path: root/drivers/media/video/btcx-risc.c
2008-10-12V4L/DVB (8745): v4l2: fix a bunch of compile warnings.Hans Verkuil
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-09-03V4L/DVB (8757): v4l-dvb: fix a bunch of sparse warningsHans Verkuil
Fixed a lot of sparse warnings: mostly warnings about shadowed variables and signed/unsigned mismatches. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-06-05V4L/DVB (7965): annotate bcx_riscmemAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6079): Cleanup: remove linux/moduleparam.h from drivers/media filesMauro Carvalho Chehab
Since at least kernel 2.6.12-rc2, module.h includes moduleparm.h. This patch removes all occurences of moduleparm.h from drivers/media files. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-13V4L/DVB (3355): removed uneeded init on structs like static int foo=0Mauro Carvalho Chehab
- Static vars are equal to zero by default. Removed unnecessary =0 from them, saving some data space Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2005-09-09[PATCH] v4l: common part Updates and tuner additionsMauro Carvalho Chehab
- Remove $Id CVS logs for V4L files - Included newer cards. - Added a new NEC protocol for ir based on pulse distance. - Enable ATSC support for DViCO FusionHDTV5 Gold. - Added tuner LG NTSC (TALN mini series). - Fixed tea5767 autodetection. - Resolve more tuner types. - Commented debug function removed from mainstream. - Remove comments from mainstream. Still on development tree. - linux/version dependencies removed. - BTSC Lang1 now is set to auto_stereo mode. - New tuner standby API. - i2c-core.c uses hexadecimal for the i2c address, so it should stay consistent. Signed-off-by: Uli Luckas <luckas@musoft.de> Signed-off-by: Mac Michaels <wmichaels1@earthlink.net> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Hermann Pitton <hermann.pitton@onlinehome.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
