc1: warning: drivers/media/dvb/frontends: No such file or directory [enabled by default] +cc1: warning: drivers/media/dvb/dvb-core: No such file or directory [enabled by default] +cc1: warning: drivers/media/dvb/frontends: No such file or directory [enabled by default] LD drivers/media/built-in.o Some details could be found in [1] as well. [1] http://comments.gmane.org/gmane.linux.kbuild.devel/7733 Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-02-28[media] MEM2MEM: Add support for eMMa-PrP mem2mem operationsJavier Martin
i.MX2x SoCs have a PrP which is capable of resizing and format conversion of video frames. This driver provides support for resizing and format conversion from YUYV to YUV420. This operation is of the utmost importance since some of these SoCs like i.MX27 include an H.264 video codec which only accepts YUV420 as input. Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Javier Martin <javier.martin@vista-silicon.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-01-10[media] Exynos4 JPEG codec v4l2 driverAndrzej Pietrasiewicz
Add driver for the JPEG codec IP block available in Samsung Exynos SoC series. The driver is implemented as a V4L2 mem-to-mem device. It exposes two video nodes to user space, one for the encoding part, and one for the decoding part. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Sakari Ailus <sakari.ailus@iki.fi> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Reviewed-by: Tomasz Stanislawski <t.stanislaws@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-12-20[media] as3645a: Add driver for LED flash controllerLaurent Pinchart
This patch adds the driver for the as3645a LED flash controller. This controller supports a high power led in flash and torch modes and an indicator light, sometimes also called privacy light. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Nayden Kanchev <nkanchev@mm-sol.com> Signed-off-by: Tuukka Toivonen <tuukkat76@gmail.com> Signed-off-by: Antti Koskipaa <antti.koskipaa@gmail.com> Signed-off-by: Stanimir Varbanov <svarbanov@mm-sol.com> Signed-off-by: Vimarsh Zutshi <vimarsh.zutshi@gmail.com> Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Ivan T. Ivanov <iivanov@mm-sol.com> Signed-off-by: Mika Westerberg <ext-mika.1.westerberg@nokia.com> Signed-off-by: David Cohen <dacohen@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-08[media] v4l: add G2D driver for s5p device familyKamil Debski
G2D is a 2D graphics accelerator engine present in the s5p family of Samsung SoCs. It is capable of bitblt and raster operations on images having dimensions of up to 8000x8000. Signed-off-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-03[media] v4l: Add v4l2 subdev driver for S5K6AAFX sensorSylwester Nawrocki
This driver exposes preview mode operation of the S5K6AAFX sensor with embedded SoC ISP. The native capture (snapshot) operation mode is not supported. Following controls are available: manual/auto exposure and gain, power line frequency (anti-flicker), saturation, sharpness, brightness, contrast, white balance temperature, color effects, horizontal/vertical image flip, frame interval, auto white balance. RGB component gains are currently exposed through private controls. Reviewed-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-03[media] move cx25821 out of stagingMauro Carvalho Chehab
This driver had the major issues already fixed. Move it out of staging. Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-23[media] move tm6000 to drivers/media/videoMauro Carvalho Chehab
The serious bugs got fixed already. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-21[media] mt9t001: Aptina (Micron) MT9T001 3MP sensor driverLaurent Pinchart
The MT9T001 is a parallel 3MP sensor from Aptina (formerly Micron) controlled through I2C. The driver creates a V4L2 subdevice. It currently supports binning and cropping, and the gain, exposure, test pattern and black level controls. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-11[media] mt9p031: Aptina (Micron) MT9P031 5MP sensor driverJavier Martin
The MT9P031 is a parallel 12-bit 5MP sensor from Aptina (formerly Micron) controlled through I2C. The driver creates a V4L2 subdevice. It currently supports skipping, cropping, automatic binning, and gain, exposure, h/v flip and test pattern controls. Signed-off-by: Javier Martin <javier.martin@vista-silicon.com> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-03[media] drivers/media: do not use EXTRA_CFLAGSArnaud Lacombe
Usage of these flags has been deprecated for nearly 4 years by: commit f77bf01425b11947eeb3b5b54685212c302741b8 Author: Sam Ravnborg <sam@neptun.(none)> Date: Mon Oct 15 22:25:06 2007 +0200 kbuild: introduce ccflags-y, asflags-y and ldflags-y Moreover, these flags (at least EXTRA_CFLAGS) have been documented for command line use. By default, gmake(1) do not override command line setting, so this is likely to result in build failure or unexpected behavior. Replace their usage by Kbuild's `{as,cc,ld}flags-y'. Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: linux-media@vger.kernel.org Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] V4L: initial driver for ov5642 CMOS sensorBastian Hecht
This is an initial driver release for the Omnivision 5642 CMOS sensor. Signed-off-by: Bastian Hecht <hechtb@gmail.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] v4l: s5p-tv: add drivers for HDMI on Samsung S5P platformTomasz Stanislawski
Add drivers for HDMI outputs on Samsung platforms from S5P family. Drivers are using: - v4l2 framework - runtime PM Signed-off-by: Tomasz Stanislawski <t.stanislaws@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] MFC: Add MFC 5.1 V4L2 driverKamil Debski
Multi Format Codec 5.1 is a hardware video coding acceleration module found in the S5PV210 and Exynos4 Samsung SoCs. It is capable of handling a range of video codecs and this driver provides a V4L2 interface for video decoding and encoding. Signed-off-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Jeongtae Park <jtp.park@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] adp1653: Add driver for LED flash controllerSakari Ailus
This patch adds the driver for the adp1653 LED flash controller. This controller supports a high power led in flash and torch modes and an indicator light, sometimes also called privacy light. The adp1653 is used on the Nokia N900. Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Tuukka Toivonen <tuukkat76@gmail.com> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: David Cohen <dacohen@gmail.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] V4L: at91: add Atmel Image Sensor Interface (ISI) supportJosh Wu
This patch is to enable Atmel Image Sensor Interface (ISI) driver support. Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] marvell-cam: Basic working MMP camera driverJonathan Corbet
Now we have a camera working over the marvell cam controller core. It works like the cafe driver and has all the same limitations, contiguous DMA only being one of them. But it's a start. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] marvell-cam: Move cafe-ccic into its own directoryJonathan Corbet
This driver will soon become a family of drivers, so let's give it its own place to live. This move requires putting ov7670.h into include/media, but there are no code changes. Cc: Daniel Drake <dsd@laptop.org> Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-25[media] Add support for M-5MOLS 8 Mega Pixel camera ISPHeungJun, Kim
Add I2C/V4L2 subdev driver for M-5MOLS integrated image signal processor with 8 Mega Pixel sensor. Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com> Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-20[media] v4l: Move s5p-fimc driver into Video capture devicesSylwester Nawrocki
s5p-fimc now also implements a camera capture video node so move it under the "Video capture devices" Kconfig menu. Also update the entry to reflect the driver's coverage of EXYNOS4 SoCs and separate the Makefile entry from the soc-camera drivers set. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-20[media] v4l: Add mt9v032 sensor driverDetlev Casanova
The MT9V032 is a parallel wide VGA sensor from Aptina (formerly Micron) controlled through I2C. The driver creates a V4L2 subdevice. It currently supports binning and cropping, and the gain, auto gain, exposure, auto exposure and test pattern controls. Signed-off-by: Detlev Casanova <detlev.casanova@gmail.com> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] omap3isp: Kconfig and MakefileLaurent Pinchart
Add the OMAP3 ISP driver to the kernel build system. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] v4l: subdev: Add device node supportLaurent Pinchart
Create a device node named subdevX for every registered subdev. As the device node is registered before the subdev core::s_config function is called, return -EGAIN on open until initialization completes. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Vimarsh Zutshi <vimarsh.zutshi@gmail.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] V4L: Initial submit of OV9740 driverAndrew Chew
This soc_camera driver is for Omnivision's OV9740 sensor. This initial submission provides support for YUV422 output at 1280x720 (720p), which is the sensor's native resolution. 640x480 (VGA) is also supported, with cropping and scaling performed by the sensor's ISP. This driver is heavily based off of the existing OV9640 driver. Signed-off-by: Andrew Chew <achew@nvidia.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] Add v4l2 subdev driver for NOON010PC30L image sensorSylwester Nawrocki
Add I2C/V4L2 subdev driver for Siliconfile NOON010PC30 CIF camera. The driver implements basic functionality, i.e. CIF/QCIF/QQCIF resolution and color format selection, automatic/manual color balance control. Other functions like cropping, rotation/flip, exposure etc. can be easily implemented if needed. Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] v4l: videobuf2: add DMA scatter/gather allocatorAndrzej Pietrasiewicz
Add an implementation of DMA scatter/gather allocator and handling routines for videobuf2. For mmap operation mode it is implemented on top of alloc_page + sg_set_page/_free_page. For userptr operation mode it is implemented on top of get_user_pages + sg_set_page/put_page. Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> CC: Pawel Osciak <pawel@osciak.com> Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] v4l: videobuf2: add DMA coherent allocatorPawel Osciak
Add an implementation of DMA coherent memory allocator and handling routines for videobuf2, implemented on top of dma_alloc_coherent() call. Signed-off-by: Pawel Osciak <p.osciak@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> CC: Pawel Osciak <pawel@osciak.com> Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] v4l: videobuf2: add vmalloc allocatorPawel Osciak
Add an implementation of contiguous virtual memory allocator and handling routines for videobuf2, implemented on top of vmalloc()/vfree() calls. Signed-off-by: Pawel Osciak <p.osciak@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> CC: Pawel Osciak <pawel@osciak.com> Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] v4l: videobuf2: add generic memory handling routinesMarek Szyprowski
Add generic memory handling routines for userspace pointer handling, contiguous memory verification and mapping. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Pawel Osciak <p.osciak@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> CC: Pawel Osciak <pawel@osciak.com> Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] v4l: add videobuf2 Video for Linux 2 driver frameworkPawel Osciak
Videobuf2 is a Video for Linux 2 API-compatible driver framework for multimedia devices. It acts as an intermediate layer between userspace applications and device drivers. It also provides low-level, modular memory management functions for drivers. Videobuf2 eases driver development, reduces drivers' code size and aids in proper and consistent implementation of V4L2 API in drivers. Videobuf2 memory management backend is fully modular. This allows custom memory management routines for devices and platforms with non-standard memory management requirements to be plugged in, without changing the high-level buffer management functions and API. The framework provides: - implementations of streaming I/O V4L2 ioctls and file operations - high-level video buffer, video queue and state management functions - video buffer memory allocation and management Signed-off-by: Pawel Osciak <p.osciak@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> CC: Pawel Osciak <pawel@osciak.com> Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-01-19[media] tda9875: remove duplicate driverHans Verkuil
In commit 411674fd189abe5910ea4caf08b7eac5c4a4d967 the tda9875 support was added to tvaudio. This means that tda9875 is no longer used since mid-2009. If there are out-of-tree users of this driver, then they can switch to tvaudio instead. The original commit message read as follows: This change allows bttv to use tvaudio for this device. Since this device has the same i2c address as the tda9874 we need to support both in the same tvaudio driver. This makes it possible for tvaudio to detect which chip is used. Originally the tda9875 was only available in the dedicated tda9875 driver, but that makes life very hard for bttv since loading tvaudio might misdetect a tda9875 as a tda9874. So there were good reasons for moving the tda9875 code into tvaudio. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-30[media] V4L2: Add a v4l2-subdev (soc-camera) driver for OmniVision OV2640 sensorAlberto Panizzo
Signed-off-by: Alberto Panizzo <maramaopercheseimorto@gmail.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] dabusb: Move it to staging to be deprecatedMauro Carvalho Chehab
dabusb driver were conceived as an experimental driver for a test device. The driver never supported any shipped product, and, while there were some updates on it in 2003, for an ancient product, those changes were never submitted upstream. Also, there's no DocBook for its API, nor any upstream discussion. So, better to remove it, on .39. If later needed, we may rescue it from git logs. For now, let's move it to staging. Acked-by: Deti Fliegl <deti@fliegl.de> Cc: Deti Fliegl <deti@fliegl.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] se401: deprecate driver, move to stagingHans Verkuil
The se401 driver is deprecated and is moved to staging. If no one will convert this driver to V4L2, then it will be removed in 2.6.39. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] usbvideo: deprecate the vicam driverHans Verkuil
Move usbvideo to staging and mark it deprecated. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] V4L: remove V4L1 compatibility modeHans Verkuil
2010-12-29[media] media: Add timberdale video-in driverRichard Röjfors
This patch adds the timberdale video-in driver. The video IP of timberdale delivers the video data via DMA. The driver uses the DMA api to handle DMA transfers, and make use of the V4L2 video buffers to handle buffers against user space. If available the driver uses an encoder to get/set the video standard Signed-off-by: Richard Röjfors <richard.rojfors@pelagicore.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21[media] Add the via framebuffer camera controller driverJonathan Corbet
Add a driver for the video capture port on VIA integrated chipsets. This version has a remaining OLPCism or two and expects to be talking to an ov7670; those can be improved as the need arises. This work was supported by the One Laptop Per Child project. Thanks to Laurent Pinchart for a number of useful comments. Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21[media] Add driver for Siliconfile SR030PC30 VGA cameraSylwester Nawrocki
Add an I2C/v4l2-subdev driver for Siliconfile SR030PC30 VGA camera sensor with Image Signal Processor. SR030PC30 is the low resolution camera sensor on Samsung Aquila boards. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21[media] V4L: add an IMX074 sensor soc-camera / v4l2-subdev driverGuennadi Liakhovetski
This patch adds an initial driver for the IMXъ74 image sensor from Sony. Lacking documentation, only very basic functionality in one specific image format has been implemented and tested. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21[media] SoC Camera: add driver for OV6650 sensorJanusz Krzysztofik
This patch provides a V4L2 SoC Camera driver for OV6650 camera sensor, found on OMAP1 SoC based Amstrad Delta videophone. Since I have no experience with camera sensors, and the sensor documentation I was able to find was not very comprehensive, I left most settings at their default (reset) values, except for: - those required for proper mediabus parameters and picture geometry and format setup, - those used by controls. Resulting picture quality may be far from perfect, but better than nothing. In order to be able to get / set the sensor frame rate from userspace, I decided to provide two not yet SoC camera supported operations, g_parm and s_parm. These can be used after applying patch 4/6 from this series, "SoC Camera: add support for g_parm / s_parm operations". Created and tested against linux-2.6.36-rc5 on Amstrad Delta. Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21[media] SoC Camera: add driver for OMAP1 camera interfaceJanusz Krzysztofik
This is a V4L2 driver for TI OMAP1 SoC camera interface. Both videobuf-dma versions are supported, contig and sg, selectable with a module option. The former uses less processing power, but often fails to allocate contignuous buffer memory. The latter is free of this problem, but generates tens of DMA interrupts per frame. If contig memory allocation ever fails, the driver falls back to sg automatically on next open, but still can be switched back to contig manually. Both paths work stable for me, even under heavy load, on my OMAP1510 based Amstrad Delta videophone, that is the oldest, least powerfull OMAP1 implementation. The interface generally works in pass-through mode. Since input data byte endianess can be swapped, it provides up to two v4l2 pixel formats per each of several soc_mbus formats that have their swapped endian counterparts. Boards using this driver can provide it with the following platform data: - if and what freqency clock is expected by an on-board camera sensor, - what is the maximum pixel clock that should be accepted from the sensor, - what is the polarity of the sensor provided pixel clock, - if the interface GPIO line is connected to a sensor reset/powerdown input and what is the input polarity. Created and tested against linux-2.6.36-rc5 on Amstrad Delta. Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: Deprecate stradis driverMauro Carvalho Chehab
The driver author seems to not worked on this driver since its conversion from 2.2 to 2.4. Nobody is known to have a stradis hardware for testing. As it still uses V4L1 API, BKL and probably some other old stuff, someone would need to work on it to preserve the driver. Instead of investing time and efforts to keep porting it to work with new API's, it seems better to just drop the driver. So, let's move it to drivers/staging and label it to die at 2.6.38, if nobody cares enough to port parallel port support to gspca or to create a new driver that uses the same gspca-cpia sub-driver. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: Deprecate cpia driver (used for parallel port webcams)Mauro Carvalho Chehab
cpia driver were re-written inside gspca driver, for USB devices. The only functionality that were not migrated is the support for parallel port, as: 1) the developer didn't find any hardware; 2) it doesn't seem important to keep support for a parallel port webcam, as this is an obsolete technology; 3) the changes at gspca for it to work with parallel port would be very large; 4) this driver still uses BKL. So, let's move it to drivers/staging and label it to die at 2.6.38, if nobody cares enough to port parallel port support to gspca or to create a new driver that uses the same gspca-cpia sub-driver. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
