Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
drivers/media/video/bt8xx/bttv-cards.c:3030:38: warning: "/*" within comment
drivers/media/video/bt8xx/bttv-cards.c:3032:20: warning: "/*" within comment
TUNER_PHILIPS_ATSC is an ambiguous name for a tuner. Rename it to
TUNER_PHILIPS_FCV1236D to be more descriptive.
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
Signed-off-by: Mauro Lacy <mauro@lacy.com.ar>
I have what looks like a Geovision GV-600 (or 650) card. It has a large
chip in the middle labeled
CONEXANT
FUSION 878A
25878-13
E345881.1
0312 TAIWAN
It has an audio connector coming out from a chip labeled
ATMEL
0242
AT89C2051-24PI
It is identified as follows on my Debian GNU/Linux Etch (kernel 2.6.18)
01:0a.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
01:0a.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
01:0a.0 0400: 109e:036e (rev 11)
Subsystem: 008a:763c
Flags: bus master, medium devsel, latency 64, IRQ 58
Memory at dfffe000 (32-bit, prefetchable) [size=4K]
Capabilities: [44] Vital Product Data
Capabilities: [4c] Power Management version 2
01:0a.1 0480: 109e:0878 (rev 11)
Memory at dffff000 (32-bit, prefetchable) [size=4K]
It was being detected as a GENERIC UNKNOWN CARD both by the 2.6.18
kernel and the latest v4l-dvb drivers, but it did not work at all. The
card has sixteen (16) BNC video inputs, four of them on the board itself
and twelve on three daughter-cards. It has a single bt878 chip, no tuner
and what looks like and audio input. After doing some research I managed
to get only eight channels working by forcing card=125 and those DID NOT
match channels 0-7 on the card, and no audio.
Based on what was working for card=125, I added the card definition
block, added a specific muxsel routine and got the card working fully
with xawtv, where the sixteen channels show up as Composite0 to
Composite15, matching the channel labels in the card and daughter-cards.
I have made no efforts yet to get audio working, but would appreciate
any pointers.
Signed-off-by: Ernesto Hernández-Novich <emhn@usb.ve>
PlayTV card
The PixelView PlayTV card definition structure was missing initialization of
the tuner_addr and radio_addr fields. As a result it was impossible to have the
tuner initialized using parameters specified while loading the bttv.ko module.
This regression became visible after the v4l rearrangements introduced
somewhere around 2.6.15 kernel version.
The root cause for the tuner initialization failure is located in the
attach_inform function in the bttv-i2c.c file.
There at the very beginning the addr variable holding the tuner device address
is initialized with the value taken from the bttv_tvcards array.
For the PixelView PlayTV card the tuner address field (and the radio address as
well) was uninitialized, and thus equal 0. Later in that function execution of
the TUNER_SET_TYPE_ADDR tuner command is guarded with check for the tuner
address either equal ADDR_UNSET, or client->addr.
Since both are non-zero (the latter in case of the card owned by me at the
runtime is equal 0x61) the TUNER_SET_TYPE_ADDR command is not executed, and
consequently in the tuner_attach function in the tuner-core.c file call to
i2c_attach_client does not result in assigning the tuner type variable with the
requested value.
Providing initialization of the tuner_addr and radio_addr with ADDR_UNSET
values as it is already done for other tv cards defined in bttv-cards.c ensures
that the tuner initialization is done correctly, just as it used to be in the
2.6.14 kernel.
Signed-off-by: Wojciech Migda <wojtek.golf@interia.pl>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Also convert audio_mode_gpio functions from audio_hook
Signed-off-by: Nickolay V. Shmyrev <nshmyrev@yandex.ru>
This is part of the old V4L1->V4L2 bttv patch, ported to current tree
by Mauro Carvalho Chehab <mchehab@infradead.org>
Currently, the only tuner-specific device that allows special
configurations is tda9887. However, tea5767 also may require some
special configurations (for example, to specify a different Xtal freq).
This patch replaces TDA9887_SET_CONFIG by a more generic internal ioctl
(TUNER_SET_CONFIG). The newer one allows specifying what tuner is
appliable to a configuration set, and allows an arbitrary configuration
struct.
This patch fixes the following section mismatch with CONFIG_HOTPLUG=n:
<-- snip -->
<-- snip -->
* Convert files to UTF-8.
* Also correct some people's names
(one example is Eißfeldt, which was found in a source file.
Given that the author used an ß at all in a source file
indicates that the real name has in fact a 'ß' and not an 'ss',
which is commonly used as a substitute for 'ß' when limited to
7bit.)
* Correct town names (Goettingen -> Göttingen)
* Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313)
Signed-off-by: Jan Engelhardt <jengelh@gmx.de>
Fix the various misspellings of "system", controller", "interrupt" and
"[un]necessary".
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Adds an entry for the Typhoon Tv-Tuner PCI to bttv-cards.c
Signed-off-by: Sascha Sommer <saschasommer@freenet.de>
There were many instances of 7-space indents spread throughout
the v4l-dvb tree.
This patch replaces the 7-space indents with tabs. The whitespace cleaner
script doesn't catch these, because it assumes that all indents are 8-space.
Since at least kernel 2.6.12-rc2, module.h includes moduleparm.h. This
patch removes all occurences of moduleparm.h from drivers/media files.
Various gpio and mux settings for the Osprey 440 weren't correct. Fix them
and provide some documentation about how the gpios work.
The osprey eeprom routine wasn't run for the 440, add it. It was also crap,
re-written to be better.
Add the Osprey 440 to the Bt878 ALSA driver's whitelist. Currently the sample
rate is fixed at 32kHz, as the driver doesn't support different rates for
digital input mode, though the card can select the rate from 32, 44.1, or 48
kHz via gpio.
Setting the audio gain via ALSA isn't supported yet; a userspace tool that
programs the X9221 via i2c-dev must be used.
The Bt878 digital audio format isn't programmed correctly for the CS5331A ADC
used, resulting in extremely garbled sound. That is fixed in a followup
patch.
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
For svhs, tuner, and tuner_type, be consistent in using UNSET instead of -1.
For tuner_type also consistently use the existing constants:
0 => TUNER_TEMIC_PAL
1 => TUNER_PHILIPS_PAL_I
2 => TUNER_PHILIPS_NTSC
4 => TUNER_ABSENT
5 => TUNER_PHILIPS_PAL
21 => TUNER_TEMIC_4039FR5_NTSC
25 => TUNER_LG_PAL_I_FM
The bttv driver has code to detect if a tda9887 is present, that was previous
used to auto-load the tda9887 driver. Now there is no tda9887 driver, so the
code is pointless; it just figures out if it should load the driver and then
does nothing.
For cards that are defined as having no tuner, the init code would still do
i2c probes for various tuner devices and auto-load the tuner module. That can
be skipped for cards that don't need it. The code is made to understand that
in addition to 'UNSET', 'TUNER_ABSENT' also means no tuner.
The tuner into printk()s are also made nicer. Levels are added, INFO or
WARNING, depending on the meaning. For cards with no tuner, or no tuner
defined, a more informative message is printed.
Card has no tuner, before patch:
bttv0: tuner type=-1
or
bttv0: tuner type=4
After patch:
bttv0: tuner absent
Card has a tuner, but the type isn't defined, before patch:
After patch:
bttv0: tuner type unset [<- also warning now, as the tuner won't work right]
add analog video support for DViCO FusionHDTV 2
Thanks to Todd Ignasiak for donating the card.
Fix support for 3dfx Voodoo TV 200 variant
Signed-off-by: Wade Berrier <wberrier@gmail.com>
SSAI (www.ssai.us) makes several Bt878-based capture cards that get used in our
surveillance, conferencing, and medical imaging systems. The attached
relatively small patch adds support for these cards, which fall into two broad
* boards with one or more Bt878s, one or more composite inputs, and no S-video
or tuner inputs
* boards with one Bt878, one composite input, one S-video input, and no tuner
input
Signed-off-by: Scott Alfter <salfter@ssai.us>
there were several "magic" for loops, addressing gpiomux array size (4).
Adrian Bunk showed that one of the loops were wrong, going from 0 to 4.
This patch provides the right fix for this trouble, by using ARRAY_SIZE
on all places where we have a for loop using gpiomux.
Thanks to: Adrian Bunk <bunk@stusta.de> for pointing me about this trouble.
Ultraview DVB-T Lite is a clone of DViCO FusionHDTV DVB-T Lite
There are some long time unused code under some media driver source files.
There's no need of keeping it at mainstream.
Those unused code will remain available at V4L/DVB master tree and also at
kernel history.
Fix uses of "&&" where "&" was intended in bttv-cards.c and tveeprom.c
Thanks to Edgar Toernig <froese@gmx.de> for pointing this.
failure case
We could go and work out if the target object is AGP or PCI but the
corner case of an Athlon 64 era box with PCI video is sufficiently
unusual it doesn't seem worth the extra work, at least until other cases
if any pop up.
Signed-off-by: Alan Cox <alan@redhat.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial:
Remove obsolete #include <linux/config.h>
remove obsolete swsusp_encrypt
arch/arm26/Kconfig typos
Documentation/IPMI typos
Kconfig: Typos in net/sched/Kconfig
v9fs: do not include linux/version.h
Documentation/DocBook/mtdnand.tmpl: typo fixes
typo fixes: specfic -> specific
typo fixes in Documentation/networking/pktgen.txt
typo fixes: occuring -> occurring
typo fixes: infomation -> information
typo fixes: disadvantadge -> disadvantage
typo fixes: aquire -> acquire
typo fixes: mecanism -> mechanism
typo fixes: bandwith -> bandwidth
fix a typo in the RTC_CLASS help text
smb is no longer maintained
Manually merged trivial conflict in arch/um/kernel/vmlinux.lds.S
We should no longer try to load the tda9887 module, because it no longer
exists. The tda9887 driver has been merged into the tuner module.
This patch removes all instances of request_module("tda9887") from
the following video4linux drivers: bttv, cx88, em28xx and saa7134.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
acquired (aquired)
contiguous (contigious)
successful (succesful, succesfull)
surprise (suprise)
whether (weather)
some other misspellings
Signed-off-by: Andreas Mohr <andi@lisas.de>
Signed-off-by: Cameron Hutchinson <camh@xdna.net>
- use eeprom data to detect Osprey 230
This patch fixes two off-by-one errors spotted by the Coverity checker.
Cleanup audio input handling in bttv and tvaudio:
- inputs were specified that were never used
- mute was handled as a special input which led to confusing code
- confusing naming made it difficult to see if the setting was for
i2c or gpio.
The old audiochip.h input names moved to tvaudio.h. Currently this
is used both by tvaudio and msp3400 until the msp3400 implements the
new msp3400-specific inputs.
Detect in bttv the tvaudio and msp3400 i2c clients and use these
client pointers to set the inputs directly instead of broadcasting the
command.
Removed AUDC_SET_INPUT. Now replaced by VIDIOC_S_AUDIO. This will be
replaced again later by the new ROUTING commands.
Removed VIDIOC_G_AUDIO implementations in i2c drivers: this command is
a user level command and not to be used internally. It wasn't called at
all anyway.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
I2C_foo were used for some i2c addresses. Bad, since those constants could
mean other i2c chip things.
Signed-off-by: Manu Abraham <manu@linuxtv.org>
