path: root/drivers/media/video/ak881x.c
2010-08-02V4L/DVB: mediabus: fix ambiguous pixel code namesGuennadi Liakhovetski
Endianness notation is meaningless for 8 bit YUYV codes. Switch pixel code names to explicitly state the order of colour components in the data stream. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-06-01V4L/DVB: ak881x needs slab.hRandy Dunlap
Add slab.h to fix ak881x build: drivers/media/video/ak881x.c:265:error: implicit declaration of function 'kzalloc' drivers/media/video/ak881x.c:265:warning: assignment makes pointer from integer without a cast drivers/media/video/ak881x.c:283:error: implicit declaration of function 'kfree' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-06-01V4L/DVB: v4l2-subdev.h: fix enum_mbus_fmt prototypeHans Verkuil
enum_mbus_fmt received an index argument that was defined as an int instead of an unsigned int. This is now fixed. This had the knock-on effect that the index argument in the callback get_formats in soc_camera.h also had to be changed to unsigned int. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-19V4L/DVB: V4L: v4l2-subdev driver for AK8813 and AK8814 TV-encoders from AKMGuennadi Liakhovetski
AK8814 only differs from AK8813 by included Macrovision Copy Protection function. This patch adds a driver for AK8813 and AK8814 I2C PAL/NTSC TV encoders. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
